PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 [116] 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Master/Slave Cylinder?
  2. looking for some street slicks for my 98 lude
  3. 93 prelude jumping rpm in 5th gear
  4. H22 running rich and burning oil.
  5. spun rod bearings
  6. looking for a new motor
  7. turbo or all motor????
  8. S300 Boost control question
  9. ATTS removed... now what?
  10. Ebay Groud Wire Kit?
  11. Redrilling (prelude vtec) rotors
  12. @ low rpms my lude is very hesitant......
  13. Koni Yellow Installation Guide?
  14. (real cf)spoon lip
  15. Engine bay noise and driving cabin vibration
  16. what to get with $1000
  17. rattle noise from valves problem
  18. Prokit + Koni Yellows and want more Ground Clearance
  19. F/H Trans Question
  20. What's this noise (got video)
  21. koni yellow/GC VS koni yellow / Eibach pro kit
  22. does h23 bolt up to f22?
  23. got another quesiton
  24. got a question
  25. wont go in reverse
  26. H22 type-s (JDM) swap done. Feedback about performance wanted - link to VIDEO.
  27. battery?
  28. How To Remove: Passanger Airbag?? 5th gen
  29. Running a turbo off an AFC (I searched)
  30. s2000 seats?
  31. h22a
  32. looking to pick up a 98 prelude sh
  33. H22A V-TECH WITH ECU , WIRING HARNESS , AND AIRFLOW METRE URGENTLY WANTED!
  34. High speed chase hollywood ca
  35. Prelude Suspension
  36. New clutch/flywheel = Chatter
  37. What is this seal called?
  38. Is it going to hurt anything if I keep adding oil to compensate for burning?
  39. Help w/ installing ARC box in 5th gen.
  40. Air Intake questions.
  41. what the difference between sh and si?
  42. Removing Door Panels
  43. h22 swap question
  44. fuked up Engine noise
  45. how do u hook up a aem wideband o2
  46. Help Car wont start!
  47. SH suspension upgrade ?
  48. Tune up instructions, several questions.
  49. Idle Problem???
  50. Carbon Fiber Sunroof
  51. frankenstiensing my h23a1
  52. vafc I help
  53. 4th Gen - Water Leaks
  54. need motor swap info
  55. 97 prelude SH performance upgrade????
  56. sidemarker installation
  57. Raze R-24, will they fit my 5th Gen Lude?
  58. h22a diagram
  59. h22a timing trouble
  60. Project: The impossible prelude.. (also a help/question thread, please help)
  61. if you have the oil at the low end of the dipstick will you get better mileage?
  62. CEL Question???
  63. Do all 4th gens come with sunroofs?
  64. jdm h22a into 97 usdm lude - tech help please
  65. Timing Belt Teeth
  66. does anyone know where to get a manual for a prleude pdf??
  67. 1988 Honda Prelude...not starting Please help!
  68. FS: MUGEN M7's
  69. gas pedal problems
  70. i have a 95 VTEc - what other year/model cars can i use to replace my broken throttle cable?
  71. Weird idle problem
  72. need pressure on clutch
  73. thorwing CEL #2? - and i am having temp gauge, overheating problems
  74. $2000 available needs a parts list
  75. What is the stock exhaust pipe diameter on 1992 honda prelude si.?
  76. wwrs kit for 4th gen
  77. slight squealing when taking off?
  78. need some help with suspension set up....plz
  79. jdm bulbs!!!!
  80. My window is Stuck
  81. hella buld or piaa buld?
  82. tips on wheels
  83. usdm headlights vs black housing
  84. Pic Request
  85. Black smoke on VTEC
  86. my RHD prelude in TPR mag... shoot pics....
  87. oxygen sensor heater problem
  88. 5th gen IC piping
  89. Turbo Prelude Help
  90. Type S Tranmission Woes - Whining gears
  91. Greddy or Apexi exhaust ?
  92. 5th gen sidemarker help
  93. Havent really found a good "how to" or write up
  94. removing back seat on a 5th gen?
  95. I saw this and it seems too cheap
  96. JDM 1pc Headlights (Black housing)
  97. Downpipe bolt size?
  98. Film all over inside of windows. Filter problem?
  99. EK foglights on a 4th gen?
  100. d series alternator
  101. h22 itbs make power or not!!
  102. Need advice on 2000 Honda Prelude
  103. tips on removing tranny with motor in car
  104. Throwout bearing question..
  105. h22a1 or h22a4 Crank pulley wanted
  106. Choosing Bearings and Rings? Sizing? HELP
  107. when car passes 3K RPM...It backfires!!!! and shuts off!!
  108. 2.4 conversion help
  109. help car is losing power...
  110. Not sure what's wrong
  111. vafc and turbo ?
  112. ac belt
  113. throw out bearing
  114. automatic to manual conversion
  115. Engine Whine (Searched)
  116. Will 8500 RPM's hurt my engine or is it ok.
  117. 4th gen h22 swap....h23 fuel filter?
  118. Quick help on Con-Rod bearings
  119. Slow returning idle
  120. Tinting gauge cluster lense
  121. 90 prelude H22 swap(not like all others and have searched)
  122. Maximum Throttle Body Bore for the H22 Intake Manifold?
  123. Downpipe too close to the sump
  124. EDM-parts or even JDM in Europe?
  125. 1991 Prelude Si, B20A, emssions and EGR woes.
