PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 [218] 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Greddy Evo 2
  2. max boost
  3. Brembo blanks patr# for 5G
  4. OBD1 Prelude injectors into ODB2 Prelude Help
  5. AcuraCL = Prelude ?
  6. Car too low, inside of tires worn
  7. Prelude ABS light comes on after 25 seconds of driving
  8. i need to run a 13.0 1/4... HELP GUYS
  9. Help!!! After start 85 prelude rpm's max out w/ no throttle response!
  10. oil pan ouch
  11. Failed Emissions
  12. How do you convert ODB2 to ODB1 on an H23A Vtec (accord engine)
  13. EGR question....
  14. 89 Prelude Head Gasket - Timing?
  15. Brake light and 4WS lights on
  16. need help buying prelude
  17. what camber kit
  18. question about a h22a engine harness
  19. H1 bulbs
  20. quick timing belt question
  21. prelude final drive question
  22. Turbo Vs. All motor
  23. H22A4 ?'s
  24. Sound clip of an H23 that'll make you cry ..
  25. If I modify the headers, does it matter which ones I get
  26. How do you troubleshoot a bad catalytic converter??
  27. to any admin
  28. headers for prelude
  29. Metal Head Gasket for H23
  30. How much can I get for my extra parts?
  31. Online H22 Tranny sites
  32. Need Opinions On This Drag 4 Turbo Kit....
  33. opinions on VAFCII..
  34. What's understeer and how do u correct it?
  35. !!!!!DC Header mod!!!!!
  36. are you guilty of Vehicular abuse?
  37. best way to sell a h23?
  38. jdm H22 wireing help.....
  39. Just ordered my Euro R h22, need a little help
  40. Vacf2 wiring instructions.
  41. 18" wheels help please quick
  42. Are studs long enough for Skunk Intake Manifold using Hondata Heatshield?????????????
  43. ?do anyone have pic of an 97 h22a injector?
  44. Jackson Racing Supercharger?
  45. Another Compression Test thread!
  46. How do I remove the l.speaker-covers on my door panels ?
  47. H-Series Fujitsubo Header
  48. got a question on the carbon trunks
  49. Automatic 97?
  50. electric problem?? HELP
  51. Problems with my sunroof door
  52. To those who think H22's don't like boost
  53. Good wheel offset for 4th gen lude?
  54. best pulleys for preludes (post opinions)
  55. Distributor coil questions
  56. Need better instructions on testing ignitor
  57. what brand headlight should i get?
  58. Weather Strip Question
  59. new horns
  60. H23 Tranny on H22 block?
  61. What size bulbs for 94 prelude???
  62. 5th Gen Front lower tie bar....
  63. Prelude has serious problems. HELP!!!!
  64. ground points?
  65. V-tec problem in 1st gear
  66. EGR lift valve solenoid
  67. valve spring compressor?
  68. new engine installed, dies at idle
  69. MAP Sensor
  70. Prelude Reliability?
  71. h22 type s
  72. WS II piping size
  73. transmission fluid recommendation and problem...
  74. My friends distributor broken twice what could it have been??
  75. 5th gen Tenzo R seat bracket help
  76. Just put on Grond Controls
  77. inlinepro Turbo kit
  78. Prelude/H22 books
  79. Compression Test figures.. ?'s and accuracy.
  80. 93 prelude mirror replacement help
  81. how much would you pay for used bumpers?
  82. Auto into 5spd?
  83. Auto Tensioner Tool
  84. Need sleeving info
  85. H22 gas mileage
  86. 88-91 Prelude FI Kits?
  87. need help
  88. mashing of teh valves - whos broken a timing belt?
  89. 4th gear redline
  90. twin turbo, rotary or 4wd prelude ????
  91. How to identify a bad bearing ?
  92. Idle problem...........help please ?
  93. Where can I find some How to Articles?
  94. Immobilizer flipped out on me
  95. Selling: H22 and F22 transmission
  96. How do i make my car go faster?
  97. 96 si stock bolt pattern?
  98. Skunk cam gears
  99. Should I turbo???
  100. 5th gen exhaust on 4th gen
  101. mugen headers
  102. What happend with that Header Compair Dyno day??
  103. why are these illegal??
  104. seafoam
  105. Spark plug question
  106. amber lights
  107. 93 prelude power mirror replacement
  108. SMSP headers?
  109. h22 questions?
  110. vafc1 wiring to p13 ecu
  111. left head light keeps goin Out? why!!!?
  112. A/C Compressor problem!
  113. Hollow Cat?
  114. type s motor in a 98 base model
  115. HID, high intensity discharge light question
  116. NOlogy grounding straps, where do i put them?
  117. 2000 Prelude after market pedal install question...
  118. f22 injector size? b18a injector size?
