View Full Version : Honda Prelude
- Vtec / Map Sensor / Tp sensor Problem that has everyone stumped.
- My 50$ paint job
- Support H/F Series
- Timing belt lower cover rubber seal help!!!!
- Interchangeable Valve Springs/Retainers for F-series?
- ground control coilovers
- help with prelude cams
- 89 Prelude 2.0 Dohc Fuel Mileage problems......
- apexi safc color pinout?
- Help with G3 Prelude head swap B20A vs B20A5
- 95 prelude with f22b1 cels
- 6 bump stop
- pads and routers
- tiptronic transmission?????
- Quicky. Anyone know which socket is for the horn on the yellow socket
- Looking for a topic i seen a few days ago... please help!!
- Premium Gas?
- 1990 Prelude Speedo Problem
- Sway Bar making grinding noise
- car shutting off while driving.
- OBD1 head and OBD2 Distibutor, what do I need to make it work?
- Oil issue....
- H22 Spec Question
- a/c removal
- water in engine
- HID install help...
- Suspension questions
- stock h22a1 header HELP
- im lost and i need some help
- Can't get my trunk fixed properly..
- H22a a what is a GOOD, RELIABLE company to purchase an engine?
- went to the track(drag strip)95' SR-V
- newbie header question
- 5th gen SH & Base - cam and valve spring different specs
- Replacing the water pump
- 92-95 H22A
- stock fuel rail question
- Fifth Genration Prelude
- F22B Head gasket
- Exhaust in my 99
- 4th gen H22 tranny on a 5th gen
- Need some prelude info please!!
- P0170 and P0172 help
- 2001 Prelude keyless entry
- Will my ecu work with this setup and h22 head differences...
- h22a fuel cut at 2k more info inside
- Red H&R Sport springs???
- has anybody had problems with GM or AC Delco synchromesh ??
- Dinan stage 2 ecu
- Tail light issue..
- fan problem after swap
- need help installing new clutch master cylinder
- Tried searching, but didn't see much v. HVAC not working....
- Newbie on ludes. I have a quick transmission question
- For those of you with an upgraded valvetrain!!!!!!!!!!!
- Accord EX head on a 95 Prelude S
- h22 cam fuction
- rebuilding my H23 motor with Turbo charger....help
- Auto to Manual swap
- Starting a New Project....Need opinions
- Brand New ACT clutch and Brand New Crower Cams H22a
- ABS LIGHT
- would a 92 fuel pump fit in a 88 prelude??
- manual transmission fluid change help
- High rev H23
- will honda ever comeout with a new prelude?
- shiftin problems
- HELPPPPPP! PLEASE!!!!
- Are Megan products any good?
- anyone going to starved rock this week end that can help
- Head Gasket Help!
- Attention: people that have used struts to hold your trunk i need help..
- which turbo kit with ecu
- Bumper Sag
- cat convs
- Head light housing removal 1994 prelude
- need clutch advice
- turbo a h23 or a h22??
- first car
- Finally Got This Piece Tuned
- Timing gear/key stuck on crank
- 93 SI stalls while engine is cold.
- Quick Question
- Has anyone over try'd to put in a 4WD or RWD RB26DETT in a 00' Prelude????
- Rim bolt pattern?
- Need Opinions on what to do for exhaust
- Prelude won't rev past 3k and smokes white
- H23 faults
- Redesigned lost motion assembly's?
- 4th gen skunk2 springs question
- h22A Running Rough!
- 93 Octane
- engine idle problems!!! please help
- cat replacement/removal
- help changing clutch master on 01
- What to do with motors?
- Changing oil filter without draining oil?
- Stock Axle strength ??
- interference motor???????
- h22a transmission ecu question
- Electrical Problem - tach/speedo, radio, blinkers :(
- Carbon Fiber interior
- 93 h22 harmonic balancer timing??????
- need diagrams for h22a swap!!!!!!!
- Who does H22 head CNC?
- Power Steering and Speedometer
- o2 sensor/ emissions
- 5th gen steering wheel???
- why 5th gens are slower
- CEL CODE 22??
- F20B VALVE ADJUSTMENT
- Crank angle sensor fault
- Honda Prelude 83, Sold I Put Side Draft webbers?
- Starting Problem: starter turns even without key
- Is fuel pressure suppose to drop to zero once car is turned off?
- 97 prelude oil pan clearance.
- jun internals
- Need new throttle body... What is best?
- pic request for prelude with 17'' rota boosts
- exhaust/header
- any one that knows anything about sh
- power enterprise super strong t-belt, who sells them?
- ecu question
- Is their another crank angle sensor on my oil pump?
- KYB/AGX Shocks question.
- Extended Crank (Hard to start car) - Fuel Pressure?
- Neeeed help with my problem ASAP plz ,,help would be appreciated,, can't drive the car
- Anyone used struts to hold up your trunk?
