PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 [211] 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. searched the posts and found something odd about factory headers
  2. why everbody hatin on dc and aem
  3. zex spark plugs
  4. Steering wheel not straight
  5. 4G H22A block
  6. Alphawerks header for 5th gen (searched!)
  7. Occasional stall going into neutral
  8. jdm distributor???
  9. official h22 tranny thread
  10. where to use floor jack?
  11. header issue
  12. Inform Me
  13. H22a1 seals
  14. Question about my Tokico Illuminas
  15. Newbie!! H22A1 question
  16. Import Palace questions?
  17. 2000 PRELUDE ECU
  18. H22 dyno sheet
  19. How do i replace the vehicle speed sensor onmy 94 vtec prelude?
  20. Raising Prelude for the Winter?
  21. H22 and transmission
  22. Another fully built h23a is done.... thanks A\V Engineering!
  23. h22a workshop manual?
  24. dohc-fi
  25. OBX intake manifold?
  26. Venom 400
  27. im confused on the diffrent motors
  28. maintenence required light
  29. Whats this luse worth?
  30. IACV SWAP
  31. DOES ANYBODY HERE HAVE SKUNK2 STAGE 1 CAMS ON THERE LUDE??
  32. good deal or bad deal
  33. Brake shims
  34. Reverse not working!!!
  35. Speed Sensor 1990 Prelude Si
  36. painted 4th gen si rimz
  37. aem brake pads
  38. Has anybody ever had valve problems before?
  39. How to: Wire in Vtec
  40. .::|WANTED ONLY|::.
  41. Will a 5th gen Type SH exhaust fit a non SH?
  42. Original brake pads
  43. Exactly how loud is a v2 cai ?
  44. vss connector location?
  45. 3 different problems, just requesting some assistance.
  46. black box under the manifold???
  47. Question for anyone with AGXs on 5th gen
  48. help on sensors on head
  49. Engine Bogging - GETTING TO THE SOURCE OF MY PROBLEM?
  50. 99 prelude front lip
  51. Stock Taillight tinting
  52. will crower stage 3 cams work fine with my type s pistons?
  53. Are 225-50-15 BFG Comp T/A Drag Radials too much for my 4G VTEC?
  54. NASA HPDE @ Limerock Nov. 8
  55. Looping the power steering lines?
  56. dc sport header, creamic or polished?
  57. tranny question for PRELUDE owners
  58. Just got an 87 lude, need some help with ideas
  59. '92 Si running like crap, after bolt-ons removed...
  60. Hail Damage
  61. Frustrations of electrical gremlins -and- truth is stranger than fiction
  62. H22A thin head gasket
  63. Building h22 all motor what is a good setup
  64. Inline Pro Head Gasket
  65. anyone know where i can get a 99 prelude repair manual
  66. Please help. 1992 2.2 exhaust fit 1995 2.0i??
  67. greddy profec b spec II w/greddy turbo kit....??
  68. No v-tec engagement, and redline is at 6800
  69. Hearing a metal clunking sound???? help
  70. Quick question about gasket between 4-2-1 header
  71. h22 trans fluid leak
  72. Does any one have a tanabe ultra medallion
  73. Cel codes/resetting ecu
  74. H-series engine swap into 3rd gen Prelude Si
  75. Problem after changing Pads/Rotors
  76. H22a wiring
  77. exhaust done search want specifics answered
  78. Well, it's official!! I am finally VTAK'ed.
  79. lude in Baltimore
  80. Prelude Exhaust?
  81. OBD2 to OBD1 : which ecu ?
  82. New CV joints or alternative
  83. How the hell does this happen????
  84. camber kits
  85. 91 lude engine rebuild
  86. prelude radiator options???
  87. AEM pulley installation.
  88. Anyone running H23 block w/H22 crank & head?
  89. size of type s intake piping
  90. Thicker Oil
  91. Jum cams on order, what kind of valves should I get?
  92. H22a4 Cp Pistons on Stock Sleeve
  93. need belt help
  94. ~~~ DOOR WON'T OPEN ~~~
  95. good-fitting aftermarket hood?
  96. what could be the problem
  97. I Need your feedback
  98. Installed Headlight now car wont start...WTF?
  99. vss question
  100. Technical Question... Auto vs Manual??
  101. Cracked Oil pan replaced, lifted the car back up a little. what a day! (lots of pics)
  102. h22a euro r swap question ?n for a 1992 4th gen lude
  103. S mode 89 lude
  104. Coolant lines
  105. full custom exhaust with apexi n1
  106. why am i still a damn trial user?
  107. apexi exhaust
  108. CEL Code 9 - CYP Sensor - what is this?
  109. My speedometer for my H23 in an EG Civic isn't working
  110. regular oil to synthetic?????
  111. How can I take my dash board window out as i need to change the check engine light bulb?
  112. What si the best prelude front end? Lip or full bumper cover?
  113. vss accessiblity
  114. HPOA Site
  115. Exhaust cam retard
  116. MAJOR starting problems
  117. 89 Lude SI Runs for 15 to 20 sec. Then dies.
  118. pistons
  119. strut bar for 4ws
  120. Is this is a good price for a 97-01 prelude oem lip $120
  121. Prelude using oil
  122. Went to the Track for the first time in my Newly Accquired 95 Prelude VTEC!
  123. weird vibrations
  124. effects of lightweight flywheel and racing clutch on daily driving???
