PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 [223] 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Clutch Squeaking/Whistling
  2. Free Mods That Pay...
  3. Synthetic ATF
  4. Prelude H22a ECU Pinouts
  5. FASTEST AUTO LUDE
  6. pre '96 h22a1 Please Read This
  7. Debate about A/C
  8. sensor problems
  9. Prelude Exhaust
  10. Changing CV Boots: Something I can do myself??
  11. Header help
  12. need help.......please
  13. what are the radio codes?
  14. B-series in a 5th Gen
  15. Still cant figure out this vibration/wierd noise on h22
  16. Low psi turbo setup for h22 ?'s
  17. Track take off?
  18. Adding Transmission Fulid to an 88 Prelude
  19. H22a compression test 180,245,265,270 what the fuck
  20. DO I NEED A FUEL REGULATOR??!
  21. External coil question
  22. pulley question?
  23. Money questions about engine swap (Also, Denver residents please read!)
  24. Help deciding weather to put a super charger or a turbo on a 98 prelude
  25. Where is the cheapest place online to find JDM foglights for 5th gen?
  26. where is the dipstick for transmission fluid on the honda prelude 1990?
  27. SiR on my title?engine codes?newB
  28. NEED AFTERMARKET PARTS FOR MY 88 HONDA PRELUDE
  29. leaking sunroof? how to fix?
  30. Problem automatically selecting 1st gear
  31. 5th Gen Brakelight-tailight problem.
  32. Type S pistons ???????
  33. Valve springs/retainers
  34. 97 sh dyno
  35. need the pin out for my jdm h22 ecu
  36. what more for my prelude
  37. cracked oil pan?
  38. Thermostat housing removal, wheres the 2nd bolt
  39. http://www.92lude.com/preludemod.html Do these work?
  40. H22 Power steering belt problem
  41. Turboed Jdm H22 problem
  42. Does anyone know the Cd of 5th gen Preludes?
  43. 2000 h22a4 OBD2 ECU: Immobilizer? Where can I get it reprogrammed?
  44. Compression Test results
  45. haze on inside of front windsheild
  46. Turbo Timer
  47. Shifting is fairly rough...
  48. H3C to H3 Conversion, anyone knows how...
  49. quick question about 97~99 vs 00~01 lude eletronics
  50. Will a H22a1 headgasket work on a H22a????????????????????
  51. need help i dont know why im not geting any spark ??
  52. wierd sound in high rpms
  53. cold start....will not start!
  54. Having trouble in Reverse!!!
  55. True Short Shifters and vibration???
  56. valve adjustment h22a
  57. Apexi Dunk exhaust question
  58. turbo for 99 prelude sh, best setup?
  59. Electrical issues - blowing fuses (ECU/FI specific)
  60. Confused h22a question
  61. Performance parts for '90 Si
  62. most horse power for least money
  63. What type engine do I have?
  64. im in a predicament... my h22's crank is screwed up :( need opinions/options on what to do
  65. Changing accessory belts (AC belt)
  66. will 5zigen typhoons fit on a '93 prelude?
  67. Wont Start
  68. Ground Control/AGX or Tein Basics....for Comfort???
  69. Is something missing?
  70. 91 prelude si 4ws transmission
  71. top speed 91 prelude 2.1 SI
  72. Good shop in orange county for h22 rebuild
  73. Anyone used a venom 400 computer module?
  74. 3rd gen prelude EGR 'stuff' fit 4th gen?
  75. Weapon R Dragon Filter?
  76. What transmission will interchange?
  77. sparco seat installation
  78. Prelude 88 keeps shaking at the front right!
  79. 1990 Si
  80. sleeving H23A1 pistons
  81. 4th gen lude, with no spark and no fuel
  82. How can i lower my Coils without a Key?
  83. my fiance's new car, is it a crap pile?
  84. couple problems
  85. Cooling/Coolent problems... pls help
  86. H22a4 crank cleaning?
  87. bolt on wire cover dethreaded. not budging
  88. Wipers have too much play in them... fixed it!
  89. Just did a dyno. first one, kind of weird .
  90. Dyno problems
  91. h22 problems
  92. Idle Problems
  93. How did you mount your OBD1 ECU into your OBD2 car?
  94. need pics of external mount coil on jdm h22a
  95. would msd ignition sci help on h22a jdm at all is it worth the money?
  96. Help with code 12, EGR
  97. Crower Stage 3's and head/engine setups???
  98. downside to oversized rod bearings? (like theres an upside "a")
  99. n00b question
  100. 4th gen. question...
  101. What type of fluid for clutch-type LSD?
  102. New Honda-specific NOS NOSzle kits > will they work on H22's?
  103. H22 timing belt install(need Pics, diagrams)
  104. Does Spoon make a LSD for the 4th gen Preludes?
  105. HELP!! Having issue with fourth gen prelude.
  106. do i need fuel managment with prospeed headeR?
  107. H22A4 piston on H23 rods?
  108. BALANCING SHAFTS
  109. 92 auto to manual swap i searched but cant find anything help me out
  110. DIY ITB update
  111. which cap/rotor do I use on obdII internal coil jdm H22a?
  112. Wats wrong with my ATTS
  113. lude mods
  114. EURO TYPE R GEARBOX IN A TYPE S PRELUDE?
  115. Knocking
  116. ABS light codes
  117. Clutch install on a f22b??
  118. Does anyone know if there are any swap kits out there for the 4th gen?
  119. 5th Gear grinding
  120. Intake control vacuum box+sensor question
  121. Prelude Si 1992 is eating oil
  122. BIG ENGINE SWAP IS IT POSSIBLE HELP PLZZ
  123. h23 wont start PLEEEASE HELP!
