View Full Version : Honda Prelude
- Prelude 2.0 EX Auto. 1989 3Gen
- Trying to Figure my Prelude Swap
- 5th Gen with Check Engine issues
- H22A4 high rpm stumble?
- Out of round cylinder bore
- Brakes & Movement HELP
- First Engine Build....Looking for advice.
- 2nd vs 3rd gen Prelude as a project
- Rack and pinion hydraulic transfer tubing
- Building my dream car
- 1999 Prelude with misfire issue at idle
- 96 prelude f22 into a 2000 prelude shell
- H22A4 using new ACL Race Bearings out of spec? Or safe.
- Overhauling 97 prelude suspension?
- Crank no start, spark ignition coil not at leads
- 5th gen front coil spring cross compatibility
- Plug gap and 22lb boost h22a1
- F20b stock ecu or switch to obd1
- Need Helms Electrical TS Manual for 97-01 Prelude El
- Driver side mirror
- Need help! Crank pulley for 3rd gen prelude.
- Fuse to Protect Ignition Components
- H22a4
- Abs light blinks for code 81 and 16
- 5TH gen PRELUDE TRANNY HELP!!!!
- Looking at a 1993 4th gen Prelude (Si?), what to look for
- Trying to fix idle issue..97 lude h22a1
- Why would someone do this? Can it be undone?
- Where to buy front fender
- Calling All Honda Prelude Gurus!!!
- Atts mu24 trans to 92 h23a1
- Full h22 build and turbo..how long will it last?
- Should I buy
- Timing Adjuster Seals Question
- H22 lsd install gone wrong….help
- Need help with power steering lines, please
- Circle track Prelude race car
- K Swap transmission compatibility
- 97 prelude spherical bushings for lower control arms?
- What is the best way to drop a 3rd gen prelude?
- is this enough oil pressure for 900 rpm, brand new oil..
- H23a manual
- 91 Prelude H swap running rich
- 97 prelude service connector location
- 1997 prelude auto low voltage no crank
- Fender harness
- 93 prelude si coupe won’t crank
- Chipped P28 H22a 5th gen bogging/stuttering HELP!!
- Honda Prelude 1992 Si 2.3
- What oil is used for a G23 engine?
- 2000 Honda prelude STUCK IN LIMP MODE HALP!
- Honda Prelude blown head gasket?
- H23 Vtec timing belt slight "walk off"
- boosting 12lbs sometimes. then 16lbs?
- H22 with h23a1 crank? Need help with valve clearance
- Prelude p1381
- H22a4 automatic swap to manual LSD m2b4
- Making A New Gear & Ratio
- H23a turbo build.. s300 .no spark I’m stumped...helllp
- H22 turbo manifold studs?
- h22a1 blowing out of intake
- H23a vtec 01 prelude swap timing belt issue(s)
- Temperature slider seized up - where to find replacement cable?
- JDM H22A Type S with atts and transmission still intact
- Restoring 5th gen suspension to stock for daily driver
- Wanting feedback on crankshaft pulley removal hack
- Air or Fuel upgrades first
- Timing belt issue
- Please help, been battling crank no start for a year
- Sluggish Acceleration
- H23A1 Compression specs
- 94 prelude si brake lights no tail lights
- Please HELP Crazy TPS calibration issues
- Twin Engine Prelude
- Alternator failure after wash
- H22a4 build need help
- h22a build question
- 1984 Honda prelude not starting
- How to fix P1459 for prelude 97?
- P14 a50 ecu daughter board...
- Master cylinder upgrade
- Jdm s-spec h22a wiring diagram?
- Are parts from 2001 and 2000 interchangeable?
- 94 h22a1 Rebuild going sideways
- Is My 96’ H22A4 Swap in My CB JDM??? or NOT!!!!
- 1995 JDM Prelude
- 95 Lude F22B JDM Swap
- Help about Engine block I acquired in storage unit
- 2000 Honda prelude warped crankshaft ?
- Crankshaft bolt tool for 1999 prelude
- HELP!! Need opinions. 95 prelude
- Brake upgrade
- 1997 Honda prelude power lock problems
- 96 prelude 5speed shift problems
- H22a4 block
- F20B, T2T4 trans with bad shift fork
- Cruise control
- H23a1 swap
- What’s needed for a mk4 swap
- G23 is it worth it
- vss signal splitter to speedo gauge and ecm
- motor mounts for 1989 prelude 2.0 si 4ws with jdm b20a
- Valve stem seals help please
- H23 having trouble starting after headgasket replacement
- H22 swap won't run
- 96 to 94 prelude inertia door cards
- Radiator fan wiring question
- 1990 b21
- 91 3rd gen prelude engine swap
- '94 Prelude Engine Swap
- H22a 5th gen misfire
- Prelude h22a4 engine build
- '89 Prelude Idle issue
- Can't get my car to start, been at it for 5 months. 5th gen lude
- Camber and pulling issue
- H22 swap with b16a ecu dumping fuel
- Will a 97 prelude exhaust fit on a 2001?
- Prelude Project
- Prelude starts jerking when letting go of the gas pedal
- H22 Swap won't stay running
- BB6 ATTS oil change question
- H22A swap- Won't go uphill !
