View Full Version : Honda Prelude
- starting troubles
- CODE 12???HELP PLEASE?
- intermittant shifting problems with 89 lude si
- H22a Crank Pressure
- I want to fit an oil level gauge on my 94 Vtec Lude. Help
- Steering Problem when i turn
- hey guys integra guy here with lude ??
- timing question
- OT: WHP Guess before the Dyno! Winner gets my.02 to their paypal!!!
- DYNOED the SKUNKPOO H22 intake manifold
- Turbo+ nitrous
- Compression and leak down tests
- Type-S Motor in my Si
- gm syncromesh for 95 Prelude Vtec Good or bad ?
- wheel bearings
- header -> test pipe -> exhaust question!
- Heres a tough one. KNOCK SENSOR specsheet
- I have a Question about Springs
- H22A Thermo Switch
- what types of things will restore my cars power?
- Pitman puller?
- Prelude taking a while to turn over
- h22/h23 exhaust manifold
- Rev Limit
- 1986 prelude turbo?
- Honda Prelude 1984 1.8 EX torque graph
- changing trans oil
- new to form, idle problems, check engine light?
- no power in the lude
- Raising Compression w/o Cams or timing?
- Anyone used a spoon muffler on their lude?
- online shops stores etc
- Valvoline Max Life
- Suspension bushing question
- Installing Camber Kits
- Anyone here running an EMS on an NA h22?
- CEL after changing clutch and flywheel
- Need new valves for H23???
- spark plug help
- carbon fiber hood / trunk
- h22 timing belt
- ID Sensor Below Intake manifold
- Wierd Idel Problem - - - Need Help
- Exhaust Ticket
- chipped ECU
- Code 41 - o2 sensor gone bad ... Whats the cheapest replacement?
- help, car not starting
- apexi n1 exhuast, DID i get the right one???
- Is it possible to lose a timing belt and not have piston and valve collision?
- question about gas
- computer help
- what are the valve clearences on a h22???
- type s aftermarket parts
- b16 manifold and a prelude b20a5... compatible?
- 5th gen alternator output
- All-motor?
- Flywheel
- P72 ecu
- Car Trouble
- vtec engagement problems
- Engine restore oil additive...
- fusebox pic??
- Finally finished my Projector project(pics)
- Shock Knock TSB
- accord F20B for sale ( tyoe R)
- Does this Head look legit...?
- what are you running with bolt on kit....
- Help!!! Accord with H23 head swap died today =(
- Rear H22A1 motor mount in Topeka...anyone?
- External coil on internal coil ECU???
- Who has stored their ludes for long periods of time? I mean LONG PERIODS!
- will f22 tb work on h22?
- GET RID OF MY FUEL CUT OFF!!!
- Venom 400 Performance Module
- Clunking noise in springs....
- crower stg 2's w/ aem cam gears??
- please help out!
- 13" Mesh Rims from 2nd gen Preludes
- h22a/h23 hybrid turbo block build up
- Prelude f22 and H22 swap head/turbo or turbo just f22
- helms manual
- Prelude injectors??
- what are the SPECs
- Quick Question on 89 Lude
- greddy power extreme on 4th gen?
- IM A NEWb, can someone help me learn about turbo kits!!???
- h23 high comp pistons...
- custom piping question
- h22 motor weight?
- Synthetic oil?
- Jdm h22a problems obd2 garbage
- Cometic woes!
- abs wheel sensor,
- NEW UK Prelude owner looking for 5th gen dashboard kits
- Sunroof maintenance tips?
- h23 internals
- turbo'd prelude
- h22a Beyond 8,000rpm's
- 92-96 'lude headlights..
- Idle adjustment screw not working.
- most powerful b20a5?
- skunk2 for ludes
- Accord axle back on prelude
- Need a solid alarm..will this do the trick?
- greddy header Q's
- removing front seats
- 5th Gen Strut Bar Problem
- Newbie to Ludes and need help
- Experience with Raxles?
- type s intake, did i do wrong ??
- Can I use my Accord downpipe for the h22 swap?
- H&R race springs
- question about sleeves...searched
- Help Finding ATTS O.P. sensor
- Exhaust Install
- Fuel pressure with Prelude OBD1 injectors
- got intake, i am lame, but now what?
- Yet another P28 Hondata / chip question!!
- DIY: Accord Lip install on 4th gen Lude
- si vs vtec rotors
- Need a part number..
- Brembo Blanks?
- does anyone have sfc-vtec controller
- factory cd player code ?
- Eagle Rods and H22A Prelude Type S TypeS Pistons
- Sportronic Transmission?
- fuel rail
- dsm turbo kit on h22a
- removing transmission?
- Prelude Race Suspension
- agx settings
- Running intake throttle body with stock ecu & VAFC?
