View Full Version : Honda Prelude
- SIDE MIRRORS
- BB6 wire tuck. need help!!!
- CAI Install / Ordering Price Scam or Not........? Advice Needed
- ANY GOOD PERFORMANCE SERVICE SHOP IN THE LOS ANGELES AREA?!!
- Air conditioning compressor shuts off
- h22a turbo question??
- -Abbreviation thread?-
- serched : cost of turbo
- -Question about (factory) keys and alarm-
- Eclipse air ride in a 3rd gen prelude?
- Mirrors
- h23 fully built turbo which spark plugs
- unorthodox under drive pulleys
- got a question
- need help with my 97-01 stock prelude cd player
- which rotors and pads are good?
- Accord rear valances on a prelude?
- OEM vs Aftermarket replacement parts
- Megan Racing NA type exhaust
- free honda 40pt inspection results.. and some ?'s
- How do I remove this part
- h22 blue top? euro-r?
- timing a h23
- 95 Lude idling at 1200 rpm after radiator swap
- F22a1 with H23a1 Tranny - Will it work?
- 88-89 PRELUDE
- Quickie; aftermarket steering wheel SRS light bypass
- ebay headers
- 2000 Prelude keyless entry fuse blown
- CarPC and my problems...HELP PLEASE!!
- Front end problems
- skunk2 valve train
- boost gauge wireing
- Htechs or PROKITS!
- 4th gen prelude door visors
- Axle???
- h22a short shifter
- How do you install Kaminari 4gen lip
- what kind of numbers can i expect?
- 5th gen Struts
- Sh strut????
- Once I get connect my P13 ECU, is there anything else I need to do.
- best place to buy a tranny??
- ICU(integrated control unit)
- Bpi Flow Stack install
- 4th gen or 5th gen
- banjo bolt for turbo pressure line?
- Ground Control Spring Rates!
- Need help...with h22 civic
- RDX Injectors on 5th gen
- G23 BIULD WITH ?'S
- battery keeps draining
- Missing key questions
- H22 Turbo Manifold, HKS BOV, JDM Intercooler
- ECU for Turbo
- prelude 2.0 carb problems
- Eagle Rods
- need some parts?!?!? or are you selling some parts???
- tuning h23 turbo
- My crazy "no cranking" dilemma
- Need Help ! H22a or F20b settings help
- 5th gen supercharger or turbo??
- VTEC Head
- Pic Request
- aftermarket steering wheel install....HELP
- Stock Filter into cold air or AEM short ram with OBX filter???which one is better
- front wheels inner edge of tire rub
- Auto tranny swap questions, on strength.....
- H22a Swap throwing IAT code and vtec solenoid code!
- automatic transmission turbo
- h22a4 build
- LED headlights
- im sure this is covered somewhere but why do some people heat wrap their headers
- h22 turbo stock internal
- i need some info
- How do I remove my EGR valve?
- 1999 Prelude Code 8 TDC sensor?
- Tach intermitantly bounces and engine misses
- What the difference between a P13-A10,P13-N00, and P13 L10.
- Vacuum line diagram, H22 Intake manifold
- What are the head torque specs for the B20 in a '90 Prelude SI ????
- Nice Exhaust System... what should i get?
- Some cool information for all you forth gen enthusiatats
- Gas guage doesnt work!!!
- M Factory final gear any good?
- Fixing The 4th Gen Cup Holder With A Paperclip
- N/A build, with B-series trans
- idle at 1200 rpm's
- Factory 5 motors in Schamburg, IL
- juts joined the family
- why dosemy rpm idel at 2grand when hot and 3-4grand when cold..
- mm
- 37820-P13-A10! Is anyone else ising this ECU?
- bucking and Check Engine light... eating gas?
- 4th Gen CEL problem
- H2b on a prelude
- h22 1/4 mile
- Emergency brake light stuck
- how to isolate a rod knock?
- questionss
- rattling noise?
- Cel code 12 after washing engine bay, Water in EGR valve / system ???
- Good Turbo Kit
- No power after VTEC
- ABS computer??
- ENDYN JRSC H22
- Rear Rotor Size for 5th gen
- Rear alternator mount?
- Anyone have STOCK EuroR H22 Dyno numbers?
- 3rd Gens Represent
- 97 prelude...help with some parts
- AVC-R in a 4th gen - Where to mount?
- Assistance needed
- wtb prelude bbs usdm fog lights
- Prelude Axle/Halfshaft
- 4th Gen JDM with Jackson Race Supercharger, Anyone?
- JDM antenna half pole switch
- tickets?!
- Vtec code 22 help
- VTEC HELP!!!
- how much to replace a head gasket?