  124. h23a
  125. obd1 in a 5th gen SH model?
  126. Wanna boost, need help on tips?
  127. does anyone know where to get an OBD1 ENGINE HARNESS? ... or better yet a front clip... (jdm) IN TOR
  128. H23 with issues
  129. after distributor install strange noises
  130. What do you think are some of the best mods for 5th gens?
  131. Making a big investment
  132. quality part
  133. SS Tranny rebuild
  134. Fog lights
  135. MY headlights Cut OFF??!!!!
  136. ABS Removal on a lude
  137. Question about JDM F22.......
  138. IACV? Which other one fits?
  139. which intake fits on a 88-91 prelude?
  140. f22 turbo or h23?
  141. i blew my h23vtec last night
  142. bad head gasket??? help fast
  143. p13 on h23?
  144. EXHAUST QUESTION"2"?!
  145. wat year 4 a newbie
  146. Ebrake light coming on
  147. h200 in a lude
  148. temperature needle is stuck. help me out. gauges
  149. Is a 75 shot on a stock motor safe?
  150. prelude oil temp is not moving , its stuck. helpppp
  151. oil leak.......rear main seal?
  152. Need help...difference inside a jdm p13 and p14 ecu.
  153. 9psi JRSC Prelude with ACT HDSS clutch
  154. Getting a code 41
  155. My N/A set up: good bad?
  156. Butt dyno. DC header vs stock
  157. 94 h23 --> to a h22...
  158. RHD cluster in LHD drive lude
  159. What happened to my H23?
  160. got in accident and no airbags...
  161. new injectors, now #4 wont fire.
  162. Prelude nearing completion
  163. head gaskets
  164. error code reading
  165. Resistance in fifth???
  166. h22a jdm.. 4000 installed with everything...
  167. 4WS fix write-up
  168. Quick question: How much does an Apexi N1 cat-back exhaust weigh??
  169. MY EG H23/H22 Turbo Hatch runs 10's!
  170. mph/rpm top of each gear
  171. New starter grinding On the Flywheel
  172. Tranny wont shift while car is running. NEED HELP.
  173. anybody ever here of a bb8 prelude?
  174. got a question about an ecu i gotta buy
  175. more torque
  176. jdm foglights anyone?
  177. JDM H22 Dilemma.....
  178. type s engine swap
  179. hcp axles on a 94 integra h22a help!!!! respond quick
  180. h22a camshaft and performance upgrade? what to get
  181. How do I take pistons off of the rods?? H23
  182. tires too big?
  183. Clutch problem going from bad to worse....please help :(
  184. resistor chip???
  185. custom intakes
  186. my h22 might not be what i thought it was?
  187. Ground Control Install Issues
  188. LS Cams in 91 Prelude Si
  189. HELP WITH HARNESS
  190. who has a cut off switch in their lude?
  191. FS: 5G Prelude Parts
  192. can an oem fpr work on an AEM fuel rail?
  193. how do you tell if a p13 is auto/manual?
  194. heater question
  195. engine ready for a turbo ?
  196. car shakes before shifting into 3rd gear everytime.
  197. The Acclude is down and wont start!!!!!
  198. Check Engine Light
  199. need to know the 'stock' spring rate of a 3gen (91)
  200. Forced Induction
  201. Unable to move shifter to the right IE: 5th & reverse??
  202. Revs stickin after fitting AEM intake
  203. Crank bolt wont come off!!!!
  204. how to install msd ignition on lude 4th gen with h22a with external coil ?
  205. h-series aftermarket axels??
  206. header question??
  207. Best place to get a good clutch for the JDM H22A
  208. Help!!! I need airbags!!!
  209. H22a question
  210. what ecu is the best
  211. forged piston on stock block
  212. ANYONE else here done a JDM Type-S OR Euro Accord Type-R H22a motor swap?
  213. fan switch and thermostat install ?
  214. RPM meter reads jumpy and motor jerks on acceleration
  215. gas Lights
  216. next mods help?
  217. JDM 92-96 Digital Climate Control
  218. changing my timing belt
  219. Air bag removal??
  220. 5 lug for 92-96 lude
  221. jdm h22a or usa version h22a ....
  222. newb question about engine specs
  223. 4g stock exhaust weight...
  224. Drag intercooler
  225. exhaust pipes
  226. ARP head stud torque
  227. Difference in size of oem H22 Rods?
  228. which header
  229. i have a problem with a type sh oil filter
  230. clutch pedal noise, uh click!click!
  231. Newbie to Preludes
  232. is it time for a swap? pls help..!
  233. Need help with 5th gen brake piston PLEASE!!!!
  234. Hyper Voltage System???
  235. 2 Radiators?
  236. PGM-FI
  237. FUEL INJECTOR SELECTION
  238. cant stop using oil with my 93 Si 4WS
  239. AROSPEED INTAKE? pic. Check this out
  240. Searched around but can't find answers for H22 from F22 swap
  241. honda prelude type R?
  242. a/c removal in 97-01 prelude question about belt
  243. Autotensioner fix???
  244. die grinding the intake plenum
  245. busted valve?...... or something else.
  246. adjust height
  247. How to remove headlight?
  248. How to turn on flashing lights for alarm.
  249. Have turbo lude - failed emissions
  250. Anyone know for SURE what the stock valve clearance/adjustment specs are for JDM Type-S H22a
