View Full Version : Honda Prelude
- couple questions
- interested in fifth gen prlude parts????
- 5th gen dome light mod with pics
- Is this kid retarded (h22 turbo)
- How do you install a AVC-R boost controller
- The clutch? Or my silly ass driving?
- turbo manifold
- Aem EMS
- Need help with lude distributor
- fast 3gen
- ac unit no working... i think a wire got cut that shouldnt have...
- modified distributor cap
- CAMBER KIT
- OEM Fogs
- Half Mast Switch
- Which is a good quality brand for Mugen replica kit?
- WTB: '86-'87 Seatbelt buckles
- hmm..how would a spoon lude look?
- Euro-R intake manifold - cost of ADDITIONAL parts to make it work?
- After I changed my pump tp a high performance paump car wont start like it should
- Starting Problem
- o2 Sensor
- Are obd 1 h22a blocks same as obd 2?
- Greddy Turbo Prelude
- orlando luders help please!
- All of you Tech head, get in here.
- h22a tranny
- Spark Plugs = More HP??
- Tranny Fluid ??s
- Anyone looking for some 5GEN Base Wheels & Tires?
- Timing gun with UR crank pulley
- Balance Shaft Plugs
- hey.. for those who knows bout teins
- distributer
- A few engine questions, please help ASAP
- driver side corner light
- H22 short block for $1000, good deal?
- Changing timing belt and water pump.. no access to helms or anything else
- My Poor Lude
- Need help swapping 99 H22 into 93 H23
- 5th gen prelude AUTO question
- Installing DVD screen into dash?
- 4th gen: EM Racing C-Pillar tie bar fit w/ autopower roll bar in place?
- SPC camber kit install
- What happened to HPOA.org?!?!
- car overheating?
- quick ques for my fellow luders
- H22/23 Block building question
- ARP main stud kit question
- Does this motor exist f22b DOHC(non-vtec)
- ******* How do I tell what year my H22a is?*******
- about the skunk2 manifold...........
- alloy rims
- How to check for problems with the ignition system?
- HOW FAST?
- Chipped ecu and nitrous
- No vtec and rev 6500 on H22 in H23 lude
- Revhard Turbo
- Prelude vs Integra?
- about to mod my collector to 2 1/4in. Has anyone doen this here?
- kinda sucks byby my 94 si my bulit h23a1 :{
- h23 wear and tear
- Camber kit/alignment
- have SI, but need new starter..VTEC work?
- 92 - 96 Prelude Front Lip
- removing a/c?
- greddy evo or skunk2 exhaust
- C E L code 61, primary O2 sensor: What are the causes?
- MSD 8.5mm NEW wires are causing problems in my jdm h22a.
- Two Piece Black headlights
- struts for 5th gen??? to match tein springs
- i put motor in runs shitty h23a
- Couple ?'s
- Need to Find.
- Stock h23a1
- H22A Swap: Emissions?
- not sure about driving having problems just driving normally
- Looking for stock wheels off of a 92-93 Prelude SI/VTEC
- installed 255 venom pump but noticing something a bit wrong
- fender platic linnings
- where can you grt 17 grids
- What are the "weak links" in the H22 at higher than stock revlimit?
- Reworking/modifying the stock Intake Manifold
- Just got my H22 swap about 5 minutes ago, how do I tell if the tranny is LSD?
- Did a compression test
- ***New to Hondas, Need some info***
- What 6.5 components fit my 98 prelude
- about this knock sensor thing
- k&n drop-in filter vs aem cai
- water guard??
- sh to base tranny swap.....going High HP FI & standalone ECU (more)
- eibach pro kit?
- Mixed reviews on Header wrap?
- Fuel Filter
- Take a look at this spark plug
- I have an A/C?
- b16 prelude
- Apparently, my engines trashed!
- 5th Gen: Camber Adjustable Upper Control Arms
- if i want to go faster whats after I/h/e?
- my new setup, im running with no blanced shaft belt. no blanced shaft pulley on crank revs high *mor
- 2.2 bolt on
- best place to get an h23
- H & R Springs
- Did I miss something? What happened to Sam, Boosted97Lude?
- Is this a good deal on a '98 Lude?
- distributors.....
- Aftermarket hub solution for 99 prelude, non-sh. Any have an idea???
- what can be done to a 91 prelude si motor please
- Power to Manual Steering...
- anyone have pic of car with hood locks?
- i need a 4th gen nostril (passenger side)
- How come these NGKs are not available for the Prelude?
- launching techniques...............
- Is this a Prelude steering wheel?
- ground wires
- need 92-96 center caps
- Are all catback exhausts for 92-96 Preludes the same in length/fitment? (see inside)
- i need a reinforement bar.
- Prelude parts F/S
- stock internals?
- ecu options..?
- Huge PotHole
- h23 crank needed
- Computer help!!!!!!!!
- Lude stranded me???!!?
- HELP!!!! 4th gen jdm h22 hesitating when accelerating with no cel....
- Road Race / AutoX Preludes...
