PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 [219] 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. AUTOMATIC INTO 5 SPEED???
  2. H22a block balance shafts. Do you need them?
  3. I can shift out of gear w/o the clutch.. HELP!
  4. Where to buy a GOOD H22.
  5. Skunk2 manifold just showed up.
  6. Compression change=power gain...but how much?
  7. jdm ebgine harness on u.s.d.m. prelude car
  8. What's the difference between a ODB2 and OBD1 USDM H22 heads
  9. What's the difference (if any) between a JDM & USDM H22 head
  10. ???? about tranny
  11. Stock wheel paint code?
  12. CP will soon offer pistons for your h23a's
  13. Who here has gotten their ECU reprogrammed at the dealership? I need help..
  14. H22 in 3gen.
  15. K series in lude????
  16. 1997 prelude a/c
  17. Would it be a problem..........
  18. How much is this worth..?!
  19. Brakes/Rotors Custom Kits PLEASE HELP
  20. anybody know what size are prelude injectors?
  21. N/A B20A5 What to do.?
  22. Weird Shaking...
  23. ssi5 lug on a 95 prelude
  24. Upgrade whole ignition or coil?
  25. help with my prelude
  26. max rpm on stock h22a block
  27. New to forum
  28. anyone install Taurus cupholders in 4th gen?
  29. quick header question
  30. old leather seat replacement
  31. 4ws alignment
  32. wonderin about engine and tranny swap
  33. h22/23 motor help for boost
  34. Anyone have the Helms pages for the Timing belt procedure.
  35. Help...CD Player Installation caused dash blackout
  36. check out this lude from japan ..........
  37. Fuel Filter changing
  38. h22 type s in to a 98 lude
  39. what is a vacuum line and where are they!
  40. When my car is at a stop with engine running it rev meter keeps rising and dropping?!
  41. h22 into 92 cx civic
  42. question about 1996 preludes??
  43. Maybe You can help me??
  44. oil pressure sensor...
  45. Leaking Coolant From Back of Engine, Need Help Finding Source!
  46. Weapon-R Dragon intake...
  47. VTEC For Beginners....
  48. Swappin 00 h22a4 into 97 Acura CL, will a 96 ECU work with it?
  49. JDM H22A Distributer internals "?"
  50. str fuel rial on h22a
  51. prelude struts fit accord?
  52. Jun cams and reprogramed ECU
  53. H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE?
  54. pedal clunking
  55. 89 prelude needs to sell cheap and fast!! so cal area
  56. Do you think this tranny is damaged?
  57. How To: Make a Bracket for your Ignition W/ Pics!
  58. JIC FLTA2 On a 4th Gen?
  59. headers making fluttering noise
  60. AEM V2 for 5g
  61. loose sunroof
  62. factory fog light install
  63. Which is faster Non V-Tech H23 or V-Tech H22?
  64. Paint On Dashboard
  65. Need some feedback...
  66. thermal exhaust diameter
  67. 5th Gen Bike Rack?
  68. H22 swap questions
  69. 50,000 mile 5th gen maintence?
  70. differences between h23 and f22b dohc?????????
  71. removing thermostat
  72. air conditioner repair
  73. pcv block???
  74. h22a swap troubles, help me out please
  75. 3rd gen engine swap q
  76. Stock VTEC settings for a H22
  77. Type S pistons?
  78. Prelude Buying Advice '01
  79. How do you replace the alternator belt on a jdm h22a
  80. gutted the cat
  81. How many gears in a 1998 Automatic Prelude with sports shift?
  82. Bearings
  83. i want to get more power
  84. 5th gen heater controls
  85. cheapest website to buy 1992 prelude turn signal lights
  86. A/C refrigerant use like an intercooler!!
  87. Odd Heating Problem...Very Confused, Please Help!!!!!!
  88. DIY on changing the timing belts on 92 prelude
  89. I need a wiring harness for a OBDI 96 vtec prelude
  90. Wheel sizing
  91. volt gauge sender? where to buy?
  92. 89 b20a5 questions
  93. RPM gauge jumpin and car jerkin
  94. Is a h22a4 a jdm engine?
  95. Nology PDA Dyno?? Does it work?
  96. XM Radio antenna placement
  97. VAFC HELP
  98. 1997 prelude sunroof rust?
  99. Car taken to Dealer for timing belt change... now has problems.
  100. Hoses, etc. missing or bad where air filter is. What is missing, what do I need?
  101. Those of you who did your own clutch install...........
  102. Where can I find an OEM 2000 Prelude catalytic converter?
  103. grinding/crushing noise in front of car...
  104. 5g H&r race spring question
  105. Amplifier power wire help
  106. boosted prelude numbers
  107. Prelude piston swapping
  108. suggest turbo for a 97' stock prelude
  109. need info on h22 in 92 lude
  110. OEM Part Numbers
  111. mugen parts
  112. red light a/c button
  113. JDM OBD I ECU conversion for Sportshift
  114. 91 prlude engine swap
  115. Camber question (Ingalls)
  116. Car is idling high
  117. H22a idling really high
  118. IM ABOUT TO GIVE UP ON THIS 92 PRELUDE
  119. T25 Greddy Manifold
  120. Whats wrong with my 98?
  121. h23 cranksaft question
  122. optimum sizing for falken azenis?
