PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 [154] 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 5th gen intake on a 4th gen bb4 does it fit ?
  2. broken crank pully AGAIN!!!!!!!
  3. What 4th gen Lude is this console from?
  4. cvc????
  5. do you daily your lude or have daily???
  6. help
  7. 92 prelude si (checkengine light problems!!!!)
  8. 1st TIME STARTED JDM H22!!WOOT WOOT! Need some help though
  9. ignition problems
  10. you might own a fifth-gen if...
  11. Tailight and interior light all out!
  12. Help - reinstalling stock intake, don't know where to connect two hoses...
  13. 5th gen door speakers need replaced
  14. 93 to 95 conversion: hazard light not working
  15. USDM vs EDM Prelude, will a F22-header bolt up to a F20-engine?
  16. exhaust tone help
  17. oil sensor need help
  18. tried michellin brake dust repellent
  19. question on turbo h22!! techs please help. !!!!!!!!!!!!!
  20. Rotor Install. HELP
  21. jdm fogs with usdm wires?
  22. jdm predlude headlights
  23. Favorite Cat-back Exhaust
  24. password jdm whale cock on 4th gen lude
  25. No PS: How Hard Is it to Turn
  26. ATR Tranny Problem
  27. Difference Between SH, Base, H22A Power Steering Pump?
  28. 99 prelude with odb1 94 h22 ecu, which injectors 345cc? help.
  29. Power Steering Gooooooooooooooooooooooooone! AHHHHHHHHHHHHH
  30. power steering/VSS
  31. Turbo H22a not running
  32. Is the honda dealership BSing me?
  33. NEED HELP! just install buddy club vtec controller now have problem
  34. f22a1block h22head?
  35. header question
  36. h23 tranny
  37. H22a vs Civic Si coupe B16?
  38. 5th Gen TRansmission options HELP PLEASE!!
  39. 1980 Prelude? answers?
  40. 4ws and code 36
  41. 4th gen corner yelllow lights?
  42. OIL everywhere after timing belt and valve seal change
  43. vafc where to mount
  44. jdm usdm differance
  45. h23A1 question?
  46. Any one have specs for FlyWheel, release bearing, and clutch/preasure plate reassembly (searched)
  47. Iacv
  48. H22 swap help
  49. jdm lude type-s rear spoiler?
  50. ATTS question on an SH
  51. Paint code
  52. Anyone got a DIY timing belt for 97+ preludes?????
  53. just an idea
  54. Bent Valves?
  55. welding a muffler...
  56. 5th Gen fogs on a 4th Gen Prelude...
  57. vss causing tickets
  58. H22a8 98' ODB2 engine into Prelude gen 4 pls help
  59. OMFG... just money shifted.. help me out..
  60. DC2 Lights on a 4th gen Prelude
  61. Auto-5spd Ecu conversion question
  62. fuel pump relay
  63. bottom turn signal wire harness
  64. question about rack and pinion
  65. fake fogs (searched)
  66. where is my thred???
  67. honing FRM issues
  68. how much oil pressure is needed to blow out oil filter gasket
  69. ECU
  70. can I use stock clutch with a licht ened flywheel. SEARCHED
  71. Tech rebest prelude
  72. what size nut is this when I'm replacing the oil cooler o ring? pic
  73. h22 lsd
  74. car lost all of it's oil all of a sudden
  75. Need the paint code for a silver 92 Prelude
  76. Removing roof lining
  77. Need Help Please..
  78. alignment
  79. How to build a custom exhaust manifold?
  80. obx lsd for lude
  81. 215 or 205 /45/16 for my 16x6.5 ???
  82. Code 15 help please!
  83. Who knows what is generation ABS on prelude 4???
  84. WTH is this sound? Tranny? Clutch? Ahhh
  85. Merry Christmas
  86. Whats next
  87. New Shift Boot
  88. My 5th gen lude just die and won't start in the middle of the street..
  89. DC the new vs. the old
  90. Remanufactured Turbo's (Searched)
  91. where do the sidemarkers go?
  92. Boost For The H23
  93. LSD or not?
  94. oil filter gasket blowing off, oil pressure?
  95. 5th Gen Clutch Hard Line
  96. Radiator problem...
  97. Mounting "S2000 Style" Antenna in the trunk or on rear deck
  98. prelude h22a swap (wire harness quetion HELP!!!)
  99. Re wiring sound 5th gen.
  100. Carfax help please
  101. H23 engine in Chicago or near central IL
  102. JDM Fog ?
  103. Wire HArness Question...
  104. balance shaft seal RETAINER part number?????????????
  105. Retrofit baby!!
  106. need help with giving a value to my RHD BB4
  107. removing stock shift knob?
  108. boosted lude
  109. With a Turbo you can get wicked nasty!
  110. power steering fluid. how much?
  111. power steering speed sensor
  112. twin turbo h22 help
  113. Why does EuDM 5gen H22 Lude have 0.7 sec higher 0-60mph time that USDM
  114. prelude color
  115. Balance shaft recall closed?????!!!!!! WTF
  116. No2 H22A good or bad idea
  117. 5th gen SPOON strut bars
  118. Anyone have pics of a 97+ Prelude in titanium grey
  119. H22A1 or K20A?
  120. Question about three "pins" on USDM headlamps
  121. what the different btw jdm and usdm
  122. B series ECU for H series??
  123. h22 euro r iac wiring
  124. turbo for SH
  125. h22 / h23 questions
  126. Write Up : Cheap, Clean 4g Prelude Battery Relocation
  127. prelude short shifter
  128. koni's with eibach springs
  129. gas mileage
  130. Won't engage into park
  131. 5th oem exhuast tip on 4th ???