- Leather interior
- short shifter......
- h23 Dohc Vtec into 95 accord????
- Anyone using Enkei EVO, RSV, or ES7 rims on a 5th Gen?
- Need Your Help H-t members!!! Clutch problem??? Trans??
- bad valve guides? rattle/grind at full vacuum
- Aggressive vtec crossover
- Fuel Supply System error. Slow moving through RPM's.
- Trunk Lid
- engine whine
- Please Advice on H22 motor turbo built
- driving with check engine light on
- Ep3 Seats in BB4?
- IM spacer and balance shaft removale
- 1996 honda prelude h23 probs.. no spark, i think the distributor wires touched? need help!!
- govenor
- yea i seach but im still stuck
- metal head gasket and shaved head plus cams
- need Help in finding where I can buy H22 Type S high compression pistons.
- Omni Testpipe...compatibility?
- Short squeal when I start the car.....
- whats the weight of a h22a crankshaft?
- possible ? JDM P13 ECU ON USDM H22A1 MOTOR
- K&N Typhoon
- BB6 Oil Filter Question
- Need Exhaust Opinions
- 92 si automatic - Sports shift light on dash only works in park
- Noise from power steering pump, please help
- Brigth headlight setting works, normal headlight setting doesn't
- Skunk2 Lowering springs on 5th gen pic request*searched*
- h23 headers
- New engine swapped, no fuel or spark
- Best offset?
- big 97 SH problem
- why did my lude die?
- Quick Prelude Color Question
- Is this normal???
- High flow cat, is it worth it?
- Clutch Problem
- What is the difference between 94 and 97 SH cams?
- I want to get tuned!!
- How restrictive is a 2.4 inch exhuast?
- Speedometer and tranny light
- H23 and H22 TB sizes
- what do i need for stage 2 cam set up?
- Just installed Apexi Ws2 Exhaust..
- Need help on rack and pinion hoses. ASAP
- Can H23A1 be supercharged?????
- No coil fire! WHY 96 prellude
- Sponsors
- 90k maintenance price
- what opinions do you have on this exhaust???
- piston type..h22a4
- ARP head studs
- Fog Light Switch Dimensions
- need help on cambers
- BB6 type-s flush mount spoiler HELP
- Can you use HID's in OEM Fogs? (5th Gen)
- Need advice on n/a build
- mismatched tires
- My car was stolen and raped...Goodbye luders
- Intermediate Shaft / Half Shaft bearing replacement
- Upper Ball Joint / Camber Kit Install
- 93WhiteLudes's Dyno Day at Church Automotive 56k no way
- major consumption
- tire size
- leak problem!! healp please 97 prelude
- Need a New Clutch!!! Any aftermarket recommendations?
- F22 TURBO BB4 GT25 8 psi
- Tach not reading correctly *Searched*
- Are all H22 cams the same?
- A/F gauge fluctuating while cruising (searched this problem)
- does the intake gasket of an h22a type-s is the same that a h22a?
- KYB AGX shocks?
- Will a DC2 Type R front clip fit on a 00' Prelude????.......
- 5th Gen eating cats
- New to the world of owning a 'Lude, need some advice.
- VC Breather Question
- Ludebehavi0r's Horrible Rattling Noise
- Pulling engine from 5th gen- ahhh!!
- H22 oil "disappearing"
- My New Lude I Picked up for $1300
- 10.1 cr ECU (USDM) running a 11.1 cr engine(Type S)... any problems?
- 5th gen prelude help!
- stock shifter
- h22 cam install and valves
- Greg H's Turbo Prelude update. New Dyno, track times, pics and video
- my $600 prelude
- Seats dont Recline Up Straight
- what did my h22a come out of?
- Headlight problems... NEED HELP FAST!
- Question about built H22 Longblock
- Need some advice on a h22a prelude!
- does anyone know???
- shitty weekend to work on lude
- Front Bumper shock absorber
- can the fuel pump be to big?
- would a fd2 civic type r 08 rims fit a 01 prelude??
- rebuilt rack n pinion
- Is This RPM Normal?
- Getting rid of CEL
- Lighted PW switch, how?
- Is there an easy cheap fix?
- Removing old gaskets
- Valve cover nut spinning
- Where to find a decent 2.5" catalytic converter?
- Progress rear sway bar noise!! plz help me out
- h22a not firing PLEASE HELP!!
- questions on my car???? please help
- wat is this?
- Tranny Problem
- h22a/h22a4 question!!!!!!!!!!
- Rebuilding this H22, give me your opinions.
- Computer code P0420, catalyst system efficiency below threshold
- Possible rear damage?
- Blowing Oil??
- Auto to manual conversion on '95 Si.
- h23 swap to h22
- My Frankenstein exhaust project
- Where Does the Air Breather go?
