PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. I may be coming back!!!!!
  2. Lip Kit
  3. h22a4 to spray or go on boost????
  4. 2000 Honda Prelude won't crank or start
  5. at what rpm should v-tech kick in?
  6. Anyone have a DIY for this?
  7. im a newbie at this i need help
  8. NGK plugs
  9. HELP! H23 prelude won't start....massive oil leak too!!!
  10. Should I buy this prelude?
  11. Is it me or did this guy not care?
  12. jdm head with a1 block and direct port N2O
  13. logicmotorsports tri y
  14. my new car......value sport lip kit??
  15. 1992 Prelude H23a1 crower cam lots of questions
  16. Cleaning Fuel Injectors?
  17. 2.5inch or 3 inch??
  18. knock noise! is not rod bearrings, plz help!
  19. Need help with 97 prelude hard start sometimes no start
  20. Need professional technical 5th advice
  21. 97 prelude without balancer pulley
  22. where can i find a tourqe down spec?
  23. driver side window/lock switch dont work
  24. need help with vtec
  25. ITR seats in prelude
  26. A/F ratio
  27. cd5 skirts???
  28. Prelude Oil
  29. This Main Relay Good or Bad?
  30. H23 wont start at all
  31. f20b h22 pros and cons
  32. 1997 Honda Accord H22a swap; Won't start
  33. Questions regarding H23 to H22.
  34. cam sensor, ecu end?
  35. H23 vtec swap in 2000 accord from F23
  36. h23 vtec crank trigger
  37. 97 Prelude Lip kits
  38. What to replace while doing headgasket?
  39. 99 prelude wants to start, but wont
  40. Thinking about selling my 95 Prelude VTEC - I really need some advice from the pros
  41. idle problem when moving in neutral
  42. h22 injectors with f22 fuel rail
  43. motor swap?
  44. Billet transmission housing
  45. 2000 Knocking clunking noise
  46. 96 prelude vtec manual transmission problem
  47. Prelude or Integra
  48. "overheating" but thermostat doesn't open and fans don't come on?
  49. 92-96 Prelude rear sway bar fit 97-01 prelude?
  50. h22a timing belt walking off the cam gears
  51. random h23 questions cuz idk much about hondas
  52. Need Torque specs for changing headgasket and Rocker bolts.. and
  53. AEM EMS Series 2
  54. engine wet...uh oh
  55. h22 oil pressure gauge, head work
  56. Will F22 Starter fit H22?
  57. Prelude swap issues
  58. Proffesional Products 68mm TPS ?
  59. Prelude Auto Transmission
  60. Innovative Mounts (mixed stiffness)
  61. p-14 ecu upgrades boosting with large injectors
  62. thermostat LAG????
  63. nippon pistons and rings r they any good?
  64. Anyone in DFW with a press to install new bearings & bushings?
  65. Will a F20B trans fit a H22A block?
  66. how much does rebuilt motor sell for? used motor?
  67. PARTS IDENTIFICATION H22A
  68. 2 misfires in vtec, no cel ???
  69. Here's mine....
  70. Second opinion (car won't start)
  71. Slave/Master cylinder help....
  72. 01 prelude wont start getting spark injectores wont fire
  73. BB1 & 4WS question
  74. help with racing an older (89) prelude engine
  75. 92 honda prelude weird idle?
  76. H22 Vtec Issue
  77. Vtec not kicking in? why?
  78. Need opinions of what engine to put in my 95 Prelude.
  79. O2 sensor failing?
  80. H22 Balance shaft belts
  81. sunroof wont open, motor works
  82. ok i got a noob question
  83. 5G suspension options
  84. Need an engine on 1979 Honda Prelude
  85. Hello
  86. tire size/specs, need help asap
  87. Possessed turn signal
  88. Adjuster Problem h22a4
  89. High Idle coming to stop. its annoying me.
  90. How are these rear lights made fit?
  91. dohc vtec side decal on prelude?
  92. Exhaust , 4th-5th Gen ?
  93. New Project 97 Prelude.
  94. Happy New Years to all!!!
  95. H22a is it the jdm or is it udm?
  96. Block choices
  97. Prelude F22A1 into a Classic 1960 Mini
  98. Compression Vs Cams?
  99. Lighting problem
  100. anyone???
  101. H22 love from kaizenspeed
  102. which ball joint? 97 or 99 ?
  103. Clutch for H22A
  104. need to clean iac and egr
  105. suspension setup
  106. 83 Prelude Questions
  107. 95 Prelude JDM H22 Weird Rev and Noise Issues!!! PLEASE HELP!!!
  108. MAJOR. OIL. LEAK.
  109. How much is it worth? RHD prelude
  110. H23 bad injector worth the buy?
  111. Season's Greetings...
  112. What motor was swapped into my Prelude? H22A?
  113. JDM Foglight Install Advice Needed
  114. 92-96 Prelude seat rails into a EG hatch
  115. tach/limp mode question
  116. Questions about transmission? Which is better?
  117. what is going on?! no start and no codes
  118. help!!! 96 vtec ecu ???
  119. Looking for spoiler
  120. 93 prelude
  121. 2001 Prelude Cold Start Issues
  122. Shaking while braking at a stop sign
  123. HONDA PRELUDE 1992!
  124. Sputter and died, no CEL
  125. Random missfire, NO CEL trying to Diagnose
  126. need 2000 prelude h22a4 head torque specs
  127. Spark and Fuel but no start
  128. which balance shafts to use?