  132. Both Tires Spin?
  133. What Shops can do retrofits in the Northern Virginia/Washington DC Area
  134. Dimensions/instructions for H22 oil passage drainback plugs for use with F22 F23 blocks
  135. Can anyone out there trace a motor's origins?
  136. Does anyone know when VTEC kicks in for a JDM H22A1?
  137. saturated injectors
  138. 95 prelude k-searies
  139. What size wrench should I use for:
  140. JDM parts...
  141. what are some different things i can do with the head lights?
  142. Turbo Build Gone Bad?
  143. 86 valve space
  144. 91 Prelude Si Codes 12 and 15... Please Help
  145. why is my car screeching
  146. 4WS problem
  147. Differences in throttle bodies?
  148. Question regarding bigger exhaust piping 2.5" to 3 "? Already searched...
  149. Why would I be tearing inner cv boots?
  150. Radiator leak....What could it be
  151. What would you do???
  152. Gas pedal sticking? and brake lights not engaging?
  153. cam shafts
  154. type s part into h22a
  155. Bogging...
  156. fleabay part of the day
  157. what what u do?
  158. IACV
  159. front sway bar
  160. How do you know if it's a base or sh?
  161. vacuum reservoir
  162. Which cams...
  163. CEL code 36?
  164. bring car into us
  165. Oil leak in the front of H22, please help.
  166. Pics of greddy exhaust?
  167. Upgrade pulley for Jackson Racing SuperCharger?
  168. is there a way i can put in my head light with out taking off my front kit?
  169. 4g m2b4 speed calculator
  170. Skunk inlet manifold: To fit H22a engine 1994-2001. Will it fit a 1992 H22?
  171. whats the diffrence, radiator
  172. engine revs up what is the problem
  173. Idle Problems
  174. Synchromesh ? (searched)
  175. Mugen Grill Question
  176. JDM or USDM Final Drive - Where to det one?
  177. do they make c-pillar bars for 4gen ludes
  178. Where can I get an H22 Stroker kit?
  179. anyone know a 5th gen map light will fit into a prelude vtec model?
  180. Lip kit identification?
  181. anyone with a 95 prelude si...
  182. 99 Prelude bottom with 93-95 Head swap questions (N/A)
  183. Help 99 prelude reverse problems
  184. 4th gen JDM sidemarker setup
  185. Need to remove gauge cluster help :)
  186. Daily driver clutch selection...
  187. hooking vtec up for swap?
  188. 97 turbo AUTO trans/axle question
  189. code 23
  190. experiences with str big bore throttle body and venom IM
  191. does anyone have a sh lude that is lowered, and is the atts ok.
  192. USDM dash conversion to JDM dash
  193. 4th Gen Steering Wheel Hub
  194. 99 honda prelude Help guys my window wouldnt close all the way
  195. h22 install!! HELP
  196. Need help for a friend
  197. prelude front grill
  198. Is my mechanic bullshi*ing me?
  199. looking for 92-96 shifter assembly
  200. car wont start....
  201. question!
  202. LSD....is it really worth the extra $$$
  203. interior light
  204. 5th gen prelude drive problem
  205. speedometer not working
  206. Door panels
  207. vtec?
  208. 5th Gen "ODB II?" location
  209. need help on the o2 sensor
  210. Noob with 5th Gen prelude, help if you're nice :)
  211. Sticky Throttle Issue...
  212. header???
  213. 1998 JDM H22A Oil capacity?
  214. Clutch is acting wierd
  215. MSD coil
  216. which cam is the intake and exhaust?
  217. engine ICE
  218. power steering leak 5th gen!!! help!!
  219. Cranshaft pulley bolt frozen / seized
  220. How do u a djust e-brake on 5th gen??????
  221. possible to pull 500-600 whp with stock head but built block and big turbo?
  222. Will these ball joint accord Camber kits work on my prelude
  223. removing stock stereo and cd
  224. 2001 Base Model Specs.
  225. no 3rd or 4th gear?
  226. ABS Light on above 110MPH????
  227. How much could i get for a B20a5
  228. Pspec or Lean Racing short shifter ???
  229. where does this connect to? HELP
  230. How can i get to this # 200hp at the wheels?
  231. Hesitation before vtec
  232. YOUR Prelude...Price, Payments, Months Left?
  233. TIMING BELT PART DEUX
  234. Reverse !!!
  235. performance cams
  236. ECU error codes
  237. 5th gen. shifter question
  238. Plastigauge a h23 Vtec???
  239. PSPEC Short Shifter
  240. Any good Shops in the Atlanta area?
  241. Joining the Prelude Croud
  242. Knock Sensor H22A BB6
  243. Halo projecters
  244. Rearview mirror adjustment on 5th Gen.
  245. car smokes/burns/spits oil after new valve job - bad rings?
  246. car shakes at speed over 50 ... diagnosis?
  247. What is the purpose of a wastegate on turbo'd cars?
  248. How much is the average price for getting a welding done to install an exhaust?
  249. my tranny doesnt go into 1st and 2nd gear!! tranny gone? please help! *searched*
  250. gauge e-brake light wont turn off
