- rpm's trouble
- Transmission Noise when Downshifting
- 94 Prelude
- Has anyone run the Mahle Gold pistons for over 60k miles and had issues?
- You are subscribed to this thread Major idle problem with 1989 JDM B20A swap
- long term storage
- redline
- assembly...
- mounts
- F22 in Prelude
- HELP!!! 1998 prelude block
- rod knock! help!
- 1994 Prelude
- question on turboing h22a
- obd1 conversion help!!!!!!@!!!!
- Whats the best tranny setup
- short ram intake - direct air
- driveshaft problem
- Jdm obd1 h22 into 99 prelude
- tapping sound coming from rear passenger fender?
- H22 swap...what else needed?
- 3gen 4ws on 4gen
- Low Offset with 18" wheels on a 4th gen?
- No odometer on EL Gauges swap
- OH NO!!!!
- do YOU think my engine is finished? MANY PICS
- H22 N/A setups. Are you guys satisfied?
- Will this motor work?
- H22 S2 Pro2 cams Qs.
- What software for Ostrich emulator and HULOG
- Blown Head Gasket! anyone try one of those repair kits?
- bad hub or trans?
- Might have big problems here with head bolts
- Crazy tach bucking jerking missing backfire at wot
- stock ignition timing help.
- m2b4, which lsd type?
- You know you own a Prelude when....
- I think the ignition is broken on my 98 Prelude
- Rpm signal intermittent....
- 97 typeSH Swaptions
- First off sorry for posting here
- Think We've Lost Another One
- can high comp pistons make u fail smog?
- would a code 1??????
- need help please!!! can somebody check something on their car for me?
- Outer tie rod end castle nut size
- Mystery clanking noise up front
- h22 intake manifolds
- BA4 Shorting out? or Garbage battery?
- bad squeeking from the wheel well?
- 97 prelude cel 8 issue..need help??
- Prelude bounse idle? im stuck
- Suspension - Lowering Springs?
- Fog light install help (tweeter switch connector)
- Temp Gauge Issue
- what should I buy to tune my 95 H22a chrome P28?
- 97 sh transmission base engine questions
- 99 lude trans reccomedation's
- H23 NonVtec Question
- more H23 Vtec stuff
- Dash light fault on 1995 honda prelude
- h22a1 into 97 prelude
- B20A6 Piston ring groove width.
- help plz
- H22 cat and O2 sensor questions?
- injector resistor box help asap plz
- Need advise on how to start build
- New Q's about my recent swap (need help asap)
- Help naming/finding a part
- Replacing distributor back to camshaft 01 prelude
- hey guys new to the site was on Superhonda
- Appearance related/Rear visor
- Need Help with spun bearing
- CEL Code 6 (ECT Sensor)!
- F22a4 and H23a1 Swap..
- Injectors
- No fuel sig. Have some questions.
- climate control led lights?
- MSD coil possible w/H22?!
- Distibutor Problems?! help asap.
- Anyone tried these suspension parts?
- 3k bog, hesitation, backfire....FIXED
- ? for my buddy.
- No power to passenger side door (99 prelude)
- Need some help on my recent swap...
- coil paks
- superturboprelude new h22 gt35r dyno redyno
- Euro r motor smoking
- No spark In my stock lude need help!!!
- 89' si
- Suspension...
- Setting Cam Gear for Milled Head
- Just got my prelude...
- Oil in radiator and small amout of water in crankcase
- Springs fittment help???
- Pioneer AVH-P4100DVD in a 5thgen
- Need lsd!! please help.
- popping noise between 6-8k rpms on h22a?????
- spinning ball joint
- 1990 Prelude Speedometer pin stuck past 220
- lowering a 4th gen
- Motor mount question
- I should know..but I've never used em so I'm asking..
- ebay FBR oem lip kit?
- Help on a question
- So that's why she made all them noises...
- Jdm h22 type s ECU
- 3rd gen resources
- 93 jdm h22 engine limp plz help
- Need opinons, going to buy a prelude
- Accord SE Wheels on 4th gen lude?
- buying H22a supercharger
- HIDs help!!!!
- axeit209
- K24 swap!
- Need Help Please
- 8 in the front 9 in the rear
- why is my Vtech cutting out!?
- JDM H22A Euro-R / Type-S Engine
- Will 4th Gen VTEC axles and int shaft work in 5th gen base?
- need some advice please help
- P/S Pump
- might get a lude
- how strong is FRM?
- Lost Pressure When From Clutch!!!
- atmospheric pressure sensor
- need help h22a headgasket!!!
- H22 245 Whp 11.5.1 Compresion
- h22a euro into 92 prelude help!!!