  129. Oil pressure sensor location
  130. questions about 1998 prelude
  131. Unusual electrical problem - 1997 Prelude
  132. 1999 Prelude starts then dies after 2sec
  133. hub swapping
  134. what else would work?
  135. Car Not Starting.. CEL On
  136. Which engine is this?
  137. no start after vacation....
  138. Video of my prelude at the track
  139. TPS Sensor? Check engine light.
  140. need help with 1992 honda prelude
  141. seriously dont know why it wont start
  142. bumper vent name??
  143. new problem
  144. 92 93 si wheel ?
  145. 88 & 90 sunroof visor question?
  146. OBD1/ECU and tuning
  147. Valve Cover Gasket
  148. Adjustable Upper Control Arms
  149. 5th Gen 'Lude interior fan only working on highest level
  150. h22a4 wiring diagram
  151. fuel pump?????
  152. Squeeking coming from driver side knuckle?
  153. Rear end bouncing/goes by itself
  154. H22A 1996 with 1995?
  155. H23a blue top vtec pressure sensor cel
  156. X01Michael's Troubleshooting Guide.
  157. No spark? ? ?
  158. H23a1 Idle Problem? Helllp.
  159. egr solenoid valve issues
  160. no vtec signal????
  161. Best shocks w/ Ground Control coilovers - Near stock height
  162. What part is this?
  163. Tial BOV
  164. New user question on spark plugs and noise
  165. Huge oil leak near atts, need help!
  166. PLEASE HELP MY CAR HIT A CURB SOMEONE HELP ME FIGURE THIS OUT
  167. Save or Junk!!!
  168. Another idle issue :/...Searched and attempted DIY's
  169. Need help on SH
  170. Torque Dampner Adjustment
  171. 85 Honda Prelude Problems
  172. 2000 Lude PM, vtec, dizzy o-ring
  173. 1998 Prelude SH
  174. Can the ATTS cause a wobble
  175. Searching for b20a5 engine/block
  176. please help....swappin a h22a4 auto to h22a manual
  177. Do I need the resistor box
  178. Help with water pump
  179. Mysterious oil loss in H22A4
  180. 1993 prelude front wheel bearing help!
  181. H22 piston options
  182. Built H22A Turbo Tranny Recommendations
  183. 97 prelude won't start - battery ok; no dashboard lights, windows, or turn signals
  184. H23 blue top ecu
  185. F22B1 into a Prelude
  186. Car shakes or shudders on clutch engagement
  187. How Can I TDC? h22a4
  188. What oil to use
  189. 93 H23 Prelude Idle Jump/Surge
  190. Ksport pro kit
  191. slave cylinder
  192. t2w4/euro r axels
  193. Difference between 93' h23 and 96' h23???
  194. 2000 A/T Honda Prelude Neutral Safety Switch Help
  195. 1996 prelude "s" won't get spark from coil. Completely lost.
  196. 93 prelude with spun rod h23
  197. 1990 prelude tranny fit in 89?? help
  198. Scan throwing codes
  199. Jerking problem .... Lol
  200. P1399 code help
  201. OEM Headlight Covers or Hiro eyelids?
  202. What is this??
  203. can a leak in the intake cause a code?
  204. p06 on a 2.3vtec with code 9
  205. advice on buying a prelude!
  206. Reputable shops near Chicago?
  207. h22 dyno, what to do for more power?
  208. JDM OBD2 H22 in OBD1 Prelude *Not Starting*
  209. Ascot Innova help!!!
  210. DIY 4G Prelude Front Suspension Rebuild - ball joints, bearings, bushings, etc
  211. turbo?
  212. 93 prelude si no power to the starter solenoid switch
  213. gauge cluster swap help
  214. high HC emission! whats wrong??
  215. Integra guy wondering about h/f swaps!
  216. *sigh* Help! My '93 Prelude is driving me insane!
  217. Inter-changeable parts prelude parts
  218. h23a1-h22a swap no start
  219. Heater
  220. 97' Prelude SH - blew motor, F22b1 swap, confused and have questions.
  221. Check engine, ATTS, and speedometer doesnt work
  222. jumping tach
  223. 93 prelude engine ticking noise
  224. Type S Intake Review
  225. Bought about $3000 in parts... forget anything?
  226. DC Sports header smoking ?
  227. ABS Module leaking....
  228. how to connect remote key fob to signal light
  229. torn tie rod boot ?
  230. Progressive 27mm rear sway bar bracket
  231. 94 PRELUDE SUSPENSION QUESTION
  232. Is this worth buying? (noob lurkers first post)
  233. Ignition problem
  234. i locked my self out of my car help
  235. location of crank sensor? help
  236. 98 prelude 02 sensors are buggin
  237. 00 prelude obd2 connector
  238. What are the best Bolt-ON mods for H23A Blue Top Engine??
  239. best header for quality AND fitment (prelude specific)
  240. ABS Light Code 1 "Pump Motor Overrun"
  241. wanting to improve my brakes
  242. went threw puddle check engine atts/cutting out helpp!
  243. F20b fit into a 92 prelude with same tran and axles and motor mounts
  244. 1992 prelude Help Me
  245. Hardline Tranny bypass?
  246. Oil Low Suddenly, can't locate leak
  247. attn parents with ludes..will a convertible forward facing car seat fit in a 4th gen?
  248. exhaust advice
  249. turbo or supercharger on a H22A fully built click for specs on motor
  250. Creaking sound while turning steering wheel