  119. Virgin P28 in Prelude.......Any problems
  120. Where to find es motor mounts
  121. EG/H22 RPM HOOK UP (HELP)
  122. H22A SH or Non-SH?
  123. 6600 rpm rev limiter
  124. sources for newbie knowledge
  125. WTB: 4th gen shift linkage
  126. Flywheel Question
  127. Coil Packs on a h22
  128. ICM blown
  129. Fast Idle Thermo valve, where is it?
  130. AEM big brake kit
  131. H23 Alternator
  132. Swapping SH tranny for JDM M2A4
  133. Powersteering Pump Whining sound is driving me nuts!!!
  134. f22 to h23 swap q's
  135. my compression test PIC: and some questions
  136. 97 prelude wheel off set
  137. Help! Prelude Specs!
  138. How to adjust handbrake...
  139. good price for a h22 motor?
  140. 200 whp all motor h22?
  141. Suggestions on Headers
  142. h23 or h22
  143. JDM H22A visual difference
  144. suspension question???
  145. whats the best intake
  146. About to go force induction in a few months have ?'s and need advice.
  147. Reasonable price for 95 prelude?
  148. Finally got my GC's put on.
  149. h23 throttle body???
  150. H22 shifting question???
  151. IGNITION COIL QUESTIONS
  152. Are used cams ok???
  153. Idle dropping slightly during normal driving, is this a problem?
  154. 200 whp NA h23 setups
  155. lude wheels
  156. smokin.....need help
  157. compatable cams for my valves???
  158. scared I think something went inside the head
  159. Speedo not working.
  160. my new lude
  161. spark plug wires
  162. speedometer pic (sorry if it is off topic)
  163. MSD EXT. COIL
  164. JDM Headlights
  165. Prelude Auto Tensioner Question
  166. 10,200 rpm on stock h22a. oops
  167. Grounding kits...Do they work?
  168. Idle Problem H23
  169. Vehicle Speed Sensor on 4th gen
  170. Need B20A5 parts...
  171. Hondata Intake Manifold GASKET or any other IM GASKETS please check in
  172. Can you believe this H22a Jdm Dyno
  173. Finally after at least 6 months of waiting.......
  174. stock 1/4 mile prelude times
  175. 4th Gen JDM Headlight bulbs
  176. Tranny error codes
  177. Greddy E-Manage VS Apex V-AFC
  178. Skunk2 manifold in 2point6's 4th gen accord
  179. Looking for these tails
  180. SH BALANCING SHAFTS DIFFERENT????
  181. Warning to those with aftermarket rear sway bars and/or other suspension mods....
  182. uh.. wth is this?
  183. ac compressors
  184. 95 h22a injectors & resistor box?
  185. Oil Pressure Sender resistance range?
  186. need help with my hood
  187. Ebay - GReddy
  188. 92-96 prelude lip?????????
  189. wat does a 93 lude vtec put to the ground?
  190. Issues with "universal" O2 sensor??
  191. vtec kick in?
  192. Radiator fans not working...
  193. Home made CAI (combining EBAY with ApexI) PICS 56k noonooo
  194. Methods for removing balljoints
  195. Jun head finally done!!
  196. Check Engine light is on
  197. A/C form H22 to H23 ?
  198. JRSC in a 4th gen?
  199. help
  200. HELP! WHERE CAN I GET A TRANNY SWAP DONE IN SO CALI?????
  201. Went to the local 1/8.....results inside...
  202. Look What happened to my Tranny (56K Beware!)
  203. location of map sensor on usdm h22 and h23
  204. engine light came on
  205. Over Heating i think...Why?
  206. engine harness differences
  207. h23 vtec
  208. 92 prelude motor swap
  209. Need some help re: buying a 'Lude
  210. NOS bottle location
  211. 92 Lude won't Start
  212. a few vids of my h22accord with ITB
  213. headlight films?
  214. whats faster?
  215. What CC are yellow marked prelude injectors
  216. 4th gen lude... obd1 or obd2?
  217. 230whp N/A...Is it possible?
  218. QUESTION ABOUT ELECTRIC SUPERCHARGER
  219. Quick question about balance shaft belt removal
  220. prelude 92-95 h22 wiring harness?
  221. Whats the fastest way to change pistons in a h22?
  222. quick question on tensioning timing belt
  223. what to do with my h22a4
  224. Prelude VIN
  225. Cabin Air filter 4 gen?
  226. H23 Rebuild: Top-to-Bottom
  227. Eng. Check Light - Code 420?
  228. Here's the dyno sheet and 1/4 ET time
  229. What chip in P28 to use????
  230. B&G coilover suspension for 4th gen
  231. attn PROSPEED header peeps
  232. Falken Azenis and Stocks
  233. Seibon Carbon Fiber Hoods
  234. DC headers
  235. N1 exhaust question??
  236. M2B4 question, Avaialbility of parts etc....
  237. To Kill an H23 (bone yard boost dsm style ... ) advice needed.
  238. Engine Light On, Code 22, Engine Light Off... What's next?
  239. Why do all pre-fabricated cat back systems taper down at the a pipe?
  240. tranny torque specs
  241. what is the differance?
  242. Misshift woes...
  243. Exhaust?
  244. More Power!!??
  245. another sad day for the prelude:(
  246. damn more problems... car DIES (FUEL PUMP?)
  247. How to contact Prospeed?
  248. aftermarket injectors for h22's (searched... not much...)
  249. what shift boot?
  250. Stock automatic (5th gen) quarter mile times
