PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Power Steering and Rack Valve Body
  2. What is the Diffirence Between Type S prelude and Type SH ???
  3. Fifth gen wont fire
  4. Need to know location on ecu for cam or crank sensor
  5. accord > prelude steering wheel swap
  6. engine coolant temperature sensor location
  7. With the lights
  8. 919 raleigh, Nc Good machine/head shops?
  9. turbo - catalytic converter or test pipe?
  10. H23 VTEC help
  11. climate control lights won't work
  12. Valve clearance
  13. 98+ h22a4 block help
  14. HELPPP!!!! problem with power!
  15. Help! Prelude 1992 Electrical Problems
  16. oil dipstick tube
  17. 01 BB6 factory radio problems
  18. H22 Build
  19. How far can I push a fully built H22A????
  20. Do these Cams Look like Type-S or Reg. H22 Cams
  21. New in forum...Just picked up a 96 Si
  22. 99 Prelude ATTS problems, HELP PLEASE
  23. Should I buy this Prelude TOMORROW???
  24. H22A4 1999 Prelude - Engine Trouble
  25. Remove OEM H22 Fuel Rail main line bolt?
  26. Active ABS??
  27. what possible consequences .. piston sticks out 0.075" at TDC .. h22 head
  28. H22A4 in the 3rd Gen?
  29. Decision: for 99 prelude sh crank pulley
  30. New (to me) 92 2+2 si MPG
  31. A/C Question.
  32. Really need help pleasee help me with my BB6
  33. MSD ignition question...
  34. 97-01 Honda prelude Tranny mount
  35. HIds working intermittinly
  36. Honda perlude 1990 4ws
  37. ATTN: F series and H series owners!!!!!!
  38. 88 SI Running way too rich
  39. starter help
  40. looking for part numbers
  41. 3G Headlights and Horn
  42. 99 prelude h22 jdm swap problem starting
  43. 99 lude Car Shakes right to left while driving
  44. pissed at this point.
  45. Timing cover leaking oil in 98 lude....help!
  46. is this foglight switch from a prelude?
  47. Can u convert the stock HPS to all EPS?
  48. H22A4 misfire? Kickin my ....
  49. Newe to Hondas; just bought a 95 Prelude SI with 123k and engine makes a loud clangin
  50. VALVE COVER GASKET REPLACE!!!HELP
  51. My ECU LED does'nt flash
  52. Has anyone cracked open a T2W4?
  53. Need to borrow tools in San Diego Area
  54. gasket for aftermarket header?
  55. 1997 prelude with h22a on obd1 nopower
  56. transmission question
  57. CEL won't flash code when jumpers used
  58. H22A1 Help!
  59. g23? help!!!?????
  60. Oil additive
  61. a really bad day
  62. 1983 prelude
  63. 3rd gen overheating
  64. ABS and ATTS fail safe relays?
  65. Options on h22 block hone
  66. wtb h23vtec/h22vtec.
  67. rim fitment need help
  68. h22a swap
  69. Making My Prelude have 175 whp?
  70. Chips on crank pulley
  71. Transmission Mount Bolt Question
  72. idle rev's and drops repeatedly
  73. Sound when turning after change of belts
  74. The amazing 250 horsepower Prelude Type SH!
  75. ABS light after engine swap
  76. Manual Transmission whine?
  77. Difference in MT and AT engine harnesses...
  78. H22a1 swap into 97 lude. Help
  79. idle issue
  80. my new 5th gen build thread
  81. FML!!
  82. Trouble starting, initial start up
  83. clutch help....
  84. G23 Vtec
  85. 5th gen running crappy/cutting out
  86. 5th gen under dash mystery wires/plugs and sunroof problem
  87. Name these plugs, win a prize!!!!
  88. H honing statement
  89. need some help on a 3 gen
  90. Do you HAVE to run an O2 sensor?!?
  91. Can someone look at their fuel injector wires please?
  92. Running extremely rich.
  93. vtec problems.... help!
  94. H2b problems .....With video
  95. how/can i make my stock seat sit higher?
  96. oil in spark plugs tube
  97. Cruise control issues
  98. 5th Gen Prelude parts ft
  99. Wierd Wiring Harness on my H22a
  100. Camber problem
  101. car wont start!!!
  102. h22a t.body vs h23a1 t.body
  103. fuel pump
  104. 5th gen and/or 4th gen accord springs fit a 4thgen?
  105. Damn fan switches
  106. fuel pump
  107. H2B knocking, oil lights and dieing.....HeLp
  108. H2B SOUNDS LIKES IT KNOCK AFTER FIRST 10 MILES....HELP
  109. h23 non vtec to a h-22 vtec???????
  110. h22 vtec issues
  111. A/C, Driver headlight, and ABS fuses keep blowing
  112. Hesitation / Slight bucking.. + running hotter
  113. Wont start after changing timing belt
  114. pulley stuck
  115. 91 prelude blinking s3
  116. Several Random Questions..
  117. Odd rattling noise
  118. H2b dieing after fully warmed up---HELP pLZ
  119. h22a tranny axle issue please help!!
  120. Engine bucking/ Fuel cut off?
  121. Running an f20b in an obd1 93 SI
  122. Need a much smaller radiator for my turbo setup? What do I do?
  123. h22 machine work piston size help
  124. H22A Serial Number Check Plz...
  125. 97 prelude electric gremlin start problems
  126. is it possible to wack a h22a VTEC head onto a F22z6 block?
