PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. H22A4 vs H22A2 on a 98 Prelude
  2. h23a and h22a4
  3. prelude not starting. PICS and VIDEO
  4. 92 prelude h23a3 wont idle
  5. bluetop h23a indentification
  6. Help me prioritize my car repairs please!
  7. 92 Accord f22 parts fit 92 Prelude?
  8. Spun bearing, replace in car?
  9. white smoke from tail pipe
  10. ABS Control Unit compatibility in 4th gen
  11. Calling all 4th Gen lude professionals
  12. my intro. new to Honda tech
  13. Passed Smog !!!
  14. '97 Prelude SH - occasional blue smoke *pics/review my findings*
  15. Any tricks on removing screw on the distributor rotor
  16. tachometer reading low
  17. 2001 Prelude OBD2 code P0401
  18. LOOKING FOR STEERING HUB FOR PRELUDE.
  19. Cut wires in harness need to know what they go to
  20. F22a1 4th gen running 91 octane?
  21. PLEASE HELP!! I THINK MY VTEC IS STUCK
  22. JDM H23A "Blue Top" DOHC VTEC Head Gasket
  23. Where does this hose plug into? Picture
  24. 81 Prelude Flooding
  25. '95 prelude: Alarm Short Circuit?
  26. How to retard timing
  27. For Sale: ECU, Distributor
  28. Fuel pressure regulator question
  29. hytech replica headers! has anyone used them?
  30. Does chipping save gas?
  31. Idle stumbles when you let off the gas
  32. 94 prelude lost all motor power while driving
  33. El Glo Gauge Cluster Green to White (Pink Acetate?)
  34. How benificial are automotive certifications
  35. thought i ran out of gas? prelude 96 si
  36. H2B help
  37. 95 Prelude Temp gauge problem!!
  38. b16a vtec iacv on h22a intake???
  39. h22 header ?'s
  40. DIY on h22 balance shaft repair?
  41. wtf is going on here h22a jdm mfg 2/97
  42. type S intake manifold on h22a4
  43. Quick MAP sensor question
  44. 01 prelude p0700 and p0740 check codes
  45. H22/H23 Questions
  46. ks tuned tensinor
  47. im looking to buy h22a engine block
  48. 01 prelude flashing d4 light no start
  49. crankshaft kit
  50. 29 spline hub
  51. Fog light lens reflector/blocker needed?
  52. need answers asap
  53. quality valve keepers for 90 lude with B20?
  54. replacing main and rod bearings
  55. Buying a 00' Honda Prelude
  56. 81 Prelude Fuel Relay Issue
  57. Help with the H22 swap (Northeast)
  58. Best tranny fluid for m2a4 with h22a
  59. Hypercoils on stock oem shocks plus a drop
  60. H22 timing issue
  61. parts help?
  62. H22A4 serial # ?
  63. carbon fiber altezza taillights?
  64. vin number
  65. bottom end rebuild
  66. 95 lude head gasket swap now wont start!
  67. Odd Rubbing Sound...?
  68. advise please
  69. Every time I bump start my prelude the ABS light is illuminated
  70. looking to buy coil overs for my prelude 97 sh
  71. 5 lug conversion question
  72. Transmission issues
  73. WTB: Type S or OEM Optional Front Lip
  74. Running rough after ecu change?? Please help
  75. distributor inner seal question
  76. Help with JDM H22 oil
  77. Newly purchased Prelude 96 SI Fuel Consumption as well as high RPMs
  78. 1995 prelude F22 to 2001 f20b swap ...dizzy question....
  79. Anyone know a trusted mechanic in NYC to clean EGR ports?
  80. Service Check Connector location?
  81. What is this?
  82. Hondapartsnow.com
  83. whining sound and no read on the speedo
  84. Fans not coming on. h22 prelude
  85. minimun wage luding
  86. Need input. Cf hood/ trunk
  87. AC thermostatic switch on '96 Lude
  88. HELP! 'Lude won't run - 5th gen
  89. still leaking...
  90. Silly hose!
  91. newbi in need!!!! h22 swap, wont start.
  92. best spark plugs for jdm h22a
  93. Need Recommendations for work to be done.
  94. 94 prelude type S. H22a dohc vtec swap need help on wire harness
  95. restoring the "black" on the lude?
  96. Sensor question
  97. Throttle body cable nuts.
  98. 4th gen prelude parts(1993)!!????
  99. Anyone selling an h22a1 block?
  100. what could be causing this. video
  101. jdm h22 into si vtec issue
  102. Pull OBD1 codes with no gauge cluster?
  103. HELPPPP 5th gen
  104. h22a4 missing vin # !!!
  105. Sound system in prelude
  106. Radius rod bolt loose, but wont come out (SH)
  107. Timing issues after changing cap and rotor - '95 Prelude Si
  108. 92 prelude cooling fan issue
  109. So I wanna lower my ride..
  110. 1990 Prelude: inner tire wear mystery.
  111. Need a Honda H22 Series T3/T4 Turbo Manifold
  112. Prelude California Cat vs 49 State Cat Converter
  113. foglight wiring question
  114. how to run a code?
  115. Ideas for a paint job?!
  116. Need advise Balance Shaft Belt or Not
  117. Ready for a dumb question? lol
  118. just a project!
  119. whose running function and form coilovers ?
  120. Need an ECU for a 1996 Prelude SI
  121. What cap for my dizzy?
  122. Suggestions on how to repair rubber lists.
  123. Axle issue
  124. My 4G is back on the road:D
  125. h22a7 snapped crank pulley bolt
  126. rebuilding h22
  127. Built H oil pressure vs. oil - strange
  128. H23a vtec timing question
  129. 96 prelude vtec misfire plz help
  130. f20b turbo build help...
