PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 [291] 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Problem after problem....Throwing another CEL
  2. remote start
  3. where to get those Fogs?!
  4. M3 Power LED Mirrors
  5. Straight Pipe at the flick of a switch
  6. 97 prelude Auto Tranny issues
  7. 3rd gen turbo owners, please help
  8. .......
  9. H22A Surging Idle HELP
  10. Let me be the first to....
  11. 3rd Generation Prelude Mods
  12. Clear Corners for 88-89 Prelude!!!
  13. 4th Gen vs 5th Gen?
  14. Can you swap auto tranny for a manual in a 93' SI ?
  15. Anyone Run Nitrous with JDMT TYPE S cams and Valvetrain?Safe?
  16. camshafts and turbo..
  17. Good place to buy Mugen header??
  18. Does a 93 prelude w/h23a have a internal or external coil?
  19. Coolant fan on as soon as you turn the key and no vtec, any ideas?!!?
  20. msd on 88-91 lude?
  21. How do I check my timing/TDC on a H22A with Clutchmaster's flywheel
  22. sycro's and bearing's different for m2b4 tranny(jdm lsd)?
  23. in need of glass.
  24. anyone know a good site to order radiator?
  25. anyone have a jdm h22 header??
  26. Blown Head gasket?
  27. does anyone in the la area know where to buy relay for jdms?
  28. yeah... the engines in... oh yes, i said it's in
  29. l HKS turbo timer on 5th gen Lude
  30. Prelude 94 offset
  31. OBD1/OBD2 Differences?
  32. Building an h22a head
  33. Service Check Connector???? where?
  34. engine installation
  35. Injectors the same for JDM type S and 98 USDM H22?
  36. want to know if someone wants my car?
  37. I summon all boost freaks.....
  38. incredible or not?
  39. Greddy lip on 5 gen.
  40. 2000 SH vs. 2002 WRX
  41. slicks for preludes
  42. Cams Aftermarket - Whos using them what do you think of them
  43. JDM/USDM Wire-Harnesses
  44. just bought a new clutch and....
  45. I love my engine
  46. using a jdm obd1 p72 with h22a
  47. Shimming Oil Pump Spring (higher oil pressure)
  48. Break boosting
  49. ignition upgrade
  50. Re-built or swap?
  51. Less gas = Less Hesitation.....HELP!
  52. 4th gens with rota slipstreams? Pics please
  53. Soon to be turbo prelude's please read!!!
  54. type sh engine w/ accord tranny? possible?
  55. Something's wrong
  56. Greddy Turbo Kit
  57. Vacuum Leak Testing
  58. What's the going rate for JDM 4th Gen Prelude headlights?
  59. WTF.. still getting water in my passenger rear seat..
  60. 93 Prelude VTEC with 175K miles for $4K. Good deal???
  61. Vtec stuttering....WTF????
  62. My site is finally back up...
  63. What would you do with a H23A1 engine with a broken T-belt???
  64. 1/4 Mile times
  65. Good site to check out Prelude kits...?
  66. How much is my motor worth???
  67. need some help 84 prelude
  68. Does F22 header fit on H23?
  69. gutted out CAT(like a test pipe)
  70. Max Rev Turbo Kits
  71. How do you remove the AC evaporator?
  72. WTB: obd1 p13 anyone?
  73. Someone who's bored.... help a brotha out.
  74. Anyone near Gainesville, FL wanna help me put my motor back in?
  75. Does anyone have a OEM Rear Bumper??
  76. Nippon Brakes
  77. JG Luder and Lildrgn have been selected to enter the Gumball 3000 for 2003
  78. gunk o rubberwondow trim...
  79. Please Help...suspension noise....
  80. HID's on 5th gen
  81. How do I get AEM adj cam gear off??
  82. boiling dot 4 brake fluid
  83. ugly 4th gen sideskirts
  84. 1994 prelude vtec needs sold asap!!!!!!!!!!!
  85. prodrive, where the hell is it?? (the website)
  86. Anyone know were I can buy honda OEM Sideskirts......
  87. new interior carpet
  88. swap drama- I NEED a new wireing harness please help
  89. 300ZX Vs Prelude?
  90. Where is the Oil Filter on 97 Prelude
  91. Omp Velocity steering wheel
  92. FS: Brand new H series prodrive oil pump gear
  93. Hope I don't get a piece...
  94. if it possible for a 93vteclude to come down to 2500 lbs
  95. im looking at buying a prelude...
  96. Honda-tech meet LI, NY
  97. I learned alot last night, how to gain 10hp easily and how to screw up your motor!!!!
  98. best place to get AEM or ICEman CAI for a 93 lude?????
  99. 99 SI Throttle Body on JDM auto h22?? What's needed?
  100. 12 second or Less
  101. can't decide!
  102. Hazards of incorrectly adjusting AEM CAM gears??
  103. If you were rebuilding an H23 engine...what internals would you get??
  104. Vtec is Weak WTF!!!!!??????
  105. HKS exhaust
  106. How many Lbs of Boost is safe for h23
  107. changing a h22a1 automatic tranny for a f22 manual tranny.
  108. Has anyone's clutch master/slave cylinder gone up on them??
  109. Cleaning off ceramic headers
  110. radiator seeping..
  111. engine swap
  112. O2 Sensor Engine Light. Help!!!
  113. 4th gen JDM headlight question...how do you aim the lights?
  114. Need Help Fast PLEASE!!
  115. 4th gen corner lamps?!
