View Full Version : Honda Prelude
- Car won't start. 'Clicking' sound in starter when turning over
- Pic Request: 4th Gen with 5th Gen FRONT SIDE BUMPER LIGHTS....
- 5 lug
- carbon-fiber hood product reviews... Seibon pwns VIS
- Gear Grind
- Tried searching, but need help knowledgeable ones ?
- question about valvetrain parts
- Q about the cross bar thing behind the rear seats
- engine wont start under hot sun
- Thermostat replacement didn't help.
- internal coil, tie rod ends, map sensor, couple of questions...
- Elusive Cold/Hot Start Problem
- neuspeed strut bar problem
- Ringlands
- My Turbo Thread
- Can anyone tell me which injectors they are?
- I need an AFPR, suggestions?
- need help installing rearview bracket
- Lose my teg for a prelude?
- 94 prelude Vtec what size hubs do they have 56.1mm?
- brakes squeek ONLY when not used???
- Buying a prelude, what to look for?
- New exhaust
- Looking for some opinions on Nitrous for 5th Gen H22?
- If I'm not running a heater...
- e-beer to the person who guesses what this is.......
- brake pedal popping?
- WHP for auto and standard or the drivetrain loss?
- Air Conditioning sometimes
- Is there a diff between reg 5th gen pistons and Type S pistons?
- Lighter/CF doors?
- Balance shaft cancelation
- jdm intake manifold question
- Venom 400 and ECU's
- wheel fitment for 4ws 4th gen.
- 5w30 motor oil
- 98 Prelude JRSC running Hondata P28 hqave some problems!
- Whats wrong with my H22?
- strut bars
- Auto Tranny getting rebuilt.
- For those that have removed their front motor mounts…
- 95 prelude vs 99 civic
- Engine shutting off
- SH engine & tranny into a 92 prelude???
- JDM BB4 cornering lights :)
- one more problem
- Noobs first post with Noobs first question
- hoods
- ATTS Light
- crank pully grinded thread.. need help....
- abs light on
- SideMarkers Measurements!!!
- Engine builders- chime in- main bearing issue
- When my cars cold
- JDM or AUDM ENGINE harness - Searched but not found.
- 4th gen sidemarkers
- Axle Bearings
- sparco seat in my 4th gen no sliders or brackets what do I do?
- '88 Prelude Vehicle Speed Sensor
- should i boost preludes with stock internals?
- the infamous 3rd gear high rpm grind lol
- JUN ultralight flywheel
- Newbie Question: Oil Change
- Moving fusebox from engine bay to inside glove box
- Thumbs up for Hmotorsonline.com
- Need An EGR Valve For A 5th Lude
- Swapping 92' F22 to H22
- f22 a/c bracket on h22...
- H22 High Idle
- Buyers beware!!!!!!!!!
- engine problem?
- How can i tell if my motor is really a JDM H22?
- car starting problem 98 prelude
- 3rd gen parts into a 4th gen?
- ecm question on a 98 honda prelude
- GSR into 92-96 Prelude
- Trans questions?
- Swoosh V-tec controller install
- 91 Prelude VSS (Vehicle Speed Sensor)
- Cruise Control
- 4th Gen clock dimming
- h23 and f22a turbo manis?
- f20b oil pump working on a h22????????
- newbie to the ludes. need help plz
- 92 Prelude VTEC
- H2B conversion?
- Ignition Problem
- h22 jdm
- Help with moonroof on 4th gen
- best tranny to go with for a 97 auto to manual swap.
- How can the main pully break OFF like this??
- Honda cargo net (what is interchangable w/ the 5th prelude)?
- Vibrant header for H22.....???
- S2K timing chain on h/f engine
- DC2 ITR wheels on 5th gen prelude???? anyone?
- custom exhaust or not
- 95 PRELUDE H23 SE FOR SALE!
- 93 prelude, 96 prelude. which to keep?
- Removing Front and rear sway bar.. for good?
- New guy checking in
- my engine is knocking
- Oscillating Idle Problem after USDM H23 to JDM H22A Swap
- f22 power steering pump on h22...
- map sensor wiring(searched)
- skunk2 stage 2 valve lash?
- how to check obd1 check engine codes
- New person
- H22 vs H23 (low end)
- 10 LBS or 12 LBS Flywheel for my H22A ??
- Type R steering wheel
- Turbo Prelude S question
- TRANNY, I NEED HELP QUICK!
- h22 swap into 4th gen, and now ac/altenator belt won't fit...
- copper header gasket
- Question about buying an 88 prelude
- skunk2 intakemanifold, IACV bracket, which one?
- JSP CF Hoods
- Piping size?
- Prelude Factory lip??
- front windshield
- i need a custom turbo kit for my 4th gen prelude
- Best swapt option???
- 5TH Gen Luder's what is the best power mods?
