PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 [192] 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. thermostat install
  2. nitrous question
  3. h22 head gasket
  4. Stock collector size?
  5. SS Auto Using 5 Spd ECU?
  6. 2.0undersized pistons
  7. '95 VTEC wheel offset? (searched already)
  8. USDM Open deck girdle question
  9. Ground wire kit on your 4th gen?
  10. Prelude oem springs
  11. 97 h22a4 w/ h23 oil pan?? will this work?
  12. Window Tint and Inspection issues in Raleigh, NC
  13. SH question
  14. Replacing aerial on '93 Prelude
  15. Do various differentials result in different horsepower to the wheels or is it just for traction pur
  16. Prelude Strut Brace Upper Front Tower Bar Compatibility (Search Friendly)
  17. ? on wiseco pistons
  18. EGR control solenoid
  19. sohc f22 swap
  20. JDM closed deck h22 main caps fit on open deck USDM block?
  21. How much boost on stock H22 head
  22. h22 VSS fit in H23?
  23. tranny question
  24. car won't start
  25. 1989 Prelude Si/FI--Power Steering Pressue Hose
  26. Rev matching...
  27. Preventing Wheel Hop...
  28. Need 5th gen. hood
  29. Car will not start, any ideas?
  30. H22 trans. gear ratio
  31. cant search...
  32. 1991 4WS???
  33. Will a H23 Head on F22A4 Block
  34. Gas smell?
  35. analog to digital cluster conversion 92-96 prelude wire up
  36. Question about tuning, and what my local place does.
  37. s2k seats in a lude
  38. Does this sound like a good idea!? please help!!
  39. Custom Exhaust
  40. question on f22 into h23 prelude 93
  41. different bt p13 odb1, and odb2 both usdm.
  42. 92-96 prelude 4ws how fast are yours
  43. Oil checking problem
  44. 2point6's update
  45. a few exhaust questions
  46. What can cause me to lose compression??
  47. H22 headwork...
  48. 91 S Driving Fog Lamps
  49. smelly problem
  50. v6 swap
  51. best engine?
  52. Need Help On Master Cylinder!!
  53. Brake Rotor guards????
  54. removing OEM 4th gen headlights...help please! (searched already)
  55. Boring H22A for Type S Pistons?
  56. turbo?
  57. 97 Lude manual?
  58. why the dust and smoke in vtec?
  59. Spoon p13 specs
  60. ACT etream clutch and prolite flywheel and check engine light is on?
  61. skunk2 / neuspeed / H&R
  62. Acceleration?
  63. Hybrid T3/T4?
  64. Mcculough HID's or Meccatune HID's, which is better
  65. h22 tranny issue
  66. Search is Down Need Help with '89 Prelude
  67. Shifter cables on 5th gen with obd1 jdm H22a swap?
  68. anyone with experience installing Brake Master Cylinders?
  69. !!My new shifter moddification=smoother shifting!!
  70. are f22b dual cam motors good for any forced induction?
  71. Sticky Speedo HELP !
  72. What causes flooding at startup??
  73. Rims & Tires for 4th gen prelude...
  74. T25 Turbo and H23 question
  75. 90 si 2.1(b21a1) code ?
  76. 1992 prelude headlights
  77. stage 3 crower cams
  78. Blinker speed
  79. What are the signs of a bad ignition coil/distributor??
  80. 94 Honda Prelude SI axel back exhuast choices?
  81. Abs light is on! help
  82. jdm h22a valve adjustment specs????
  83. 3rd gear in trouble!
  84. better shift knob for 5th gen?
  85. axle installation (searched)
  86. vafc vtec engagement point
  87. icm/ignitor question
  88. Something done wrong when swapped
  89. Horrible Shaking...
  90. quick question
  91. 92-96 prelude & 94-97 accord suspension same ??
  92. ??How much hp are you making with an H23??
  93. Trial user status?
  94. fitting JDM ITR wheels on 4th gen vtec
  95. Suspension (dampers) interchangeable between 4th and 5th Gen VTECS?
  96. lude oil pressure
  97. Difference between the h22 and h23
  98. disadvantage of a h22/ h23 vtec... your input
  99. CEL code 8 after race (vid inside)
  100. questions about HIDs
  101. is there a cwest bumper for a 92-96 prelude?
  102. TDC code 8
  103. Prelude wont go into gear!
  104. fuel regulator mounting locations
  105. nitrous??? 150k
  106. car smokes out muffler after sitting in driveway for a while
  107. Emission Laws
  108. 3rd Gen Cruise Control Switch Removal
  109. Which one is better?
  110. Anyone have a T-28 H23?
  111. When did your OEM clutch fail?
  112. c-pillar bar for 4th gen
  113. Need C & R radiator cap
  114. How do I check my clutch fluid?
  115. Air in the cooling system.
  116. where do i get heavy duty flywheel bolts
  117. f20b ecu
  118. Who has the FASTEST H22 chassis AM in NOR CAL?
  119. Working windows when car is off
  120. what ignition set up for 400+whp?
  121. Problems Shifting into 1st
  122. 909 prelude b21a1 [erformance ?s
  123. seats for 98 prelude
  124. Read the rules... or get docked.
  125. ??once you go synthetic you can't go back?? is this true?
