help me take my wheels off
Old Oct 15, 2003 | 03:44 PM
kidaniel's Avatar
Default pretty ****** gay but...i need help
So when I got my car back from the shop 3 weeks ago, they put on my volks for me. The other day I wanted to put the stock tires on so I could do some burnouts.
The problem is...these ******* aren't coming off...I tried pretty much everything except an impact wrench(which I don't have...yet). Do I have to take off the center cap first or something?
again....I am ashamed
Old Oct 15, 2003 | 03:50 PM
poison's Avatar
Default Re: pretty ****** gay but...i need help (kidaniel)
So I understand you are trying to remove the lug nuts now?
And did you torque them before you did "burn outs"?
Old Oct 15, 2003 | 03:51 PM
kidaniel's Avatar
Default Re: pretty ****** gay but...i need help (poison)
....I can't get the volks off to get the stock ones on...so I haven't done the burnouts yet
Old Oct 15, 2003 | 03:55 PM
bad-monkey's Avatar
take your lug wrench, while the car is on the ground, and pull like a **** (counter clockwise)to "break" the lugs, aka loosen them, do NOT remove them, just kind of crack em.
then jack up the car, put it on stands, remove the lug nuts, and put your stockies on along w/ lugs. take it off stands, and torque the lugs. you should have a torque wrench but in case you don't, pull hard (clockwise). you should be good to go.
my question is, how are you gonna do burnouts with your ss ?
Old Oct 15, 2003 | 04:40 PM
SsTiNgEr77's Avatar
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">take your lug wrench, while the car is on the ground, and pull like a **** (counter clockwise)to "break" the lugs, aka loosen them, do NOT remove them, just kind of crack em.
I think he knows how to take off a wheel on a prelude...
seems like your shop torqued the wheel lugs to much and they are stuck on...either i would get you and a friend or somehow get more leverage on your wrench to break the bolts off, i wouldn't recomend using a chemical loosener like wd-40 types of things to loosen the bolts because it might ruin the finish of your volks...
Or why not just go to the shop? they shouldn't charge you for something little like that if it was their mistake.
Old Oct 15, 2003 | 04:49 PM
Shakes's Avatar
space cadet
Default Re: (SsTiNgEr77)
a very ghetto way would be to hook some wrenches together for more leverage. i usually just stand on the wrench, but hey, do what ever works.
Old Oct 15, 2003 | 04:58 PM
aklucsarits's Avatar
New User
Don't even mess with it. You can damage the lugs and/or the studs and/or the wheels themselves.
Take it right back to the shop. Have them break each lug loose with the impact. Then put the lugs back on yourself by hand with a manual wrench. I hope they did not damage the wheels themsleves...
Andrew
Old Oct 15, 2003 | 05:01 PM
satan_srv's Avatar
Default Re: pretty ****** gay but...i need help (aklucsarits)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aklucsarits &raquo;</TD></TR><TR><TD CLASS="quote">Don't even mess with it. You can damage the lugs and/or the studs and/or the wheels themselves.
Andrew</TD></TR></TABLE>
Agreed don't touch then as you'll probably break them impact gun is the only way to get them off safely.
I never let a shop torque my wheels with the gun I give them my torque wrench or I do it myself.
Old Oct 15, 2003 | 05:05 PM
SKDRCR's Avatar
Default Re: pretty ****** gay but...i need help (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
I never let a shop torque my wheels with the gun I give them my torque wrench or I do it myself.</TD></TR></TABLE>
so what do you torque your's to
Old Oct 15, 2003 | 05:20 PM
New User
Default Re: pretty ****** gay but...i need help (SKDRCR)
Factory spec: 80 ft.lb with a torque wrench
Andrew
Old Oct 15, 2003 | 07:11 PM
LudeyKrus's Avatar
Is it that necessary to torque down the lugs w/ a torque wrench???
I always just tightened them down as hard as I could in a criss-cross pattern...?!
Old Oct 15, 2003 | 07:23 PM
rjr162's Avatar
Default Re: pretty ****** gay but...i need help (jz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz &raquo;</TD></TR><TR><TD CLASS="quote">obviously he doesnt if hes asking how to take them off leave the car on the ground. take out your lug wrench and place flush on the lug. dont allow the wrench to sway or twist. get a big *** bar and place over your lug wrench. pull like a **** and they should easily break off. then once you broke them loose jack the car up to further take them all the way off. </TD></TR></TABLE>
It's actually not hard to sheer a lug off. *DO NOT TOUCH IT YOURSELF* I'd also take it back. They tightened it wayyyy too damn much, and any of the lugs could be weaker now. I sheered one on my old car taking it off. Had a 3 foot braker bar... pulled that bitch like a **** until I felt it ease up. I was thinking sweet, I got it off! when all of a suddent the whole braker-bar fell to the ground. Lug sheered off
Old Oct 15, 2003 | 08:35 PM
kidaniel's Avatar
Default Re: (shakes)
yea I tried standing on the damn thing, using 2 ppl to pull and push, and used my 3 ton jack bar for leverage(about 3-4ft long) nothing...not a crack
Old Oct 15, 2003 | 08:45 PM
del_parker's Avatar
just take it back by the shop and tell them to loosen the lugs and let you retighten them with a torque wrench
when i use my impact wrench, i use the lowest torque setting. no problems. ARP wheel studs help though.
Old Oct 15, 2003 | 09:14 PM
93ludeSi's Avatar
you really should torque the lugs down to specs, if you tighten them unequally you risk warping your brake rotors. When the rotors heat up, they will twist in the direction of the tighter lugs, causing that dreaded vibration when you are on the brakes
Modified by 93ludeSi at 11:27 AM 10/16/2003
Old Oct 16, 2003 | 04:46 AM
LudeyKrus's Avatar
Default Re: (93ludeSi)
Well! Learn something new everyday on Honda-Tech!
Wish I could say the same about college...
Old Oct 16, 2003 | 09:01 AM
skunk2lude01's Avatar
actually if they are on there that hard, then some of your studs may still be stripped even if properly uninstalled with a impact gun. Big 10 tires(losers) stripped seven of my studs and when I went to ntb, they took them off with impact wrench and they were stripped, went back to big 10 raising hell and this guy said they werent responsible because I took it somewhere else. The reason I took it somewhere else is because they rashed on of my wheels. The majority of tire places around here are full of drunk rednecks, who dont give a **** about anything. Id rather do it myself, except for getting the tires mounted. How much do one of those machines cost that mount tires?
Old Oct 16, 2003 | 11:17 AM
93ludeSi's Avatar
well there are too types of machines, one is not too expensive, but makes a real mess out of nice alloy wheels, the other type, commonly refered to as a "stand up machine" does not touch the rim but they are much more expensive
Old Oct 16, 2003 | 04:23 PM
Steppin Razor's Avatar
New User
Definitely torque down to spec if you do any drag/autox/road racing.
I suggest putting on a small bit of anti-seize before retorquing lugnuts.
Old Oct 16, 2003 | 05:09 PM
93ludeSi's Avatar
Default Re: (Steppin Razor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steppin Razor &raquo;</TD></TR><TR><TD CLASS="quote">
I suggest putting on a small bit of anti-seize before retorquing lugnuts.</TD></TR></TABLE>
Tenzo
Dec 13, 2011 03:10 PM
sjteg
Jul 13, 2003 06:39 PM
BoostedGSRBubble
Oct 30, 2002 09:04 PM
typer464
Sep 28, 2002 05:12 PM
