PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. how do i put in this strut bar?
  2. Acoustic Feedback System -- Help?
  3. 4ws box
  4. jdm f22b help
  5. Stock Intake Manifold Question
  6. HELP!!!!! I have an ECU Problem Im sure someone here has the know how to help!!!!
  7. how to build a h22a for a prelude
  8. headers
  9. 5th gen new headers and cat = throwing fire! normal?
  10. brake light not working (searched)
  11. exospeed.com
  12. header and intake
  13. 4th Gen Prelude Weight reduction
  14. 5th gen radio code
  15. Acids H22a Swap After Math
  16. Crank angle sensor location
  17. Which Preludes came with an OEM spoiler?
  18. Hmm! I Wonder... ;)
  19. Crankshaft Pulley Bolt
  20. its been asked a lot but i just have a quick question. h23 to h22
  21. tranny
  22. Exhaust manafold cherry RED
  23. Harmonic balancer and Crankshaft Pulley Question
  24. JET computer re-flashing? anyone else used them?
  25. 2point6's Accord going k24
  26. "Performance Speed Chip" 15HP gain
  27. 91 Prelude Brakes
  28. i know youll call me noob but i wana know
  29. lower timing belt cover reinstallation help
  30. is there a difference on map sensors?
  31. can someone help me with a few questions i have??
  32. Random ticking
  33. General Clutch Question
  34. side views, heater/ac, and brake light?
  35. :EM Racing C-Pillar Bar: Any feedbacks?
  36. someone please help me!
  37. Projector beam headlights
  38. Timing Belt Tensioner Pulley Bolt issues
  39. AEM Tru-Time Cam Gears
  40. wingswest
  41. h22 laskey sleeve block
  42. Fuel issues...
  43. Timing belt replacement.
  44. 4th gen parking brake adjustment.
  45. Balance shafts on h22?
  46. :::QUESTION-RIMS
  47. *ADVICE NEEDED* Might Sell My Boosted Lude...Should I part out or sell as whole?
  48. 5th Gen Base vs. Type SH Radiator
  49. tuning
  50. Tach not working Please Help
  51. highest offset + size wheels on 4th gens.
  52. Crank Pulley came apart ... pics
  53. CAN A TPS BE REPLACED ON A 5TH GEN PRELUDE, WITHOUT REPLACING THE WHOLE THROTTLE??
  54. Rough Idle at cold start help please.....
  55. Ignition wire
  56. tail lights and dash lights fuse blow
  57. H23 dsm turbo question
  58. whp to hp calculation?
  59. ..::: members telling other members to SEARCH and being DICKHEADS in general, READ THIS NOW
  60. Rear Seat REMOVAl Trick?
  61. JDM & USDM h22a tune up parts the same?
  62. 4th gen mods?
  63. M2B4 losing reverse
  64. honda prelude 5th gen, turns off when i make a complete stop!! help!
  65. ignition system
  66. Coolant leak..help me!
  67. Torqing Cam Gears
  68. Picture Of Cam Seals Installed (Not Cam Cap)
  69. Timing Belt/manual tensioner/oilpump/waterpump
  70. 95-96 cupholder picture wanted
  71. **JDM H22 TRANNY W/ LSD FOR SALE**
  72. ***New To Honda-Tech***
  73. I'm finally Preluded out.....
  74. Dyno tune results
  75. shifting issue into 2nd gear
  76. EXHAUST questions for all 5th gen lude owners
  77. is it possible to convert 5th gen prelude's headlights to s15?
  78. Rear brake pad replacement for my 1997 lude
  79. my 3rd gen build thread
  80. h22a4 question...
  81. issues with the speedo
  82. 4thgen preludes help pls
  83. Half Shaft help!!!!! Please
  84. Aftermarket Bodykits?
  85. dropped in the f22b. no start. ideas?
  86. Clutch pedal engagement....Please need experienced help!
  87. rear center speaker 6x9
  88. replacing headlights
  89. Crankshaft position sensor NEED info...
  90. Is something missing from these spots?
  91. parts for engine help? h22a
  92. speaker replacement help
  93. car wont start need help asap!!!!!!
  94. Prelude won't stay started
  95. where's my dipstick i must be a dipstick
  96. alternator belt - replacing/adjusting
  97. f22b knock sensor help!
  98. Tach not working right
  99. Clutch problem on '99 Lude
  100. How do you put those tiny little keepers into the retainers?
  101. Bump stop needed?
  102. JDM BB4 Black Housing Headlights
  103. So, I threw on my header today. After tuning I lost 8tq and only made 1hp.....
  104. trying to track down a blk/yellow wire inside the car. Any assistance appreciated!
  105. Glass Moon Roof Conversion
  106. Accord Rear Lip
  107. 92' Honda Prelude
  108. Help? Changing a speed sensor...
  109. Hondata S200
  110. Selling a B18 vtec head
  111. New Idea
  112. Need a little help on my h22 conversion.
  113. called up modacar today!!
  114. need help "electrical problem"
  115. 5th Gen Innovative Mounts Install Help?