  125. replaced clutch wont go in gear
  126. First trip to the track
  127. how much horsepower do the Individual Throttle Bodys give?
  128. my car is shaking like fu*k
  129. need help: clutch question
  130. Problem running one oxygen sensor!
  131. Brake sticking
  132. bad tps or what
  133. H22 recommended oil?
  134. Short throw shifter for 89 Prelude?
  135. Projector HID for 97-01 Prelude???
  136. 98 prelude base, check engine light. need help please.
  137. h22 transmission fluid
  138. meGan strut tower bar Review
  139. Anyone converted their 4ws to non-4ws?
  140. h22a4 crank pulley wobbles at idle.
  141. Piston Upgrade
  142. 205x50x16...is this ok....?
  143. Rota Slips 4-$ale
  144. Power window wont roll up, help please!
  145. Quick help onmy rear brakes
  146. JDM rods and pistons for sale!!!
  147. DSM H22 Setup?
  148. vtec solenoid?
  149. WTB: 5th gen. OEM front lip kit
  150. just called crower...h23 cams
  151. NEED ATTS HELP
  152. balance shaft alignment or removal
  153. VSS problemo
  154. kms egr blocker plate
  155. asimo in atlanta
  156. H22 install: Tips on how to get the bolt back into the rear engine mount??
  157. Ecu for 99 prelude sh
  158. looking for 5th gen. Any problems i should look for?
  159. Prelude Clutch Cable or Hydraulic
  160. Ease of changing synchro
  161. Quick Clutch Question
  162. Engine noise at lower RPM's
  163. Any good forged rod and piston packages for h22 engine?
  164. Alaniz streetmaster port job
  165. do they make projector headlights w/ lights that are adjustable?
  166. Red key...5th gen
  167. removing 91 doorpanels?
  168. H22 Euro R swap
  169. aem fpr install on an h23 lude, fitment probs
  170. What is your Oil Pressure
  171. abs light keeps popping up
  172. hard to start
  173. I am doing my H22A swap over the weekend and I have some questions
  174. Honda changed out my autotensioner...
  175. NO OIL PRESSURE
  176. how to adjust 5th gen prelude headlights (with hid's)
  177. car runs like shit after i put back in the p13 jdm ecu?
  178. SELLING MY HONDA PRELUDE!!!!!!!
  179. Fuel pump issue
  180. 89 si starting problems
  181. replacing pistons
  182. projectors headlights on 97-01 ludes....?
  183. What could this noise be?
  184. oe 94 vtec cooling fan inop
  185. Painiting the inside of the headlight
  186. Rear Lower Tie Bar 5th gen
  187. is this a good combo??
  188. ITB
  189. idel problem
  190. camshafts at TDC
  191. skunk2 products
  192. JDM p13 Codes?
  193. h22 accord v. gsr
  194. H22 Secondary runner question
  195. Update on the JRSC
  196. Air Intake Mods for 91 SI
  197. Technique for torquing camshaft pulley bolt.
  198. Bad front or rear main seal?!?!?!
  199. Skipping gears
  200. Rich Oil
  201. h22a7 accord type-r motor? or build one?
  202. problems
  203. clutch pressure problem
  204. brake lights
  205. Whats the cheapest way to stroke an H22 ?
  206. building the bottom end
  207. Check Engine Light / ABS Light
  208. does anyone know the redline of the jdm prelude type s engine?
  209. Another FI question
  210. im building a turbo kit from strach need help
  211. Forbidden Short Shifter - AWESOME!!!!
  212. Water gushing out of RAD cap
  213. h22 sputtering at low rpm
  214. Question...
  215. what is this sensor on the right of my intake manifold??
  216. Witch bearings???????
  217. Its time to Rebuild
  218. Anyone in SOUTH JERSEY nice enough to swap out there ecu for a cpuple minutes to see if mine is work
  219. where can i buy a built h22 head?
  220. where can i send my H22 Vtec head?
  221. Need a price estimate on my car
  222. SH wheel hop problem?
  223. H22 problems Need Help
  224. alright.. o2 sensor CEL43 question for you guys
  225. Valve troubles for a 00' Honda Prelude SH
  226. buying prelude, good deal?
  227. need help with a tranny code
  228. 1st time removing tranny, are these necessary items?
  229. Knocking
  230. Rear sway bar on a 4th gen.. Good purchase?
  231. How hard is it to install a spoon power chip?
  232. i got a question
  233. Timing belt help
  234. H22 Vacuum routing?
  235. optimal shift point???
  236. Will Accord IACV fit on an H22?
  237. orlando ..................
  238. 97+ Rear Rotors
  239. How much to Knife edge a crank
  240. skunk 2 intake manifold for 5th gen SH??
  241. USDM p13 chip program recommendations PLEASE!!!!!!!!!!
  242. question on iginition kits
  243. Another H-series head / F-series block motor RUNS
  244. How to build higher compression?
  245. Prelude Offset & Aftermarket Rims
  246. "How to..." -> ebrake swap 1995 -> 1992
  247. 5th Gen Blue Tailights???
  248. JDM H23A DOHC VTEC dyno with I/H/E only...
  249. DC header interchangeability
  250. rear toe adjuster