  116. Balance Shaft belt Question
  117. Advantages and Disadvantes of.........
  118. Prelude Ques?
  119. injector question
  120. What are the best rods for N/A reving to 9000 limit bottom end.... fully built
  121. HELP!!!!!
  122. powersteering
  123. I hate H22a motors
  124. Mugen front bumper for BB1 prelude
  125. preludeonline.com have to pay!!!?
  126. help!!!!
  127. Events
  128. car surging in neutral
  129. 3rd Gen owners...sign in
  130. EGR Valve on brother's car
  131. squeal in my engine?? What is it?
  132. WTB 5th gen rear bumper
  133. car trouble
  134. S2000 Pistons
  135. Engine Work/BodyShop
  136. Oregon/Washington meet
  137. Quick question about Type-S pistons.
  138. 95 or 01 lude
  139. shipping costs for exhaust system
  140. a few questions about my next phase...
  141. is a camber kit a do it your self job?
  142. Perfect gearing for dragging?
  143. VAFC and OBDII questions
  144. 94 bb1, gauge wiring
  145. KYB AGX Settings
  146. For all the turbo guru's....
  147. Speed Limiter????
  148. dx map on h22?
  149. synthetic to non synthetic
  150. Freeway Revs
  151. Prelude Si ECU w/Hondata???
  152. Honda-Tech Meet Nov.24 sunday read on....
  153. anyone in the n. atl area want to help me w/my turbo/engine install
  154. how to get shorter gears for h22 tranny???
  155. wat do u guys think?
  156. walbro fuel pump
  157. Didn't want to, but it's come to this.
  158. h22z1 help.
  159. Speed Shifting
  160. 3rd gen alarm help
  161. ?Is it possible?
  162. question about prelude parts
  163. how do you check the cel on a 4g
  164. Top Fuel 2.3 stroke kit
  165. exhaust piping question...
  166. prelude sh needs help!!!
  167. link to classifieds: fs: super fast 97 itr #309 lots of mods
  168. Free slotted rotors for the 88-91 Prelude Si
  169. carbon hood for a 3rd gen
  170. body kit or lower? 4th generation
  171. Buying Already Modified Cars can be dangerous
  172. Question about exhaust smell...hondata and turbo
  173. Best setup for $3k?
  174. I need help in buying a prelude!
  175. Does the H23 TB have coolant lines?
  176. Car is stiiilll sputering like a mofo!!
  177. Possible if 5th generation...
  178. Neuspeed or Comptech Sport stainless steel brake lines???
  179. bulb type
  180. supercharger or turbo?
  181. Spun rod bearing. Can it be fixed??
  182. might be getting a RHD 5th gen...
  183. fpr?
  184. HELP!! My g/f's 00 Prelude broke down. Both belts came off. What could it be?
  185. F22A1... what to build up in prep for nitrous...?
  186. Best thing to do for under 500$?
  187. Roller Rockers for an H22
  188. how the hell did u guys get the cam gears off
  189. valve problem
  190. need help w/ shock/strut...
  191. Individual throttle body
  192. helm's manual 92-96 same?
  193. Need help !!!!!!!!!!! with CEL
  194. good deal?
  195. Accord Type-R valves
  196. PLEASE READ, i dont have much time!!!
  197. how-to: h23vtec
  198. spoon strut bar 4th gen
  199. Should I boost?
  200. H22A7 tuning?
  201. Auto lock problem in 5th gen.. comments, suggestions?
  202. Octane rating req. to run 11.1 cr
  203. Max streetable compression?
  204. B20 or B21a can take any B-series cam gears?
  205. 5gen SS lude w/ greddy turbo times?
  206. rim help...95 prelude si
  207. Injector Size For My Car?
  208. Headlights Bulbs?
  209. leaning out, why?
  210. egr pic?
  211. Timing Advance!!!
  212. Need some rod measurements stat!
  213. In need of 94 Prelude parts
  214. Unorthdox underdrive pullies
  215. 92 lude SI w' intake
  216. Help! Something Isnt Right
  217. Should the tranny fluid drain out the passenger side axel hole if it is removed?
  218. N/A power limits of an H22???
  219. why?
  220. need help with 4th gen
  221. notched block neede for eagle rods in H22?
  222. My girlfriend might die =(
  223. New smaller stroke...can I remove my balancer shaft belt?
  224. anyone know of some cheap, decent tires i can put on my stock 16s
  225. * 92-96 prelude 4th gen parts for sale for Vancouver BC residents
  226. feedback on ACT streetdisc clutch and Xtreme Pressure Plate
  227. Nitrious
  228. does anyone have these 3g pics?
  229. brake fluid?
  230. Greddy fcu for 92-95 civic?
  231. suspension stuff to buy w/ x-mas money? $500
  232. Need help spending $200
  233. Stock wheel prices
  234. need help, . . . !!
  235. type S my ass....
  236. codes
  237. using too much gas
  238. '97-'01 Fog Light Install
  239. BEHR Intercooler
  240. Drag radials on base rims........
  241. Reverse Gauges
  242. To Turbo.. or not to turbo?
  243. removing power steering... more
  244. Boosting a B20A (3rd gen)
  245. Anyone got Pics of AEM cai w/air bypass valve installed???
  246. what are the best cam gears. (design, lightweight, counterweighted etc)
  247. Suspension on 2001 Lude
  248. 98 swap into a 92 lude?????
  249. Need relay ASAP
  250. what do sh's run?
