PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. f22b prelude
  2. Throttle/ignition problem
  3. h23a i can put a turbo?
  4. Test pipe and mechanical CEL fix
  5. Rough Idle CEL 5 and 14 MAP and IACV
  6. bellhousing size difference?
  7. Need help to distinguish between my clutch slave or master problem
  8. Looking for Zack "MLBZ521" - Unfinished deal
  9. car died at idle would not restart, honda dealership does not know whats wrong
  10. How To Clean Headlights
  11. FUN! fwd on gravel!
  12. I have exhaust questions...
  13. H22 Cam Cap bolt quandry
  14. Exhaust System
  15. Fluctuating Tachometer as I increase speed
  16. stage2/3 cams question?? h23 blue top vtec.
  17. 99 SH Swap to 92-95 h22a
  18. OEM Cam Seal
  19. headgasket seeping oil
  20. blox cam users chime in
  21. Seals blown in turbo or wastegate problem..... please help
  22. Quick apexi AFC neo question
  23. f22 tranny on h23 /h22 VSS question
  24. help! fixed my A/C now i have water in my carPics inside
  25. 4th Gen. "brake lamp" annoyance???
  26. PLEASE HELP!!! 93 h23 piston replacement PLEASE HELP!!!
  27. weapon-r header
  28. 97 prelude starting problem with remote start
  29. nippon vs. OEM questions,...
  30. h22 noise??
  31. idle and stumbling/misfire problem questions.
  32. Rear main seal.
  33. dizzy for h22a
  34. H22a1 to a JDM H22a
  35. Lagging acceleration
  36. Head gaskets...
  37. flickering oil light
  38. no spark
  39. JDM type s motor in a prelude type sh
  40. Interior lights fuse keeps blowing but radio also doesnt work?
  41. Gears Grinding in 5th
  42. Stock steering wheel size?
  43. Fan switch problem
  44. Removing FIV
  45. calipers look ugly
  46. im new to the prelude scene need some advice!
  47. Wheel Stud Install
  48. Removing/Installing Transmission
  49. 93 h23 piston broke i think
  50. prelude running very rough..after new h22 swap.
  51. Oil and coolant issue
  52. 93 h23 piston ring size
  53. H22A FUEL PRESSURE AND IDLE CONCERN
  54. Idle Problems
  55. tried to smog my car today , how to fix these
  56. Drilling through firewall
  57. converting h22a1 to a 96 prelude f22b obd2
  58. Rota Slipstream Rims (Anyone else trying to buy?)
  59. NRG quick release hubs, Which one should i get?
  60. JDM Sidemarkers for BB6
  61. 93 h23 throttle body help please
  62. Body Kit Painting Price??
  63. Every time i launch i lose my alternator belt...
  64. Need street tuner.
  65. new to arizona need help
  66. service connector
  67. another question..
  68. so how does this sound...(your ganna want to read)
  69. idle air control valve and fast idle air valve help.
  70. Need help with belt and idle issues.
  71. Prelude roof rack
  72. dizzy cap question
  73. vss shot? would it cause limp mode?
  74. Hi, New to this thread, Got some questions!
  75. turbo question?
  76. rear seat removal
  77. Cold start injector?
  78. electronics not working
  79. how to offer for h22a4 block+dizzy
  80. Upper control arm bushings
  81. Shifter Bushings
  82. LCA bushing removal/install
  83. Bushing Grease
  84. Just did the manual tensioner conversioin, timing belt TOO tight.
  85. no spark?!
  86. euro r im
  87. 1982 prelude convertible **RARE**
  88. h22a A/C different than stock?
  89. bb6 egr cleaning
  90. anyone running type-s pistons with stock h22 cams?
  91. Rear Mount Help!!
  92. F22B vs. H23A1
  93. Midori Green 5th gen
  94. BB1 prelude
  95. CF hood on black prelude???? Skunk2 IM????
  96. h22a piston bearing marks?
  97. Good Deal?
  98. H22 Turbo Overheating issue. Need Help
  99. 94 prelude h22a stock injectors?
  100. fan motor wiring
  101. h22 swap serge problem
  102. Dyno vid of my 780whp run - s372 turbo
  103. Starter will not disengage
  104. best cams?
  105. what do you think about this exhaust???
  106. muddy radiator water!!!
  107. h23 stuck head bolt NEED HELP
  108. How much could i get for this prelude shell
  109. Can't find a wheel I like
  110. brake part swap compatibility?
  111. Engine wiring harness '89 Lude, SI 2.0, 4WS, Engine B20A5
  112. Possible limp mode? wont rev past 3500
  113. 01 Base prelude problems..
  114. Heavy vibration ONLY WHEN letting of the gas.
  115. friend's prelude is havin issues help
  116. jdm fog lights
  117. Main & rod bearings .. Is it worth staying to OEM specs sizing if I'm going Turbo ??
  118. Huge Smoke scene - head gasket?
  119. your Mahle piston experience, how are they holding up?
  120. My first 5th gen Prelude
  121. 98 Prelude help!
  122. Clutch Slave Cylinder
  123. prelude will not start
  124. 92 f22b swap to jdm h22a w/lsd
  125. H22a swap, Cylinder 1 ahhhhh
  126. MSD Blaster
  127. my fans dont turn on at idle and it overheats, but they work w/ AC on
  128. cold air intake install
  129. 4ws problem
  130. help with engine harness
  131. Replaced tie rods and atts fluid- now no start
  132. 5th gen shock knock even with teins
  133. Help: smoke under the hood!!
  134. Oooops....sputtering
  135. Venting from Valve Cover? Pros and Cons
  136. Timing on a H23 Si??? I need help!
  137. Question about 4th & 5th gen suspension.
  138. 2000 Prelude, 5spd, 76k miles. Is $6,500 a good deal?