- Main relay part number
- Clunk & Popping Noise From Wheel/Axle/Transmission
- Crank Pulley rubbing against timing cover
- What Is This Thing?
- Fuel Pressure Regulator line
- ENGINE SWAP HELP, Prelude SI 1994
- Need help badly with my Honda prelude
- Prelude Boosting
- 4Gen - Immobilizer install - where to tap the ignition wire?
- Did shop cracked my block?
- main dashboard - wiring harness mappings / diagrams - honda prelude 1994 si 4ws
- 89 Prelude No Fuel Pump Noise
- Headers prelude
- Adding knock sensor to 2g Prelude
- Is it okay to pull away in second?
- Random misfire on all four cylinders
- Transmission.
- 93 honda prelude si transmission
- Long start problem
- 4ws error code 20 on 5th gen
- Brake System: Math, Specs, Forces, Hydraulics
- Type SH clutch/flywheel replacement (with atts unit)
- Header Help for H23a swap.
- H22 Head Studs
- 2001 Honda prelude tires to start but won’t
- Twin Engine 5th Gen Prelude Wheels/Tires
- Power windows need help
- 1987 prelude (base) d series swap questions.
- 95 Prelude - fog lamps - what relay do I need?
- 95 Prelude: Any idea what this damaged tube is for?
- H22a Flywheel & Clutch replacement
- F22B1 distributor on F22A2
- F22 Crank inside a JDM H22A Block
- 1992 Honda prelude h22a DOHC
- Needing help to fix my Lude!
- Am I at top dead center?
- H23a1 intake manifold
- Motor ID and recommendations for build
- No start
- H22A4 to H22A swap
- JDM H23A wont start
- new to forums, looking for help
- 4th Gen H23A Swap
- P0441: Evap Incorrect Purge Flow 2000 Prelude
- P1381 CMP Sensor A Intermittent Interruption
- 96 Prelude S Easy 200hp Swap Questions
- New Build H22
- Low Idle/ Other Issues
- Used 97 Prelude with f20b/LSD advice
- Help!! Why is my flywheel too big! F20B to H22A
- 96 Prelude S H22a1 swap
- Speedo not working, D4 flashing! 01 lude
- 92 prelude no crank no lights
- 96 prelude si h23a swap
- Can't decide on Wheels?
- 98 Prelude Pricing
- F22b (sohc vtec) swap into 96 Prelude S help
- Manual rack and pinion for 91 honda prelude si
- Exhaust Rumbling
- JDM H23A into 4th Gen Prelude
- MSD blaster 2 coil on 5th gen prelude???
- Need help! Transmission
- 88 Prelude
- H22A4 EGT Values
- oil pump shredded
- Code P0301
- Brakes & rotors for 1997 Honda Prelude type SH
- Should i shim a OEM oil pump or Auto parts store oil pump??
- Prelude SH BC Racing Coilover selection Standard vs. Extreme Low
- H22 stock outer valve spring pressure?
- Prelude SH GC/Koni lowering help
- Dim oil light
- 4th gen Gas Tank
- Tach/speedo/thermo gauge help
- Exhaust Gasket Distributors
- Decode fuse box on driver side compartment
- Nude lude
- Turbo D16 in a prelude
- 95 Welded EGR Passage
- Engine Noise Diagnosis (video included)
- 91 prelude si vss
- Shift cables
- H2k intake manifold on 5th gen prelude?
- A1 to A4....why go obd2 motor...."??"
- 5G - Replaced my roof moldings
- New exhaust setup recommendations
- H23A VTECH Blue top/NITROUS/Built head
- Lean misfire help
- 4th Gen Prelude
- 2nd gen Prelude swap options
- Timing belt tensioner broke
- 1991 Honda Prelude no fuel pressure
- H22a
- 97 prelude tac and speedo jumping
- H23A VTECH not engaging
- Swapped 3rd Gen axle help
- Can’t find vss. Vehicle speed sensor. To purchase for 91 prelude 2.0 si automatic
- 1986 Automatic Honda Prelude 2.0 si Bad flexplate?
- Need help f22a1
- 98 Honda prelude misfire cylinder 3
- Jumpy Prelude 1997 si
- Deference between EDM H22A7 and JDM H22A Prelude Type S/S-Spec
- 4th gen F22a1 to F20b help please
- 97 prelude cuts out when I floor it
- Sh to H22a wiring diagram please!
- H23A1 Build
- H22a vs h22a4
- SH to Base swap question.
- 91 Prelude
- Throttle body?
- External to Internal Distributor Coil Modification
- 92 Prelude Build
- H23a JDM swap help on a 2000 prelude
- Help please! Oil leaking bad from behind timing belt
- H22a swap
- boosted h23 help
- 4th gen prelude fuel filler leaking
- 345cc peak and hold injector resistor box
- Piston rods??
- 2000 Prelude timing
- What size TB and Injectors for H23A with Nitrous???
- Anyone running nitrous? H22 or H23??
- Cracks????
- F23a swap 2g prelude
- PSJB_Prelude build thread
- Help a tall guy out....
- Compression ratio Piston for turbo?
