View Full Version : Honda Prelude
- NeeD Help With COdes on 97 SH
- are all preludes usdm 97-01 the same
- eclipse ecu
- stock fog lamp?
- idle drops at red light
- aftermarket coil anyone?
- oem injector impedance?
- OBX for h22
- what is good intake for my 96 vtec lude?
- E-bay header
- buying prelude
- Jason Budd's lude
- EL gauges installed
- h22a swapped accord 6500 revlimit kicks in?
- Redline - JDM H22 block & P13 w/ USDM h22 Head??
- h22 cam timing
- h22a built head
- Suspension going out?
- WEIIIRRRRRD Noise...help me figure it out
- Which impact to get to kill the crank pulley?
- Spring Compressor.....valvetrain upgrade
- speedometer
- my RS*R exhaust clip
- 02 sensors
- Transmisison codes for the H22
- what' s defective for a code 15.
- H22A1 oil cooler needed...will pay $$$$
- cranks
- Part name needed
- Built h23 ludes runing boost...Any OIL LOSS probs?
- 97 prelude IDELS REAL HIGH I NEED HELP
- Type S cams help needed
- need help w/ ecu codes on 97 sh
- Engine/Exhaust Noise
- Seafoam = Amazing
- Driverside Axle, help please
- throw-out bearing
- anyone running a msd sci or something similar?
- water pump failure?
- For all you NA ppl, how many ponies are YOU pulling?
- Radiator fan with Koyo radiator
- H22A, drag turbo, emanage, profec ef01..anyone know how to tune?
- New supercharger for h22??
- Headgasket blew, need instruction...
- GSR Wheels on 4th Gen.
- WTB:::h22 OEM JDM or USDM pistons
- wiring up an external coil
- what pistons for more power..for h23
- What ever happened to Brady or Apexii from the old days......
- Help. Rod knock?
- Skunk2 coilovers, kyb agx...
- h22 guys what kind of compression number are you seeing?
- buying a prelude, good deal?
- Need help with A/F gauge please!
- crackling noise when putting stress on acceleration?
- Which company to buy FPR from?
- h22 syncro rings and slevves the same as h23
- FULL COILOVERS set up for 4gen and 5gen prelude's " Q "
- h23 vtec is it worth it??
- Crazy custom Intake - heard of this?
- Rebuild?
- fix, replace, or leave it alone
- h23 with h22 head what all do I need to replace?
- 92-96 prelude JDM headlight install DIY
- aluminum alloys from a 93 V-tec
- the D.A.R.E. prelude.....
- New blower on market for lude.....maybe
- Ecu code 7=tps
- Headlight Removal
- need help with shock cap removal. pix included
- Transmission Fluid/ Grease? in transmission
- Aftermarket Springs with Stock Ride Height?????
- just have a question about an exhaust leak
- buyin lude
- Brake/clutch trouble
- H22a and H23a1 intake manifold difference ???
- before and after
- h22 built
- Modifying DC header collector
- Spoiler mounting
- 98 h22 swap.
- H22 vs. H23 intake manifold
- White smoke still, after new HG (searched)
- Wondering if i should buy this 94 vtec lude
- OE Cam Markings/Letters for Type S and Standard
- wat exhaust??
- HELP!!!!! Need parts number for JDM BB6 TypeS tacho and temp meter part number.
- Unbolting the Intake Manifold h23. Its fun ever tried?
- Engine problems!!!!
- How did u keep ur HID lights in????
- Crower Cams Info, They are on sale
- hooking vafc up and code 22
- Looking for pics of 5th gen's with eibach sportlines
- OBD I Conversion / Emissions Question
- map sensor and the evap purge control solenoid valve sensor
- Good site or not?
- how does air get into the cooling system?
- Tenzo R seat install in 97 prelude?
- Questions about the greddy e-manage on a Type SH
- gaining power
- possible clutch slippage?
- new skunk2 throttle body... ??
- powerslot rotors
- crank angel sensor help
- Anti Freeze Leak help please quick i might be stuck at school.
- 4g crank same as 5g?
- Octane Question
- h22 tranny
- What would be written on a Type S piston?
- lowering springs
- Oaks Racing Prelude - Top Tuners Magazine
- Climate control and speakers not working WTF??
- 5th Gen Prelude Front bumper material?
- no fan after shut-off
- VTEC engagment
- 2.5" or 3.0" piping for turbo @5-8PSI?
- 97-99 Prelude Helms Manual
- Jeff @ Import Builder's H22a.....Real or Fake???
- H22 Tranny grind 2nd gear?
- transmission oil change
- Blown Fuse
- Good A/F ratio for H23
- H22 now runs rich at idle
- stalling...h22
- 4 lug to 5 lug conversion????????????????
- Weight reduction: removing heat shield under car?
