- engine swap
- OBD 2??
- ABS Problems - I have searched
- H22A...iddle trouble!
- CAT converter mods
- where can I get them in A ??, not just standard...
- Passenger window randomly out..
- PART # needed
- H23 boost question
- Traany fluid
- skunk2 cam gears
- 5th gen 1999 lude with only 1OS sensor stock. WTF?!?!
- cardomain prelude ricer....
- throttle body
- The story of a lifetime and headache
- is anyone selling a h22 engine or block???
- ABS & TCS warning lights illuminating... Why?
- throttle body spacer
- 90 in an 89??? help please asap!!!!!
- Need Input: Buying 4th Gen VTEC.
- Quick question: shock know fix
- limp mode
- best motor mods for h23a have 3000 to spend
- Fixing rear view mirror...
- Where to build h22
- VAFC Help
- prelude 5th gen eyelids
- 5th Gen. Fog lights?
- 5+ quarts of oil????
- Best muffler........
- Will FITV affect idle after warm up?
- flashing D4 light
- AC and Turbo on a 4th gen.
- Spring and shock install
- water in my trunk
- stock alloy 5th gen wheel weight
- Detailed diagram of h22 bottom end..
- lsd bad traction.
- idle question
- Engine Management
- JDM H22A short or long block.Also some Stage 2 cams
- Crower Stage 1 cams (H23)
- TURBO ON EBAY
- steering wheel question
- antenna question
- single butterfly IM good for h22a?
- found the CLUTCH problem
- car runs fine with IAVC unpluged
- Trip to VIR raceway and dynoed my car.
- M2B4 Tranny Identification
- In car Sounds
- Dyno Day Revenge
- injectors
- Climate Control Vent Selector Problem (5th Gen)
- H22a Idle Problems..
- 2.5" mandrel bend w/ES tuning review
- Went to the drag strip...got owned
- Energy suspension complete master bushing set?
- connector wire questions
- installing type s pistons without honing.....quick
- usdm vtec ~vs~ jdm vtec
- need help on 94 lude!
- vtec eattin oil
- safe mode?
- guess who finally has another Honda....
- obd1 p13 ecu wiring
- NEED HELP ON MY 4TH GENERATION LUDE, REALLY NEED TO KNOW!
- Need Help taking tail lights out
- what can i do to unbolt my muffler off?
- question about light flywheels
- 95 HONDA PRELUDE
- H22 Question!!
- Damn my seven sided lug nuts
- H22a4 Turbo, What size injectors?
- bored what to do?!!!!
- I HAVE LOST PRESSURE IN MY CLUTCH!!!!!!!
- What do I need?
- VTEC transmission reassembly problem
- Cat-Back exaust installation
- body parts
- forbidden Motorsports 1/4 time increases
- my lude is finaly back on the road
- need to know how low front lips are
- I finally got a VTEC lude :D
- 2000 type SH build i need help
- Removing driver's side rear seat
- where 2 jack up 5th gen
- head bolt torque specs
- Lowering Spring Installation
- what is the code of the jdm transmission
- I need to barrow an OBD2 dizzy please!!!
- best power adders B20
- So I Am About To Build A Performance Engine
- Traction problem
- BB6 auto trans
- how is this possible
- What's Up Guys
- How often are ludes stolen?
- Guy with the 700 sum whp lude!!!???
- H22/H23 Hybred- how much trouble?
- rear wheel drive prelude
- HELP ME PLEASE!! TRANNY PROBLEMS!!
- timing
- piston pin location?
- JDM Aero Magic lip???
- Aftermarket shifter bushings? Who has used them?
- h22 hatch with jdm headlights
- how do i adjust shift cables on a 88 prelude?
- I need to find a good Honda mechanic in the bay area or San Jose.
- Anyone successfully running a P72 hondata?
- Best a/c compatible turbo manifold?
- Vtec Problems
- quick question on rebuilding to stock specs
- Transmission innards
- Supercharger with type s pistons??
- killswitch!
- Compustar 2W8000FM-AS alarm for 96 Prelude
- supercharging safer?
- Dash problem *HELP*
- Idling problems...with shaking engine
- Test pipe flanges, catalytic traingle source help?
- Needs help in changing antenna 92 prelude.
- new clutch bad after 200 miles?
- type s pistons
- Rims without lowering........
- how noticable is vtec?
