PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 [301] 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Selling an H23a
  2. Need a 97' milano red front bumper
  3. prelude and LSD???
  4. need automatic ECU and Automatic TCU
  5. FI for 5th Gen Sportshift ??
  6. 5th Gen with NOS , Turbo , or JRSC ??
  7. Timing belt issues!
  8. quaife installtion ?s
  9. finally.i got a ticket!
  10. What Do I need to swap in a H22A4?
  11. F22 in a S model Prelude to H23 how to.
  12. Fixed my surging idle!!!
  13. black widow kit
  14. Need a new clutch! Help me iz-out :)
  15. brake noise... replaced everything won't go away.
  16. Some H22 info??
  17. Compression test #'s okay?
  18. Which NGK's
  19. Need some figures (already searched)
  20. JUN header for sale
  21. NR gauge?
  22. SVT 4door?!
  23. TSB: Engine - Flapping Noise Between 1,800 & 2,600 RPM
  24. thinkin of getting a prelude, couple questions
  25. Those with 2.5 inch diameter exhaust systems, what muffler you guys using?
  26. Tein HA's the same for Prelude/Accord???
  27. any one got an extra h23 crank?
  28. Clutch Disc recommendations for H22A?
  29. Question for PO.com members
  30. who else is takin their lude to nopi?
  31. Convert a H23to H23 with V-Tec
  32. h23 vtec oil jet clearance problem...
  33. need help.. hit a divider
  34. Flooded roads, H&R race springs, and an H22
  35. Hi everyone, new member here
  36. H23 crank in H22 ????
  37. S15 or S14 Headlight Conversion?
  38. does 4x114.3 rota slipstream out yet?
  39. Post pics. of clean 97 or newer preludes.
  40. Looking for a ECU for a 2001 H22
  41. best place to buy kosei k1's?
  42. Court and Honda Canada (long)
  43. Camber kit needed?
  44. August Limited Time Specials!!!
  45. Prelude SR-V?
  46. Springs vs. Coilovers??
  47. CAI .... what are your opinions?
  48. Will Accord Springs fit the preludes (93 accord onto 94 Lude)
  49. how hard is it to install a clutch?
  50. 14.15 @ 99 mph in my lude with bolt ons!
  51. Anybody need a prelude?
  52. How do you remove the hub?
  53. some H22 info PLZ!!!!
  54. Cold engine problems!
  55. B20A5 engine vs. B21A3
  56. How much power loss when A/C on?
  57. Check out my Lude and tell me what you think
  58. FS: '92 Prelude Si
  59. anyone want my JDM pistons/ rods?
  60. JDM Headlight install
  61. turboed, 99 prelude need NGK spark plug # for 1 step colder
  62. What is your take on racing other Preludes?
  63. need to know about dust shields
  64. Prelude Q's and A's
  65. Help! Car ran hot and now idle is off
  66. immobilizer
  67. Dam co-worker smashed my car (BAD)
  68. ecu identification???????
  69. Removing spindle nut - which direction?
  70. need a cheap lude in Fl?
  71. No responce at all from my engine. HELP!!!
  72. Still plagued by idle problem :(
  73. oil on timing belt, headgasket not sealing properly.....
  74. cool ass luder
  75. cheap place to buy Green Stuff brake pads?
  76. PP head and Head gasket question!
  77. a friend got a lude
  78. skunk2 intake manifold
  79. Where can I find touch up paint for a white diamond lude? (non-dealer)
  80. WTB OBD II Prelude Parts
  81. Finally had some time to take pics (GE sleeve 90mm and build up)
  82. A few Questions???
  83. AHhhhhhhhh! I just bought 2 Preludes Today! A few Questions.
  84. what is the lowest weight reduce on the 4gen lude that you see???
  85. prelude S to h22a help! read please...
  86. plugs cover
  87. UR Crank Pulley
  88. newbie question about brakes
  89. 1990 prelude project car???
  90. selling: Spoiler off '91 red Prelude Si
  91. Removing Hub on a 4th gen
  92. WTB: Stock 97-01 Prelude muffler
  93. FS 2000 lude
  94. Hey Chris, what is the deal with HP.com???
  95. need piston/rod help for my h23a1
  96. What is the cause of a busted crank pulley?!
  97. is it normal for coilovers to...
  98. Spoon tower bars for 5G Prelude
  99. Oppps Cooked H22A5 rebuild time?
  100. Twin Trac LSD unit?
  101. need a complete pinout of my ecu, anyone have one?
  102. motor swap question
  103. QUESTION FOR turbo ludes!!
  104. Broken Wheel Studs
  105. Rod Knock, Vavle Tap, WTF?
  106. a/f ration gauge
  107. Engine swap.
  108. instaling springs and shocks
  109. oversized valves and stock springs and ret?
  110. Tranny Code M2U4
  111. ECU Swap, OBDII to OBDI, Different Injectors yadda yadda yadda
  112. Taking my '97 Prelude into a Honda Dealer for a Diagnostic ;/
  113. EXEDY clutch installed...
  114. Dead Lude
  115. MUGEN rear spoiler for 4gen lude....
  116. about the new prelude?????
  117. itr wheels on 97-01 prelude???
