View Full Version : Honda Prelude
- Weight of shortblock
- 2000 Lude Flooding out, whyyyyyyy?
- Prelude exhaust
- Stupid coolant question....
- Where to get...
- Comparing H22a and H23a VTEC
- Lower tie bar for 5th gen
- identifying flywheel
- H23VTEC vs. H22 (89mm)
- S2000 Steering Wheel
- Poor man bottle heater.
- Stock Radio question
- is N02 possible to do right?
- sleeving miy h23
- what's your best 1/4 mile time?
- Looking to be a new Prelude owner...question
- weather stripping
- H22 turbo
- how do I check tranny fluid?
- Headlight Conversion
- Those of you with H22As
- Tein EDFC and Strut Bars
- motor mount inserts any good
- Speedometer problem
- cold weather suspension creaks (5th gen)
- 95 PRELUDE ABS LIGHT IS ON....
- Spark Plugs on JDM H22
- USDM H22
- Can I relocate my tanabe racing medalion under the car? (stealth mode)
- problem with idle
- is typE sh cams tha same as jdm regular h22a ?
- b16 VS h22
- New Member with a header question
- Should i be making more Power??
- VAFC II Questions
- Should I keep my 93lude vtec?
- Oxygen sensor location??
- h23 head specs
- BB4 JDM Headlight #
- skunk 2 exhaust
- Easy mods for a 98 Prelude Si! (Need Help!)
- how to tell between h22 and h23
- Tranny noises... HELP
- Built Motor Break In Questions
- WTB: (for all you 4th gen guys swapping in H22s).... H23 or H22 complete swaps needed
- Creaking Clutch??
- Hi, New Member with TURBO QUESTIONS
- BB Squad
- Dyno's in south florida
- f22 question
- suggestions on price for used H & R race springs
- The good and the bad
- Stock intake hose w/ turbo?
- Anyone familiar with clutch/transmission in a 98 5 speed?
- Transmission removal
- double the power??
- 89 prelude body kit
- Funny thing happened on the way to the office today .......... (tranny question)
- remus muffler for the lude
- skunk2 stage 2 cams
- Headlights get a lil dim going up an incline at low rpm..normal?
- H22a1 stock compression numbers
- H22 Header Review???
- so my shift boot came loose..
- Vacuum Diagram? Anyone have one?
- Possible to determine if a Prelude is 5spd or Auto from VIN?
- swapping out clutch
- VTEC DOES NOT WORK ....
- CEL on p28ecu ????
- Greddy Evo TT
- spark racing h23 rods..
- Best ecu to use for Hondata?
- 97 prelude vibrations
- Need advice for headlight conversion!!!!
- !992 H23a1(USDM) into a JDM H22a
- Front Tower Bar/Rear Sway Bar/Rear Strut Tower Bar/Lower Tie Bar question
- winshield washer hose replacement, remove fender?
- What happens when..........
- Low beam HID worry free?
- Easy to install JRSC while motor is in car?
- car wont start because of cold?
- torque spec for alu oil pan?
- NOS Stealth Install on a prelude.... NOS ? What NOS ??
- I broke my shift cable!!!
- Code 9 (CYP Sensor) ...
- Turbonator. Yes or no?
- Annoying 'rattle' from rear end of '95 Prelude
- Those with Tuned VAFC/2s read.........
- Cams help
- misfire in 1st (jdm vtec)
- Can I put 9:1 H23 pistons into H22?
- What size tires to run on 17 inch wheels?
- Will 185/65QR14 tires fit on 89 SI wheels?
- 97 prelude WHEEL PATTERN?
- Nitrous Video of lude?
- Wrecked my '92 prelude, parts for sale.
- Honda Prelude Header DC Sports Greddy Difference between 92-96 and 97+
- 95 prelude Si with JDm h22a....hood clearance??
- Problems With JDM H22 Need Help Please
- Esslinger 5 Bolt Cam Gears...good?
- SEIBON carbon fiber hoods?? anyone
- Turbo Build: 87mm or 89mm bore?
- navigation
- Is this a Type SH prelude
- anyone ever come out w/fiberglass hoods?
- PoP sound when cold? bb6
- Metal Tension Sound
- How would you know when wheel(hub) bearing is bad or what type of noise would it make?
- Is this a good buy?
- Intercooler Sizing for 98 lude
- Skunk 2 stage 1's Vs JDM OEM
- i want to turbo my h23
- motor mount install...gone bad. help
- shrilling sound at low rpm?
- oops. 92 4WS, snapped tie rod and .. ??
- Oxygen sensor bad??
- H22 turbo help
- ECU Mod
- Tein SS-P Coilovers and EDFC Installation
- fitment of 7.5" wide rims?