- Unique Swap
- P0420 - How to proceed?
- H22a Thermostat Temp
- bore size 88mm
- Surprising results dynoing my new stock JDM H22a motor 187whp/?tq
- A little help please
- Dont wash AEM filters!!!
- vtec question
- Brake light problem!
- Where do you get this?
- Anyone Turbo a 4th Gen H22 AND KEPT A/C?
- how to retrofit JDM 1 piece headlights with TSX projectors!
- Motor Swap
- what is the thread size on a 97 prelude secondary o2??
- Problems closing me hood
- Weird rattling in H22 when tapping the throttle quickly
- '95 prelude electrical wackiness troubleshooting help?
- Jdm H22 Dizzy.
- strut squeek helpppp please
- roll fenders
- Water in Trunk
- 2000 coolant leak
- intake manifolds
- Need help diagnosing and pricing....
- Where can I get a bell housing
- H22A Year??
- Oil under transmission housing and oil pan...ideas?
- jdm obd2 h22a type s motor
- Torque specs for breaks and spark plugs
- exact lug pattern????? please need asap
- Head Unit Problem
- stripped trunk
- 92 Lude HELP!!!
- Is the writing upside down on these springs?
- Hello all!
- my turn signals and hazards arent working(help)
- bracket issues please help!!
- replace Prelude engine with K20Z1, or rebuild
- 5th Gen How to wire 3rd brake light
- a couple 1987 Prelude Q's
- Will A/C work without a fan?
- Stupid question Im sure
- Need a reasonable price range
- HELP MY LUDE PLZ=/
- Code 12 EGR Valve....
- high compression?
- f23a1 tranny fit on h22 and bolt right back in the lude?
- need help wit bodywork!
- Which platigage should I use...?
- Front wheel bearing--- did I get the wrong part?
- Heat/AC fan and radio not working
- can any prelude owners help out a itr owner?
- Which SPC Alignment Kit Do I Need?
- Need Help With Rim Choice..=/
- Need Help 1st car and needs work,any advice?
- 92 Prelude Si ABS light
- possible for a manuel tensioner to begin to fail?
- car is acting wierd
- 92 Prelude JDM H22A Swap Bad idle
- fog light trouble
- h22a all finished let me know what u think
- prelude speedo cluster conversion
- type S confusion
- Prelude H22a ITB ... What ECU and Mods requiered?
- help! car has overheating problems!
- NEED HELP! CAR HAS OVERHEATING PROBLEMS
- prelude lip kit question
- performance question
- Grinding noise when step on the brake....????
- Where can i get carbon fibers doors??
- Best Way to Remove Bolts
- h23 bluetop swap
- Front lower ball joints where to get the best ones.
- I'm I in trouble with my front wheel bearing?
- What head to use on a mutt of a turbo build
- tranny help
- MP1A ratio....
- 5th gen prelude h23a vtec swap?
- F22A1 - Can the waterpump be repl. without removing timing belt?
- Write up on ATTS install?
- trouble removing oil pan on '98 Base 5spd
- New Headlights
- Temp Gauge Sensor on JDM h22a
- Ignition Leads: OEM vs Aftermarket
- Putting Racing Seats in. Will rails fit on the seat? NEED HELP ASAP!
- Anyone know a good Local Tuner in NJ?
- H22 bearing question
- obd2 to obd1 conversion on 5th gen
- 4th gen HID question
- Oil Pressure Switch
- how to replace vehicle speed sensor in a 91 prelude si
- Front License Plate 97 Prelude
- 1FunRyd's 88-91 Prelude - Auto to 5 speed swap, B20A - H23 Non-VTEC swap
- please help me diagnose this leak!
- Do I need to hone the cylinder walls?
- h22a ecu help
- NEED HELP DIAGNOSING THIS LEAK!
- tuning question
- 1989 Si wont start
- tranny from f23a1 fit on h22
- Car is running like a Harley motorcycle...HELP
- Bearing Question.
- 1990 PRELUDE S (1958cc/dual-carb/5-speed) STALLING PROBLEM when WARMING/FULLY WARM
- H22 skipping timing?
- CPS - crank position sensor obdI obd1 1995
- b20 swap
- Running Rich
- Is my coil hooked up right? (Video)
- H22a turbo kit?
- H22a help....
- Changing automatic belt tensioner to manual belt tensioner...???
- Problem with LMA installation on my H22A
- cluster lights not working..
- Questions F22
- H22 ARP head stud torque specs
- h22a4 piston rings
- 4th gen . bb4 headlight question?
- Building Block
- Restore USA Engine Restorer
- My Fully Build H22 Project
