View Full Version : Honda Prelude
- can it be done???
- swaping h22a out with b18a1 in 98 prelude
- Rim/Wheel compatibility between 92-96 to 97-01
- h22a4 timing belt
- h22a4 best head bolts/ studs to go with?
- 2.0I wont start.
- Checking In.
- 2nd gear grind
- honda prelude mirror 1e generation
- question about fuel pump power connector
- Prelude basemap from Phearable not working properly
- Prelude 5spd swap - Should I?... and what else would I need besides this...
- Obd 1 2 wire iacv fit obd2 manifold
- 97 Prelude SH ATTS LIGHT ON?
- f22b1 in prelude
- Rebuilding my first H22a4. Any Tips or pointers?
- Weird noises help
- pde hf-1 euro r ?
- h23v qith k mani ??
- New Owner 96 Prelude si
- new member approaching 97 SH clutch job
- 1993 prelude door latch broken, help???
- 90-91 prelude negative battery cable length
- Rare JDM Parts Manual
- H23A Vtec! Questions
- Fuel Pump not priming
- Oil leak investigation
- H22a with cracked pistons?
- electrical problems!
- Vintage 1988 Prelude 2.0 Si
- honda preludes pros and cons?
- 1992 SI HID Problem
- What is the correct vacuum hose size for 93 Honda Prelude SI
- For Sale: 97 Prelude SH Hunter Green.
- Wiring for 5 speed swap questions!!! NEED HELP
- funny noise when engine warms up
- best vtec for my honda prelude $$$
- Thermal R&D Exhaust Review Model CL Part B117-C117 Prelude SH
- Can front quarter panels be used as rear quarter panels!?
- Are H23 balance shafts
- Preludes????
- Help identifying a connector
- can a ecu be the cause of burning oil?
- help with pigtail 0bd2 to 0bd1 look at pic
- If someone can't figure this out, I'm burning this car down.
- Radiator fitment issues
- Stealing Preludes?
- Timing Belt Cover Removal
- help: front motor mount engine bracket
- 1993 honda prelude door latch, help!
- EGR problem H22A obd1
- 2000 prelude brake lights
- TPS issue.
- o2 question
- 1997 prelude need some insight!
- ecu help...
- exhaust help
- new member! 92 prelude s
- performance parts
- Desperately need help
- Car wont Start
- h22a full wiring diagram for project
- flashing oil light? but plenty of oil
- what are the differences betwen f20a accord and f20a prelude engines?
- Common tranny problems
- nippon racing frm compatability ?
- 4th Gen Sunroof Size Question
- Camshafts for h22a1 (question)
- what oil to use and how many quarts
- wishbones and balljoints
- Bumper sidelight Q
- tire sizing....
- oil pump question
- my lowbeam headlights do not work.how do I fix this?
- 94 prelude swap problem.
- H22a piston ring question
- jdm center console?
- cat question ??
- Car starts but dies instantly
- oil leak/possible related issue
- random engine dying issue
- apexcone model harrier replacement blub help
- Help: Running very rough
- h23v questions & build
- no spark cold weather
- SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, PICS REQURED (as links) -Jan- Mar 2013
- WANTED TO BUY ONLY :: NO TRIAL USERS, NO PICTURES - Jan- Mar 2013
- OIL PRESSURE SWITCH PIN NUMBER?????
- 2000 Prelude Auto...How much longer will it last?
- overheating problems
- 5th gen. prelude oxygen sensor locations
- few small engine swap questions,
- Question
- piston/sleeve/FRM/rebuild questions...
- USDM PDE head vs EURO R PDE head
- looking to buy car that needs work. head tapping noise.
- Sunroof wind deflector
- Anybody got pics of 4th gen with Track R's?
- calipers interchangeable?
- What the difference
- 1993 Prelude Aftermarket Tail lights
- P13-A12 which injectors?
- It's been a long road and a long time.... my final build.
- photoshop request
- 4th gen wiring diagram
- What "H" emblem is this off of?
- 4g prelude cluster
- No acceleration and Hesitation - Please Help
- SiR F20b head swap on F20a dohc block
- tool list to change upper control arm
- H22 vw polo HELPPP start up
- 2001 Prelude. No key.
- Bleeding coolant system with rad cap off, blowing out radiator
- Fan not kicking on, circuit good, new fan switch
- New O2 sensors but ECU code 1, 2 in '89 Prelude Si
- Fuse box diagram 95 Prelude Se?
- h23 bottom/h22 vtech head NEED HELP.
- 4th gen Prelude backfire, no start?
- 44 or 60
- Grounded main relay out
- 89 prelude 2.0 build
- k2h/k2f anyone running this setup
- Fans not working 95 Prelude se
- BB6 J35 SWAP
- egr cleaning?
- How do i tell which h22a motor i have?
- h23a vtec build PROBLEMS PLZ HELP
- prelude 90 si a/c bypass belt?
- 95 prelude Jumped fan connector now wont start? fuel pump not priming
- Need help..98 Prelude shakes when accelerating, can hear noise from moving parts.
