View Full Version : Honda Prelude
- Nhra Sport FWD 92Prelude 11.44 quarter mile Denver, Colorado
- I Manual Transmision upgrades
- Is it the fast idle valve?
- Low vacuum 93 prelude si.....Cant find the problem?????? Newbie Help
- Difference between H22A1, A2, A4, or whatever?
- vtec loud?
- 95 jdm h22a into prelude 92.
- 1996 p13 in 99 lude...will it cause problems?
- problem with replacing headlights
- Help with h22 swap into my 95 si
- Factory immobilizer on ecu?
- Ideal turbo build on h23??
- I need est HP on my h22a turbo please.
- Timing belt broken - bent values - 1996 Prelude SI w/ Vtec
- help with B&M fpr
- Where to order an H22 engine for swap
- H23a1 Factory Header?
- h23 shift point
- A or B pistons, where is it stamped?
- 5th gen fuel cutoff???
- header modification update ...
- Supercharger Info
- jdm h22a (with mad vtech powa) put into prelude si... not starting help!
- '92 stock Prelude
- LOOKING FOR A BRYAN WITH A WHITE 5th GEN
- 2nd gear grinding
- Port an Polished Intake Manifold Questions?
- Where in Florida is GOOD shop to install turbo system and tune on 99 lude?
- can I run no fluid in my steering rack???
- SPOON
- h23a for replace for h22a 95 vtec lude
- ?vtec egagment lowering??
- headers Problem
- Noticeable difference in SH vs. base model?
- 5th Gen Vtech, Fmax, Greddy, or Maxrev turbo kit?
- Further Axle Problems/Spindle Nut Removal/Wheel Not On Car
- Can anybody identify what year and model Prelude(?) that this shifter assembly is from?
- A 4thgen turbo prelude just ran a 11.44 at 123 mph at nhra denver colorado
- I am really close to getting my first car can yall give me some tips on what i should get?
- 5th Gen fittment question
- I need Help: problems with my lude.
- Compatable Swap for a 1988 prelude-S
- chiping my ecu
- strange noises
- driveshafts
- ABS or NO ABS
- h23 cam questions???
- 92 prelude h23a 180k miles suggestions please!
- <---Prelude/Automobile newby and enthusiast... Help? Haha..
- H22a4 in a 4gen
- Type-S air chamber
- wheel offset
- *PICS* ebay intake install/review *PICS*
- what oil should i run 2.3 4th gen on?
- H22a aftermarket oil gauge
- Smoke coming out of the exhaust. Can someone help? Any knowledge?
- Do I have an LSD or not?
- making my lude faster?
- got a new prelude but has some problems...
- Injectors
- h22a1 and h22a4
- 97-01 Dashboard
- ??jdm bracket??
- Rear sway bar
- Question about the Tiptronic shift plate
- My Lude is sick :(
- My brakes are f*cked.
- Exedy or Spec
- Car won't go into reverse
- JDM foglight install???
- ITR wheel on my lude...
- 91 Prelude Si speed sensor
- how fast have you taken your 4th gear on your h22 engine?
- easy question for those who know their stuff about Preludes.
- bogging problems on h22a swap
- Sleeve durability on stock H22 (5th gen)
- CEL this morning, help.
- Vtec engaging late in 3rd gear
- prospeed headers???
- H23 swap to H22 question????????
- question about the Greddy header
- Buying a Prelude
- what are broken ring lands.. i read that somewhere and would like to clarify
- Headlight bulbs keep blowing out? ('97 Prelude SH)
- i am looking at a 92 prelude will it be vtec.
- Blow off valve vacuum line goes to?
- Cylinder Position Sensor???
- 4th gen service connector
- sea foam !!!! smoking engine
- DSM 450cc's on an obd2 prelude
- what belt???
- Turn Signal bulb is out
- New suspension on
- Newbie with shift problems?
- Q about carsound cat
- Wheel stud broke off!!
- does a 2.2 litre non vtec prelude exist?
- Skunk2 Valvetrain + Skunk2 Intake Manifold Setup
- F20A sohc???
- bronze valves bad for honda engine?
- spool question about the sc-61
- CYP Sensor - how far out of range is too far?
- I have a wiring issue can someone please help im in dire need
- quick Q about Apexi N1
- 3g and 4g Strut Braces
- Prelude Alternator Swap
- gauges
- header question...
- 440 cc saturated injectors
- cut out desperate i need of help please help
- OEM tire size OK ??
- aiming jdm headlights
- h22a crx resistor box
- ecu demobilize
- low tranny fluid?
- repair manual
- All 5TH gen BASE models the same?
- Do Jdm H22 come with vtec oil pressure switch
- What catback = good power but looks stock?
