PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. how rare is the 93 Fog Light Tweeter Switch?
  2. Help, Doors wont lock
  3. Electronic turbo
  4. A/c electrical issues
  5. H22 valve guides
  6. msd coil question
  7. Just bought a 00 BB6.
  8. Is the h23 thermastat cover the same as the h22
  9. h22a rough idle
  10. Bad VSS or Stupid move?
  11. H22 parts limits
  12. is there a difrence in intakes for a 94 and 97
  13. EGR Valve 99SH
  14. 4th Gen Foglight Relay ?
  15. ecu questions. help
  16. 99 base model dies while driving-help
  17. blow by help
  18. AC Electrical problem 99 Lude Pls Help
  19. 1983-1987 Prelude Carb 16100-PC7-435
  20. Blew Piston ring. question
  21. Blinking OIL LIGHT
  22. Help identifying this "light"
  23. 97 prelude shift knob
  24. rim pix?
  25. ECU Question.
  26. starter problems
  27. problem starting my car help asap
  28. 88 Prelude s
  29. H22A question
  30. Compression check results
  31. Clutch won't keep pressure
  32. removing doors 97'
  33. Anyone try this before?
  34. 92 Prelude SI 4WS/VTEC
  35. Header & Exhaust Combo Debate 5th gen
  36. Prelude Exhaust suggestions?
  37. Question about ECU's affecting my fuel pressure.
  38. accord door light/prelude courtesy light?
  39. Help some one 88 Prelude
  40. '92 Prelude Engine Code Error 12 Help
  41. carbon fiber intake??
  42. o2 sensor wire replacement?
  43. engine swap/frankenstien
  44. spongy brakes, no pressure..
  45. Bride seats in a 97-01 lude
  46. G23 issues
  47. my 88 prelude is puttering!!
  48. anybody using je pistons on the h22?
  49. Help finding the right remedy... terrible rod knock!!!
  50. Help finding a cat delete
  51. New guy here with a water pump question H22
  52. Help/Advice tuning with VAFC 2
  53. 98 Prelude...Thermostat/temp guage problem???
  54. Vtec Solenoid please help.
  55. failed smog please helpppp
  56. need help on wires
  57. 1993 Prelude 4ws Contorl Unit?
  58. General Questions prior to engine swap
  59. Prelude Gauge Cluster
  60. main relay toast twice
  61. 98 prelude, non working temp gauge/ speedo
  62. throwing code 20 and 23 on my 4th gen
  63. hondata help
  64. What and where does this plug into? Sensor help
  65. Some Help Please!!!!
  66. No power besides horn and hazards
  67. 95 wont Shift (video link) need help
  68. Fuel pump set up
  69. H22a Turbo set up
  70. Tire in the rear! PLEASE HELP!
  71. Code 9 CYP Sensor h22a4 Prelude OBD1 chipped HELPPPP
  72. 94 Honda Prelude H22 running on two cylinders???
  73. Can you confirm this OBD2 EGR DELETE CEL Fix?
  74. BB4 keeps blowing bulbs?
  75. Suspension Rebound/Bound Setup & Height Setup
  76. engine size help needed.
  77. Buying jdm h22 asap! need help to order
  78. 4th gen: Are the uca anchor bolts in the front the same as the rear?
  79. 95 h23 to 92 h22 jdm plz help
  80. Rear sway bar endlink question...
  81. CEL: CKP: Crank Position Sensor - P0336 (range/performance)!!!HELP!
  82. OBX H23 ITB
  83. 88 Lude help
  84. need help ASAP
  85. what kind of fuel pump should i get?
  86. Idling issue
  87. 1989 prelude wheel bearing replacement problem.
  88. axel on drivers side will not come out.
  89. questions on the fuel pump. please help.
  90. CEL + ATTS Light help!! Code 22/P1259
  91. 4th gen ported intake manifold swap in a 1999 SH
  92. ECU PINS???
  93. OBD2 to OBD1 HELP!!!!! PLZ!!!!!
  94. Type-S engine suitable replacement?
  95. Need Help With Traction Bar
  96. Clicking Noise Coming from Valve Train???
  97. aftermarket throttle body problem
  98. Civic A/c thermostat in prelude?
  99. can i buy a speedo gear housing
  100. HELP!!!: Camshaft position sensor (range/performance) CEL...???
  101. '10 tri-state meet please bump up if view thanks
  102. 92 si idle going crazy, car does not warmup till 1hr,
  103. H23A1 not rotating by hand need help!!!!!!!!!
  104. need help/advise
  105. ECU upgrade for NA H22A.
  106. random misfire
  107. Good Deal???
  108. Valve springs n retainer
  109. Hows the mileage? '95 prelude
  110. Spring Rate suggestion
  111. NEED HELP ASAP!!!
  112. prelude idle and fuel CEL
  113. obd1 dizzy on obd2 harness
  114. what kinda shifter is this?
  115. h23a1 (non vtec) to jdm h23a (vtec) swap. Help!
  116. VTEC Solenoid
  117. engine swap
  118. SH auto tranny in a base model prelude?
  119. 99 prelude speakers not working.
  120. bypass knock sensor?
  121. Valve Spring Compression Tool
  122. 95 prelude not starting
  123. Stock H22 intake manifold idea
  124. need some help with bolt torque specs on waterpump
  125. h22 Balancer shaft drive gear wont move??
  126. Hanging throttle, whats the deal??
  127. t2t4 rebuild help
  128. 5th gen rim size?
  129. Sudden Power Loss & Stalling.
  130. Older TEIN ss coil overs question
  131. IACV problem
  132. h22a ecu troubles.
