View Full Version : Honda Prelude
- Crankshaft pulley help please
- lack of lubrication causing camshaft to make loud noise
- Hard to get into 1st
- Clutch, shift cables, or what!
- What to look for when buying a Prelude?
- Few engine questions
- Tranny swap
- H22 turns over but won't run
- 20w-50 in m2b4 trans???
- SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, PICS REQURED (as links) -APR- Jul 2013
- WANTED TO BUY ONLY :: NO TRIAL USERS, NO PICTURES - APR- JUL2013
- 89 Si 2.0L
- what engine to build
- 97 Prelude cooling fan not working
- need help
- Axles Shaft ??
- WANT TO BUY PRELUDE
- screeching metal noise around timing belt area
- Gen4 H22A Prelude possible LSD fault. Help!
- Paper clip trick
- Power steering pump squeal :(
- spoon ecu chip.
- fuel cut off switch
- bad sound on head
- Help Plz
- Passenger tail light not lighting up when braking only?
- Potentially buying a prelude.. let the n00b questions ensue.
- Press on/Trapped rotors?
- Hello Fellow Preluders!
- 1995 Prelude Digital Fuel Gauge Stuck On Full??
- Steering Wheel Vibration? HELP!
- Compression rates
- Problems with reverse lights not coming on
- Hello, everybody!
- rack and pinion help (noise/damage)
- 89 SI w/ rebuilt engine running rich in one cylinder
- OMG WHERE TO FIND HARD RUBBER BUSHINGS FOR 4th gen! HELP!
- h22a plunging sound from intake
- h22a problems with picture
- Fuel Pump/Injectors
- H23 turbo????
- New best 1/4 mile
- H23A1 TPS/Rev Problem Need Help!
- Worth the money?
- K2H adapter
- healthy way to get my H22a to 300-400 hp all motor
- Presentation from Italy
- halo wiring problems
- Squeeling belt?
- H23 vtec build
- electrical/ignition problem
- need help picking
- 97' Prelude SH temp gauge is stuck
- cv axle problem
- PLEASE HELp H22a specs when done ?
- H22A SPECS AND ADVICE ??? please help ! ?
- vtec engagment adjustment
- Need help!!!!tensioning timing belt!!!! h23!!!!
- Change of rim size.
- Blower motor/power mirrors stay on with key off
- HEEELP ! i have a H22a on My EK
- Prelude 1997 17"x9" ET37?
- Odd noise from timing belt area
- F22A in 93 Prelude
- secondary butterfly plate removed!!
- lower ball joint help please! 98 prelude
- location of EGR valve and cleaning
- missing on all 4 cylinders
- 98 prelude obd1 chipped ecu with euro-r map questions
- 95 Honda Prelude - Dash Gauge - Max Temp - HELP!!!
- loud noise coming from engine compartment
- ABS unit? HELP!
- How to replace the ignition rotor?
- radiator fan on 92 4th gen Prelude
- Phearable ECU and IABs
- any experiences with mfactory 4.64 or 5.1 fd. how about synchrotech's carbon synchros
- h2b again !!!!
- H22 swap concerns
- can I use transmission oil on my transmission? H22A
- 98 Honda prelude transmission
- oxygen sensors
- 96 lude H22 block resleeve opinion ?
- h22a vtec engagement problem
- National back-order
- 75mm tb and 75mm skunk2 IM on a stock block h22a n/a setup
- 1998 CV Joint Help Please (prelude)
- need help with my auto trans
- h22a help intake manifold
- h22a euro-r in 98 prelude IACV question
- Wont start
- TD-940 Distribitor?
- New to HT forums, my 98 prelude
- What's up Hatertech? New guy here.
- Can someone explain me this H22 with 1.5 civic untake manifold
- euro-r vs type-s ECU
- Got my f20b NA tuned yesterday dynojet
- 2000 Prelude clutch slave cylinder question
- Please need help in need of an h22 block only
- H22 Camshaft troubles... what would you do now ???
- Cant pass smog....HELP!!!!
- What Headers for my H22A??
- 98 prelude idle problems
- gasket part number?
- what would you offer for my prelude
- Question Hondata S300 V.2
- removing or resetting apexi air flow converter?
- 94 prelude with swap harmonic balancer touching chassis
- 88 prelude s carb insulators
- VAFC II help
- 1997 Prelude - Is this safe?
- need help finding a part
- Immobilizer ECU location
- Failed smog because of a 900rpm idle?!
- Which Color for my car?
- Halo Lights?
- HALP!!! 97 Prelude Trans Issue
- misfiring under load
- cam gears installed slight hesitation
- LSD fitment
- Proud new owner of a '97 and couldn't be happier...
- 97 prelude engine swap
- What would cause no spark and no fuel pulse?
- crank pulley bolt
- my 98 sh with the ol 0302/1399
- Which car do I tell my mechanic I have when ordering parts
- 89 Prelude SI B20A5 Cold Start Issue
- 98 Prelude with DC sports 4-2-1 header feels slower then stock headers.
