PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 [196] 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. ATTS Light
  2. Terms??
  3. Removing Rear Center Console 94
  4. idle kill (searched)
  5. all motor h22, a few questions
  6. smog equipments, need you help asap.
  7. Tanabe Sustec Pro S-S Coilovers
  8. Trouble with Honda Prelude Gearbox
  9. maintenance required light (5th gen)
  10. auto preulde 5sp swap
  11. Cams question
  12. Best cams to use
  13. distributor
  14. thinking about this from another member
  15. Pulling code for check engine light...
  16. auto to 5spd??
  17. Would anyone be interested in a prelude poster?
  18. identify this plug on h23a1 please
  19. New high hp H23VTEC build (in progress - 56K alert)
  20. Will these injector work on Honda Prelude 95 OBD1 used for Turbo h23
  21. Is it possible to get a 2.25" inlet muffler and weld it to 2.5 custom piping?
  22. 1990 Prelude 2.0 Si cv halfshaft problem
  23. JDM climate controle on your 5 th gen
  24. exmag rusting on me?
  25. just put in tokico springs/struts
  26. hesitation fixed!
  27. Oil Leak: from Oil Cooler and Coolant Lines
  28. Type SH skirts and rear lips, Under OEM Kits
  29. abs light acts diiferent in cold weather...
  30. jdm h22a engine service manual.
  31. materials for intake
  32. need help with emissions, EVAP??!?
  33. Best cams for the power
  34. zex 2001 Prelude??
  35. RESULTS OF COMPRESSION TEST, OIL CONSUMPTION TEST, UPDATE ON DASH LIGHTS
  36. Swapped ECU's, idle is surging. any ideas?
  37. Problem with high flow cat-- engine light and runs rich????
  38. lsd worth it?
  39. Suspension inquiry
  40. Built h22 bearings question.
  41. bouncy idle?!?!?!
  42. H22A4=(SH OR NORMAL LUDE??)
  43. Need pics of moddified stock bumpers (4th gen) for intercooler clearence
  44. I REALLY NEED HELP ON HEADERS PLZ THX
  45. H22 HEADER HELP
  46. p13 ecu help (need to make it stock program again )
  47. 95 Lude, JDM headlights, what size bulbs?
  48. ..... a little comfused about the resistor box compatability
  49. h22 lsd
  50. JDM headlights pealing
  51. tie rod ends for my 4th gen vtec
  52. Knocking in rear, bad bushings...?
  53. 5th Gen TurnSignal & marker Bulbs?
  54. JDM Prelude A/C
  55. Apex'i World Sport2
  56. Help me out with this idle(searched)
  57. ABS light on after dropping car 2 inches
  58. Compression Test and Gas Line
  59. New timing belt.. Making noise
  60. Turbo Blown?
  61. 97 PRELUDE NEED HELP
  62. MSD: Loose wires anyone???
  63. Questions for H-T members......Please comment
  64. DC sports exhaust for SH fit on base?
  65. Violent shaking in 4th gear
  66. prelude dash light
  67. 97 prelude code p108
  68. Broken rear motor mount help me please!!!!
  69. Prelude Combo Shock/Spring Question (Yes, i've searched)
  70. installing alpine 9833
  71. Signal lever doesnt return to center.
  72. 99 prelude s - tranny issue?
  73. reverse lights come on only when they want
  74. how do you know when the alternator is going bad?
  75. DC5 wheels on 5th gen prelude??
  76. Questionnare: How many H22 trannies don't have or have lost reverse gear?
  77. JDM tranny have shorter gears?!
  78. Modifying Mugen Header Collector (Flex pipe question)
  79. dont no what to do need some advice
  80. 5th Gen Stock Ride Height
  81. Idel surges w/ IAC but fine w/o IAC ???
  82. Help with wiring......pre-wired for vtec?
  83. H22 in Civic
  84. need some advice
  85. need help with swap fast .(h23 out jdm h22 in )
  86. Will a 5th Gen Axleback on 4th Gen Work? Already Searched
  87. can i beat my buddys rsx type s
  88. Hondata
  89. JR Supercharger question
  90. Help w/ Hondata H22A need base map and suggestions for tunning
  91. Well everyone I guess this is goodbye
  92. Auto to manual tensioner question
  93. test pipe or highflow or stock
  94. 4 wheel steering ???????????
  95. Integra seats in a Prelude? Hmmm...
  96. help with my 2.0 SI won't go over 4200 RPM
  97. exhaust noise, any ideas?
  98. went to the strip today...
  99. How to replace EGR on 88 S?
  100. k&n filter
  101. 1987 Honda prelude si
  102. Question about lip.
  103. Suggestions on the stock 8" inch sub??
  104. Misfire...??
  105. ABS Light
  106. What do I use for transmission fluid in a 89 Prelude-S 5 Speed?
  107. Decent Port & Polish??? Ideas Welcome
  108. H23 build up questions
  109. Ebay cat ?
  110. Lip and side skirt question
  111. Knock sensor
  112. how to tell difference.
  113. obdII injectors into obdI car?
  114. vtec works on the dyno but not on the street???
  115. What projectors should I use to retrofit into 97-01 headlight
  116. Getting Dry Shot NOS...should i get engine management ?
  117. JIC Magic Suspension Question 97-01 Prelude
  118. 4th gen traction issues.
  119. gas efficient?
  120. is it worth it?
  121. Bad Oil leak
  122. i keep getting a air fuel metering code
  123. im leaving the prelude and getting a new car
  124. HOW DO YOU KNOW IF YOUR LSD INSIDE YOUR TRANNY IS NOT WORKIN ANYMORE?
  125. lowering question
  126. Question abt cam profile
  127. shock swap
  128. anyone have a h22 turbo manifold non-ac?
