PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. msd 6al-2
  2. NEW H22 BUILD LOW OIL PRESSURE
  3. TB coolant bypass mod?? ques..
  4. K&N filter or SRI
  5. Clutch will not bleed. (process included) ONLY THING LEFT AFTER SWAP!
  6. valve leak???
  7. How do you align the upper control arms (5th gen)
  8. FITV??????????????
  9. WTB!!!
  10. ecu chip
  11. i need tips on a lower ball joint.
  12. H23 lots of miles seeking suggestions/help :/
  13. My Rpm's are jumping
  14. has anyone ever seen this interior?
  15. Timing Belt Tensioner
  16. light replacement for nostrils? anyone try them?
  17. replacement fuel filters do not exist according to Fremont Honda
  18. Transfering 6x9
  19. Torque Specs
  20. anyone selling a h22a vtec drive pulley
  21. Trying to contact MJOLNIRvTEC!!!
  22. b-series mounts for 91 lude
  23. What ECU?
  24. Oil Leak
  25. h22a vtec
  26. k20 swap on a 92 prelude
  27. few question to what goes where?
  28. I'm a noobie!
  29. 17x8 48mm offset
  30. any body with turbo 4th gen AND fog lights!?
  31. 4ws conversion help
  32. New OEM Clutch for 98' Prelude SH
  33. h22a drive pulley problems
  34. Oaks Racing Prelude year ending 2008 update
  35. jdm h22 swap questions
  36. Changed Head Gasket Now Cars Not Right...
  37. OBD1 Dizzy
  38. Vtec Pressure sensor splice not the right thing to do.
  39. help! need a crankshaft
  40. Out with the old and hating the New
  41. h22 swap into 4th gen computer questions
  42. Recently Tuned H22 by Jeff Evans
  43. side panels
  44. Starter solenoid circuit issue
  45. 92 Prelude Light problem
  46. Pic Request: 5th Gen Prelude with Tein or Skunk2 or Eibach lowering springs
  47. fixed slave cylinder
  48. hi flow cat
  49. Dash E-Brake light
  50. HELP!!!! 1990 2.0 2.05
  51. '86 prelude help
  52. i finally got my 92
  53. post permissions
  54. Trial
  55. ATTS
  56. HEADERS!
  57. have a h22 in a 94 civic , have some quetions
  58. OIL BLOWBY.
  59. location of crank and cam sensor
  60. Alternator Problem
  61. Ecu chip recommendations
  62. how do identify type s cams?
  63. Is My Speed Sensor Bad
  64. Drivers side door won't open
  65. OEM headlights
  66. New shock collar, noise not fixed, help plz..
  67. Obd I Pinout question
  68. does sh tranny fit in base?
  69. Prelude Forums
  70. Compresion check?
  71. VTEC header downpipe compatibility?
  72. Help?!
  73. headlights
  74. lowering spring and stock struts
  75. 1991 prelude si timing belt snapped
  76. How do i wire the crank sensor???????
  77. code 043 obd1
  78. off set
  79. m2b4 diff into an m2a4 ?
  80. Type SH Tein H type, Which struts are best to buy?
  81. Oil in number 2 exhaust port
  82. Rear Main Seal leak .... maybe ?
  83. obd2a to obd1?
  84. Question on Trannny
  85. 1989 honda prelude hood
  86. Short Shifter
  87. i have a question about my injectors
  88. having problems with new manifold
  89. Treadstone turbo kit?
  90. 92 couple questions-cooling fan and paint
  91. What's wrong with my lude? 92 4WS
  92. Will this 02 sensor work for my obd1 h22?
  93. Wierd shifting.
  94. h22 swap guide
  95. Help - Coilovers
  96. Bulb Sizes HELP
  97. F series build options
  98. 99 starting issues then stalling - think it's flooding
  99. need help, no reverse
  100. Whats wrong?
  101. short throw shifter
  102. Coolant Problem
  103. Start up problem, but will run fine when started...(boosted with AEM EMS)
  104. 97 prelude, all sparks plugs fuel/fouling
  105. is this h22 original
  106. Knocking or ticking noise
  107. Custom supercharger
  108. Stupid thread. Tie Rod End bolts just spin and won't tighten.
  109. H22 perfromance cam
  110. 5th gen wheel width?
  111. climate control problem
  112. H22 making TICK-TICK noises at ~2300rpm and 3500rpm
  113. Ryan's H22A1 to H22A swap Prelude. Everything from start to finish.
  114. clutch keeps going out
  115. Looking for parts: Power steering pump and pressure hose 98 prelude base model
  116. need help with new 3rd gen
  117. Check Engine Hell!!!!!
  118. 1995 prelude LOTS OF PROBLEMS!!
  119. Oil leak
  120. need help on toque spec
  121. Car cuts out at 6k. has fuel and spark
  122. How can you tell skunk 2 h22 cam gears
  123. code 12 how to fix??
  124. 2001 Prelude SH Front and Rear Rotors
  125. hose clamps
  126. To buy or not to buy
  127. 92' Si Auto Tranny Issue
  128. modified intake
  129. Clutchmasters lightweight flywheel
  130. Alternator installation guide for 96 S model prelude
  131. eliminating the abs
  132. Where's the cheapest place/source to buy pre-painted OEM bodykit??
  133. megasquirt + VTEC + Daily Driver... possible?