  127. RATTLE PROBLEM HELP!!!!!!!!
  128. alternator problem
  129. Replacing the window molding on 2001 Prelude
  130. H22 swap/ecu swapping
  131. Attn NC luders
  132. H22a SH shell with base motor
  133. it's already been covered.. LINK??
  134. 3rd Gen D2J3 vs D2J4 - Electric vs Mechanicle Speedometer
  135. 85 Prelude - appraisal help
  136. Engine noise at idle, goes away when accelerating
  137. '99 H22A Prelude Power Sterring Grind
  138. Del sol seats in a 4th gen
  139. Hey i just have a question
  140. Black Smoke
  141. Bad mileage running too rich help!
  142. Wont go into gear when on....
  143. looking for a upper control arm for my 92 prelude
  144. 01 H2F, which axles to use
  145. Cam Caps
  146. 1995 prelude si vtec rear brakes
  147. 93 Prelude Si with H22A4 swap...engine is cutting out, can you help?
  148. 1988 Bumper Removal
  149. Battery drain on the clock/radio fuse?
  150. CXRacing Turbo Kit??
  151. modified engine mounts
  152. ABS Code 1 - The fix with pics
  153. h23 crank pulley on h22?!
  154. H22-H23...DIFFERENT TPS? t-bodies?
  155. cb7 h22a swap.first drive. few issuses
  156. 91 Prelude Si overflow tank blowback
  157. h22a4/h23 hybrid tech question
  158. h22a cams
  159. no vacuum to egr valve
  160. intake air bypass control diaphram
  161. 97 prelude immobilazer problems
  162. Fidanza pilot bearing problem ?
  163. DTC p0441 & P0170 -- already searched
  164. Calling out all 4th gen owners.
  165. How slammed is your 4th gen with F&Fs
  166. What is this part?
  167. Audio Question, Prelude Specific. Components/Door
  168. hid halo lights help
  169. Omni power throttle body question
  170. 98 auto
  171. Bushings for KYB AGX/GC Setup
  172. h22a JDM overheat prelude 93
  173. 99 Prelude Base No Spark No Start
  174. 92 Prelude No Start, fuel issue?
  175. Advice on 4th Gen lude springs
  176. Car won't start NEED HELP!!!
  177. What's the reason for switching to a manual T-Belt tensioner?
  178. H22a idle is high
  179. 1981 Prelude
  180. prelude sounds faint?
  181. black box next to ecu on a 96 prelude.
  182. Changing timing belt on h23, need help please :)
  183. clutch master cylinder issues
  184. Koni Yellow Rebuild Questions?
  185. NEED EXHAUST MIDPIPE HELP!!
  186. obd1 f22b1 sohc vtec into a 92 honda prelude si!!!
  187. Prelude starting difficult, what could this be?
  188. Valve cover bolts/studs
  189. h22a4 timing tensioner
  190. plz help! where does this part go in my head?
  191. Throttle Dependent Surging.
  192. camshaft recomendations for my setup
  193. Interesting Starting Issue - penny for your Thouhts
  194. how can i drop my 4th gen lude without the right key to my ground control coilovers?
  195. h22 balancer timing question????
  196. alternator/battery/sensor problem? need help
  197. h22 atts swap questions?????????
  198. 95 Lude VTEC – Strange noises from engine compartment, almost like a Jake Brake
  199. h23 exhaust
  200. Transmission Issue
  201. just a shot from last weekend. :wave:
  202. JDM H23A non vtec, oil pan Q
  203. h23 vtec capability?
  204. Question regarding H22A4 block..
  205. cb7 h22a swap help VACUM HOSES
  206. Need help with my H22
  207. 3rd Gen Prelude SI for figure 8 racing
  208. h23a vtec swap
  209. 98 JDM H22A wont turn over
  210. h22 swaped del sol
  211. Annoying starting issue. Im giving up
  212. Help with jdm h22a into 99 prelude
  213. h22a1 boost!!
  214. OBD-II to OBD-I Quick Question
  215. H22A4 OBD2 Vacuum Diagram Needed
  216. 10 MILES TO THE GALLON HELP!!!!!!!!
  217. honda prelude new lock ignition
  218. 4th gen speedometer problems!!!
  219. 01 Prelude SH O2 sensor/ cat
  220. Intermediate shaft oil seal replacement information
  221. S2K steering wheel in 4th gen Lude.
  222. Broken spark plug!!
  223. tranny help!!!
  224. 2000 prelude - fried motor - quick question
  225. idle bouncing shutting off :(
  226. looking for a honda h22 vtec ecu
  227. 97 honda prelude exhaust question
  228. 97 prelude short shifter question.
  229. Do i really need a fuel pressure reg?!
  230. h22a same as h22a4
  231. Any reputable engine rebuilders?
  232. looking for a Front Nose Cut!
  233. H22A4 oil pan on A1?
  234. msd blaster 2 coil
  235. dose anybody use an v-afc2 on there h22
  236. Having some issues, need some help!
  237. impossable h22
  238. h23 help
  239. Suspension Problem Need Help
  240. DIY front Lip install?
  241. Code 71 & 72
  242. Egr/Egr delete/3k-4k hesitation,question?
  243. electrical issue
  244. Surging idle after warm up h23a1
  245. Tanabe or Megan Racing rear lower tie bar
  246. Help!!! 5th gen window motor died on me and need to know how to let window up
  247. HELP!!5TH GEN WINDOW MOTOR DIED AND I NEED TO KNOW HOW TO MANUALLY LET MY WINDOW UP
  248. JDM USDM h22 injectors / any difference?
  249. 1990 prelude stalling problems
  250. 4ht gen w/Type S intake...
