PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Is it Worth it to Switch to Synthetic Oil at 160k?
  2. Power steering fluid
  3. 86 prelude 2.0 si question
  4. a/c problems
  5. recommended size intercooler for 01 prelude
  6. Hard time finding a throw out bearing.
  7. Oil Filter ? for H22A Swap
  8. Starting Problem
  9. 1991 Prelude Si B21??
  10. 97 SH: Overheating/ boiling over and osculating idle
  11. Balance shafts
  12. Power Steering repair/ problem?!?!?
  13. Rough Transmission
  14. Custom axels
  15. ignition switch
  16. Camber kit for a BB1 with 4WS??
  17. Help Please
  18. CEL45 malfunctioning fuel monitoring system
  19. Skunk2 Stage 2 cams, best vtec cross
  20. CYP Sensor. NEED INFO>
  21. How's Type S Pistons + NOS?
  22. Fujitsubo Header
  23. Brakes...Vtec Brakes....brackets....rotors....calipers...wtf.... (4th gen)
  24. CAMP1320... NO COMMUNICATION AT ALL
  25. rims for sale!!!
  26. 3rg gen engines swaps
  27. resetECU
  28. for sale:::
  29. Power steering problem.
  30. Help with H22A NOS Build?
  31. H22a4 ignition timing value?
  32. VIS mugen kit 4th gen
  33. rear motor mount q
  34. 2008 accord
  35. how much does the h22 block weigh
  36. maybe i'm crazy... removing front crossmember
  37. obd1 head on obd2 block in obd2 car?
  38. 4G facelift date?
  39. oil pump?
  40. trailering a lowered lude on a car dolly. is it possible??
  41. um...whats this hole??
  42. Weird idle
  43. Vss speed sensor mount(On transmission) is broken, no speedo, HELP?
  44. Power steering leak/brake problems
  45. ECU PROBLEMS
  46. Can VAFC cause a stall?
  47. AP2 wheel
  48. JDM M2A4 TRANNY SEAL... (output shaft)
  49. Sh tokico Hp comb ?
  50. H22a4 Blew Up Headers off - cylinder 1 nothing inside
  51. SH hub vs base hub
  52. Strut bars
  53. whats normal op temp of a 01 prelude?
  54. 92 gsr iddle surge and engine gurgle
  55. burnout
  56. ohming injectors
  57. Removing head from my h22a4
  58. Yes another ignition switch question.
  59. Oil pressure switch
  60. h23 vtec... got ?'s
  61. base prelude motor in a SH prelude?
  62. Went to start the car yesterday .................
  63. I've searched, (archived aswell) but no other cars stall under same conditions as mine. Any help ple
  64. if you converter your obd2 car...
  65. 420A eclipse injectors into H22????
  66. OBD2 self corrects????
  67. my car screams!
  68. THROTTLE BODY
  69. Heating up?
  70. H22A -JDM w/ LSD - Transmission - How much do they sell for?
  71. Honda tranny fluid capacity
  72. Possibly Maybe...
  73. Bad Knock Sensor '97 Prelude
  74. Transmission question
  75. Strut bar Spoon/Tanable/Neuspeed
  76. megan exhaust
  77. starter bolts
  78. Hellp!!! Who can block sleeving.
  79. prelude bb1 vs rsx type s
  80. **The Definitive way to extract Valve Seals**
  81. injector clips question
  82. K-series Prelude
  83. CKP air gap ?
  84. Clutch Break in
  85. need some tech help from some gurus
  86. e-beer: Quick everyone laugh at 98vtec before it gets locked and I lose points
  87. questions about F22A Prelude
  88. question about h22a rebuilds
  89. injectors
  90. Removing Cam caps
  91. Suggestions on this rebuild
  92. I need a radiator but....
  93. need lots of help
  94. 90 Prelude si wont start after sitting a day or more
  95. 97 prelude SH foglights
  96. Powerband?
  97. Anybody good in rebuilding h22a obd2?
  98. hard to get in reverse!!
  99. H22 Type S motor
  100. Shifting Cable!!!
  101. it runs
  102. would this tire size work?
  103. NEW SHIFTER CABLES ARE 2IN LONGER?? THEY DONT FIT??
  104. 4ws 1991 Lude
  105. e-brake adjustment?
  106. exedy flywheel ?
  107. Removing Cams- Tensioner question
  108. skunk2 cam gears installed, car runs then dies
  109. Questions regarding F22 crank in an H22 block....
  110. options
  111. H23A1 Disctruction Pictures
  112. Turbo H22 map sensor
  113. Best Insurance for a '97 Prelude?
  114. H22A4 Hondata Questions
  115. Timing Question
  116. seats for 5th gen.
  117. will a 91 Si motor bolt into a 92 4ws??
  118. I think I blew it up.....
  119. Some advice on a possible purchase......
  120. I'm opening my doors (literally)
  121. 5th gen Innovative Motor Mounts
  122. Turbo H22 sudden hesitation at 3000-4000rpm
  123. Power Loss and Car jumps while in gear / Sputter
  124. Dash Lights??
  125. 93 Prelude caliper upgrades
  126. air conditioning compressor
  127. catch can return
  128. Hondata s300 base map
  129. foglights
  130. Is this a good deal?
  131. CEL 4: CKP sensor
  132. If I were a 1 pin connector, where do I go?
  133. would this be a good setup to go with?