  123. Jdm taillights
  124. Jdm h22a header or DC sport 4-2-1 2 piece?
  125. Can't make up my mind: tein type ss or flex?
  126. RPM needle jumping around
  127. Whats wrong with my motor? Video inside.
  128. 230.3whp all motor
  129. PLEASE SIGN THIS PETITION TO SAVE NHRA DRAGSTRIP "ENGLISHTOWN"!!!
  130. H22A Tranny working or not!
  131. where is the hole in the fire wall on a 92 si
  132. where is the iat sensor??
  133. Eclipse w/ h22 Engine -HAHAHA
  134. show me some repositioned front plates, 4th g's
  135. AUTOMATIC SHIFT CABLE????
  136. SH and base 5th gen
  137. dumb q?..but i have to know
  138. h22 build in bay area
  139. Best Engine Performance Parts for H22
  140. Parking lights and gauge lights not working
  141. Removing the a/c? power?
  142. any problems/recalls on 93 ludes?
  143. 93 lude help
  144. H23 IAC H22 ??
  145. 4 wheel drive prelude
  146. Exhaust Question for my 2.2 VTEC 94 prelude
  147. 0.030 mill with skunk2 stage 1 cams....
  148. Test to evaluate car proper performance ?
  149. RPMs not dropping quickly enough under 2k
  150. How to keep the engine bay cooler?
  151. 2Step rev limiter wiring.......
  152. Turbo Timer
  153. Tranny Shifting problems...plz help
  154. Skunk 2 Intake Manifold
  155. Vafc....valuable for launching at the track
  156. Can someone tell me......
  157. venom intake manifold?
  158. h22 v-tec wiring
  159. Quick question: 2.5" or 3" exhaust for turbo at single digit psi
  160. How stop the lagging
  161. cold start question
  162. Need help to solve problem
  163. Prelude masters...
  164. H23 crank pulley
  165. TURBONATOR??????
  166. Aftermarket LSD's for T2W4 and U2Q7 transmissions???
  167. 1\4 mile times for 97 Prelude (Base) or 95 Integra (LS)
  168. Prospeed header doesnt fit
  169. Lude "bogging" while quick gas pedal command?!?
  170. Oil Streaks on top of Hood...HELP
  171. Universal Ball Joints
  172. good place to buy a trans?
  173. 4th gen bumper replacement
  174. Apexi GT Cat Back
  175. Mickey Thompson slicks sizing help!
  176. pics of 94 prelude. mostly interior and engine. would help alot
  177. Fans not working
  178. tps screw size
  179. VTEC question..
  180. 5th Gen Tanabe Springs
  181. Distributor Fit?
  182. WHat are the signs of tming that is off??
  183. To Type S or not to Type S JE Arias Eagle Rods
  184. Custom parts and peices that you would like to see for the lude?
  185. clicking/staticy noise behind dash...?
  186. 2001 Prelude door handles
  187. LSD owners.... How does the car feel after?
  188. Magna flow stuff?
  189. new forum for only va,nj,ny,pa
  190. Safe Legend dual piston caliper installation into a 4gen prelude
  191. 5w30 or 10w30
  192. my 96 lude
  193. cold air intake
  194. Need info on building a H22a1 motor full rebuild And want a 9 to 1 compression
  195. Stroking the H2.....2
  196. anyone have pics of their engine bay? 94 prelude vtec
  197. will f22 greddy exhaust bolt up too h22????
  198. Left Headlight High beam off?
  199. Cams give power?
  200. 4-2-1 or 4-1
  201. Would you get an h22 from an insurance company?
  202. Painted calipers and brembo rotors *PICS*
  203. Rear Bearing Replacement
  204. New clutch
  205. Which is better
  206. How are Kamikaze headers these days for a H22
  207. Does anyone know if there's any chance of Hasport making a swap kit for a prelude?
  208. What years/models had which console?
  209. Question About Replacing Some Parts Around The Axle?
  210. 87 gas in a Prelude
  211. HOW DO I WIRE MSD?!?
  212. Part Number or Size for this Part on the Throttle Body IDLE
  213. removing antenna
  214. Unorthodox racing pulleys
  215. CALLING ALL TURBO H22A OWNERS
  216. Can A Usdm head work on a Jdm block
  217. EGR block-off plate
  218. 94 prelude M/T needs new engine
  219. Question on Painting Wheels
  220. Timing Belt Parts Necessary now
  221. Need info on H22A2
  222. Please HELP with tach problem
  223. 3rd gen lude rims
  224. restarting problems
  225. Honda Fuel Pump Compatibilty...
  226. Exhaust
  227. HELP!! Installed Tein SS and squeaking like crazy
  228. 5G Stock Exhaust On 4G?
  229. After stalling, cant start after about a minute
  230. intercooler sprayer
  231. Nitrous vs. Chipped ECU
  232. Question on 5th Gen JDM Power Folding Mirrors!
  233. h22a4 block build
  234. What will fit in an 87 lude??
  235. P0170/P0172 Codes
  236. Carbon Fiber Emblems
  237. Piston to Valve clearance
  238. triple pillar gauge pod? cant find one anywhere...help
  239. VSS SENSOR LOCATION NEEDED PLEASE! FOR A 4TH GEN 94 MANUAL PRELUDE
  240. Where do these parts go?
  241. motor oil?
  242. best headers for a prelude?
  243. cleaning engine?
  244. F20b Block strength??
  245. QUICK QUESTION----->Prelude idle control valve!!!!!
  246. Rocker Question
  247. How Much??
  248. Timing belt damage to engine
  249. SH Headstuds are different?!?!
  250. New Problems with the Lude
