View Full Version : Honda Prelude
- My title.
- Boosting with JRSC. How to prepare for boost?
- doing the rotors
- To all you guys with upgraded sway bars
- autpmatic tranny question
- H23 ecu's which one to go with
- 92' 23H misses after reaching operating temp? Help!
- ECU Placement
- replacing struts
- 5thgen rims on a 4thgen
- $20 Albany brake pads from Autozone
- WTB or WTT h22 short block or long block
- Is this a sign of worn out clutch?
- Brake differences on a 4g lude.. Vtec-SI?
- o2 sensor
- shift light question
- aftermarket h23 rod bolts?
- check engine light?
- Map sensor wiring order on the harness?
- Changing To Manual?
- 5 lug prelude hub bore?
- Wheel Bearing Loose on rear pass.
- Help with my 84 Prelude
- Gude head work?
- help car shaking
- is this true?
- Removing PS, What to do with VSS
- How do you adjust headlight for a 98 Prelude?
- MSD plug wires
- shift boot and main relay
- rods to use with JDM Type-S pistons?
- 2.5" or 3" CAI?
- Thinking about getting a Chikara exhaust ...
- Replacing the timing belt
- spark plugs
- Can a Auto P13ECU run on a Manual Prelude Si
- b21a trans problem
- sway bar and left wheel shakes
- fuel pump relay
- *********help needed, questions about, valves? cam setup, sleeving pistons????
- 1988 Prelude Si 2.0 Manuel spin no start any info
- top speed short shifter adapter
- The mid-engine Mini needs your help
- Turbonator
- What kind of grease Honda use?
- notice to those fitting JDM integra type r wheels on 4th gens
- Spark plug wires
- prelude seats
- JDM and USDM engine difference.
- clutch so soft why??
- STP full fuel system cleaner with jet fuel; check engine light
- h23 with p75 revving limits
- Does the VIN number have the trim level?
- 4th Gen front lips and sideskirts...(yes I searched)
- Exhaust Questions
- vafc I or II or does it matter?
- 4-1 headers?
- Best way to improve top-end power on gen 4 SI?
- Jun dyno
- How can Prelude be considered 2 + 2 if adults can't sit in the back?
- tacho porblem, its weird
- Car won't idle unless headlights are on
- EGR failed NOX
- Need Help Check Engine Light
- F/S H22 head and trans
- Need help on swap from H23 to H22
- axle question need quick advice
- DC5 R Wheels on a Prelude?
- Aftermark brand for SH 1997 struts.
- prelude SI and VTEC ?????'s
- HELP ON HEAD SWAP
- Installed AEM fuel rail yesterday and now check engine light
- Sway Bar Mod? Is this better by taking off the OEM?
- Break In Clutch
- Anybody know anything about these pistons??
- Question concerning custom headers...(hytech, an-r, prospeed, smsp etc)
- It runs...and then it dies
- Excedy clutch problem
- STR 68MM throttle body install question
- BB6 Squad?
- engine oil sg rating
- Runs well on p14 but not p13
- car start problem?
- H22 JDM VTEC Auto -> Manual conversion... help!
- I will give 50 bucks if you can tell me whats wrong!!!!!
- ABS indicator light
- HELP!! EGR code keeps coming up?!
- 4th gen seat question
- Misfiring caused by moisture?
- tein suspension help
- Most psi a stock h22 can take
- Prelude 92 engine noise
- Cd player/Radio options
- Sleeve install price?
- No one knows the solution.
- Need to see some prelude dash pictures
- Any Customizing needed to put in HID's
- ???My bouncing idle goes away only when I let the clutch out a little???
- I'm only at half a tank and have gotten 200 miles out of it...
- Removing Power Steering Belt.
- Energy Suspension - Wheel Hop - 5th Generation
- replacing syncros?
- JDM h22 Swap into 5th gen - CKP/TDC/CYP Headaches!
- 94 honda prelude si vtec or non-vtec
- wtb field fac-vtec controller harness (sorry i didnt post in classifieds)
- 95 vtec with SI tranny
- Cost to get front windshield replaced on gen 4 lude?
- H22a wont start need help
- No Clutch Feel
- Hydrolock Risk of Removing Intake Resonator...
- apex'i safc I, or safc II
- how to check if there is gas in the oil?
- H22 and NITROUS????
- Can I re-use a weld-on muffler if cut off?
- 88 Honda Prelude SI / Door Glass
- H22A swapping into a 4WS???
- Which mark for TDC?
- oil on spark plugs....
- Good RPM take OFF?
- who out there knows the timing belt specs for a 2.1 SI motor
- T1R B-pipe and Header
- 40mm offset 16"rim with 225/45's anyone have experience? Will this rub on a 4th gen?