  139. starting issues with a 93 h23a1
  140. H23 VTEC Apexi V-AFC controller
  141. Need advice, two preludes but I have to choose one.
  142. secondary butterflies
  143. ATTS vs. LSD
  144. looking for 89-90 fuse box diagram
  145. 94' Prelude H23a-1 2.3L, No Spark
  146. JDM H22A transmission...
  147. Dry sump setup
  148. maintnence required symbol
  149. Pinout Please F22b1 motor replacing a F22a1 motor
  150. JDM Engine or USDM engine?
  151. Car sounds like it's farting :/
  152. Exhaust System
  153. Echaust System
  154. Replacement wiper blade discussion: 1995 Honda Prelude Vtec
  155. Getting a lude
  156. h22a sh camshaft vs skunk 2 tuner series stage 2 camshaft
  157. What do you love/hate about your 5th gen?
  158. cluster options for a 98 prelude
  159. Funny sound from the rear??
  160. Check Engine Light is on and Get all four cylinder Misfiring codes
  161. Corbeau seat brackets
  162. Qestion on starter?
  163. question
  164. WTF!!! A/C Problem... Help
  165. help! wheel studs!
  166. Installing JDM rain guard window visor...
  167. block is stamped with HA has anyone heard of this
  168. Typical RPM's while going 65 mph?
  169. WHY "H23" VTEC???
  170. Upper Ball Joints
  171. H-Tech's & the Type SH Suspension
  172. RPM's are jumping around!!!!?
  173. How valueable are used Type-S pistons?
  174. A/C compressor clutch swap
  175. 1992 H23 Auto. Tranny Oil Capacity Question:
  176. h22a4 engine mount different?
  177. Having the hardest time removing balljoint
  178. LEAKING COOLANT HELPP!!!!
  179. H22 or H23 blue top?
  180. h23a1 internals into my h22a1 block .. compression and redline Q's ..
  181. anyone know where fenders are in the helms manual for a 1998 prelude?
  182. bb6 SiR front bumper on a USDM prelude
  183. What code is this? Running very rich and bogging! Help!
  184. H23 vtec question!
  185. Stock F20B injector sizing?
  186. Hey h23 knocking question
  187. problem with axel or brakes poping sound when braking
  188. 4th Gen ABS Code 41, what is it, how do I fix it.
  189. Code #8 TDC error.
  190. Replacing the coil with a MSD
  191. supercharged or turbocharged???....
  192. Help with H23!!!!
  193. i need axles for 01 prelude lsd tranny
  194. 98 prelude manual trans different? help w/auto swap
  195. @@@ 89 2.0 si swap questions @@@
  196. New 32psi dyno ... 780whp
  197. help with bogging
  198. I NEED HELP ASAP!!!! WIRING PROBLEM IN 2000 PRELUDE BASE MODEL
  199. I'm suspicious about this car. Anyone else?
  200. center console conversion help!
  201. Anyone tried to install JRSC onto 4gen prelude?
  202. Does anyone know where I can get parts numbers?
  203. Exhaust Question, I Need Your Help...
  204. Need Some help with my PRELUDE
  205. h22a1 wont start?
  206. reverse lights 93 h23
  207. Oil Burning Prelude - Need Help
  208. Is there a lightweight torque converter/ flywheel for an automatic h22a prelude?
  209. timing light...
  210. tbelt conversion
  211. Egr Cel code after oxygen sensor replace
  212. Carbon Fiber
  213. JRSC on a 5th gen..average MPG?
  214. Internal coil replacement
  215. Temp gauge shows overheating!!
  216. H series intake manifold testing brought to you by IMPORT SPORTS
  217. 93 front end
  218. 01 sh blown engine
  219. Overheating to redzone after about 10 mins of driving. here are my symptoms:
  220. Removing Air con and still driving when raining etc?
  221. lovefab and full size radiator?
  222. Blown Timing Belt, always bent valves? H22
  223. Automatic to Manual 4th gen
  224. Fill hole for 98 prelude tranny
  225. rpm gauge not working after swap
  226. Whats wrong? Brake + Battery light on at same time.
  227. Rough Idle
  228. Whats wrong
  229. '90 prelude fuel injection / o2 sensor problem?
  230. 93 h23 check engine light
  231. h22 help
  232. Quick question about lowering the lude with a set of s2000 wheels
  233. transmission question
  234. Transponder bypass?
  235. car will not turnover! need help ASAP
  236. honda prelude mods help
  237. Time for exhaust... Custom anyone?
  238. Helms manual
  239. can anybody explain these wheels
  240. tensioner question ???...
  241. idle problem with a/c on
  242. Carfax needed
  243. Ok...Big, weird problem with my 98 lude...help?!!
  244. Adjustable distributor?
  245. air condition diode
  246. what would be best for my 2000 honda prelude ?
  247. triple gauge pod?
  248. how to remove VTEC STICKER
  249. msd blaster coil gone bad?? no spark from dizzy
  250. 98 Prelude Transmission -what is that pipe sticking up supposed to be connected to?