  134. Welding Together A 2-Piece Header???
  135. are arp main studs a must/.
  136. 89 Prelude S to 91 Prelude SI Swap
  137. Intermittent solid CEL? bad wiring or ecu?
  138. Valve questions?!?
  139. Mahle Piston questions!!??
  140. Forgive me if this has been asked!!!
  141. help me diagnose my cold start problem
  142. Burnt ecu... which component is this? P28
  143. Question on launching.
  144. h-b transmission
  145. springs and retainers? what brands
  146. 92-96 lude header on a 99 lude.
  147. Another stupid jdm option ?
  148. Help on installing oil temp gauge
  149. h23 trans or f22 trans
  150. Little Black Box...
  151. AC Clutch/Compressor?
  152. Main Fuel Relay!!
  153. Turbo @ 9+PSI + Civic Half Rad = Over heating
  154. 6 hr search/ reading...eyes hurt...new poll for turbo prelude owners
  155. SMSP fitment?
  156. Will a JDM A/T Speedometer work with a M/T Prelude?
  157. cable shift linkage
  158. How to tell if your front mount is bad?
  159. Question on OBDI II
  160. Brown/Rust colored spark plugs!?!??!
  161. b20 mods?
  162. my JDM headlights look like @ss.
  163. 92 prelude with 4 wheel steering broke a mount.....
  164. Header For Sale
  165. Towing Hitch on 96 H23
  166. valve adjustment f22b help me
  167. Main Relay rplaced and wont start at all
  168. universal o2 sensor for h22a?
  169. WTF is the point of intake piping?
  170. 2000 Prelude Oxygen Sensor - Part Interchange
  171. 95 JDM H22a motor has jumpy idle
  172. ebay shift knobs...
  173. Sunroofs in 1988-1991 Preludes?
  174. The OFFICIAL "My clutch is slipping and I think it is dead" Thread!
  175. help with installing autometer tach
  176. P28 Mounting
  177. I need wires...
  178. what next...
  179. Squealing Belt or AC Compressor?
  180. 93 Prelude H22 Hit & Miss Starting!!
  181. 01 prelude Trunk Measurments
  182. progress sway bar ?
  183. Transmission Problems w/ My Prelude. Please Help Me. Thanks.
  184. header question
  185. turbo h23 question
  186. f22 flywheel on a h23
  187. LF 5th gen prelude that is for parts
  188. obd1 h22 into a 00 Lude questions
  189. oil sandwhich plate
  190. royal purple
  191. Exedy Stage 2 Cerametallic Clutch Dead Already?!?!?
  192. Thread with weight specs (when lightening lude)
  193. autosux
  194. cooling fan
  195. Underdrive crank pully
  196. 92 having trouble starting
  197. Convert 5G To RWD?
  198. so what kind of T3/T4 turbo manifold is good for my build h22 block? and i can keep A/C?
  199. h22 head h23 block???
  200. twin loop mufflers/ who has em and how are they?
  201. -NTF- Widebody kits (Specific)
  202. i need a list of engine codes for prelude with h22
  203. rpms too high??
  204. ARE ACCORD TRANNYS GOOD FOR H22?
  205. SH springs/shocks.
  206. Torquing down crank pulley bolt
  207. cam gears cover???
  208. h22 swap injector question
  209. h22 6 speed
  210. help with tire size?
  211. 97 prelude tranny problems
  212. compression test and timing question.. need help please!
  213. question about converting auto to manual.
  214. who has BENT a clutch release fork???
  215. horsepower, torque, and VTEC
  216. EACV CEL 14 5th gen / ABS codes 100 and 1
  217. Timing Cover
  218. f22 swap tranny for a h22a asap help
  219. Jdm ECU
  220. Wish to replace old worn out bushings on a 5th Gen Lude
  221. turbo h22
  222. comments about EBAY
  223. Questio? brake rotors for 96-97JDM-ITR : PRELUDE
  224. 5th gear swap
  225. Tranny clunking sound questions
  226. What kind of valves should i use
  227. How Hard is it to Mod a Type SH
  228. h23a1 oil pan on h22a
  229. Bolt size?
  230. adjusting idle (4th gen)
  231. should i get this lude
  232. 1988 Honda Prelude SI question about steering wheel
  233. 2000 PRELUDE cluster in an EG help PRELUDE CLUSTER PINOUTS.
  234. Eliminated resanator with 2 1/4 piping?? OBD1 ECU on 5th gen
  235. bb6 fog light switch question
  236. s2000 wheels
  237. 97 h22 block with darton mid sleeves? need head gasket
  238. i need the part # or size of alt belt for lower esp alt bracket
  239. Anyone know whitejm?
  240. stock jdm internals on boost?
  241. Header Question
  242. HID 5th gen problem
  243. performance header for base
  244. H23 motor shift problems please help (car is new to me)
  245. what kind of ECU is 37820-P5M-A02?
  246. wires
  247. Carbon Fiber Hood
  248. Help Car Doesnt Start
  249. Alignment problems
  250. Potential New Prelude Owner Need Advice