  133. H22a/f22 rear bracket question
  134. H22a obd1 into 98 obd2 finishing touches
  135. H23a Vtec ECU?
  136. vents only working on highest setting
  137. ((NEED HELP ON WAT TENSIONER TO GET FOR MY H23 HEAD AND H22A BLOCK))
  138. Oil pressure switch help please?
  139. 97 Prelude - timing belt/valve adjustment - now loss of torque and whining noise
  140. 2nd gear pops out at low rpms, help!
  141. JUN/ChargeSpeed Front Lip
  142. 92 EG H22A cel 12
  143. PA State Inspection
  144. underhood fuse box fuses stay hot after ignition is turned off....
  145. ITB question
  146. HELP need to know if 94 and 92 parts are interchangeable
  147. F23crankshaft into H22a4 block
  148. Cooling Fan?? What?
  149. Pilot bushing
  150. ..:: WANTED TO BUY ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - May/June 2010
  151. ..::: FOR SALE ONLY :::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - May/June 2010
  152. h22 loss power help
  153. How do you put on a regular ext. coil???????
  154. Will a 97 accord auto tranny work in a 97 prelude?
  155. HELP! Can I swap jdm h22a into bb6?
  156. 97 Prelude spark plug cover bolt missing/broken
  157. are 95mm crank with 50mm mains known to fail?
  158. Axle Seal for T2T4?
  159. Just drove'er home
  160. 91 Prelude speedometer jumping/blinking S4 light no overdrive
  161. 225/40/18 +42 on 5th gen
  162. error code P0441
  163. immobiliser light flashing 5 times
  164. Air Intake Question
  165. h22a4 in 96 prelude S won't start...help!
  166. Prelude (H22) Oil Pan Baffles
  167. high compression problems/questions
  168. Catalytic convertor/secondary O2 sensor question
  169. HELP!!!!! swap done car wont start
  170. error code 102
  171. Do any of the 5th gen Ludes take a cabin filter?
  172. help with new head gasket.. quick question and i have pics
  173. my '92 prelude grinds going into 3rd - how long do I have
  174. Check engine light problem
  175. Prelude turbo oil pan question
  176. 2 cylinders low compression
  177. F22 to H22a swap problem!!!
  178. Intake Air Butteflies??
  179. Help...no power being transferred to wheels
  180. speedo stops working at high RPMs
  181. megan header question
  182. h22a4 swap
  183. 95 honda prelude ignition cylinder problems!
  184. In car Vid from Honda-challenge race at Summit Point, April 2010
  185. Want to buy a prelude. advice?
  186. What is the H22's normal operating temperature?
  187. having problems accelerating, help!!
  188. deletin rear seat
  189. 5TH GEN Suspension KYB AGX w/ Ground Controls
  190. 2 wire IACV?
  191. car wont start
  192. 4th gen Front lower balljoint same as Rear lower?
  193. 97 prelude ignition switch
  194. Running problems with my '91 Prelude
  195. need 93 prelude vacuum diagram!
  196. 99 H22 SWAPPED CIVIC OBD1 CODE 14 & 21
  197. No VTEC Oil Pressure =(
  198. h22a with no serial number?????
  199. Turn signals out!!light comes on theirs not clicking but no turn signal!!
  200. 1/4 mile times????
  201. Oil Burning fast (need Help plz!!)
  202. old set-up 240whp--new 220whp whats up?
  203. jdm h22 vtec problems
  204. Unknown problem need help 5th gen
  205. 92 prelude lip options
  206. HELP!!!! H22 acting up It wont hold a steady rpm
  207. Need urgent help with cam bearing torque settings for b20a
  208. Leather seats
  209. Blinking dash lights : fuel and temp gauge
  210. New Prelude Owner (Minor inside)
  211. cooling fan not working on 4th gen prelude!
  212. Electrical Problem Please Help!
  213. Make sure you pull the valve cover and spark plugsbefore installing your engine...
  214. JDM F22B O2 sensor help
  215. NEED 1992 honda prelude s parts!!!!!!!!!
  216. Time for another Engine - Please help me decide!
  217. please help me with vacuum diagram on h22a4 asap
  218. HELP!! 97 Prelude lagging when stepping on gas!
  219. tps problem i think. help needed
  220. I dont know what happened.
  221. H22A ecu wiring
  222. 92 prelude s dash swap???
  223. Problems with the signal lights and parking lights
  224. Has any one tried to build a f22v Turbo?
  225. Code 9 Cylinder Position sensor WTF? help
  226. Questions about the F23 block series
  227. Rev Limiter, No Vtec
  228. h2b swap wont go past 6500rpm help!
  229. Speakers cutting out when turning
  230. Prelude problem... limp mode?
  231. oil control jet
  232. HELP!! High beams stay on...
  233. Need a little help suggestions on coilovers?
  234. Valve Tic still there!
  235. Megan front strut on 5th gen
  236. Condensation in EGR port?
  237. ecu problems
  238. Jingle bells h22a?
  239. Honda cranks stamped ????
  240. accord euro r h22 oilpan question
  241. Internal ignition coil wiring problem?
  242. anyone know where to get a cheap tranny?
  243. Sportmax 002 16x8s on 98 lude..
  244. Milled head timing issues...please help!
  245. Anyone need an ECU for 92 prelude (manual)
  246. Hytech piping size question
  247. Anyone need an ECU for 92 prelude (manual)
  248. 5th gen exhaust on 4th gen?
  249. i need the m2b4 ring gear torques
  250. need help replacing passenger door on a 5th gen