- PLEASE VOTE ON MY NEW PRELUDE 2.2VTEC
- HELP WITH ECU CODE 17 FOR 94 2.2 vtec Prelude
- Check out these springs guys...need quick advice
- Ferrea roller rockers & NA roller rocker cams
- chip it?
- A/C troubles
- h23 non-vtec & h23 vtec: what's the crank difference?
- Turbo Question for H22/H23
- PLEASE HELP ME- i'm stranded
- Ok someone needs to breakdown racing chips for my 93 lude
- Installed CAI and headlights acting funny
- 93'-94' Preludes opinions...
- H22a hb vs ls/vtec hb eg style
- carb legal ebay intake?
- does anybody have write up on how to do an oil change?
- cryo treating crank...before or after balancing
- STR Throttle body 5th gen
- Vortech Supercharger for 5th gen?
- Throttle body question
- Starter help please...
- are these parts important
- egr valve question
- h22 oiling system upgrade
- Whats the difference between the full swap and the engine, ecu and tranny?
- Mechanic in the Atlanta area
- Adjustable front sway bar for 3rd gen?
- problem with restarting 97
- Best upgrade for $100 ????
- Prelude Winter Tires......need experienced opinions
- Can't get Prelude started. Need help ASAP.
- internal rebuild question
- Quick question on starter and alternator....
- H23 -> H22 Swap :: What do I do with the plug that went here ?
- F22 fuel rail on an h22 will it work?
- Swapping to Digital Gauge cluster?????
- if you think your car is clean...
- HELP CAR WON'T START!!
- 4WS Light on
- 5th gear m2b4 tranny grind
- 5th gen HID
- How heavy is the H22a?
- Prelude Starting problem!
- 60mm flex pipe and cat?
- Springs/shock install on SH
- Either 4th Gen or 5th Gen??????????????????
- quick question
- i have a 93 lude how much can i get for it
- timing belt change?
- My prelude tells my its overheating.
- Car hard to shift ?
- xtd clutch
- Mystery headers....need some info
- h23 intake manifold
- diffrence in manifolds??
- H22 Balance Shafts
- Does greddy make a universal exhaust for 92-96 preludes?
- doing valve adjustment on h23 - 4th gen non-vtec prelude
- which exhaust?
- Timing belt snapped, destroyed my valves...
- Install of Skunk Mani?
- intake
- Carbon Fiber Side Skirts
- Did the hood...what else can I make lightweight....
- Prelude Inertia Switch
- H23 Pistons,Rods, Sleeves
- Wiring Problems
- 4WS Towing Question
- Intake question
- F20b ECU
- To all you peeps who pimped your own ride
- 4WS 5th gen prelude trouble code 25
- would this be a good purchase
- H23 Vtec Safely Reving to 8,000rpm's
- taillights
- need aftermarket seat brackets for 92-96!!!!!
- Question About Radiator On SH Model...
- fuel pump interchangability
- Oil return line
- NEED TO KNOW WHAT IS GOOD FORGED CRANKSHAFT FOR MY H22
- H23 tranny on H22??????
- h23 fuel injectors
- Fuel problem?
- help!!! something wrong with my lude
- stroke of b21a1?
- MSD help!
- Stripped tuner lugs!!!HELP!!!!!
- gauge cluster brightness
- Super VAFC and Nitrous
- Will a 4th gen rear sway bar fit on a 5th gen?
- starting problem with 89 prelude
- intake problems
- help on exhaust
- 93 Prelude SI help...
- anybody use the auto to manual belt tensioner h22????
- ATTN Apexi RS muffler users
- we put my block together and the pistons (JDM Type-S) pop up out of the block... question inside!
- Looking for an affordable mech & perf shop near San Jose, CA
- TAILIGHTS where do you get the amber-cleared ones?
- prelude s (1993) dsm turbo kit
- How much horsepower should i see from a v2 coldair intake?
- Air conditioning problem
- Tubular Control Arms?
- Adjustable struts for 3rd gen?
- magnaflow apex or rs-r mufflers
- tire size questions
- VTEC Oil Pressure Switch (Code 22) but VTEC works?!?!
- 96 type-r wheels on the forth gen
- Good things to say about SFP manifolds..?!
- 92-96 prelude, koyo radiators?
- Idle problem
- JRSC...what cams
- 88 Prelude 2.0 si = What Transmissions Will Interchange?????
- Buying a Car HELP, Lude vs. DSM vs Saab?? Need 300HP
- How do I replace the CV joint on a 89??????
- Engine won't restart when warm
- h22a7 euro r swap in a prelude 4thgen ?
- h23 vtec with vtec tranny or h22a with lsd?
- turbo h22a stock