  131. Just in case you missed it, I have a H22A Head
  132. rpm whacked out mph fine and no vtech
  133. PICS !!! h23a black top need advise and criticism
  134. 92 - 96 prelude shocks in 97 bb6
  135. 92 Si odometer/trip not working but hear clicking when driving.
  136. IS JDMTIGERJAPANESE RELIABLE?
  137. '93 Prelude Engine Swap Help!!
  138. with my 94 prelude it wont start sometimes
  139. ABS Speed Sensor needed? 92 Prelude
  140. How far can stock injectors go?
  141. Compression problem.
  142. 99 rebirth project
  143. Need some advise with h22a4 crankshaft threading for pulley
  144. hi. I need help. Pl
  145. Speedo needle crapped out HELP!
  146. brw blackworksracing 70mm tb
  147. no good ???
  148. H22A Parts Questions
  149. 4th gen fuel pump wires
  150. 3rd gen 1991 prelude *summer project* looking for coils&lips
  151. 97 Honda Prelude base no start
  152. H23a JDM to USDM h22a1 swap auto to 5 speed
  153. Im new & HELP! Lower control arm / trailing arm bushing stuck!
  154. odds of a cracked block H22A4
  155. H22 Swap Type SH
  156. Help No Running lights! Not typical problem! D4 out also!
  157. I have a problem!
  158. T2T4 LSD Type
  159. Prelude short shifter
  160. I need help!!
  161. h22a toasted a magnaflow race cat
  162. 5th gen prelude oil problem.
  163. 95 prelude crankshaft help!!!!!!!!
  164. 88-91 prelude trans question
  165. SH Transmission on 4th gen?
  166. prelude intake maniflld flapper valves
  167. h23v obd and wiring questions ?
  168. ECU Options?
  169. Need help finding part number
  170. Hello everyone
  171. I need help with my MUGEN headers
  172. Need a car!
  173. What other Distributor shafts fits the H22A
  174. anyone know about the 4ws wiring?
  175. CO2 emmissions high, if replacing cat does not work what else could it be
  176. 01 PRELUDE SWAP/ NO POWER TO DASH OR MOTOR?
  177. 01 PRELUDE SWAP/ NO POWER TO DASH OR MOTOR?
  178. 01 h22 turbo upgrade
  179. Acura CL or Honda Prelude
  180. How to change h22a timing belt
  181. 97 prelude misfire problems!
  182. Fixing sunvisor, 94 Prelude
  183. prelude power gains?
  184. no spark no fuel main relay clicks.
  185. H22A1 VTEC Lacking?
  186. Fuel Gauge, RPM Gauge Problem
  187. kaizenspeed tensinor
  188. Coil springs for 1986 2.0si 5speed lower 48
  189. 1993 Honda Prelude Distributer O Ring
  190. WTF!! h23a1 h22a4 engine tranny prob
  191. Misfiring, Red inside my dizzy???
  192. HELP whats the difference between a h22a and a h22a4?
  193. oil pan dented
  194. 5spd Transaxle questions for my 96 h23a1
  195. Suspension overhaul, control arms, coilovers, steering rack.
  196. Is a cello compatible with a prelude?
  197. H22A Rattling Sound?! *Video Inside*
  198. prelude hood dilemma (need opinions)
  199. 91 prelude si throttle issue
  200. Crank Pulley Problem.
  201. Breather setup question
  202. How much has been milled?
  203. 2001 vtec prelude is spitting and spuddering. Help!
  204. PCV valve
  205. h22 skunk2 pro series IM fitment in a eg hatch
  206. 92 Prelude H23 Distributor Replacement
  207. 1998 Prelude cranks but won't start
  208. swapping h23a1 to h22a4 in 94 si ecu?? Please Help
  209. Help for 92' Honda Prelude Cylinder Head Rebuild
  210. 95 Prelude Adjustable Rear Camber Kit?
  211. 01 Prelude clutch.
  212. Pressure Plate Bolt Length?
  213. What wires are these?
  214. Got sent here from the Accord section
  215. H22a4 prelude help!
  216. Some 5th Gen Prelude Issues
  217. my 94 si build
  218. Torque Specs For 5th Gen Preludes.
  219. Update from a Long-Time Lurker
  220. H22a4 5 speed swap into 4th gen
  221. Euro r H22A with PCD install
  222. H23a Bluetop question
  223. K2h on a jdm h22a
  224. Roll cage in 1992 prelude
  225. 94 vtec ECU question........
  226. h22 with h23 manual tensioner? help
  227. Prelude or Accord Decision Help
  228. Fuel economy thoughts.... :)
  229. which year is my h22a -pics-
  230. Random ticking/tapping?!
  231. 92 prelude running hot!!!
  232. engine smoking 97 lude?!?!?!
  233. H22A4 ENGINE LOCKED UP
  234. My Honda Prelude build!
  235. 96 Prelude stuck in park and speedometer stoped working
  236. NEED ADVICE
  237. rear speaker wiring-replace speakers w/new ones
  238. 1990 Honda Prelude 4WS
  239. Fast idle air valve question...
  240. Misfire?
  241. New Transmission How Much Fluid??
  242. Where to find?
  243. H22A1 loss of power/running rough
  244. 98 prelude h22a euro-r engine throwing code 21 HELP!!
  245. HELP?!? ASAP
  246. California smog question for h22 swap
  247. What Head unit In your 4th Gen?
  248. Installing rack and pinion
  249. 92 prelude project
  250. Car wont start
