PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 [266] 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Brake Light Bulb Replacement
  2. radiator?
  3. Rear Speakers Don't Work with Head Unit
  4. 5th Gen LSD
  5. need help with headlight
  6. F-max kit on the prelude
  7. 2.5" piping on H22A with GReddy header?
  8. Prelude S mods
  9. Please help me! prelude 2.2 vtec 4ws
  10. wheres my redline at?
  11. wirg questions about tachometer
  12. Doors & Cat & more.........
  13. any body using an aem fuel press. regulator on a stock rail?
  14. help on h23
  15. Cleaning Throttle Body and Intake Plenum
  16. 2" primaries to big for a All out Allmotor header ? running big cams ?
  17. possible to completely remove balance shafts, not just disable them.
  18. H22a4 Valve assembly question Help Please!!!
  19. f max turbo kit for sale $2000
  20. H22a here
  21. those with you balance shafts ELIMINATED
  22. How far can i bore a built H23 to?
  23. H22A1 Timming Belt wont stay on
  24. Rota brake clearence question
  25. Weight of an H22-Head?
  26. cam gears and cam shaft
  27. checking ecu codes
  28. h23 piston options???
  29. how much is a tranny worth???
  30. How many luders are running with a lightweight flywheel?
  31. Boosted Lude oil pump failure
  32. Quick Spark Plug Question
  33. ECU trouble Codes
  34. Jdm engine specs on all the jdm engines including the h23dohc vtec and h22 vtec and type s
  35. Wheels?
  36. H22 timing belt tension
  37. Secondary O2 sensor
  38. Suspension Dilema
  39. Another Message from your Mod, Please read
  40. factory fuel pump
  41. type s cams help
  42. What is the interchange on 5th gen base 5 spd ecus?
  43. port and polished
  44. What is the difference between these DC headers??
  45. How to change the power steering fluid??
  46. cel jumper in 4th gen?
  47. what should my compression levels be? and what is egr?
  48. can i solder a broken bolt?
  49. Suspension.
  50. Where can i find some prelude vids??
  51. wtb: 1995 prelude vtec helm's manual
  52. Hey peeps, i posted yesterday that my car sux...
  53. Where to buy Energy Suspension Motor Mount Inserts?
  54. uberteg chip
  55. what's a good FPR?
  56. h22a block, h23a tranny
  57. 5th gen konis on 4th gen?
  58. fuel pressure regulator
  59. H22 JDM motor swap
  60. I think I'm losing compression!!
  61. Syncromesh with a JDM H22 LSD?
  62. Getting Hondata, few tuning Q's!
  63. i need a H/F series tranny or tranny casing, H23 head etc, H series block
  64. wheel bearings?
  65. 5th gen steering wheel.. *sigh*
  66. Tein BASIC Coilovers..
  67. tranny mount parts for sale - posted in classifieds
  68. My black SS (SuperSlow) Lude.. n00b pictures
  69. Got some suspension problems! !
  70. 3rd gen suspension parts
  71. engine needed
  72. I am tryin to sell these wheels of my 1996 Prelude that I no longer have...
  73. Any of you guys run a 1 Layer headgasket?
  74. **Help**Skunk2 coilover install
  75. 5th Gen Gas Milage
  76. where can i find a block for a h23? brand new head with a possible cracked block
  77. please help me out!!!!!!!!! luder 4 life
  78. 1988 S?
  79. South Florida peeps plz help, my car is a mess, cosmetically dings and scratches
  80. HELP \\\\\\installation hyper blinks/////// HELP
  81. Stepped Sleeves?
  82. 4th or 5th gen??
  83. V-AFC on 99 SH
  84. Help Please!
  85. trouble finding parts
  86. HELP again
  87. ecu threw me a code 65!!!!!!!!!!
  88. can't find ecu!!
  89. exhaust manifold bolt pattern
  90. anyone looking to buy a h23 turbo manifold
  91. ***** Need a H22 longblock ******
  92. Dash Swap? 5g into 4g? Will it work???
  93. header installation guidelines?
  94. now this is a big ass prelude meet
  95. clutch in 00 type sh
  96. Lets see some time slips
  97. Prototype Header #5, This "Should" Be The One
  98. rotating assembly installation
  99. 3rd generation engine swaps
  100. NOS for 5th gen - Got any recommendations?
  101. hondata clutch switch???
  102. Will these rims fit?
  103. ABS Braking
  104. Carbotech pads?
  105. Tires,wheels....
  106. Quick H22A power
  107. need Help wiring jdm headlight
  108. Automatic to manual Swap info and parts needed.
  109. People with 1992 4WS Preludes!!
  110. compression
  111. Need Help with Fuel Line!! asap
  112. Need help!
  113. help
  114. 4th gen head on 5th gen block
  115. Will a VTEC Neuspeed strut tower bar fit my H23??
  116. I Need a Honda Guru's help
  117. tappingg after rebuild
  118. Car wont start
  119. holy shit!! tornado just went by my house and almost hit my car!!!
  120. Question on APEX Lowering Springs on 5th Gen
  121. How do I post in the classifieds?
  122. Billet vs Forged?
  123. will an s2000 tranny fit in a 00 lude?