  116. Windshield washer nozzle removal
  117. HOW DO I WIRE HEATED SEATS INTO A PRELUDE
  118. What comes in the Box with OTS GC coil overs
  119. Synthetic brake fluid?
  120. Help! Having Problems with 98 Prelude!
  121. High Beam issues.
  122. Chipping and tuning ECU's with hondata s200
  123. do not buy engines or anything from this
  124. no low end power only at 5-6k i have power
  125. Electrical Gremlins vs. RPM
  126. PLease help: Banging noise from front left of car only in sub 32 degree temps
  127. Question about TPS adjusting. Searched
  128. argument
  129. '92 Prelude - problem w/ passenger turn signal
  130. -08 AN Fuel line ....will it fit in stock holder
  131. The Offical "What Does this Muffler Sound Like" Thread
  132. would you get these for your lude?
  133. Clutch / shifting problems
  134. cams
  135. wings west rs lips
  136. H22 crank pulley
  137. shifting to reverse
  138. si this good for a cat back?
  139. Camber Kit?
  140. Choke 2nd gear
  141. alignment?
  142. FI question
  143. Vibrant or Magnaflow?
  144. Valve springs ?
  145. No Power to Fuel injectors!!!!
  146. Clutch issues
  147. Oil consumption issue
  148. Prelude SH 5spd tranny for a $1
  149. cat question?
  150. P13 JDM OBD1 pinouts please. code 36 traction control
  151. Some very funny stuff
  152. Newbie to Preludes...few questions
  153. fastest auto
  154. front lip
  155. gpassing emissions with punched cat converter?
  156. My Prelude at the Honda-challenge National Championship race
  157. simple timing question
  158. Bring back the Honda Prelude - Petition
  159. Heated seats not working?
  160. Burning smell from t-belt cover area
  161. 2nd generation lude with b18a1 head
  162. weird problem need help cylinder 3 misfire
  163. Please I need to know...
  164. Type S heads
  165. H22 Stroker
  166. 4th gen lowered
  167. exhaust question
  168. What should I replace while my motor is out of the car...
  169. skunk2 pro vs. tuner series camgears
  170. Possible bad rack or bad cv shaft... violent jerking
  171. Prepetual oil leak
  172. What is this tool called...
  173. Loss of good power/acceleration/vtec???? please!
  174. aftermarket muffler
  175. Wings West RS lip kit
  176. rebuilding my busted head
  177. Vibrant exhaust header
  178. NEED HELP 99 PRELUDE ENGINE PROBLEM
  179. 89 Prelude and What front end conversion would you go with
  180. Crashed Prelude!
  181. Air filter=horsepower gain(?)
  182. Part list for auto to manual swap
  183. Exhaust headers
  184. Smashed headlight...easy fix?
  185. "jdm" bb6 cluster and usdm cluster the same? (wires & gauge face icons)
  186. The 5th gen is operational
  187. anyone know where i can get racing seat bracket for tenzo-R seats?
  188. swapPRICE5thgen
  189. JDM H22A 94 ---> euro-r
  190. idle problem....need professional opinion pls
  191. Future build questions for a 5th gen: Auto --> manual and complete euroR swap
  192. stick vs auto
  193. how to launch
  194. Rpm's hold while shifting????
  195. shift linkage repair?
  196. need help with pistons
  197. electrical problems
  198. 1992 prelude si- which alternator
  199. hey guys quick question a/f gauge
  200. ststststuddering
  201. how do you replace the cigarette lighter -4th gen ?
  202. Replace timing belt?
  203. Oil Pressure
  204. skunk 2 H Series pro Intake Manifold
  205. 10k RPM over rev
  206. tach installation question
  207. Well Im feeling Pretty accomplished
  208. whats new for password jdm?
  209. Motor Mount Bolt Broke off In my block!!!
  210. need help w/ h22 swap
  211. Wierd Noise at Idle
  212. turbo power
  213. Brake Piston
  214. 1990 Prelude Fuel and Suspension Q's?
  215. Idling fluctuating, only SOMEtimes problem starting (?)
  216. Need Help with suspension
  217. h22 to h23 tranny swap question??????....HELP ME
  218. squeeky sound
  219. wiring a tach....PLS HELPP
  220. skunk 2
  221. Loud engine tick slippage in power driving at 80mph
  222. question???
  223. will the mahle gold series be ok in a sleeved block
  224. Has anyone ever smogged an H22A in a 5th gen???
  225. H22A4 Head on a H22A1 block?
  226. spill gas everywhere
  227. cracked wire tube causing misfire?
  228. help! 93' SR heater not working and winter's on the way!
  229. Seatbelt sensor
  230. Drive shaft, removal and Installation
  231. dash question - top plastic piece and rubber tabs
  232. need quick help on H23, H22A1, and 95 Accord Engine Harness
  233. prelude crossmember
  234. starter, short to ground?
  235. Production Tr-Y header?
  236. Radiator Issues
  237. Raising Exhaust Piping? (searched)
  238. BPI velocity Stack vs Blox velocity stack
  239. Turbo Prelude help
  240. 96 Prelude build
  241. h23powered's h23vtec NA setup
  242. how do i adjust timing on the prelude 5th gen?
  243. New radiator but still running hot...
  244. Odometer fell off my dash?
  245. threads that need to be in the faq
  246. I have looked everywhere
  247. 5th gen failed SMOG horribly
  248. fans not working
  249. Ok, what did I just screw up?
  250. state ref