  134. Clutch isn't fully Disegaging
  135. HELP!!!!
  136. Custom Engine Torque Damper (ETD) for the 4th Gen
  137. Head gasket install question...
  138. stock H22 spark plug wires
  139. How To Put The Cooling Fans Direct
  140. intake comprarison dyno
  141. atts & tranny fluids what do i do?
  142. AC question....! take a look.
  143. ecu and hondata
  144. ebay rotor
  145. Faced with a decision- New engine or part out
  146. Headrests?
  147. Toe like tire wear - alignment good - what gives?
  148. WHAT DO YOU GUYS THINK????
  149. brake experts please comment
  150. 1988 prelude alternator question **please help**
  151. prelude squad?
  152. Wheels sizing
  153. prelude newb question
  154. havin trouble startin my 92 prelude need help!!
  155. About 2 Buy ( OEM CARBON FIBER HOOD ) i need opinions please
  156. 2001 Prelude dies with no gas
  157. is seafoam a good idea?
  158. Gauges
  159. New Cams?
  160. Gas grade?
  161. 92 Prelude SI 4wstr - I need oversize pistons
  162. can i get your input on a msd ignition
  163. used p28 with hondata s200
  164. 1990 Honda Prelude Mechanics???
  165. Little question on tuning a car?
  166. transfer case in an 01 h22
  167. stock head
  168. GSR swap in 5th gen prelude
  169. HELP!!! broke my brand new exedy clutch a million pieces
  170. 2000 Prelude H22A timing belt/water pump question
  171. Cooling system holding pressure for DAYS
  172. Stock fans airflow characteristic?
  173. Need H23 Vtec Build question!!! Has anybody done this before?
  174. Extended Wheel Studs on a Prelude, anyone else done it? I need help/advice
  175. Need H23 Vtec Build Help!!! Will my combo Work!!!???
  176. Cylinder 1 misfire, Please help
  177. honda prelude h23 torque specs
  178. H22 Stock Rev Limit 8k
  179. Auto-Manual Swap Complete!
  180. Knob & switch near ignition?
  181. JDM Case ecu???
  182. y dont i have spark?
  183. bogging down when warmed up
  184. Ecu Code 80 (EGR)
  185. kinda simple question but help me out please(spark plugs)
  186. SRS light
  187. Quick Question
  188. Short ram to cold air "conversion"
  189. 92hondalude h22 turbo build nb-performance
  190. Distributor fault
  191. ECU troubles (CEL code 16)...
  192. H23A vtec dizzy problem
  193. vibration on accell. with sh conversion
  194. Intakes??????
  195. Suspension Help.
  196. clutch issue
  197. 94 Prelude Si electrical experts please help!!!
  198. Caliper Paint Question.
  199. H22A Swap Problems!!
  200. h22a4 rebuild
  201. Where the funk...
  202. 37820-P13-000 JDM or USDM?
  203. h22a adjusting cams: need help ASAP
  204. Car not starting: compression, spark, and fuel is good...what next?
  205. Crank angle sensor fault
  206. Type S pistons
  207. burning oil
  208. Help: 5th gen. No dash lights or tail lights.
  209. hondata s300 question help please.
  210. anyone using E85 in a h22?
  211. What do you do to make the most HP out of SMSP header?
  212. torque specs?
  213. 93 prelude with jdm h22...stupid ass knock sensor
  214. 92 prelude, sunroof, not working
  215. Suspension Question
  216. Rim Paint or powdercoat?
  217. Street Keys? Locksmith reflashing ECU?
  218. Mfactory Final Drive Pro or regular ?
  219. B20A5 v-tech
  220. Clutch Petal Sticks to the floor randomly???
  221. Engine cranks, but won't start
  222. Euro R IM with 70mm TB
  223. Tow Hook
  224. Troubles with 1990 Prelude.
  225. Interior Leaks
  226. best ems for ur dollar.
  227. Oil Pump different between OBD1 and OBD2 engines ?
  228. g23 piston deck clearance question?
  229. My 450hp 6th gen accord
  230. How do I check my ABS?
  231. Crank pulley and ps question
  232. 92 Prelude w/ 97 h22 swap
  233. Will this work
  234. 4th gen vs 5th gen catback exhaust???
  235. Technical Information and Data on FRM
  236. can anyone what color lip this is....
  237. Distributor Parts swapping. TD42U(95civic ex) to TD60U(JDM H22A)
  238. 92-96 PRELUDE CLUTCH LINES.
  239. wondering how much power my motor can handle?
  240. TD60U Internal Coil resistance
  241. Immobilizer Key Question?
  242. Sh to base conversion plates!!!
  243. how to take off a 5th gean door panel
  244. 92-96 prelude and 97-01 lude
  245. i need to find a stock cam for a f22a1
  246. Lude wont stay running upon start
  247. ABS is acting up
  248. Engine bay shave thread
  249. pic request for prelude with gt3s
  250. are these springs good?
