PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 [119] 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Can I...?
  2. Problem After H22 Sawp - Tranny Issue
  3. 99 Prelude, switched to obd1 but have no immobilizer key *no start*
  4. Need a tranny Exploded view
  5. Can somebody help me find an exhaust extension for Twinloop...
  6. h23 how much can i boost
  7. ***Some Good News***
  8. Lean or Rich?
  9. steering wheel shaking
  10. oil overfilled!!
  11. Timing belt in h22a1 loose
  12. 2000 relude losing oil?
  13. Any lude owners driven an R
  14. Honda Dealer Claims I have a bent Valve
  15. 99 base prelude shutting off while driving searched need help not a noob.
  16. H23, H22 head install
  17. darton "big bore" for h23
  18. Change lever bushing (plastic cube) Short Shifter install question
  19. fan question
  20. H22a vtec rebuild
  21. Anyone tried the TopFuel Power Chamber?
  22. NEWB Question
  23. is this the ground wire that goe to the thermostat h22a1?
  24. how much do you think this is worth?
  25. Walbro fuel pump benefits ?
  26. Taking IM off ?
  27. HELP!! cant figure out a/f gauge
  28. "antenna" wire
  29. Bumper install
  30. HELP!!!!! What usdm car do I use to get parts for a jdm f20a????????
  31. Which is the correct ECU for my car? H22a
  32. Tranny problem after rebuild
  33. ported Euro R IM expected numbers
  34. would a bad ICM or dizzy parts hrow a CEL?
  35. P29 ECU is it V-tec or not
  36. BBBB block, oversize or standard?
  37. (Searched) Power Lock Install..
  38. do i need a new temp sensor or could it be installed wrong or a bad ground?
  39. slow oil leak between head and block? what could cause this?
  40. Transmission Swap 5th Gen to 4th Gen Auto
  41. Will a stock SH exhaust fit on a base prelude?
  42. methanol injection
  43. help with getting more hp n trq w/ F20A
  44. i need bigger injectors when i install my turbo on my F22
  45. Battery Drains Over Night
  46. 92 SI 4WS cranking question
  47. Taking off stock headers on a 5th Gen
  48. F22A1 vs F23A5
  49. Crank pulley issues !!
  50. H22x EUDM Vs USDM vs JDM
  51. 4th Gen Lude suspension reassembly
  52. question about camber kit
  53. iab
  54. H22 crank pulley help!!!!
  55. H22 Build Q&A's
  56. write-up request - Throwout, pilot, and input shaft bearing replacement
  57. ?boosting f20a dohc
  58. California 5th gen owners
  59. alignment problem after drop my car
  60. TB coolant bypass idle issue
  61. f20A
  62. Tein,d2,tunabe, buddy club complete coilovers
  63. Coolant Lines reroute TB
  64. There is a god that performs miracles!!!!
  65. Tranny clicking.... need some input....
  66. changing gears in high revs with cai sounds like i have a bov
  67. Misfiring issues
  68. How do i rotate to TDC with camshafts off
  69. compleate engine swap ideas
  70. h22 h23 thottle body
  71. Brake lights don't work!
  72. Map Sensor wires? What wires go to where? searched.
  73. NGK Powerdex AFX Air-Fuel Ratio Monitor Kit
  74. Ground Control going on today
  75. Scraping sound engaging 1st gear
  76. DIY 4th Gen Supplied Kneeling Pads for Working on your Ride
  77. HVAC (vent) selector doesn't work
  78. idling problem
  79. O2 problem, CEL light is on
  80. trying to turbo my prelude need advice
  81. anyone have a traction bar on a bb6
  82. vacuums
  83. Starting the car first time of the day...Got a question...
  84. Type S intake
  85. Need help with my Sp manifold & alternator!!!!!!!!!!!!!!!
  86. Brainstorm ideas as to why I wont start....
  87. 95 Si 2.3 Engine Swap
  88. fidenza flywheel have timing marks??
  89. car is acting up intermittently, stalls, hesitates, jumpy tach. ICM problem?
  90. Help (searched) Resistor box install in 92-95 civic With H22
  91. transmission swap!!
  92. no vtec, how do i test VSS.
  93. Regreasing Dust Boots on Upper Control Arms
  94. 86 Prelude Engine Swap
  95. 97 Prelude Engine swap
  96. ATTS drain plug
  97. Will an F22a1 header fit on a H22a1?
  98. Another Problem with my lude...:(
  99. Unorthodox Alternator pulley
  100. spark plug wires?
  101. 94 Tune-up
  102. 1992 honda prelude 2.3 si oxygen sensor wiring diagram
  103. MADCITYLUDE - Thanks you all
  104. FRM honing specs
  105. F22/H22 pistons
  106. Broken Piece from H22 tranny. PLEASE IDENTIFY!!
  107. !Low on Cash. Going in for a timing belt fix but got some questions!
  108. 93 Prelude fan problems. Help me out please!
  109. mahle pistons
  110. oil leak need help
  111. DIY: Replacing Cam Plug
  112. need help v-tec not working
  113. Headlight issues
  114. WILL THE EXHAUST MANIFOLD FROM A H23 FIT IN THE H22A vtec SWAP
  115. Differences in USDM ATTS ECU and JDM TYPE-S ATTS ECU
  116. prelude wont start
  117. V-Tec Head?
  118. type s cams... what good do they do?