- H22A exhaust issues
- High RPM
- Folding rear seats??
- h22a4
- tranny swap
- Jdm Headlight / Center Fog light question
- Car Overheating
- MSD SCI Plus Install *** Where are you guys mounting it ??
- performace upgrades
- Compression ?
- H22A question
- h22 pro2 cams won't idle!! any suggestions
- there is somthing wrong with my vtech
- 89 Si 4WS...wont start when hot???HELP!!
- Clutches and Flywheels for 5th gen lude
- anyone have pics of h22 oil pick up
- You like possible tow hooks?
- lude storage
- JDM H22A spun rod bearing how does my cylinder wall look?!?!
- Does the JDM Automatic Tranny comes factory LSD?
- 1989 Honda Prelude Coilover Installation/Camber kit
- H23 allmotor guys...
- Prelude Soon.....Suggestions Please, No flaming
- 5th gen air bag tray?
- safcII wiring
- Buzzer won't shut up
- H23 Vtec build almost done. inner crankshaft sprocket not lining up HELP
- Engine Died
- Quick question
- b21a1 motor
- Swapping OEM Parts (bb6)
- front bumper hole
- will a h22a1 oil pan fit on a h22a4
- Installing EDM rear fog light
- How much is this worth??
- new car or stay
- blown air bags wat to do now?
- Rear caliper toasted pads in 5000 miles
- for sale 1997 honda prelude
- H22a4 head on an h22a block
- MAP sensor reading on a VAFC2?
- will this fit on a 98 h22a4
- Map Sensor Problem
- autometer oil pressure gauge
- JDM Fog light kit 5th gen $335 Group Buy
- Compression and nitrous with 93 octane
- gears grinding?
- How to?
- Oil Pressure gauge
- knock sensor
- H22a1 Clutch Shuddering Issue
- Help!!!! Stupid Problem Occured During Engine Build
- 4th gen 7" lcd touchscreen install (pics intensive)
- 1988 Prelude ----ECU CODE HELP
- best performance rim/tire sizes for 4th gen?
- honda spec alignment???
- Foam in Radiator and cooling system bad headgasket?
- Endyn Rollerwaves anyone running them ?
- Dealer parts are expensive!
- need stock h22 injectors 340cc,,,,,,,,help!!!!!!
- If Your Timing Belt Broke
- Car isn't starting... need help
- F series tranny on a H series engine ?
- JUN or Crower stage 3 both with valvetrain and manual tensioner
- shifter feels really loose, miss gears sometimes
- HPOA.com..... back in spirit!
- 5th gen vs. H22 head 6th gen Accord?
- converted h22a4 injectors to obd1 h22a 345cc injectors, need help!
- Help finding a 1 piece header 4 H22
- any experienced Honda techs help me out with these troublecodes?
- Pic request... 92-93 fog switch wiring
- h22t wont boost
- No spark--need some ignition help
- coolant leak
- spec sheet for alignments
- 5th gen lude A/C compressor work on 4th gen?
- ECU Chip
- Alternator problem?
- HELP! Frying ICMs
- cleaning engine bay
- WTB: 92 H23A1
- Sway bar endlink -- shock knock
- 4th gen pics?
- Putting together own turbo kit. Guidance appreciated
- '96 Prelude Coilovers on a 2001?
- Mugen Strut Bar for 5th Gen Prelude?
- 88 Brake Proportioning Valve Question
- What will painting a WWRS kit cost me?
- Easy Question: Wheres the best price for Skunk2 cams?
- Greddy Evo 2 Exhaust (5th gen lude)
- OEM Parts
- F/S: H23 Parts
- Good trans to get for my 5th lude
- A couple motor mount questions...
- put the prelude on a diet? 96 vtec
- P13-900 desperate
- did some photoshoot with my projectors and HID
- Lowering 5th gen...having problem (searched)
- Ignition tune up? which ngk plugs , searched
- header gasket
- First littel Feature
- WHAT TRANNY FLUDI FOR MY PRELDUE M2A4 TRANSMISSION
- my 252whp h22 thanks to RLZ and RMF
- f22b owners.. pls help
- engine smoking problem
- ECU???????
- injectors
- Problems with 5th gen JDM H22 swap....please help
- Suspenion squeaks over bumps.. why?
- looking for a lude
- Replacing Knock Sensor
- Prelude pistons
- H22 oil pan???
- Skunk 2 inlet manifold for H22A7 engine!
- what lsd is in my tranny
- Climate Control Problem Please Please Pleaseeee Help
- Gauges
- Wideband
- cat rust
- jdm import vs converting from usdm
- gas pedal diagram/pics request - something must be outta place HELP
- Hondata s300j Gains ?
- Inaccurate Speedometer
- piston ring blew? ands breaking
- National Prelude Meet track day spot
- electrical connectors by oil filter?? help
- any try these?
