View Full Version : Honda Prelude
- HELP: problems after egr/coolant bypass
- Intake manifold runner mod.
- Oil seal question
- Does anyone need a H22a4 Head gasket?
- ecu question
- Where to tap oil line on the HEAD thats going to top of TURBO?
- Volk Ce28n..i have a question
- So Cal shop to install clutch into Type SH?
- An Angled Muffler on a 5th Gen.......pics?
- OEM Hood gone...thinking of getting CF hood...couple of questions
- My dad f'd up my car!
- hole in engine???
- auto to manual conversion?
- yellow KONI.....need to lower my Lude?
- NICE short shifter! Thanks 4bidden
- AEM cam gears tunning for H23
- SPEC Clutch and/or Flywheel Group Buy - The Clutch Depot
- H22 usdm VS H22 jdm?
- Camber Kit Question......
- Part number help needed...
- Sensor problem
- Putting MSD coil in ?
- Prelude specific forums?
- Nitrous ?'s
- Check Engine Light?!?
- tranny problems..
- Switching my AEM CAI out for a generic? should I??
- prelude engines
- Power Loss (Exhaust Holes??)
- I need pics of turbo manifolds for 92-96 prelude?
- Greddy parts
- PIAA Bulbs
- Looking for 4g moonroof in good condition
- will B&M FPR for 92-95 civic work???
- Trouble removing crank please help..
- Problem with clutch pedal spring on 4th gen
- Knock sensor
- Anyone need Missing link for 92-96?
- Filter Maintenance
- prelude head
- auto prelude wishing manual
- Has this ever happened to anyone else? Distritbutor related..
- N20 Help please.
- head gasket power/response restore?!?
- Anyone know where I can find these?
- Open loop at WOT
- New suspension.
- cats interchangeable?
- Carfax IN NEED!!!
- Help, How much do u think my cars worth?
- CD player install on 5th gen....Please help
- Idle problem
- what about bullfrog performance for h23 ?
- -HELP- Idle problem check engine light?!
- 4G Prelude Replacement Carpet?
- LSD in an H23 tranny
- camber kit help
- What I found out from this weekends' shock/spring install
- Cleaning cai??
- Black widow rear bumper owners please help
- Which size tires to use on a Stock Lude SH 99'?
- 92-95 prelude h22a idle
- need to know what size.........
- question about knoi yellow
- kyb's or koni yellows???
- F*&$ING dogs!!!!!!
- fpr
- Cel and atts light codes need some help
- Show some pics please!
- SH Alignment Questions...need answers A.S.A.P
- Those with TEIN SS Coilovers
- weres the best place to look for engines?
- pics of milano red ludes
- CF Trunk Lid *pics*
- Higher rev limit
- Torsion Bar Removal
- any pics of 92-96 prelude with rh evo c5?
- How much do you think my h22a1 engine, tranny, and ecu is worth?
- Brand new in box Apexi Dunk catback 300, stock H22A valve cover 90, Racing Medalion axle back 140.
- pics of rs*r equipped lude
- FS: '97 & up Prelude driver & pass airbags
- Problem with VTEC
- JDM Digital Climate Control & Gauge Cluster
- painting the headlights on a lude
- FS: Custom Arias H22A/H23A VTEC 11.5:1 Pistons
- laggy h22a probs down low in rev range
- h23 VTEC Question
- turbo prelude
- intake manifold
- Colorado Prelude Owners
- Best Header?
- what color rims will look best on a black 5th gen prelude?
- Need all the info I can get for building block
- CRAP..broke off coolant bleeder....JB weld OK?
- Replaced Fast Idle valve...what next??
- Starting my Car h22a
- Where to buy Spoon Bar?
- tach and shift light....
- Looking for h23 block
- Guess what I got today?!?!?!?!?
- Does Honda make a dash mat...?
- STR products
- good size for nitto 555 tires
- Engine Paint
- Fuel Line Size
- Ouch!... my car got ripped a new a**hole..pix inside
- Fuel Pressure at WOT
- Anyone willing to sell h22a4 290cc injectors?
- 16" 5x114.3 Bronze Rota Grid Group Buy
- Lude stalling out, why?
- FS: 16" 5x114.3 slipstreams gunmetal w/ polished lip
- did a compression test for my h22a....what should I do now?
- Hit a curb hard, what do you think I messed up?
- Identify this part (manual tensioner)
- okay, quick question..?
- Tranny question. What are these holes for?
- Nitrous Question
- launching a 5th gen lude sh
- Prelude Parts for Sale...
- h22a swap tranny mount
- nd p13's for boost
- skunk 2 camgears vs AEM cam gears
- Play guess the problem...
- F22 and H22 parts interchangeable???