- idle
- 200 HP?
- Air intake problems..Help
- 95 lude with a 96 special edition gauge cluster?? GGrr
- Does anyone know about alarms?
- NEED SPEC. H 22 VALVE LASH
- JDM h22 transmission and LSD Question
- 98 h22
- where about is the fuel filter ad clutch enquiries
- change power window motor
- any shops that will install lsd on the east coast?
- helms idle adjustment procedure
- my vtec wont kick in...:(
- b series into 3rd gen
- e-brake help,
- Sh h22 into 4th gen
- Need Help with Tranny fluid
- please I need help!
- JDM H22A Engine build for turbo
- 6500 rpm rev limit on JDM H22a w/ P13...
- h23 to h23VTEC?? questions
- Where are Hytech h22 headers?
- F22B parts
- Oil leak from head?
- A/C compressor question
- putting h22 pistons in a h23
- 92-96 1 piece headlights
- 5th generation emblems
- level 10
- ??h22 parts interchangeable between 92-95 & 96-98??
- Does My Oil Look Normal??
- Engine Managent Options
- cat spec
- Where is the fuel cut off?
- Cooper Tires?
- where to go next?
- Rattling noise around 2800-3000 rpm. Anyone familiar with ...
- metallic scratch/squeal from driver side of motor
- New clutch and flywheel do i have to pull engine?????
- What is the difference between p28 and p72 ECU
- Weapon r intake?
- Plz Sticky This Someone
- my setup
- Which one to get?
- What size is the outlet diameter
- help with stuttering?
- how do i remove my emisions controls?
- Navigation in a 5th gen.
- ib motorsports
- What size injectors?
- Do all 5th gens have amber interior lighting?
- Who can sleeve me up!
- Electrical?
- What does a Hondata Intake Manifold Gasket do? maintance questions ?
- TURBO 5TH GEN EMS
- what bolts do you use to check tranny fluid on a 1992 lude si 5spd tranny #M2S4
- Fastest 3rd gen Prelude?
- aftermarket injectors... H22 Euro R
- exedy stage 1 or stage 2 clutch
- tsudo exhaust
- SPS service connector
- H22 block year identification????
- h22 alternator problem
- Atts question??
- resleave for high compression build?
- cel p0441 EVAP Emission Control System Improper Purge Flow
- AEM short ram vs V2
- h22a distributor problems
- AM I STUPID OR ARE MY FRIENDS?
- tranny choice
- H22 help needed in accord
- RSX tail light conversion=NICE
- Can the radiator coollant be flushed by DIY
- How you my sleeves look?
- is it my clutch?
- MY SWAP SOUNDS LIKE ITS DIEING
- CAN YOU USE SATURATED INJECTORS ON A 98 5th gen
- lude nitrous
- Autozone Duralast Gold brake pads rock!
- antenna hasnt worked since ive owned the car
- whats good intercooler piping???
- afc for the jdm ??
- Changing brake pads
- racing hart c5 3 piece
- cel light codes how do i find them on a 1992 honda prelude si
- where can run a mp power wire 4gauge? 1992 prelude si
- NEW TRANSMISSION
- Motor Mounts
- EGR control device not working
- Where is the VSS on a SH located?
- flywheel question
- H23A to H22A, what all parts are needed?
- wire mesh instead ofair filter.
- is this a good motor setup for fi?
- Advice - Looking to Buy a 4th Gen. Lude
- Rear Quater window Rubber???
- For those who have swapped out their H series final drive
- Clutch squealing/whining
- Fuel and Temp gague
- Painted my block. Debating looks
- O2 sensor
- supercharged h23??
- user rating points
- questions on H23 starter
- Obx throttle body spacer??
- Someone tell/show me how to
- Question About Install of Cam Seal?
- AEM underdrive pulleys
- How hard is replacing the o2 sensor in a 2000 'lude?
- Springs and Coilovers
- K20 into a Prelude
- Paint my prelude
- New motor changed - advice
- New clutch too smooth?
- 95 lude
- Does anybody know whay company makes engine mounts for a 97 prelude.......
- whats better uberdata or vafc???
- where should I set Vtec at.
- 97 Prelude Suspension
- injector ohms
- Odd problem with HID Kit 4th Gen
- Stock center caps are fadding
- boosted lude with accord trans?? opinions?
- 93 h23a1