- Knock Sensor
- SAV
- When shipping freight don't use ROADWAY
- -H23 engine-
- Hondata IM gasket and Euro r
- Replaced Radius arm bushings,What a difference
- Overheating
- Shocks and springs
- Main Relay Wiring
- h22 dipstick
- boost gauge vacume line
- swapped H22a random boggin , loss of power , sputtering, stalling
- Tming cover fitment?
- Bogging?? Something bad is sbout 2 happen...
- Balancer belt ASAP
- 1991 Prelude Idle Surging
- 4th gen cup holder......anyone know where i can get one?
- Pic request. Black 4th gen Prelude with polished wheels
- Code 21 Troubleshooting
- Apexi VAFC good investment?
- fast idle control valve question???????
- 5thGen USDM Foglight + Parking light
- H22A. Problem with overheating.
- H22A Oil Pump ( Turbo ) Question ...
- turbo setup what ecu p28? p72?
- STOLEN INTEGRA IN SOCAL
- fuel pump
- --> This Should Be The Official 4th Gen Front Lip Thread!!! <--
- H22a Header
- What Transmissions will work on a 5th gen
- Header and intake manifold test!!
- H23A1 -> H22A swap - ECU question...please help
- EBAY TUBO KIT?!$
- ACT or EXEDY?!!
- Need input from the prelude experts - Looking to buy a 5th gen
- Replacing USDM foglight bulbs w/o removing bumber?
- brake upgrade
- Preludes and type of gas (93)
- Engine Restore?
- Accord lip pic request
- Knocking/Pinging
- F22B intake manifold fit H22 engine?
- megan headers worth it?
- Vtec help????
- -C.E.L question involving code 12-
- Blown H23a1, in the process of swapping a H22a.
- fog relay buzzing?!
- Exhaust info which you might find helpful
- 93 h22 lude ABS light??
- Eibach Pro-Kit .1.3 inches
- JDM H22 Overheating. NEED HELP ASAP
- performance shops?
- adjusting windshield wipers
- '97 SH Left Headlight Going Out
- Neptuned H22 204WHP, STOCK HEADER/IM
- Looking for a 96 honda prelude EL gauges....
- Holy dirty relay batman..
- question about preludes
- WHERE IS SOMEWHERE I CAN HAVE MY H22 WORK ON???
- power steering pumP?
- 4th gen helms manual download link???
- vtec DONT WORK
- Compression Test- what does it actually test?
- Timing belt
- Mugen lens cover for front bumper
- Need a mild buildup on the lude motor
- check engine light
- wtb p28 with hondata
- Possible to use ABS modulator from another Honda?
- How can i raise the ride height in the back just a bit, without changing the springs?
- TPS adjustment when it's riveted in?
- took butteryflys off, how do i take off the bar?
- shift knob install question
- atts light on in dash
- where does the ignition coil bolt on at..
- cf plug custom mount
- Did lots of searching and reading, now for an educated question...
- 4th gen to 5th gen front end conv. questions
- swap??????
- chip
- Accord top mounts
- Retrofitters ONLY
- Anyone have the link for the v8 prelude?
- p28 hondata
- lude problem
- WTB: 5th generation prelude parts
- How to take off rear seats
- T3/T4 Turbo Kit For Sale
- Broken Timing Belt
- what is the value of this switch?
- Racing Beat exhaust on a Prelude?
- aftermarket header brands?
- New BB6 owner here
- white gunk in alternator connector?
- Timing belt help
- Wiring harness questions
- Question: Why were my tires spinning when jacked up and in N?
- non a/c belt
- H22 3rd gen Prelude or???
- nub w/ wheels and lowering
- fog relay from auto store
- Anyone know what became of this RWD Drag Prelude?
- how far do u go on coilover 2 get stock hight?
- d3 install in a 98 lude.
- Transmission Identification question.
- camp 1320 header
- VTEC solenoid bolt snapped problem
- New to cars...help plz...
- Gauge bulb type
- Tach no working
- taking off top part of IM?
- 5th gen...should I upgrade base suspension to SH?
- Looking for shop in South Orange County CA that can hone FRM sleeves
- what the air intake can do??
- JDM one pieces
- Stock Sway Bars
- hissing noise?
- What muffler to get? Tanabe?
- knocking noise??? but not a rod!
- H22 in an SI... what is rev limit?
- quality HID kit?
- which PS pump to use??!!
- Power Steering Question?
- bouncing idle (searched)
- in-car Video from Midwest Honda Challenge, H1 #117 Prelude
- SOHC VTEC
- H23 from the ground up... RECOMMENDATIONS?
- What to do?????
- **Calculating Intake Manifold Runner Length** get out your vtak calculator Yo!