  124. yozausa email me
  125. 5th gen center console removal....I need to change a bulb
  126. Need opinions/reviews on Nippon wheels..
  127. ebay clutch any good?
  128. 4th Gen Heater problems
  129. JE pistons... Stock Sleeves
  130. identify type s cams
  131. Engine is rebuilt - use regular or syntetic oil for break-in?
  132. Type SH shocks vs. Base shocks
  133. please help asap. car is stuck in neutral?!
  134. AHH.. They tried jacking my CAR while I was Finding Nemo..
  135. 1992-1996 prelude question very simple
  136. looking for a post by firedrake...
  137. HELP: Ignition Switch & Door Keyholes
  138. Anyone put a trailer hitch on their lude?
  139. need help bleeding clutch
  140. quick ? couldnt find the answer searching ht,
  141. How much is a 94 Si worth
  142. Alternator belt, engine swappers please help
  143. Turbo problems .....please help
  144. Which rings for boosting?
  145. someone help
  146. 3rd gen poly bushings
  147. 13 inch rims with slicks ?
  148. need picture of h23 intake manifold vacum hoses
  149. Looking for a VIS OEM style CF hood 4th gen. Best place to buy?
  150. Oil question, is it safe to ride on.....
  151. *pic* tell me the correct firing order
  152. Prelude head gasket size
  153. Best cams for the h23?
  154. OT: 1st place in STS both days at SoloI
  155. What is an acceptable amount to pay for micropolish & balance teh crank
  156. spoiler
  157. build time : h23 block and h22 block differences
  158. Opinions on this motor build...
  159. lossing top end
  160. '91, bad luck...
  161. new track times ..bad
  162. My car sounds like crap, help please....
  163. OT: Another lude lost.
  164. JDM H22 header gasket
  165. Anyone do a b16a in a 3rd Gen?
  166. B20 & B21 Tranny Swap Will It Work
  167. valve interference from new rods
  168. problem starting
  169. Forged Internals
  170. overheating problem (94 prelude vtec)
  171. what would be the signs of bad rings?
  172. h23 timing help
  173. GReddy Header Question??
  174. throttle body spacers
  175. Foglight install.
  176. kyb shocks...which one to get?
  177. clicking on right front side.... when i turn....
  178. h22 into 92 lude help!!
  179. Tensioner Assembly and Oil Pump
  180. Burning Oil
  181. Camber correction for 99 Type SH Lude
  182. $200 what to do?
  183. problems with the gas guage
  184. Guage Bezel Install
  185. 94+ console upgrade caution light wiring
  186. anyone have a passenger side grille?
  187. Exhausts and your opnions...
  188. Transmission Help
  189. question about weight reduction? fifth gen lude.
  190. someone carfax this car for me something is not right!!!!
  191. Valve Adjustment
  192. What CC's are OBDO Prelude injectors? Where can I get them?
  193. something is crooked and its no bueno
  194. JG Cam Gear Settings
  195. Lowering Springs
  196. ecu upgrade
  197. Skyline Conversion Kit ?????
  198. H22A1 coolant flow direction
  199. installed h22!
  200. No PS or AC which belt?
  201. help!! rotating thudding sounds coming from tires/suspension???
  202. jun cams
  203. JRSC only $$$$$$$1600
  204. Overheating HELP!!!
  205. H23 VTEC??
  206. open,close deck?
  207. Type-S cams (from ATR) in 95 VTEC?
  208. Axle breakage
  209. Annoying Rattle Found!!!(I hope)
  210. lower ball joint, how screwed am i?
  211. Turboed luders/hondata users. Please help.
  212. ac controls wont work..and i live in Florida+summer=:(
  213. tools for valve adjustment
  214. what is the fastest street turbo prelude what is it time
  215. 96 Prelude SI high flow cat which brand ?
  216. Are gears from various (H series, f series) transmissions interchangable?
  217. What does a sleeved h22 block look like?
  218. stock flywheel question?
  219. Cracked Wheel Studs? How hard to replace?
  220. h22 - Does Engine gasket manufacturers...make a difference?
  221. need your idea's/opinions
  222. need turbo help for my h22 accord
  223. Camshafts: manual Vs automatoic!
  224. Top Secret... Shhhh.
  225. Newb.....please help???? jdm 96 prelude headlights????
  226. Desicons Desicons
  227. Removal of Cams Housing
  228. What would be the signs of a bad p/s pump??
  229. Nissan 350Z Blue...paint code?!
  230. JDM h22 exhaust collector?
  231. pulleys
  232. wheel bearing....
  233. Short shifter swap...
  234. completely lost.....
  235. Euro R intake manifold... Question.
  236. jdm headlight..harness?
  237. exhaust piping question
  238. reading the helms, question about bearing install
  239. Red Valve Cover or Blue?
  240. GT4 Shots
  241. Brake ducts partII
  242. lower ball joint, please help!!
  243. Rebuilding my H22 - look at my cylinders (pics)
  244. USDM Quaife will replace JDM H22A Differential?
  245. Anyone know of a Honda / Acura sunroof that would fit ...
  246. H23 machining by goldeneagle
  247. ATTN: Members w/ Agressive, Low Body Kits
  248. H22 problems
  249. 5th gen black housing headlights
  250. quick quesion
