View Full Version : Honda Prelude
- Happy New Years to All
- JDM headlights
- Gas Milage
- Prelude injectors question
- someone HIT MY CAR!!!!
- What site to get JDM foglights for good price?
- I need to make my 94 Prelude S faster. Should I turbo it, or do an H22 swap?
- spec-s ?
- JaY-Dee-eM
- How low can you go?
- The Prelude--no more, well for a while...
- Need help very desperate
- Timing Marks
- H23/VTEC motor for sale. Great bargain. All new, never ran. look if your interested.
- which factory h series oil pan is made out of aluminum what gen and what year ?
- head removal & transmission swap help
- Piston Type A or B
- what could cause an engine to be loud
- Turbo on 98 Sportshift????
- Are these OEM Prelude Floormats?
- Can you use 92-95 cables on a 99 transmission?
- a/c lines
- Bored, My New Exhaust Pics
- 97-01 lude brake question hybrid stuff???
- apexi n1
- Exhaust
- how do u tell the diffrence from auto or manual p13?
- SH oilpan and BASE oilpan are they the same
- 5th generation Lude or Integra Type R
- a stupid question.. here goes
- What is the Fastest All-Motor 97+ Prelude you've seen?
- Custom Gauge Install Pics.. check it out
- Found some nice deals(V-AFC's)
- 3rd gen lude with S-AFC?
- 92' Lude Black Widow Fiberglass Kit
- shift knob problem
- h23 & h22 oil pans the same??
- low compression pistions???
- locating sensors
- anyone have greddy turbo on 99+ ludes?
- Hey Everyone
- Need New Rotors bad! What kind?
- fluid in tranny is destroying my clutch pads...why?
- Timing belt just changed...break-in period?
- Please Help! Type S question---tranny, engine, ect
- Stock Wheels For Sale
- sputtering... What do you think?
- E-brake problem light problem. . .
- Type R seats
- which clutch do I go with?
- radiator question
- Apex N1 exhaust question
- Turbo Lude in Need of NOS "PURGE KIT"
- Yet another ATTS question
- B20 with a B16 Vtec Head?
- People with a Thermal exhaust on your 4th Gen. Opinions?? Sound clips??
- Which Distibutor? Need help Now!!!!
- clutch master cylinder
- Need Quick response please
- Neuspeed
- H22A: Removing Head Bolts, I must be blind!!!
- Preludeparts.com
- Crank Shaft Position Sensor (Code 4)
- OBDI Conversion
- h22 cam gear settings
- Qustion about coilovers
- has anyone done a h23 to h22a swap in their prelude
- carbon fiber hoods
- Newbie has quick header question
- I need Interior Prelude Parts
- prelude bb6 with jdm recaros
- Car suddenly turns off
- jnm
- Still the unanswered question for my 92 Prelude
- Seats that will fit...
- Garrett t04s
- In search of...
- did a search... still have questions on type s pistons in a h23
- Stock 5th gen Trunk weight?
- Air/Fuel Ratio Gauge
- New Tires and Alignment problems!
- OK question.. (of course)
- coolant?
- questions about short shifter and adapters???
- AEM fpr install
- Turbo question
- h22 and h23 intake manifold the same?
- knock sensor
- need help finding M3 mirrors for 5gen
- roomate needs a swap for his 3rd gen, any possibilites
- Need Help!!
- can anyone help with my lighting problem?
- H22a specs?
- Prelude ATTS question
- Please help a turbo newbie out.
- cleaning question???
- whats wrong here?
- '83 Prelude bolt pattern?
- 95 VTEC parts... make a list and I'll see what I can do
- cal dragstrip4th Gen Short Shifter
- CAN SOMEONE HELP? Detailed diagram of h22a4 timing belt/waterpump/oil pump assembly
- Dealership Totaled friends 1st Gen Lude! :o
- experts: oil catchcan/breather help!
- Valve clearance adjustment temperature
- How important are these?
- Turbo folks. Look at my Turbo and tell if you think which Mani will work with it
- squeeling noise?
- Brakes act warped when cold but not when hot?
- Header #3 Finished
- Were to get motor's
- pictures?
- Speedometer cluster changeover
- v-afc
- Idle problem
- need some opinions.....
- intercooler size?
- Charleston, SC meet- GA/NC/VA/FL/SC/TN EVERYONE COME!
- jdm black one pice how to
- 3G Prelude engine specs?
- Skunk2 Stage 2 cams
- Low End Misfire
- Anyone in the Bay Area selling a set of rims with tires for a 4th Gen Lude
- Going to test fit my intercooler, can you ID these 2 lines?
- Shorter h22 gear ?
- Ball Joints
- Side Skirts
- any fast preludes?
- the balance shafts on H22s
- Euro R Accord tranny.....