  119. 4Gen Rear Driver Side Spindle (bearring is gone)
  120. 98 Prelude smoking on WOT? help me
  121. clutch kit
  122. Radio Code
  123. h22 v-tec
  124. prelude relay swith
  125. prelude steering wheel in an accord?
  126. Engine check light came up!
  127. Fuel Pressure For H22 Build?
  128. CAI for a 5th gen base fit on a 4th gen?
  129. Tein S-tech on 4gen
  130. Prelude Strut questions
  131. h22 vtec
  132. prelude struts
  133. OEM prelude parts
  134. code 8, TDC sensor...
  135. how do you effectively check the wear of the timing belt?
  136. VTEC PROBLEMS (YES I SEARCHED)
  137. Type S cams ?
  138. WheelGuyz.com?
  139. car cut off again...
  140. So one of my cams was off 1 tooth
  141. Help with Driver side Window Replacement
  142. Model ?
  143. lude does't want to shift, help plz
  144. cel but no code, 5th gen p72
  145. engine swap questions<searched>
  146. euro r intake manifold
  147. Silly Question Will GSR Leather Fit into 4th Gen Prelude, and how about Type S 5gen Leather into 4th
  148. ecu chip question
  149. Noob Question: JDM foglight switch? (searched)
  150. h22 pulley question
  151. should i buy this prelude? 90' SI
  152. 4th gen h22a coil compatibility
  153. Bad Main Relay?
  154. JDM Distributor
  155. O2 - Oxygen Sensor why is mine different?
  156. 97 Prelude Shuts off Completely while driving.
  157. 1983 parts
  158. switching to 5 bolt... broken wheels studs again...
  159. i think i busted up my shift cable
  160. Buying new motor?? Where???
  161. Why wont this light up?
  162. What Transmission do u prefer?
  163. H22a swap issues
  164. Removing the EGR valve
  165. Anyone know of a source for new OEM floor mats for a 5th gen?
  166. bumps dont feel like bumps....more like hitting curbs
  167. f22b block
  168. Prelude motor for turbo
  169. Struts/Shocks ?
  170. Fan override for our cars?
  171. Water in the trunk?
  172. need help with lowing down my 5gen lude
  173. h22a VS h23a1 Main Relay Question (searched)
  174. Whats a fair price for some Type S camshafts
  175. forged pisons and FRM
  176. Front head lights (low beam) not working
  177. Prelude injectors
  178. f22b motor swap questions about knock sensor
  179. vtec controller settings
  180. O2 Sensor Problem
  181. Car not starting.........starter or spark plugs?
  182. Black 5th gen with CF hood?
  183. Oil light flashing ???
  184. length of resonator
  185. Cadence 6x9 for VTEC Sub
  186. quick 4th gen fog light question
  187. fuel on the floor
  188. exhaust question
  189. location of h22a main relay
  190. building h23 for boost
  191. new pics
  192. 91 Accord Tranny on 96 Prelude H22A, will it work?
  193. AC/Heater not working at all need advice.
  194. Blower Fans/Heater/AC
  195. Anyone running 18'' rims on 5th gen? (searched)
  196. Wiring Harness
  197. 89 prelude runnin rich extremely
  198. just a quick question bout my engine.
  199. '05-'06 RSX-S rims on 5th gen?
  200. Machine shops for FRM... any recommendations LA, San Bernadino Area
  201. Engine Disassembled? Take a look, problems
  202. 225/45/16 tires
  203. Low Beams
  204. H23 compression number
  205. valve guides suck!!!!
  206. ANYONE KNOW WHERE I CAN GET A BELT?
  207. H22 shortblock+F23 SOHC head
  208. H23 vtec or H22A
  209. Storing car for winter ..what precautions to take
  210. need new brake master cylinder... help (searched)
  211. Stalled at idle then would not start!?
  212. Help shop for head !
  213. Just curious...
  214. RSX Seats..???
  215. Prelude help to a newbie Please
  216. 1992 h23 auto 4ws
  217. Max piston size+bore
  218. What damage am I looking at here? Timing Belt related.
  219. help ASAP dead car on the road!!!
  220. Short Shifter swap write-up
  221. Clutch/Tranny Problems
  222. calling out all fwd auto x'ers!!!
  223. El Gauge Trip Odometer Question
  224. please help...
  225. Preludebbduce has lost his rocker
  226. Definitive way of finding out whether fuel is getting to cylinders
  227. Removing ignition coil input plug
  228. H23 IAB vs. H22 IAB???
  229. removing knock sensor..Plug the hole or leave it??
  230. eg wheel on prelude?
  231. One headlight out...
  232. 1989 2.0 si 4-ws
  233. Koni ride height clip
  234. 2 inch drop
  235. Someone has to know what causes................
  236. H22 Low Oil Pressure - New Motor
  237. Can I identify JDM H22A cams from others?
  238. H23 with h22 head
  239. Venom 400 performance module
  240. do you have tokico advanced handling suspension kit?
  241. plus sized tire help
  242. Intake and Oil
  243. Magnaflow exhaust for a BB6? Thoughts?
  244. engine getting louder
  245. viper alarm??
  246. Is it normal for 01 preludes to accumulate black soot on the back?
  247. Prelude is overheating
  248. i just did something very stupid (electrical)
  249. Intake Control Solenoid valve? do I need this?
  250. Quick Charger settings for winter