- Prelude Builds - links only
- 1995 Prelude Project
- suspension problem
- Help PLS- Misfire No 1 & 2 Cylinder
- 93 Si VTEC issues...Help!
- F22a1 dizzy problems
- P0420 code HELP!!
- Swapping VTEC H22a into 93 Prelude Si (non-vtec)
- having issues
- having issues
- 96 swap, h23 to f22b CPS help!!
- H22 Help on Prelude
- H22A do I need the vtec pressure switch? and other questions
- High rpm stutter problem, I need help!
- oil in plugs and honda fluids
- HELPP NEW TO HONDAS NEED HELP WITH A FEW QUESTIONS :)
- 98 T Belt 119K
- H22a Idle fluctuation - VIDEO - help me pinpoint!
- h23a1 intake manifold leak? HELP!
- cold air intake
- electric power seats conversion?
- New Lude Build
- H23a to JDM f22b dohc swap!!
- innovative traction bar question??
- Welcome back 98VTEC!
- 1992 prelude help
- fabrication on PLM TRI-Y hytech replica header
- from what year and engine do I buy the Manual tensioner?
- Prelude Idles Up and down Up and Down
- h22a map sensor wiring
- h23 driver side motor mount, same as h22a??
- ►►►►►►►►►WE HAVE ADDED SERVICE MANUALS◄◄◄◄◄◄◄◄◄
- h23a1 valve adjustment
- k20 vs h22
- prelude builds
- torque specs ?
- T2T4 LSD transmission fit a 94 lude with 92 h22a
- NewBie HeRe!! new 2001 Type SH owner
- not related to a prelude need opinions
- Urgent help needed!!
- help me please im sol
- 96 h23 to f22b help!! SENSOR HELP??
- Will OEM lug nuts bolt down properly - ARP extended studs, 15MM spacer, OEM wheels
- Radio Code for my 2001 Honda Prelude
- Euro-r Intake Manifold
- Daytime running lights, gauge cluster lights, and running brake lights>>not working
- Clutch problem - Pedal needs to be slammed to the floor to shift. Lude 95 VTEC
- hepl h22 die after 30 seconds
- wiring iabs
- This girl needs some HELP! Automatic 5th Gen H22 Swap
- boring h23 ?
- h22a4 to f20b swap wiring help
- Stock color and standard spoiler
- H22A no compression
- trying to sell the right way but dont know how
- iab observation
- h22 injector question
- 93 Prelude Si Wiring Issue Advice
- Starter Problem?? 1995 Prelude VTEC
- 89 lude burns oil. Looking to upgrade B20a5
- Replacing catalytic converter.
- 3rd gen sounds like a diesel after valve adjustment
- 3rd Gen needing mods
- Strange problem after warm up
- 1996 honda prelude map sensor hook up
- 5th Gen H22A4 Problems
- h22 accord first time turbo build HELP many questions
- Typical idle issue but common fixes dont work..
- Shaved engine bay and fuse box relocation
- Motor Mount
- Parking light wiring issue
- Prelude bushing options
- 1993 Prelude Engine Swap HELP
- need help asap please
- evo turbo on h22a
- BoostedBB6 Build Thread
- What's the deal
- Intermittent low/sputtering idle @ start up
- 98 prelude issues!!! Need help and confirmation ASAP!
- Can't get smogged because of this port on manifold
- new car question
- short shifter adapter question
- oem vs energy suspension bushings?
- Can u cut coils out of springs on a 97 prelude?
- power steering whine
- Bogging when throttle opened
- brake and battery light keep flickering on
- looking to by a Prelude soon
- jdm h22a vtec not working/oil pressure problem
- Catalytic converter options
- 98 Prelude engine cut out while driving
- Thinking of buying a gen 3 prelude. Got questions.
- Put my car in a ditch... now won't move forward. Clutch? HELP please
- 95 honda prelude heat stop working
- Moisture inside my BB6
- S2K steering wheel in 5th gen
- Question on my 93 prelude lower ball joints. Please HELP!!!
- usdm h22a4 to jdm h22
- Has anyone tried this....?
- 94 prelude idle and running problem
- new tune 302hp
- First upgrades for my 98 prelude 1.5k to drop, NEED ADVICE
- 1997 h22 high fuel pressure searched, missing on cyl 2 and 4
- 5th gen prelude fog lights
- H22a4 Swap
- 1997 honda prelude , white smoke from exhaust ?
- Serious hesitation on my '92 Prelude Si
- ODB2 H22a into a 1995 Prelude?
- oil stick keeps popping off
- 97 Prelude - Major Problems Fuse 14
- installing sunroof panel
- I was thinking to "dub" my whip bb6
- Quicker steering rack in a prelude ?
- h22A turbo
- H23A1 Crankshaft Keyway issue
- 91 prelude 2.1 Si computer code help
- Whining Noise around 800-1500rpm around Timing Belt
- 95 honda prelude brake lamp light on
- what distributors can I use?
- Major problems fuse 14