  129. Skunk2 ECU and intake manifold
  130. 2000 Prelude Turbo
  131. SH to Base Tranny Swap.
  132. best place to buy west wing lip kit, springs, and struts?
  133. any fast h22's still using stock flywheel???
  134. QUESTION HELP!!!
  135. quick turbo question
  136. OE Size tire replacement...
  137. New Clutch prices
  138. changing the seats
  139. were do get 2.5" diameter test pipe for 97+ prelude??
  140. Parting out 1989 Prelude 2.0s
  141. Cam seal help
  142. how does a prelude do in the snow?
  143. torque specs
  144. quick tranny question.
  145. F23 tranny on H22
  146. h23a2
  147. full throttle problems
  148. Prelude Fender Kit... ideas?
  149. will 9.5 wide fit
  150. Bought F22 accord turbo Manifold Skeptical about fitting H23a1
  151. Volk Racing AV3 rim???
  152. H22A baseline dyno, tell me what you think!
  153. 5th GEN: maintaince required light
  154. h22 in 96civic ex have code 4,21,36
  155. Intake and value
  156. NEED help removing Sun Roof visor any ideas
  157. Bought and installed the crossd drilled and slotted Rotors for Prelude
  158. tore front motor mount
  159. building an H23 vtec..
  160. cat convert.?????
  161. want to rebuild new motor, need help. H22a1
  162. Who did I talk to about a CF hood and Sunroof?
  163. Cost to paint fender in San Diego
  164. 3rd gen ps line removal and install
  165. JDM Speedo question
  166. fishy VIN
  167. 92-96 Stock vtec rims?
  168. WHAT THE NEXT THING I SHOULD DO TI MY CAR
  169. Tuning Shop in MN?
  170. Misfire Afer Swap - Again... Odd. (H22A4>H22A OBD-II)
  171. H22 LSD Vs. Non-LSD Tranny
  172. Need Opinions
  173. Where to buy Bride Zeta 3 seats?
  174. Seats for my lude?
  175. Will my car be to loud with smsp header, 2.5 carsound high flow cat and custom 2.5" cat back with no
  176. buddyclub prospec on a 97+
  177. when to put on smsp header??
  178. Should i get a IM with cams or doesn't really matter?
  179. 98' Honda Prelude front sway bar end link is bent. What caused this to happen? Help
  180. Spring install on 4ws?
  181. H22 Tranny w/ LSD Problems... HELP
  182. b16 pistons in b20a
  183. question about kncok sensor
  184. Aftermarket 97+ Headlights?
  185. Chikara Headers?
  186. Oem Catback Piping 5th gen
  187. where can i find a good transmittion?!?!?
  188. bog issues need help
  189. Lowering a 5th gen...(already searched)
  190. Performance clutch and flywheel
  191. Gonna paint my OEM rims, should I sand them first?
  192. non proveked stalling. 98 'lude greddy kit new head gasket. egr plugged and blocked.
  193. turbo running bad
  194. Cold Start Prob.
  195. h22a4 in 4th gen, which a/c bracket
  196. right radius rod (installing clutch)
  197. Surging idle still!! Please help!
  198. Prelude 1997-2001. What is the best shock combination to go with Eibach Prokit?
  199. 97 Base will not start
  200. Cam Question for H23
  201. No spark help
  202. 4th Gen Lude MSD install help
  203. what color tint should i put on my car ?
  204. Swapping my h23 for a JDM H22....which chipped ecu??
  205. clutch damper location?
  206. B16 vS H22 (h22 lose)
  207. prelude parts needed
  208. ATTS disconnection 5th gen SH
  209. Did Honda lie to me?
  210. JDM H22 hesitation at 2800-3k partial throttle, anybody else have this?
  211. weird sound from the passenger side
  212. h22a swap....internal..to external coil
  213. Need torque specs for driveaxles/related parts for an '89...
  214. what's your lude's 1/4 time
  215. would this gain me alot of hp?
  216. MSD 6al
  217. Convert to external coil...
  218. 5 lug conversion offset
  219. What else to make turbo safer!!!
  220. how many resenators should i use for my custom 2.5" cat back and where should they go?
  221. Help: 4th Gen VTEC rides like sh*t with KYB/Neuspeed
  222. Need Prelude parts
  223. F20B vs. Type-S H22A vs. SiR S-Spec H22A vs. Euro-R H22A vs. Type-R H22A7
  224. Clutch pedal height
  225. Aem v2 CAI
  226. This might help some people out CODES
  227. replacing two rods...what about the bearings?
  228. '88 seatbelt won't stay buckled.
  229. ABS Brakes Help!! No brakes & ABS light
  230. Exhaust Fluttering noise under neath?
  231. "highflow CAT" from eBay
  232. I need a wire diagram for a 2000 prelude
  233. Good Alternative for OEM under body spoiler Kit?
  234. Can find a Fire Wall hole in 92 SI.
  235. Water temp switch
  236. teaser pics
  237. Greddy Stainless Steel Headers
  238. Type-S Strut bar
  239. h22 transmission swap
  240. how would i know if its 4ws
  241. Who would win the race
  242. What is the best turbo to go with onfully built H22 wiht bore and stroke kit to a 2.4?
  243. Instant black snow from exhaust?
  244. oil capicity of 92' prelude MT?
  245. Intake Questions
  246. headlights
  247. Your best MOD
  248. rear main seal drain oil?
  249. h22 tranny max hp
  250. cold air intake