- Rear Brakes
- H22a obd1 or obd2?
- H22a in 1992 prelude. will I pass
- 5 lug conversion.
- J-swap and K-swaps Q?
- Saving gas on a prelude
- H22A, there is some oil were my timing goes??
- where can i buy this
- Power feels way down,help!
- help with tire size!
- 1.75 or 1.2 drop on 4th gen?
- H22A head on F22B bottom end??
- 2001 Prelude Runs Crappy once warm
- removing a tps sensor on a h22a1?
- starting problems
- airtex water pump -bad or good???
- OBD1 engine with OBD2 oil pump
- Heater Blower Motor
- Bought a 98 SH today.. and it begins
- h22a1 bogging on aceleration?
- USDM to JDM engine
- Engine issues URGENT
- h23 blue top h22 head question
- 98 Prelude ABS light is on and yet the codes will not show up
- H22a to H22a JDM type S-tory
- H/F build
- Honda Prelude 1996 2.2 H22A5 map pro
- Lost 4 quarts in 1100 miles
- Tach is showing 1000RPM more!
- H22-H23 build
- f20b ?
- H22a oil leak from around oil filter
- whats the best combination?
- No spark
- exhaust
- P/s fitting delete question.
- H22a1 vtec won't engage after warm up
- 2001 honda Prelude port and scanner doesn't communicate.
- H22a4 wont start
- Prelude rear lower tie bars are here!!!
- Have a 92 Prelude 2.2 S need help with part compatability
- how do you access the oil pressure sending unit on a SH ?
- h22 type s cams or skunk2 tuner 1 cams
- Oil leak
- Will JDM h22 pass emissions test in ontario,canada
- Whats your thouhts??
- 92 prelude stalls right after fuelling up!
- need help. engine making squeaky noise
- My H22 92 Prelude Build *Lots of pics*
- Turbocharging my h23a vtec "blue top"
- bypass cooling fan timer unit - w/out losing any other function (3rd gens)
- getting a 1992 prelude with h22 on friday
- h22 died shifting to 3rd
- Are Gates timing and balance shaft belts any good?
- 1999 prelude f20b swap need help!!
- Prelude Knocking!!
- 3rd Gen Lude stalls at WOT please help!
- suspension
- 5th gen prelude swap ideas
- Upgrading CAMS
- (video) H22A swap barely idles when cold and bogs/bucks when throttled (video)
- new look! (copper plated)
- Blue Smoke Every Morning
- 94 accord tranny interchangeablity ?
- rust in combustion chamber
- L.F. 2001 Honda Prelude Service Manuel (Base Model)
- 1997 Lude (ss) tranny swap to MANUAL!
- Misfire
- 99 Lude vtec issues
- jdm H22a oil light blinking random.
- ABS codes pulled
- h23a headers question
- My 92 prelude si ;D
- 1987 Honda Prelude Si 2.0
- H23 build Questions?
- 92 Prelude question
- Quick question about main bearing clearance...
- 1997 Prelude SH Keyless Entry
- Knock sensor HELP & others
- h22 turbo
- h22a 2.2L Si4WS VTEC bb1 issues.
- Help with accord swap
- No Electricity/power to car
- Drivers Seat Leg Room
- Help me with my prelude
- aftermarket caliper on stock rotor?
- Anyone knows the stock headers gasket part number
- What rims should i get?
- 97 Prelude won't start
- Prelude type-s grille, with an accord euro-r grille emblem. Would it even work?
- euro R calipers on 4th gen?
- 1995 Prelude Auto Tranny Shifting Hard?
- cling noise when pressing the cluth??
- converting H23 Blue Top to OBD1
- 95 prelude jdm f22b dohc non vtec build
- Stock Replacement Clutch Change Options for 97 SH Lude?
- Auto to Manual Trans Swap
- Axle replacement
- 98 Lude SH oil change?
- Ingalls Ball joint question/opinion
- Power Steering Line Replacement
- 98 lude windsheild whipers not working?
- What radiators will fit in my 92 bb1 prelude
- identifying if my radius arm is bent
- cranks: Main Journal Sizes
- H22A4 help
- 94 h22a won't rev up
- 95 prelude gas/temp gauge out helpp
- h22a4
- Ground Control Help!!!
- rebuild help
- h22 type s real or fake [piture inside] help
- How do i know what tranny i have?
- 93 Si H22A4 wont run
- 5th gen rear bumper??
- Oil Pressure Problem!
- Automatic Shifting
- 96 prelude start then no start
- Kteller 2.5" catback piping with stock headers/cat h22?
- h22a4 good deal ???
- ok get a vtec or turbo my f22a1 $$$$$$$
- Ideal Swap for a 5thGen
- 94 prelude making a clunking noise under acceleration help!!