  126. Idle issue and car tries to stall out
  127. Does VTEC increase the VE of an engine while it is engaged?
  128. Problems with H23 lude 92
  129. Lightweight Battery
  130. RM cams and valvetrain
  131. Anyone dealt with Japanese Domestic Motor?
  132. having trouble with rain water
  133. Fuel Rail/Pressure Regulator?
  134. timing with tilton clutch
  135. v-tec problem
  136. 1996 JDM H22a -- Auto or Manual Tensioner?
  137. nasty noise when turning right! (searched)
  138. H22A1 Can U Hone (Searched)
  139. 5th gen stock intake pipe diamteter
  140. 97+prelude owners with 18inch wheels.What tire size do you use
  141. v tec problems
  142. Aasco flywheel
  143. turbo kit for 2.3litre prelude
  144. rmf and smsp header question
  145. CEL question..please help if you can
  146. Soon to be 1993 Prelude SI Owner... I need your help...
  147. HT car owner vs. Honda service technician
  148. need help with my 93 prelude si
  149. Accord Suspension
  150. Oil change problem
  151. H23 T-belt tensioner on H22
  152. Battery Relocation
  153. Prelude type sh
  154. a good read
  155. I've had enough
  156. 92 prelude 1pc black projector head lights
  157. open deck or closed deck h22
  158. 4th gen prelude (93) need some advice
  159. Final Drive
  160. Prelude 95 Mugen Front Bumper
  161. My prelude retrofit thread.
  162. a little 97 prelude advice
  163. does any one know
  164. CEL
  165. FS: 93 prelude, pearl white
  166. HELP!!! getting out rusted caliper bolts
  167. Prelude problems
  168. OBD 2 plug.. where is it?
  169. obx spark plug wires
  170. Holding Fuel Pressure
  171. Is F22 manual tensioner and H23 manual tensioner same
  172. Suspension Setup
  173. Skunk2 Pro series cams and gears **Quality ?
  174. Timing Belt Broke At Idle - Ok or Not
  175. Has anybody clayed a stock h22
  176. Can someone hook me up with a spark plug cover for my h22?
  177. Swapping in shorter upper control arms bb6?
  178. Jump Start
  179. Can I put S2000 on Prelude
  180. a few trouble codes
  181. A18 Head & Cam Stud Torque
  182. Hesitation/Bogging JDM H22 (searched)
  183. Any OBD1 MAP sensor compatible with H22a1?
  184. 235 too wide for my 4th gen?
  185. Cold Air Intake + Huge Puddle = Unhappy Prelude Driver :(
  186. 5th gens running '05-'06 RSX Base Rims
  187. Finally 4th gen one piece projectors
  188. Cold start up question???
  189. After Swap Idle Issue Resolved - Hooray
  190. Best way to find oil leak
  191. h22 idle problem...need help
  192. whats a prelude SR-V ?
  193. HELP! rebuild or replace my motor???
  194. JDM H22 idle problem
  195. Sunroof Diagram plz =)
  196. help with gas milage!
  197. Upper rear ball joint ?'s
  198. H23 Compression Ration
  199. h22 aem cam gears, scat rods, str fuel rail
  200. PLEASE HELP
  201. Osaka JDM motors or Hmotorsonline for H22
  202. H22 Operating Temperature???
  203. Knock sensor
  204. 15" vs 16" lightweight (searched)
  205. HOW TO: Keep your Cruise Control :+: 4th GEN prelude :+:
  206. Shock After Battery Relocation
  207. Break into the 14.s
  208. Shiftboot Slipping
  209. Gettin my first car need help!
  210. new 4th gen carbon fiber rear lip!!
  211. How to check if alternator is going ?
  212. Question-Buddy Club Spec III for Prelude
  213. Do 5th gens have a little flap over the gas fill hole?
  214. Dashboard Change and No Headlights! Need Assistance.
  215. WTB... 97+ Moonroof, 97 spindles all 4, Coilover system
  216. turbo??
  217. Would like to get into the 13s with my 97. Best way to get there?
  218. 88 prelude si
  219. Sylvania Silverstar Amber bulbs
  220. CV Axles: Base Model vs. SH Model?
  221. After a year of XTD...
  222. Master cylinder for 5th Gen ABS removal
  223. F22 spark plugs and wires compatible with H22?
  224. question about H22 auto tensioner
  225. 5gen suspension has sqeesh sound
  226. ABS light on 92 prelude
  227. What Should I build H23 Vtec t3/t4 ADVICE
  228. help with obd2 jdm swap into a 5th gen
  229. Curious...
  230. 4thGen h22 swap issues....Need Help!...
  231. piston 1 at (TDC) on h22A?????
  232. S200
  233. engine whistle at idle
  234. need help making list of parts for swap... help if can... mahalos
  235. tune up..
  236. Bouncing idle with extra electrical loads
  237. I need your pictures for your suspension set up!
  238. is 13.0 compression too high for daily driver
  239. Part number request: Oil pressure service hex bolt
  240. WHat sort of cat should I use for this exhaust setup 5th gen
  241. searched for Idle probs but nothing
  242. ATTS removal
  243. 1999 Prelude Problem = no taillights, no horn, no cruise, no odo light!!! HELP!!!
  244. Anyone know where to find......
  245. Help - steering wheel making "woo, woo" sounds. lol..
  246. h22a1 Crank Pulley couple questions
  247. check engine light
  248. Help prelude isnt starting
  249. Autozone velocity stack home made filter!!!
  250. searched but no luck
