PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 [304] 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Tired of this Sh1t!!
  2. Curious about the JRSC'd Ludes...
  3. Turbo People...Help me Out
  4. What kinda ECU's are you guys using?
  5. A Few Pics of the 4-2-1 Header Installed on Corey's Car
  6. Apex Dunk
  7. Engine swap...
  8. Vacuum Hose Diagram for 5th Gen Prelude
  9. blah blah blah...
  10. prelude body kit molding
  11. My Apexi N! Exhasut is too loud PLZ HELP
  12. Exhaust Question?
  13. where can i find some performance handbooks for turbo preludes
  14. 5th. Gen 'Lude Tire Questions
  15. Can Someone tell me what CODE 8 is??
  16. First Gen Lude
  17. Help me identify this underhood stuff?
  18. 2nd Gen
  19. Exhaust question
  20. Door panel removal?
  21. So what's the deal with H22 ARP studs?
  22. Quick bitch: advancing timing on '96 Lude.
  23. I was thinking about putting a turbo in my Lude
  24. break in period/proceedures on rebuilt h22a
  25. 1993 Prelude VTEC prices? Is this a good deal?
  26. Need Main Bearings for 93-96 H22A
  27. Got a question.. yes, me... a question about a 96 VTEC....
  28. FS: 16" ssr type-v rims(semi-forged)
  29. Anyone selling an ECU? for H23a (p14?) or even a p74 would work (LS Int. ecu)
  30. Who makes Valve Spings fro NON -Vtec head? (H23)
  31. collector mod
  32. chances of blowing up my motor w/turbo?
  33. Want to buy a prelude for cheap any suggestions?
  34. Clutch Problem
  35. 2.2 Prelude Heater Hose
  36. My boy ditched his teg, and bought a real car....
  37. VAFC...problem...HELP
  38. which one to get??
  39. Timing belt?
  40. AC 93 prelude
  41. Suspension..
  42. Just recived Top Fuel Stroker Kit!
  43. EASY coolant question...
  44. Will a 5th gen rad fit a 4th gen? I want a Fluidyne!!
  45. H23 manual tensioner on an H22?
  46. FS: 5gen Service Manual...
  47. A couple more questions guys...
  48. need suspension upgrade advice!!!
  49. New Cams ... problems need help.
  50. What is diameter of stock exhaust piping on a 91 2.OSi prelude please
  51. 92-95 Prelude ECU
  52. H22 jdm trans final drive?
  53. Completing the mods (?air/fuel?)
  54. another luder... or not???
  55. H22A or Factory H23A...I don't know which one to choose.
  56. Squeaky suspension?
  57. H22 Turbo Power
  58. what's the speed and rev limiter on a jdm p13 set at?
  59. Lightest 5G Prelude?
  60. H23a Injectors
  61. Resurface or Replace rotors?
  62. oil grade
  63. h23 cams
  64. Top Line MatchUP
  65. skunk2 cams
  66. ITR or Lude-SH
  67. Any one got a wrecked or Parts 94 Vtec Lude?
  68. what's it gonna sound like
  69. 4th gen manual tranny with 5th gen motor?
  70. 4 wires near crank pulley back of engine ??
  71. big problem vtec lude!!!!
  72. Opinions - should I put money into my S?
  73. FS - 99 Prelude
  74. Just bought a 98 SH. Need advice on modding.
  75. 94 Vtec problem!
  76. Compression test results on my H22A1
  77. Determining rod and main bearing colors.
  78. 5th Gen. JDM Foglights..
  79. help, how to open hood without hood release cable?
  80. NEED HELP ASPA PLEASE!! CAR does no accelerate
  81. JG Luder / Todd 94's Prelude. Torn apart. :)
  82. Adding Power lock???
  83. how much boost?
  84. is 223 whp about right for a JRSC lude?
  85. OEM Clutch disk size?
  86. changing SS tranny fluid.....Questions
  87. Pistons
  88. how much would this conversion cost all together...and some other stuff
  89. Stupidest damn question--but has a good chance in becoming real.
  90. Reference Check
  91. Lude v.s. RSX-s
  92. Squeeky brakes!
  93. Damn seized bolts!!!
  94. need info on h23a1
  95. EXhaust PoLL!!.....for my 95 Lude
  96. Anybody have a frame diagram for 3rd Gens??
  97. SH tranny on 93 block, will it work?
  98. ATTN 5th gen owners
  99. Good to be part
  100. question about exaust
  101. went to the track too.... hondaprelude.com MI meet
  102. Fidanza Flywheels?
  103. turbo h23a1 dyno charts plea.
  104. JDM Fog Light Bulbs..
  105. What kind of suspension does the JDM 5th gen Type-S have?
  106. u.s. lude motor specs and years
  107. boosted h23a1s......or you h22a punks...... Return Line fitting ?'s
  108. Exhausts for my 95 Prelude Non-VTEC....step right up.....
  109. I need help
  110. Transmission Pictures?
  111. my two preludes
  112. Went to the track last night...
  113. who has no power steering in Your car
  114. Headers give good head?
  115. AXLES!! Argh! Doesn't fit...
  116. resonator
  117. Is this a good deal or not?
  118. largest shot of nitrous on a BUILT h22a?
  119. need help install indiglo guages (4th gen)
  120. 4G transmission spline count
  121. any southern california 4th geners in here?