  118. 99 Prelude Buying Question base vs SH
  119. why does the spoon s2000 run cross drilled rotors up front instead of slotted
  120. Parting out 2 88 Preludes.
  121. stage 3 crower cams
  122. Is this legal???
  123. camber kit question
  124. Best Valve springs for H-series?
  125. couple questions (fi) (wheel bearings)
  126. Who has removed their power steering and AC?
  127. worn bearings
  128. Frustrated with the 3rd gen
  129. Buddy of mine is gettin a 93 Si
  130. Prelude HP ratings
  131. WTB Prelude VTEC Tranny
  132. Rust on oil pan
  133. New pics
  134. ECU / Piggyback for soon to be turbo'ed '98 SH
  135. 92 Si's jumping idle
  136. how loud is the Greddy SP on 5 gen preludes??
  137. Carbon fiber front lip...
  138. Jun front end...
  139. 3rd Gen Auto Transmission
  140. Window Tint on my ebp....
  141. WTB H23 tranny !!! LOCAL SO. CAL ONLY
  142. Portmatch intake manifold in one day?
  143. Will this oil do?
  144. I need some real help with my suspension
  145. H23 with H22 Head
  146. prelude ECU codes...help please
  147. All MidWest Luders must visit our Chicagoland Prelude Club website...
  148. h22a sawo in 89 SI
  149. WTB:92-96 Prelude injectors
  150. Which Ignition Wires?
  151. shift boot ripped :(
  152. Aftermarket Sites
  153. Canadian prelude for sale, would you buy it from USA ?
  154. 2001 Prelude - Where is the ODB-II connection port?
  155. Venom 400?
  156. JDM Manifold and Stock Exhaust on H22
  157. Ignorance is blessed....
  158. Type R Hosted Chicagoland BBQ - All Are Welcome~@!~!~!
  159. problem with sparkplug wire boot!
  160. Accord Type R Intake Manifold
  161. **perfect 4 you turbo ludes **
  162. Wheel question
  163. H22A Lude Question..??
  164. 2 questions. 1.turboing, 2. SH or no..
  165. timeracer and illusion
  166. Could someone please regulate!!!
  167. selling f22 engine and trans
  168. I need a definite answer...17 x 8 rims...what offset???
  169. I am disappointed in AEM.
  170. other prelude-specific web boards??
  171. Volk Te-37's for sale
  172. Newbie NO2???'s for NO2 Know it all!!!
  173. Please post pics of bottle mount and gauges for NO2
  174. Spark Plugs, Wires, Cap/Rotor and Fuel Filter: OEM or aftermarket?
  175. Question on wheels
  176. engine codes.
  177. Car Show in The Dalles, OR
  178. Is this more feasible than I think?
  179. Got some goodies in at the shop yesterday!!
  180. attn: FAH Q
  181. Seat Brackets.
  182. kamikaze header
  183. Best Coil-Overs and spings set
  184. any one familar w/ "L'Natural"'s setup? turbo desial sleeves!?
  185. Looking for a 5th GEN rear bumper
  186. Need Info on this ECU
  187. N1 exhaust and oem rear lip problem
  188. Which front lip should I get for my 5G?
  189. What is the best start and so on for going n/a?
  190. How much higher will my car sit with 18's?
  191. Wheel sizes for a 96 Vtec & hp.com
  192. 97 prelude sh bogging...help
  193. Head work?
  194. Whoa buddy...no more posting on PO.com until you pay up
  195. FS: 5th gen JDM Fog Lights
  196. HondaPrelude.com FUNDS
  197. Grinding 5th gear
  198. JDM Engine Differences?
  199. OH NO!!!!! hondaprelude.com is gone!!!
  200. Timing Belt one tooth off?
  201. Preludes Vs. Integras!!!
  202. EXEDY clutch ............
  203. ? for stock camgears..
  204. Timing belt problems...
  205. MOMO HUB adapter question, Help
  206. lights out???
  207. Does anyone know what's going on with the Drag 4 kit for the 5th gen?
  208. skyline?
  209. Help replacing wheel bearing
  210. Lightweight Flywheel is in, now how do i check my ignition timing????
  211. Anyone fitted Type-S intake pipe to 4th gen?
  212. WTB: Stock Radio for 4th Gen PRELUDE
  213. lightwieght or ultra light flywheel for h22?
  214. Water Disappearing and Engine Light
  215. Chicagoland BBQ
  216. Has Anyone Ever Had a Problem with Cam Gears?
  217. Integra vs Prelude...but not the usual reasons
  218. need some info on sleeved blocks!
  219. N1 Exhaust or HKS Super Drager?
  220. Which map sensor do i use???
  221. boost or all motor h22?
  222. Bad O2 senser ?
  223. honda shifter headaches
  224. What happens when too much motor oil is in your car?
  225. "Adjustable" Cam Gears
  226. This years club name for NOPI is......
  227. Bigger rims?
  228. VAFC install
  229. What is the Best Exhaust for a Prelude?
  230. Import Eurasia oct 12th garden state nj
  231. MSD or Crane
  232. Ok, is our Lower Front Balljoints replaceable?
  233. 89 Prelude 2.0si.....
  234. went to the track agen..
  235. just got back from the track
  236. 98 jdm h22a??
  237. Replacing alternator tomorrow..i just have a couple questions.
  238. Engine dying?...
  239. Hub centric and ROTAs
  240. removing lower control arm bolts on a 3rd gen?
  241. gauge cluster is out
  242. Prelude got wrecked :( Have a question about VIS Invader style CF hood......
  243. this my not be appropriate but...
  244. My Future Turbo Setup
  245. tranny's
  246. Very easy/retarded question (please help I'm a newb :)
  247. '97 Prelude Tiptronic Transmission problem :(
  248. Does anyone have the Gude package on their 3g prelude?
  249. Timing belt replacement question
  250. turbo and oversized valves
