View Full Version : Honda Prelude
- need help with injectors!!!
- Hi Everyone
- removing head unit??
- Exhaust?
- How long do new springs take to get the full drop?
- rebuilt engine
- Headers for H23 ? Apart from DC
- Needed: 97+ Prelude PS Bracket
- Prelude parts...Exhaust, Wheels and tires.
- clutch questions
- h23 tranny
- Tires
- problems with heater/ a/c unit
- still having clutch problems
- individual throttle bodies / skunk 2 stage 2 cams
- spl with a 4th gen lude
- i need help buying a 97-01 prelude......
- 93 Cluster Lights (and tail lights) out...Is it the Dimmer Relay?
- need clutch help, shift fork will not disengage
- Well I kinda wrecked the lude errrrghhhhhhhh. I need bumper,cf hood, and passenger headlight.
- question for apexi N1 owners
- Compression suggests some internal modification?
- h22 in hatch!!
- Hondas Warranty on the OEM exhaust question
- grounding kits for prelude
- 88-91 prelude wheels (blades)
- how do you adjust the tach on the EL gauges??????
- i was wondering???
- Best plug for turbo H23?
- 4th gen vtec colors
- s2000 wheels on a 5th gen?
- friends don't let friends buy neon ground effects, and install it themselves:
- ARP Head Studs & Rod Bolts?
- URGENT! left side of ride just dropped and is slammed to ground..
- N/A Help...
- distributor cap?
- H22A and boost
- question about 'jap spec' engines
- clutch plate question?
- what is this button?
- window pops off track
- H22 type S cams for sale
- H22 INJECTOR ?
- Question: Is it dangerous to take the cover off the exhaust manifold?
- Its about TIME! many pics
- racing conditions
- Dyno results
- Bolt Rounded. How do I get the seats out?
- Jdm H22a specs?
- were does it go?
- Someone with EX: or some Knowledge help please
- ok.. prelude turbo people need some help
- auto tranny problems =[
- Ok...tried searching. Who has detailed knowlege of SH to Base tranny swap
- Possible to remove the block girdle with engine in the car?
- went to California Speedway; 1/4 mile track
- Throttle noise...
- tweets
- pic request. h22a closed deck w/darton sleeves
- Jdm H22 ECU conversion
- prelude cv axles
- egr code
- just replaced both axles and they click when turning.....?
- The 212hp all-motor H22 beast is no more...
- h22 or h23 prelude short shifter
- balancer shaft question
- Moroso distributor... worth the money?
- Engine nosie with VAFC
- fly wheel
- Oil Change difficulty.
- h22 and f22 intake
- vacuum nipple on top of throttle body
- A/F problem
- 1989 prelude tail lights
- H22 Idle probs (already searched)
- will a steering wheel hub for a 5th gen fit on a 4th gen vtec?
- JRSC NOT WORKING!
- Integra Type R ECU w/ H22A1 - any power gains?
- Where to find a USDM H22 swap.
- what's this noise coming from my brakes?
- Exhaust pics
- Anyone just have an AEM alternator pulley to sell??
- injen shortram installation
- PetroGuy's Alarm Install additions and questions.
- I need fifth gen OEM wheels ASAP!!!
- What tranny do i have?
- how to get the cd player code for my lude without goin to the dealer??...please help!
- f22 h22 engine swap 96 prelude S
- tein's flex's on 5gen lude
- hood
- "Borrowing" a Prelude for a couple years :)
- is it just me or.....
- Wheel Stud Replacementl 92 Prelude, Easy Way
- totalled car...what do i do now?
- Im looking into how much am i gonna spend turbo wise
- HELP...bearing question
- GOT HIT CANT STEAR
- how do you remove the a-pillar?
- 92-96 wheel offset....4 by _____
- shortshifter adapter questions.???
- Valve Cover install: H23
- People who went from H23 to H22 I need your help!!!
- xenon kit 7000k or 8000k?
- Looking for H22A1 ECU
- Problem: Friends 2nd gear not working
- Question on model
- type s cams help
- wtb: h23 stock motor parts due to almost blown engine
- Lowering Springs or Coilovers? advice please
- Air Intake opinions... plz help.
- need help!
- Prelude Type S Tranny
- HID's with the JDM 1 piece black headlights
- Please help with install..............
- Suggestions on back bumper?
- How long should it take to uninstall and reinstall OEM shocks/springs??
- will 16x8 wheels fit the rear of my car?
- Which is faster Lude or RSX type S?
- 5th Gen Prelude 1/24 Scale Model
- Prelude OBD1 Vtec Distributor??????
- Keep my current set-up or sell it and get a prelude? Advice?
- removed stock spoiler...HOLES!!!
- H22 BS belt
- How reliable is ATTS?
- Help!!!