- VSS Rewire
- caster rods
- Need advice, 1cm scratch on cylinder wall; Hone entire cylinder?
- Repetitive CELs
- Automatic tranny cables?
- crank pully machining
- question about SH suspension
- Trouble with the SS tranny!
- Full lip kit?
- Skunk2 IM & TB in EG question.....
- ecu opinion's please
- Rsx Seats In 5th gen Prelude
- skunk 2 throttle body
- SRS lights On
- how do you know if you have bad shifter cables?
- another spc camber kit issue
- people with 96 vtec's what is your engine code?
- automatic engine into a 5speed chassis.
- Accord Invidia Exhaust on 93 SI
- SH Shifter Cables and BASE Shifter Cables
- shifter cable packed it in?
- Help Needed
- running wierd?
- Motor Mount Inserts for H23
- Rebuild kit for B20A5 2.0 Si
- gonna go in a couple of days to the dyno here are my mods
- Question about exhuast differences between 92-96 and 97+
- Howling Noise?
- oil dipstick question
- FLYWHEEL TORQUE SPECS
- ignition problems need help
- Exhaust Manifold Gasket help
- Clutch Question: Clutch Damper Replacement or Removal
- cracking noise from underneath the steering wheel when the key is in the on position
- I need pics of 88 DOHC SI prelude engine(b20a5) pleeeasse
- instead of removing AC...
- Prelude 1995 vtec cold air induction kit
- Transmission Problem, Clutch? Synchro?
- who makes tha best undertdriven crank pully
- JDM Tranny help M2A4
- bb1 B motor swap has it bin done...
- OEM parts
- ran into a BIG problem while installing STR cam gears on my 98 lude..
- Where can i get these parts?
- 95 Prelude H23->H22 swap - use H23 tranny?
- underdrive pully hurt
- Anyone know about the ACT flywheel/clutch?
- wire harness odb1 aqnd odb2
- Manual Tensioner vs. Auto tensioner
- Exedy Stage 2 Cerametallic Clutch
- '92 Honda Prelude Si - H23A Timing Belt Change Interval?
- Qestion about the IAT sensor location on a 2000 Prelude?
- FM Cooling plate installed..pics for those who are wondering.
- H23 head questions
- 90 Prelude SI - Code 41 - replaced, still code!
- prelude torque converter??? HELP!!
- 4th Gen corner lights
- Type S ecu
- Skunk 2 Lower Arm
- my compression test results...any good?
- Prelude Info wanted
- H22a Idle Issues with p72 and hondata s200
- prelude quarter mile
- Buying CF Hood online, your input needed.
- 92-96 prelude exhaust question. please help
- vtec controller?? Please give me your imput, spoon? Apexi?
- Buzzing sound when car is off.
- h22 in civic?
- What if I put 0.9bar radiator cap instead of 1.1 bar?
- Wiring Harness
- jdm h22 vs. jdm h22 type s
- between the h22 h23 are the heads the only difference?
- Knocking Camber Kit
- How To: Bling Bling your Interior - Goodbye faded Carpet
- type s oversized or standard pistons with 100xxx miles on lude
- Immobilizer locked me out after swapping ECU
- Honda prelude ECU
- Overheating WOES... Please help!
- H22a vs H23
- removing shift cables on 4th gen.
- Rear Suspension: Bushings?
- Shifter problem!!
- crower in with skunk2 ex
- help!!
- Best bang for the buck
- 4th gen Antenna......
- Weird noise, may be common.. Help
- 97 Prelude stalls while driving...
- JRSC in a 99 prelude OK?
- Turbo manifold for h23 fit h22?
- brembo rotors 97-01
- OBX HELICAL LSD
- 1/4 window rubber molding question
- new timing belts?
- 90 talon turbo in an H23?
- just out ............prelude OBX LSD
- H23 Tranny swap auto to 5spd: What do you guys think?
- very dumb ques
- hooking up gauges
- Getting rid of shifter slop part II
- 4000rpm @ 80mph ... how stressful is it to an engine on gen4 lude?
- type-S cams vs. skunk 2
- is it worth getting a vtec controller?
- Balancer shaft timing Q need answer ASAP!
- H22a burning too much fuel
- looking for some help with a vafc
- putting back on ac!??
- WTB: Bare H23 block - mod approved
- Need wiring Help
- brand new 225/46/16 yokohama tires
- Tranny is leaking fluid "problem"
- engine noises, take a listen
- IACV problem, high idle... please help!
- Intake manifolds available for h22
- Thermal R&D Exhaust and JRSC
- 3rd gen turbo kit testing water
- what type of lights bulbs do i use
- tranny help ..*urgetn*
- Need help with choosing springs for my 5th gen prelude
- no compression at 900 miles
- what is a good High mileage motor oil
- JDM H22A / Coil conversion
- how to do oil analysis?
- How to Remove Parking Lights 4th Gen