- Need help picking out new floor mats
- Pls post pics of...
- suspension for now
- HKS Super Dragger for 5th Gen Ludes 95mm piping?! is this true??
- lude wont idle when warm...
- 3rd gen oil pressure gauge
- Light Numbers help!
- Quick question for those with torque specs for 5th gen
- Cat Cams... If you're tired of broken aftermarket cam, check these guys out
- 5th gen prelude racing wheel 18"
- need h22a manual tranny for 5th gen
- Header Cover
- Anyone using a Moroso oil pan?
- Christmas Presents
- NSX Caliper
- i need parts!!
- droping in a H22
- Anyone have the specs on the Euro R/ATR transmission?
- parts for sale
- Valve Train???
- 97 prelude w/POTENTIAL ODOMETER ROLLBACK should I buy?
- I NEED HELP........ NO FUEL PRESSURE!!!!!!!!!!!!
- Chipping Options/Possiblilities for OBD2 P13???
- shaving the antenna
- 4bidden Motorsports short shifter Review
- good all motor suetup for 92-96 H22A
- satan_srv: how much did you sell you seats for??
- Need some advice on shady person
- WW RS kit..
- Need some help finding parts
- 4th Gen Si auto to MANUAL
- Rumour or Reality/ Need help
- how much to replace the transponder key?
- D@mn Thieves....*rant*
- h22
- need interior kit...seat covers, door panels, boots, etc..
- the difference between a typeSH and reg VTEC prelude?
- need your opinions (especially boosted ludes)
- has anyone dissasembled their H22 tranny?
- The Land of the Stupid *story*
- vafc hack help!!
- FMU install
- that thing under the carpet.
- starting the engine without a key. how?
- 92 prelude H23 into a H22 need help
- Prelude Problems
- insurance news for 95redLUDE....
- What clutch/flywheel combo for 200whp?
- Pure oxygen? for the air intake...
- JDM H22 pistons in an H23?
- best intake
- Price Check: H22 Tranniezzz
- WTB passenger's side mirror assembly 5th gen
- does any body know where i can find.........
- getting H22..any changes needed?
- Exhaust
- Top speeds...
- 96 Prelude Stock Hood And/Or Front Bumper
- how much for SH wheels?
- concerns for H22 boost
- Another 4th Gen suspension question
- obd2 to obd1 wiring harnest addapter
- I hate Mobil 1 oil. *mad*
- its all GUDE
- Best turbo for a Prelude
- ho mwcuh do calipers affect???
- Finally got some decent pics of my lude
- NY/NJ/CT Tristate H-T Meet
- People with H23 tranny mated with H22
- Anyplace online to get torque specs on prelude H22?
- how do i...
- central florida lude meet PICS INSIDE!!!
- 4th Gen Suspension Question
- Still Not Finished But Here Are Some More Pics
- waht brakes???
- weight reduction.... the last post needed for prelude owners!
- are 4th/5th gen neuspeed strut bars interchangable?
- short shift
- wow!! Prelude hybrid ...
- how many 4th gens produced?? Please help for insurance.....
- brake caliper swap
- need a lil help!!!
- Key is Stuck in Igintion-Help asap Please
- How many miles do original stock shocks last?
- Weird noise. Symptoms of a broken engine mount?
- camber plates
- Best fitting/looking Wing 4th Gen
- Mugen Header & Exhaust?
- for you JDM whores....
- Difference between JRSC for SH & non-SH Preludes
- favorite prelude pics...
- Shifter Problems help!
- differences between h22a, h22a1, and h22a4
- whats better? prelude vtec turbo or gsr turbo? or non vtec turbo?
- I CANT DECIDE prelude-turbo/ls turbo or Pvtec-turbo/Gsr turbo
- Cam Tuning?
- RevMatching???
- 2000 5spd black lude 12,500 OBO
- Engine Overhead Exhaust Cooling. dumb idea?
- Exhaust Size for Future All Motor Beast?
- Camber kit? 4th gen
- Prelude Body Kits.....
- one more ?
- help b&m short shifter kit
- arriving at our lowered destination...
- Help! (please)
- First mods?
- Bet your lude doesnt do this!!!!!
- Rotating when jacked up NORMAL?
- exhaust
- VAFC hack vs AEM EMS at 7PSI...
- looking for BOMZ Racing 4-2-1 Header
- PLEASE HELP Clutch might be going!
- lowering question for a 2000 SH
- R.I.P. 95 BB1
- ecu question.
- Mini Cooper
- Anyone know the torque specs for the ARP head studs for the H22?
- HT gets first dibs on FMAX turbo kit 97-up prelude
- what size bolt pattern and offset do 5th gens need??
- V-AFC wire diagram??