- New H22 Running, But Won't Give Me Any Grunt
- ATTS light problem
- Is this a JDM or USDM P13?
- *posted with permission* Parting out red 4th gen - JE, AEM EMS, SFP, OEM
- itr seats!!in preludes??
- h22a 4th gen
- love fab mani
- Still got unanswered ?'s after searching?
- Sport Shift common problems???????????????????????????????????
- bumper painting
- what's a good tire size for 18's?
- need jdm p13 help ASAP!
- Need some information from you prelude guys. Thanks
- Prelude Front Brake Pads
- Beware this Ebayer
- what's better
- FS: AEM H22 camgears...was sold, but lost username please respond.
- Mixing head parts!
- what is code 21?
- any other 2g lude guys?
- anyone running skunk2 cams on h22a?
- Just did an H22 Swap......questions
- 93 Prelude stuff, REally for sale this time.
- SMSP Header...any info from recent buyers?
- Edelbrock Performer X Intake Manifold
- rims
- Help! Idle issues
- JDM H22 ?'s
- Possible 4th gen pillar pod....
- I smell new Turbo mani's for H22 AND H23 cooking:)
- Losing power w/ vafc vs stock
- JDM climate controls
- Question for those with GC/Koni
- H22 into 3rd gen 'lude
- Mugen Question..
- Turn signal lever on 5th gen
- Head swap: which head gasket to use?
- Not for sale but wondering what a boosted 4th gen is worth?
- Type R block GSR crankshaft
- h22 wiring diagram
- how do i know if i have bent valves?
- 97+ Vtec Head on 92-95 closed deck bolck?????
- Wheels question
- Qick CAI question... HELP!!!
- help takeing off stickers?????
- AEM fuel pressure regulator on stock rail
- curious what size piping is good to convert my exhaust too?
- 5th gear grind?
- Things to think about when pulling motor
- where does this black box under intake go?
- I went to an autoX Sat 8/23 and lost to a...
- 5th gen SH exhaust and 94 SR-V
- okay now its buggin me o2 sensor related and car condition.
- Where can I can the cheapest prices on stock Prelude pistons/rings?
- complete h23 to h22 swap
- BB1 prelude sway bar questions.....
- FS: 11.8 lb millenia wheels 5x114.5
- good price on a aem cai?
- went to the track
- Borbet Type E wheels
- Flywheel bolts
- Please tell me where this ground cable goes!!! 5th gen
- H23 Cams and Gears for sale...40k miles
- 1995 honda prelude turbo?
- JDM Brake Question
- How to remove the rear center console on 92-96 Prelude?
- prelude clutch problems PLEASE HELP!!!!
- laying 3" piping...ahaha
- Nitrous H22a question...(moved from FI forum) =[
- What is the difference beetween P13 2W and P13 4W ecu?
- 3g Prelude h22
- brand new AGX for sale
- h22 tdc?
- SH vs Base model suspension.
- cf hoods
- Looking for 92-96 Jdm Headlights
- 2 wheel locks on one wheel a problem?
- Beefy Automatics out there?
- Prelude Third Brake Light
- h23 for sale!!
- is it my pressure plate or clutch master cylinder
- I got hit HEAD ON !!
- Ignition Problems, can doesnt start/has problems starting
- Finally joined the Prelude club :)
- JDM One'ers
- indiglo gauges help please
- 5g front calipers...
- More realiable Fully built H22 or H23VTEC?
- will s2k steering wheels and seats fit in preludes
- Power door locks
- Bumper Removal
- brake light on and off offen.
- Vtec works but won't rev past 6500rpm
- turbo manifold
- leaking oil.......boost gurus please help
- replacing stock shift knob/boot (96 prelude)
- 92-96 prelude mugen front bumper...where to find?
- VAFC for turbo?
- Is there really a prelude siR?
- prelude swap for dummies
- race starts
- prelude rear upper strut (gen.4)
- h22 clutch not enough pressure
- Looking for 4th gen EL Gauges
- Schematic of wires to be jumped to show codes.
- shims under the differential?
- PLEASE HELP
- Newbie prelude question
- can't get over 6500
- DVD in Prelude??
- f-max turbo, What can be tuned?
- anyone know torque specs for brake caliper screws?(5th gen)
- need help in wiring up egr for my eg(smogging)
- headlight install
- Check Engine light just came on!?
- Strait Pipes... no exhaust?
- attn: guy with weisco pistons on stock sleeves
- JDM H22A dyno plots
- 5th Gen Parts for sale or trade
- Prelude Modifiers?
- Semi OT: Please help a national road racer out....
- ARP Headstuds?
- torque specs for the valvecover bolts. help!!
- my prelude sucks i need a vtec for it
- 4th Gen Clutch Master Cylinder Swap
