View Full Version : Honda Prelude
- No injector pulse, '92 Prelude, F20B, GSR ECM
- 92 prelude trans leak at top?
- Front Brake Issues
- Having trouble lining up cam gears to install timing belt - H23A1
- Type S Front End, Spoiler
- Atts codes
- 92 prelude si
- Honda prelude msd 6200 making noise video
- Are 90-91 tailights interchangeable for 88-89 models?
- Converting 1997 Prelude from ABS brakes to non-ABS
- h22 issues
- CLUTCH PEDAL TOOOOO LIGHT, CANT SHIFT INTO ANY GEAR!!
- H22 EGR delete and P13 ecu
- 97 prelude h22a4 all motor build
- 1998 prelude lost spark while driving
- HELP leaky transmission
- jdm b20a questions???
- 5th generation speedo issue
- strange blockoff plate H22A
- 92 Prelude Si, Transmission Identification
- Possible Engine Swaps For 96 OBD2 Prelude
- About the 1982 Leude
- header links
- 92 Prelude... Electrical Problems?
- throttle issues? back fire from intake?
- Can you run an auto trans ecu on a manual car
- Alternator belt snapped. Bring it in or replace myself?
- Snapped wheel speed sensor bolt. Help!
- DEAFLUDE/NUTTYVTEC's 92 Prelude S "Bella" build thread
- EFJ's 4th Gen Re-build/Upgrade
- 4gen Lude bad Idle and high fuel consumption
- Another H23VTEC Build;a few questions
- 96 prelude euro r swap
- No start
- Backfire from Intake 94 lude f22b1
- How to tighten a loose timing belt?
- 1988 Prelude Si gearbox issue
- 98 prelude base transmission interchangeabilty?
- Prelude vtec skips
- M2U4 SH ATTS Trans and M2B4 JDM H22 LSD Cases the Same? You decide!
- 97 prelude fuel injectors not working, please help!
- New problem
- 92 prelude si auto backup fuse blows
- Lots of ticking after changing timing belt?
- Temp guage almost always reads cold?
- Rod Knock?
- Prelude to Accord Euro-r CL1 front end conversion
- Advice needed/ finding a new way to love the lude or move on??
- will sh ecu work on base model??
- 96 prelude si limp mode
- Quick h22 question
- Considering finally upgrading from stock exhaust
- H22 01 base transmission MT 3rd G locking out?
- 01 prelude injectors not firing. please help!
- Thoughts on this gates water pump?
- ECU Options
- Entirely New
- Under carriage oil leak
- Bouncy Idle problem with CEL on
- Is this causing my Shifting issues? PICS
- P1457 - Vapor Canister Vent Valve/Solenoid
- H22 turbo build questions
- edited 97-99 service manual
- Turbo H23 VTEC On the way, hopefully.
- Accord 5 lug fit Prelude?
- H23a1 to H23a4 swap
- 92 Lude keeps dying
- 96 prelude OBD2 Engine Swap help
- Why would my radiator fan be doing this?
- 89 Prelude si mod ideas
- Honda Prelude Muffler Replacement Options
- 94 prelude h22a tps wiring
- F20b swap, valvetrain noisy?
- 5 Wire OEM fog light switch question
- Is this price ridiculous? (5th gen Prelude for $4900)
- Function & Form to Koni+Ground Controls - What Hardware?
- 89 prelude si JDM b20a swap questions.
- anyone dyno a stock intake cut out internally (not just IABs removed)?
- Prelude ignition
- Bad Power Steering leak
- 1985 Prelude DX air suction valve?
- 4th gen front bumper
- 92 Prelude shifting problems
- 2001 vti-r ABS light, codes 51/53
- 2001 prelude radiator support removal
- 98 Prelude Euro R with Jackson Racing Supercharger
- Fuel injector resistance obd2 JDM h22?
- 5th Gen Prelude NA Motor Parts Availability?
- k swap
- Buying a prelude
- Where does this vacuum port goes to?
- 93 prelude h22a
- 1998 Prelude
- New to preludes
- dry sleeves for an h23a
- 98 prelude looking for suggestions
- EGR port plug
- Prelude Passenger Door lock issue
- Bank 1+2 o2 CEL codes returning
- h23a dohc vtec ecu question.
- h22a vs h23a
- 92 Prelude S restoration project
- starting issue
- Car wont start after head gasket change
- 2nd Gen 1985 PRelude fuel pump location.
- Cam cap suggestions
- h22a vtec swap vtec dont seem is working
- HELP NEEDED! Brake pedal will not hold pressure.
- What cam gears are these?
- Car doesn't start please help!!!!
- 2nd Gen Prelude Seat/interior compatibility
- Help with my pde hf1
- 3rd gen ecm compatability
- IACV wiring problems. CEL P1508
- Nothing works except my headlights and wipers. Help!
- Can someone tell me????
- Crank angle/position sensor
- All motor build?
- g22 or g23 guys
- RWD Prelude?
- whistle/belt squeal on acceleration
- H22a4 compression low?
- Massive oil leak !!! help
- oil filter relocation issues?