  122. Can the H23vtec use the H22 ECU
  123. Torque Specs for Camber Kit Installation
  124. p28 ecu
  125. H23a1
  126. anyone ever have a problem with engine bogging or backfire?
  127. whats the pattern for the plug wires on the h22?
  128. Attn: All 4th genners with 4ws i need some help.
  129. H22 Header #2.....Almost
  130. H22a tuned p72 (GSR) ECU
  131. Note to newbie trial users:
  132. Gauges, possible?
  133. sunroof jammed?!
  134. Best way to tune under/over steer...
  135. Lude can't get off it's feet
  136. What the heck just happened? This forum went to hell....
  137. 4th gen peepz, i got a question....
  138. Road Trip???
  139. FS: Some cheap parts and some prized possessions
  140. 94-96 gauge cluster conversion
  141. What size lug nuts do I need for a 93 Prelude v-tec?
  142. Major Brake Upgrade
  143. NOS Plate kit fitment issues
  144. H.I.D.!!
  145. getting my car back from the shop in the morning
  146. ATTN: 4th Gen Owners- found 2 4g's at a junkyard, need parts?
  147. automatic to manual conversion
  148. did search, need quick answer on shifters.....4th gen-5th gen
  149. In San Diego and looking for any meets or races this weekend!!!
  150. Cost of JDM Type S cams? Anyone?
  151. Rust in the Door
  152. 4th gen Si
  153. What year did they start making Type-S valve covers Red?
  154. Recognition of ODB 1 and 2....
  155. I need 411 on where to get FORGED Pistons?....for my 95
  156. FS: Prelude TypeSH wheels with tires
  157. Da Year... Da DiFF ?
  158. Type S cams for US spec H22A
  159. Informal (and last minute) Oceanside area Meet TODAY!!
  160. Which engine is better the GS-R's or Prelude's?
  161. Bypass Valve (trying to prove a point)
  162. VAFC tuning question???
  163. Mild name change: JG Luder - this
  164. sort of off topic
  165. 95 SR and SRV?
  166. Type (displacement) of Eaton blowers in Prelude JRSC?
  167. Will GSR Seats Fit in my 95..
  168. H23a1 Brethren!! Help Meeeeeeeeee!!!!!!!!!!!1
  169. Prelude SE 2001 or RSX Type S What to buy?
  170. IM SO SORRY FOR THIS BUT..........................WTB
  171. am I running rich
  172. got turbo?
  173. best turbo for 97 prelude????
  174. anyone with fmax?
  175. Could someone please explain Prelude's cable transmission?
  176. I am thinking about buying a 94 or 95 VTEC Prelude
  177. Brake Fluid
  178. What exuast is best for a V-Tech Prelude?
  179. Question! Can I put an H22 Head on an
  180. compression ?
  181. Will lexus IS300 wheels fit an 97 Prelufe Sh
  182. 89 Prelude - Will start, then won't start. Please Help.
  183. can you add an lsd on a type sh tranny?
  184. 3 inch exaust on a lude
  185. Just got my 97 H22a JDM LSD?
  186. Prelude Convertible
  187. 4th Generation rocks
  188. most recommended coilovers
  189. ATTN: All automatic 97 prelude owners. HELP
  190. Which years had All Wheel Steering?
  191. only one
  192. 3rd gen swap?
  193. useless, yet usefull...
  194. Detailed engine swap instructions for a H22
  195. Urgent-- I need a H22a4 (base model)
  196. clutch and flywheels?
  197. Anyone Parting out a 92-96 Prelude?
  198. types of Preludes???
  199. SoCal Beach meet june 29th
  200. 02 sensors?
  201. dealers...
  202. what controlls the scondary butterflies on a h23dohc?
  203. Help on map sensor probs on motor swap. please
  204. jdm header specs? non-type s
  205. Advancing Timing on the gen5
  206. Reliable N/A company..
  207. Last Try
  208. stereo wiring diagrams
  209. Can I swap tranny's?????
  210. 2nd gen
  211. rattling, need help
  212. 95 HONDA Lude SE..keep or .....
  213. lude vs. ctr
  214. SoCal PCH run anyone?
  215. EGR blockoff questions.
  216. hondaprelude.com meet on the 22nd
  217. GM Synchromesh Tranni Fluid
  218. ABS indicator light wont go off
  219. I need a quiet cat back exhaust system
  220. would an H23A (no NOT an H22A) swap be worth it in a 3rd gen?
  221. prelude styling......
  222. Turn that Engine Sideways and stick it right in that engine bay
  223. question about coil?
  224. Ok.. this is a dumb question but...
  225. Who wants to sell me their stock injectors? ('97+)
  226. help wheel hop like no budies bussiness
  227. Anyone Know?
  228. new clutch.... break in?
  229. 5th gen jdm sidemarkers
  230. question......
  231. Prelude Turbo Manifold
  232. Prelude N/A injectors?
  233. where can I get one?
  234. Suspension combination for my prelude
  235. problem: car cranks for up to 6 seconds then fires up.....
  236. custom tail lights?
  237. Which LuDe, DuDe ?
  238. 4th gen jdm h22a NEEDS HELP!!!
  239. 97 prelude
  240. who would win this race?
  241. type s motor
  242. Could someone a pic please?
  243. Cam Gear Tunning
  244. oil pressure
  245. attn: Honda318DX --header question
  246. CM stage 1
  247. Throttle Postion Sensor questions
  248. considering buying a prelude, What to look for
  249. emblems...
  250. 1/4 mile times.