- engine knocking
- what size in MM are the bolts on the H22a1 Crank Pulley?
- is a mugen chip worth it....??
- aem cai????? bypass valve or not?
- removing h22 oil pan
- racing seats
- ~~HELP~~ Idle Problem with 86 Lude
- GM Synchro Mesh in 4th Gen 5 speed. HUGE DIFFERENCE!!!!
- h motors in fast cars
- Looking for a luder with a 1992 Honda Prelude with a P13
- good for a laugh
- jdm stock header or us dc
- Having problems adjusting valve lash for Crower Stage 2 camshafts for H22A.
- 90 Si times?
- H23: Replacing seals while t-belt is out
- how do i hard wire through the cig lighter?
- oil pump on h22a - h23 different (friend blew his)
- I made into a magazine. Sports Car
- Best Header
- Gen4 direct port nitrous installation
- Question regarding port & polish
- best springs for KYB AGX shocks
- got rear ended the other day!
- removing oil pan
- wtb. es oval muffler 225
- so dumb... proly a waste of time
- hey out my weekend project! TEINS!!!!!!
- 4th Gen. Stalling, No power
- question for people who removed kyb's
- Altenator belt for h22 with no a/c
- ride height
- GOT MY EXHAUST Setup from Kteller...Pics
- Exhaust question... Need help ASAP!!!
- post pics of your CARB certification!
- is anyone selling there distributor for h22/h23?
- Speaker question??
- Good news from AHC
- prelude videos??
- Injecter size
- 44K anyone?
- 89 Prelude...stutters at red light W/ air cond on?
- For BB1 owners with JDM headlights
- 5th Gen DIE CAST Model!!
- just thought I'd share this Bad-a*s vid....
- Is anyone a member on Preludeonline?
- Wrecked my car tonight
- h22 girdle
- Rattling Cat... can you fix it?
- how much do 17"x7.5" rota subzeros weigh???
- Intake Manifold
- HELP! motor seems to bog
- spoilers on a 5th gen...worth it or not?
- can somebody post a transmission diagram for me?
- How to Install clear front bumper lenses on 5th gen??
- Automatic 86 prelude Si....Tranny Fluid Leak
- obdII prelude 97+ to obdI p13 ecu can ne tell me the pro's cons is it a good idea?
- AAAAHHHH NEED HELP... Car doesnt start, just barely tries to turn over... already diagnosed it.. her
- bearing question, helms isn't too specific on this IMO...
- Help!!! whats the stock fuel pressure on a h22?
- Koni shox ?'s
- I found this exhaust system, it is what i like, but...
- PSI H22a1
- Midwest Prelude Fest '03 - Aug 17th
- Techedge: Can someone explain what you can do with it? What it does?
- Engine Break-in w/ Preludes...
- front strut bar
- 92 Prelude A/C troubles
- clutch (release bearing problem)
- Anyone have STR Intake Manifold for the H22?
- help with faded red paint...
- whats a good clutch to buy??
- Honda Prelude OEM/JDM Front Lip
- was thinkin about forced induction but something to hold me down
- Max HP on H22 N/A
- I need to see the pic of a 97> prelude firing order
- I am back... and so is my car.
- If the timing belt goes.......
- Turbo kit for sale
- Maintenance on a 167K miles 3rd gen Si.
- should i take off my cat????
- what years came with the passenger airbag??92-96
- crankshaft pulley is not siting flush how to fix it h23a?
- very strange crankshaft bolts are not the same on h23a
- forged pistons?
- Need help - new to ludes
- black housing jdm headlights
- Full coverage insurance: Worth it?
- Know of any experienced turbo tuners in the southwest OHIO area?
- Hydrolock Mayhem, Part 1: Surveying the Damage...
- installed a high flow cat today
- crank shaft pulle will not sit right, sits to fare on one side!
- need more power
- timing belt gear stuck to crankshaft...
- idle drops fast. even faster with ac on. stalls.
- Air filter
- 98 prelude
- blown? broken? huh? HELP
- erratic idle problem
- who does quality H22 build-ups?
- H22A1 w/Skunk stage2 Cams, Skunk springs&retain, Skunk Cam Gears having probs need help...
- Recalls
- JDM H22 rev limiter
- open headers?
- More Injector Help>? H22a same as H22a4>?4th gen/ 5gen Possible
- n2o and plug types...
- clutch problem
- OEM bearings vs. ACL bearings in a prelude
- jdm headlight wiring problems?
- POWER FAILING NEED HELP PLEASE!!!
- does this work?
- Jackson Racing blower
- 4th Gen Help please!!!!
- need an opinion from those with FI experience
- wheel hubs??? LOOK PLZ> help needed
- crank pulley came loose and got destroyed
- ground controls? need advice for 01 lude
- Springs!!!!
- ******BEST CAT-BACK EXHAUST SYSTEM FOR a 92 SI????
- 92 lude wont start
- Another engine down the tubes
- upper ball joint removal: press out
- S200 rims on a Prelude SH?