  126. Prelude problem Pls Help
  127. 2001 base prelude, what would u do?
  128. Prelude Throttle Body
  129. drag radials for stock 5th gen rims?
  130. OBDII to OBDI conversion question
  131. jackson or greddy?
  132. Venom Intake Manifold questions...
  133. '98 5spd $1 clutch bolt cost me $1,650
  134. VTec kick-in on a 97-02 G2
  135. *****rim size, 19/235/35*****, will it fit a fifth gen, can i lower if it does,?????
  136. Amsoil
  137. Water Problem
  138. 98 honda prelude turbo choices
  139. Temg Guage Problem
  140. maintenance required light on..
  141. help
  142. tach problems
  143. would an 13x8 fit?
  144. Torque Converter Fluid Change?
  145. ashtray?
  146. secondary intake runners??
  147. 68mm vs. 70mm
  148. Should I Upgrade Valves?
  149. H22A4 Wiring Diagram (searched already)
  150. Engine Oil Cooler question
  151. thinking about f20b swap
  152. highflow cat make my check eng light come on?
  153. h23a1 crank in h22a4
  154. 5th Gen repair
  155. steering problem
  156. PrecisionH23a can suck a big one
  157. H22 Ignition and Fuel Injector Questions
  158. A few questions about my new 3rd gen
  159. Honda Tech, please help me find a rear subframe for 92-96 4WS lude!
  160. New 2 The Prelude and the Wonderful world of tunning...... HELP! (part2)
  161. Engine swap from h23 to h22
  162. Need advise in picking out an aftermarket limited slip differential!!!
  163. lights after acceleration
  164. WTB H23 bare block with main bearing caps and crank and
  165. h22 bo0st...stock internals
  166. Check engine light(Self check)
  167. a good place to get body fasteners (fyi)
  168. Manual Tensioner and No Balance Shafts
  169. Jdm h22 in USDM prelude
  170. turbo h23 ignition
  171. Valve Floated??
  172. wich h22a for 96 si?
  173. brake cylinder
  174. AWS swap
  175. help with alignment problem .
  176. difference in Long block H22 and short block H22
  177. wreck
  178. h23 + Crower cams (any stage)
  179. noob question
  180. H22A Connecting Rod Hardware?
  181. H22 High HP
  182. need help with a crank pulley
  183. 93 prelude h22a1
  184. Does anyone know about the H23 Crank Pulley????
  185. Spring and struck ? for 90 Prelude
  186. 97 dsm injectors.... will obd1 h22 clips fit??
  187. help with part #
  188. I need an Ecu
  189. getting ripped off?
  190. H&R sport springs & KYB shocks... anyone have this combo?
  191. h22 ground question
  192. h23a or h22 axles
  193. Throttle Help
  194. PERFORMANCE PROBLEM, info needed
  195. Head Gasket help
  196. Has anyone used a J's or J's style intake in a 4th/5th gen prelude?
  197. Tail lights MOD
  198. Spark plug diagnosis...
  199. tranny doesnt click into gear anymore
  200. Two Versions of the Euro R Intake Manifold?
  201. search is down......best springs
  202. Search is down.. how can you tell if a H22 is JDM??
  203. car idels at 1500 to 1800 rpm
  204. Type S H22 into 4th gen...complications?
  205. Calling all Clutchmasters Clutch owners
  206. new info on forged pistons with stock block!
  207. VAFC
  208. car wont crank
  209. Are All Intake Filters Built Equal?
  210. Rough Idle when warm.
  211. How to setup a BOV
  212. Dash/Center Console swap
  213. Place Racing Solid Rear Mount: Where to find?
  214. new dyno sheet as of 2 13 05
  215. Golden Eagle Manifold...what rail and regulator?
  216. Automatic tranny acting up
  217. Tokico quality?
  218. prelude idling funny
  219. Is the mechanic bullshittin me about timing??
  220. Wiggling noise coming from Clutch Fork
  221. DipStick shows no oil, No oil lights
  222. How bad is this?
  223. Quick Q. Starter from H22VTEC compatible with 2litre Prelude Engine?
  224. NEED HELP! WITH PRELUDE 98 SH
  225. Crankshaft question...
  226. h22 stroker??
  227. 99 5spd tranny problem, no more notch going into gear
  228. Failed Emission JDMH22
  229. 1986 FI Prelude surges at idle???
  230. axle question
  231. h22 valvecover replacements..Suggestions? places to buy?
  232. lowering methods.
  233. Anyone Selling Foglamps Prelude 93 SI
  234. H22A???
  235. obd1 H22A into a obd2 prelude?
  236. cam selection: stage 1 or stage 2 ?
  237. Leaking Radiator. Where can I find a replacement OEM one?
  238. Active Torque Transfer System
  239. type of exhaust??
  240. Burning smell with my '97?
  241. Help with 88 lude
  242. removing prelude deck...
  243. anybody with eibach sportlines on there prelude and didnt get a low drop?
  244. Question on JDM M2B4
  245. Motor Jacked in transit to get built!!!
  246. H23 Build with pics
  247. engine swap
  248. Bottom build question
  249. Prelude falls on its face after 2500rpm.......
  250. Valve Adjustment?