- Open SMSP header
- Fast Idle
- Projectors or JDM headlights
- New Guy...
- Couple Questions Regarding Oil Pressure and Water Temp Gauge Install...
- ebay gauges for 92-96 lude si/sr
- h22a or h22a1 ECU
- help with check engine light
- Merge collector worth it?
- koni yellow help
- Ecu swap.
- Oil Pressure Gauge help
- question about my air
- easy question for people that know preludes.
- code 9, cyp sensor or distributor
- I just bought a prelude. OMG LOL WTF!!11!!
- Will an ECU from a 1997 Prelude (MT) plug into a 1996 Honda Prelude VTEC?
- I need some 98 prelude injectors!
- how do i get engine trouble code in a 97
- Brake problem after instalation please help!
- VAFC install question, vtm wire?
- ABS Light
- Type-S pistons
- hey guys need help with next mod?
- intake manifold gasket/air temp vs fuel
- emanage ignition harness install help?
- tribute to HT and another clutch question
- Bouncy Idle
- ticking getting louder
- turboing a 92 prelude h23
- 1998 Prelude SH VS Lancer oz rally turbo
- Body Kit
- KYB AGX questions
- Wiring??
- no power in vtec ...?
- MSD Blaster 2 owners.........
- water ran to cold air intake
- 95 vtec radiator
- Where to buy an OEM Lip Kit for a 98 Prelude?
- 97 jdm in a 98 help needed
- opinions needed on suspension
- Loud ticking on #1 cylinder?
- Right headlight not working?
- Need help identifying a part + how to fix?
- is it possible to pass smog with no egr
- how difficult is it to lower my prelude 2.3?
- damn scammers
- 4th gen ecu location
- koni's perch's ok with sport springs or stock only?
- Will a 2.5 displacement jeopardize cylinder walls?
- still throwing a code90
- Easiest way to change intank pump in 4g?
- Looking to buy car V-tec or non-V-tec thanks alot. nEw gUy
- Glass Sunroof on 93-96 model
- What is the best cat back for 97 Lude?
- chikara header
- charge pipe
- Need help on lowering my ludse
- OBDI or OBDII?
- what else to do?
- Balance shafts removed... and plugged question
- for those that wanted pics of the egr
- Mugen MT105
- type of gas?
- H23 vs H22 Intake Manifold
- lower compression headgasket for h22
- Will someone 6'4" fit in a 97-01 Lude??
- turboed h23a
- Custom FMIC Question Concerning JDM Fogs
- will sea foam/carbon cleaners clog my cat??
- springs + shocks - bump stops
- Planning on boosting h23 lude, any suggestions?
- HOW DO i install brake rotors
- reverse lights not working
- oil light
- what size CAT...
- Confused Buyer
- check out my prelude....
- camber question.
- need help
- Tiptronic vs Stick
- h23/vtec or h23 non vtec???
- Tripmeter calibration
- HELP PLEASE. $500 for a new immobilizer?! 2000 Prelude
- cf hood questions
- Where can i take old fluids? (antifreeze)
- Factory Foggie
- new to the Prelude Forum...here's my lude...
- Dyno dissapointment
- Oil question
- Prelude factory spring rates???
- !INtakes!
- Transmission Question
- Clunking sound after brake work
- Fidanza Flywheel friction plate probles?.............
- New '88 prelude rear control arm prob.
- need help: Where does this plug go?*pic*
- obd2 to obd1 conversion on 99 base lude
- Skunk2 internals question
- Hot To Remove Popped Bulbs Inside Headlight (4th Gen Lude)
- engine runs ruff
- which header do you recomend from experience?
- 97-01 Prelude..?...17x7.5 with 45mm offset? Will it fit lowered?
- possable to make dash lights brighter?
- 93 Prelude
- Electrical problems w/ dash/gauge cluster
- Timing Belt
- p13 ecu?
- vtec oil pressure switch (light or gauge)
- Should I trade..or no?
- 93 Prelude VTEC
- fyi: SMSP prelude header dyno
- No Vtec No codes
- what are the specs on an h22a
- A/C Removal
- Restored valve cover
- Inline Four N1 Enduro crank pulleys...
- Whining noise when i put it in fifth
- AFR- what's the best combination.
- How do I change the transaxle fluid on a prelude.
- jdm h23a vtec motor
- SEA FOAM
- A jdm distributor cap does anyone have 1 for sale?
- Idoling Problem
- CRV in a 88-91 Lude?
- My experience with TEIN Basic coilovers. NPM Beaver Run
- intercooler pipe question?
- h23 tuning?
- Bearing break-in time
- serious motor pickel
- different engines in the lude!