- H22 Golden Eagle Help
- ANyone have Pic Of Stock H22a1 Cylinders
- Half shaft for Type S?
- skunk2 h22a intake man.
- prelude swap forsale
- i wanna buya h22 head
- Looking for damaged CF hood (4th gen)......
- how do you check for codes?
- Gloden eagle intake mani?
- Gear ratios:
- good idea??
- Bilstein Shocks
- Crankshaft Pulley
- piston ring replacement 5th gen
- How hard is it to aquire 5th gen foglights?
- looking for racing medalion exhaust, and coil-overs
- How do I legalize a RHD lude?
- 18" rims vs. stock 16" rims Question~
- help me with my paint dilema!
- Let's settle the O2 sensor agrument once and for all. (ODBII sucks)
- h22 or f22
- Does Apexi N-1 come out slanted for 97 base prelude?
- Car won't run in rain
- Accord intake on a H22?, quick question>
- check it out...
- Looking for Alot of 4th gen parts!
- H23 hybrid or H22 ?
- What year is does the 5th Gen come Milano Red?
- Help getting McCulloch H1 HID to fit in the LUDE
- Where to drop the clutch for the best launch?
- Need a built(TURBO)block for h23 or h22 fast
- some 4th gen stuff i need to get rid off....
- STR Throttle body for sale
- People with koni yellow
- Can you switch a "normal" Prelude transmission for a "Type SH" one?
- 4th gen selected solutions guide <yo-yo idle, lights, noises...>
- Head Gasket Help (Full Seals Kit)
- CF Trunk Weight
- Good Website?
- Lower ball joint install
- How To: Wreck an H23VTEC
- What's the quietest exhaust I can buy with the biggest performance gain?
- preludeonline.com
- need help h23 turbo...?
- Installing a new clutch on 5th gen.........
- Help a fellow luder and sell him your...........
- problems built h23 bottom....
- Turbo H22 Questions(Calling all Prelude Turbo Gurus i.e. GudeH23a and BluShadow)
- Wheel Questin
- Boost on H22s...
- Suspension question
- JDM vs. USDM, CC flanges the same?
- How do I become a member?
- which injectors to run
- h22 for sale
- Fuel Pump?
- do they make a g4 si greddy evo
- Pulley problem (Crank-Alt-Ps) aem and unorthodox......
- Place racing
- sttering wheels size??
- 3rd Generation Ludes...
- exhaust question?
- anyone know anyone that wants to buy a teg???
- Should I remove "pin stripes"...
- suspension
- about legend brake conversion?
- German 5th gen...DDM y0 (need help)
- Skunk2 coilover
- CAN I ?????
- Ar Ar, block help please
- JRSC lude goes Bye Bye
- What Cams to get? Jun, Crower, Skunk, Type-S?
- I feel stupid asking this ?
- thinkin of h22 for ek swap
- rims going for!!!!!!!
- help please!! in need
- What would you guys buy???
- chassis codes
- Need help ASAP!!! Ignition/Starter/Distributor??
- prelude tires!
- FS: 97+ GReddy Prelude turbo kit with custom extras
- H23 Sleeves?
- H23 aftermarket cams??
- B20A Main cam bearing cap torque spec?
- How much is a new honda bumper?
- coilover options, need help fast
- final drive ratio
- VAFC affect...
- Sup everyone just need some help on makin a small desicion...
- getting new lights...
- exhaust on the 4th gen
- to teh guy with the wiseco pistons on stock sleeves............
- custom intercooler/charge piping??
- Has anybody ever seen a ITR wing on a 5th gen?
- 93 si injector's
- First time to the track {1/4 mile time}
- H22A in a 90S
- Gas Mileage
- Ground Control and KYB AGX
- Cams for h23
- Pic request: 5th gen auto tranny parts
- RC 370cc Injectors P&H
- h23 turbo items fs & n2o plumbed cai for trade
- offset??
- about to buy a 4th gen. prelude...need help....
- Prelude with nitrous
- WTB: AEM Fuel Rail and FPR and gauge is possible...
- What can I do to make my VTEC pull HARD?
- helms?
- paint colors...
- i have an urgent question
- Someone With A Helms for a 94-96 Please help me
- Guys...i need your help and suggestions!
- Skunk2 new Intake Manifold
- Rattling noise around 1000-3000 rpm
- Attn: Boosted H23 guys..
- Need help diagnosing problem...
- any one got racing seats?
- Spoon/Mugen jdm p13 chips
- Oil pan problems...need help.
- Oil questions
- puttin the Turbo Lude on eBay tonight....
- Quality issue on a manifold
- CR Calculations and Compression Testing
- Hub hole size in wheel...?
- clutch question (stock)