- How much do cams really Help?
- Thermal cat back-5th gen...
- Vtec gauge cluster
- How should Oil dipstick be checked?
- Cad drawing of outside of h22?
- Help! Cylinder to headgasket clearence
- CEL Question
- tie rod boots
- Tranny and axle questions... No one can figure this out!
- 97-01 Wings West Evo hood
- 2001 Prelude SH Clutch Problem
- JDM 4th Gen Climate control
- HELP? can someone give me a step by step on how to Tune an APexi SAFC
- replace the tach?
- s2 IM w/ boost?
- Quick Rear Main Seal question
- h22a block replaced by f22
- Code 20 ELD
- quick tire question.
- no 2ndary 02 sensor
- Tein vs. D2?
- couple of things about my new prelude
- Power Steering Issue, Help Please...
- Possible group buy on frm compatible pistons...
- Crossmember Interchangability??
- JDM One Piece Headlights
- golden eagle intake manifold and fitting wiring harness
- Confused about this wiring harness business (searched)
- HeLP !!!! motor wash
- Video of supercharger?
- H22A Crank Differences?
- will uncut bumpstops ruin my shocks?
- 4 gen brake upgrade
- Camshaft Pulley Bolt Stuck some how still!?!?!?!
- Anybody got pics of a 3" downpipe on their lude?
- 4th gen axles fit on 5th gen?
- 4th gen Prelude in GT4!!!!
- Honda Prelude Retro fit questions
- ECU Code 45
- H22a - H23a1 pistons
- Blue wire mod what color wire on the ecu pin out
- Car not starting...
- WTB: 97 or newer Prelude in or around Sacramento, California (NorCal)
- Intake manifold
- bulb size (not headlight its interior) 4th gen.
- JR Supercharger question..
- 88 Lude Needs Help
- distributor cap
- clutch/flywheel was changed now having problems
- The prelude can be turbocharged in GT4 :roxor:
- pcb ecu pinouts
- H22A4 > H22A Swap Misfire Solved!!!
- leather seats
- changing clutch.. need help
- 5th Gen Turbo Exhaust
- How to tell the difference between a SH and Base
- H22 Build
- 0-60mph time for 4th gen lude SI?
- Distributor and rust
- Fixing powered antenna on 4th gen lude
- transmission issues: occasional grind/lockout
- Tranny swap Question
- Fans problem
- SH transmission differences
- chamber kit = less handling?
- removing power steering the right way (or better... whatever)
- BAD NEWS....anything would help right now
- vtech head on 1st gen.
- prelude swap possibilities...
- h22 VSS interchangeable with m2b4?
- Timing Belt Play
- info needed on h22A ls vtec conversion
- Idling Issues
- cams for h23?
- Compression
- prelude front lip-jdm hiro
- 225/40/18 series tires too big for lowering?
- hey all have question
- new bearings((emergency!))
- memory and ignition kill
- Need Cat recommendations. 4th Gen
- 400whp out of a b20a5
- H22 injectors on h23?
- Tranny Woes
- Replacing the water pump on a 1988 Honda Prelude 2.0Si 4WS: hard?
- wider tires on stock rims
- Stock bottem End all motor H22 hp
- brake options for vtec prelude
- Quick question: Prelude S, h22, and F-series tranny.
- Question about field vtec controller harness
- Thermostat
- pulley problems
- Prelude without Power Steering
- What happened?(h22)
- (Stock JDM Block or Type S pistons?) and 12:1 Compression
- JDM H22A Driveability Problems
- plug for rear brake
- possible to add 4ws?
- h22 cams
- 4WS and suspension..
- Do any H/F Prelude/Accord transmission have anything longer than a 3.285 1st gear?
- Car sputtering at 3K and up.
- nsx calipers
- 35mm offset 18x8 rims,is it ok.......?
- H22 cams reversible?
- Power steering resevoir leak...
- could any damage occur?
- Valve Cover Nuts
- nsx cailpers
- Greddy sp question
- Non-PS rack for 3rd gen lude
- Turbo Prelude vid 13.2
- Flywheel does wut?
- Finally weighed my car...
- Exhaust Leak
- Prelude Axles for a swap: H23 > H22 (how?)
- Climate Control Install BB4. How To?
- fuel pressure gauge
- Auxillary ATTS Switch
- Just wanted to thank all my fellow honda-tech prelude forum members and say goodbye
- Fuel & Temp gauges real hard 2 see
- 5th Gen - Oil Problem
- h22 bottom end strength
- tell me about my prelude
- need prelude info
- fully built H23 head
- Is transimission fluid changes normal for a 5spd