- No spark issue (and yes I've searched for 2 weeks straight)
- 5th Gen engine bay size
- 5th Gen SH Strange Electrical or Immobilizer Problems?
- Balance shaft pully help
- Driver side wheel Sticks out longer than passenger
- Manual Transmission Shifter Handle Compatibility for 96 Prelude
- Cold Weather starting problem 97 Base Prelude
- 01' SH/MT H22A4 compression test
- 87 lude b20a swap
- 00 Honda prelude having some problems after swap was done please help
- '92 Prelude Distributor Replacement--
- lower ball joints question
- 01 prelude transmission noise please help
- electrical problems
- Sandrail motor swap
- 01' SH ABS code #13
- Crank but wont Start after whirring noise
- Need Harmonic Balancer bearing on 1993 F22B
- Prelude Turbo Track and Drag Build
- Will Type-S Swap pass Smog?
- F20B Auto to Manual Differences Vs H22 Info Inside (Sticky if you want)
- Fuse box problems
- Prelude is wrecked :'(
- Help! 1996 prelude won't engage gears
- 5th Gen Prelude ABS delete which prop Valve?
- 1997 Prelude runs on 1 cylinder
- DRIVETRAIN SWAP
- Why didn't I get foglights?
- Car losing power briefly while driving
- Temp sensor or thermostat?
- Car Shuts off when steering wheels is all the way left/right in neutral
- New Prelude owner
- Limp mode after swapping H22A for H22A2?
- 01' SH P0172 & P0175 rich condition troubleshooting
- I need a chrome plater. recommendations?
- Climate control lights
- Prelude not shifting into gear
- HELPME!
- parts/ interchange list
- Help with timing belt.
- 2000 prelude, intermittent dying please help
- First Car. PRELUDE SL Might need some advice
- Boosted H22a4
- Help with manual tranny fluid change.
- retrofit lense and shroud 4th gen questions
- 2000 Lude N/A Street build
- rim specs
- NEED HELP!!! 01 prelude sh wire loom
- headlight bulb holder/clip?
- 4th gen SI -> 5th gen Type-SH exhaust compatibility
- 1998 Honda prelude turbo build
- 01' SH O2 sensor data confusion
- Is this an SH Axle or Base?
- Stock Tach is worthless, but Autometer is fine...
- Is my temp gauge inaccurate?
- prelude with h22a euro r engine noise vtec problem
- Immobilizer and the RED key HELP
- Honda Prelude problems!
- Went through puddle. not hydrolock
- What factory honda wheels fit the 2001 prelude
- 1997 Prelude No Crank No Start
- M2B4 JDM H22 LSD Transmission Differences... Need a rear case :)
- Anyone know a good H22a tuner in Missouri?
- Serpentine belt issues
- seat bolt sizes for 90 prelude?
- 92 Lude cranks but won't start
- f23/h23 crank swap?
- Car Randomly Died
- Are our Steering Column's adjustable?
- Oil leak after head gasket replacement
- Vaccum line diagram needed
- h22 alternator not charging battery
- H23 vtec clearance help
- 1992 Lude with blown F22A
- cams?
- Wider wheel base for a 4th gen?
- Rear Lower Control Arm B
- racing seat brackets
- Rims for 97 Prelude
- Maintenance required light 98prelude 264k kms
- JDM F23A swap into 4g Prelude. Which powersteering pump/bracket?
- Auto transmission problems
- the final verdict. finally. of a CA smog fail
- Honda Mechanic in Houston area
- H22 Euro-R Oil Pan Mystery solved
- PRELUDE SILVER PROJECT
- H23 vtec piston to valve clearance help.
- Vtec or non-vtec?
- H22a7 swap tuning help
- NEED HELP!
- Converted JDM bb4 auto to manual T2W4 which Ecu should i opt for P13 manual or P72j?
- NEED HELP!!
- Auto h23 vtec ecu help.
- no vtech/ loss of power in higher rpm after 5 speed swap
- Will f22 sohc tranny fit f22 dohc
- Prelude thermometer only reads cold.
- Knock sensor issue
- h22a swap help!!!!!! ecu/tuning prolems
- Temperamental '88
- speedometer and odometer not working
- Car Won't Start. Diagnostics all OK - Abnormal results - HELP! Don't know what to do.
- Weird whine after head gasket replacement
- El cluster lights problem.
- Here's a new electrical problem question for you all
- H22a1 cylinder 4 compression low
- Manuals
- Buying a 98 sh
- what engine my 3g prelude have?
- OEM style floor mats
- fluctuating intake manifold pressure
- Help first rebuild 94 prelude
- Where head bolts thread to
- compression test
- h23a1 to h23a vtec swap
- H22a Swap HELP!
- Bogs down while accelerating, and clutch sticks '99 prelude
- Helicoils problem
- 01 prelude engine is done!
- 1992 prelude limp mode
- testing fuel gauge ohms
- Anyone have actual ecu wiring for h22a euro-r
- IACV Coolant line location
- prelude probs
- Make sure your tail lights aren't staying on
- 92 Honda Prelude dead in the water
- Possible rubbing trouble with these Wheels? offset?