- JDM H22 Setup
- Harsh vibrations at practically any speed.. ?
- ARRRGHHH!!
- Would the JDM DC2 Recaro SR2 Seats fit my 92-96 prelude?
- 2001 Prelude going OBD1 JDM motor: Need Help
- h22 in 97 acura cl
- 97-01 prelude owners, I need your help.
- new guy
- Need a downpipe measurement
- Jdm and USDM H22 Tranny
- JDM side markers
- header differences ??
- questions about the SS
- H22----> h23 Turbo swap???
- nology hotwires
- For coolant flush
- Apexi SAFC on h23
- Oxygen Sensor question?
- Where can I find SPOON CF Lip for 4th gen?
- H22A cams, OEM specs for the low cams
- Frustration with repairs
- are all 4th gen dizzys the same?
- did i do this right?
- dc header
- What oil pan doesn 97 prelude use?
- H23 autos out there i need your help
- a couple jdm 1 piece questions and opinions
- H22 Dyno Results - 185 whp, 155 tq
- retro fitting headlights for a 2000 lude
- went to the strip tonight very pleased with my time
- H22 head
- Prelude Idle problems and others.......
- need quick, accurate, answer
- n00b question
- Where can i find these products ( Suspension )
- Engine Rebuild - Looking for advice
- Advice on New spark plug wires...........
- gonna change dizzy and cap
- going to trade my 01- I guess
- What are the P13 Tuning Options?
- ECU Mod
- folk shift 5th and reverse?
- h22 compresion
- Noob Question on springs
- Traction Control in 5th gen?
- Idel fine before spray?
- What a week. RIP Si
- Intake Manifold necessities
- H22 transmission - any aftermarket transmissions?
- 92-96 Stock Prelude Parts, Wedge seat brackets, sparco Sliders...
- How much for block rebuild
- Power loss tru tranny?
- Finding TDC on H22???
- Good Exhaust Piping Size?
- Stock radiator cap?
- timing mark on pulley HELPP
- crank pulley
- anyone need H22 VTEC Solenoid????
- Is this too good to be true?
- SuperchargerVSTurbo
- h22 swap question
- Distributor Help
- Informative Topic - Code 0401 Official Solution
- High hp h22 question
- JDM key console the same design as USDM?
- 2000-2001 Grille
- Will a stock 97 base prelude ecu fits in 98 prelude sh ?
- Intake manifolds for boosted h22?
- Solid Radius Rod Bushing for better Traction?
- Back from the dyno with proof that our stock ignition systems suck.
- What mods??
- Looking for a tranny....
- H22 accord...so which CAI?
- atts at high hp
- anyone parted a prelude before???
- update - exhaust noise
- 2.2 to 2.4
- Black smoke-Help Please
- Engine knoking
- 92 prelude purchase
- HELP CAR SUCKS
- 94-96 electro luminescent cluster conversion wiring PLEASE HELP!!!
- F22B to replace an H23?
- Will it fit?
- 18:1 air fuel ratio - EGR problem?
- 1997+ Prelude Trans. Control System: ATTS Unit Oil
- crack shaft
- Has anyone seen this prelude? Or have more pics?
- H22 exhaust Noise
- RS-R ExMag or Thermal Stealth?
- turning a h23 into an h23 v-tec
- Bleeding the coolant system.
- The difference between an 92 - 96 head and a 97+ head on an H22
- Testing on H22A prelude street header
- flywheels....need some direction
- Another FRM question
- tps problems again
- building a motor ?
- 94-94 EL cluster conversion wiring PLEASE HELP!!!
- I need an after market flywheel for 98 prelude. Any suggestions? Please Help!
- Buying used aftermarket wheels, what to keep an eye out for?
- Thermal Cat-Back
- prelude oil pressure
- type-s cams the part number ? p5p?
- Ebay HID Headlights set which size 4th Gen
- Anyone know rad size of BB1 preludes?
- old school vid of the turbo h23a
- Bad oil leak!
- 2001 prelude sh
- Really Need H22a Crankshaft!!please help
- With a SH if i put a test pipe and my CEL came on y would my ATTS come on as well?
- h22 guys.... WTF happened to my motor, DAMN!!
- little advice
- Camshafts locked up......Help!
- wanted wings west front lip. 4th gen
- Spark Plugs
- ? on top end rebuild gasket kit
- wings west front lip
- Didn't pass Smog (cali) EGR valve/Cat
- b20 vtec
- distributor arm broken
- jdm prelude
- vafc2? wiring
- Check engine light on
- 92 Si driver window
- 94-96 EL cluster
- 4th generation steering wheel compatability questions...
- JDM Climate Control Sensors location and air mix motor question
- Suspension
