View Full Version : Honda Prelude
- WTB: 90 91 HONDA PRELUDE SI WHITE 5 SPD
- What K&N Filter works best with a AEM Cold Air Intake?
- Help with F22B
- Relays above Fuse Box
- i got a serious /? can any one help?
- buying a short shifter
- hello
- Removing Engine Bay Extras!
- some trans ??
- JDM body kit knockoff
- ROTORS ON EBAY
- Head Lights + rust question
- JDM BB6
- what color are the rings on the 97 + h22 injectors
- turbo oil pan options
- Help with an engine swap--- PLEASE HELP---
- slow acceleration
- replacing m2a4 transmission
- new clutch
- oil pan bolt problem
- 93 Prelude Noob Literally
- problem!!! please help
- HID Harness
- My Lude
- labour hours for timeing belt and water pump?. should i do it myself, any DIY tips?
- !!!!!!!!!!!!!!!!!!!!!!!!! 92-96 Prelude Si Bolt Pattern???
- AEM V2 Intake or AEM Standard Cold Air Intake?
- will not rev past 2000
- Euro R Questions and Concerns
- Suspension for a 5th gen Prelude
- h22 Question
- Bearing Location
- DSM 450cc injectors with OBD0 CRX resister box
- 4 gen header on a 5 gen H22?
- Omni-Power USA Quicklutch Master Cylinder
- Skunk 2 Cam ?
- Persistent transmission axle seal leak
- HElped....Fuel Problem!? Searched...No pressure no start cold...ewww!
- h23 bearing cap bolts
- OBD1 ECU car runs great, back to the OBD2 ECU and car is throwing codes and running like s*^t.
- motherf$%^ front speaker install
- turbo h22
- TPS and 02 sensor problem.. getting real annoying..
- H22 LockOut (searched)
- Finally fixed + a couple questions
- 92si distributor
- i need help plz i have a 98 prelude!!
- 92 si problemo
- What sized LED bulbs are in the interior A/C dash and CC/SR/DIM buttons.
- h22 build
- HEADER PROBLEM I THINK
- another dash light small prob
- 4th Gen CEL: Code 1 and 43, Intermittent
- crower cams in turbo h23, lots of rattling.
- Anybody have the calculations to get the acurrate time from LACR
- !!Quick question about coilovers!!
- Confused about the affect of a Lightened Flywheel...
- Kinda a weird problem
- 93 prelude si, QUESTIONS!
- Jdm H22A Oil
- Fitment 2.0 / 2.3 Radiator
- CLUSTER
- Help!!! white smoke
- My Not so good experience with PROSPEED LONG ass story
- removed evap stuff.. most of it :(
- anyone with a c-pillar bar installed?
- Nex Type-SS Coilovers?
- Stuck in 1st gear on my auto prelude
- clutch problem?
- HELP PLS!!
- will this camber kit fit?
- Replacing Rear Struts
- weird problem with car when is hot outside or i just turned it off and try to restart
- P0325 23 KS Circuit Malfunction???
- How can i get a right hand dive prelude in houston???
- FS: 1997 Honda Prelude Type SH LOWW MILES!!!
- Question about brakes
- is this right for my setup? (header)
- 97 Prelude buy?
- engine swap
- Prelude Seats
- car wont start
- what do you guys think about this???
- Eagle rods
- Removing the A-pillar molding
- need help with vtec
- Free 40 point inspection on our hondas this month of April
- Distributor ?'s
- Ebay FMIC piping?
- i got a ? about my 98 honda prelude it will not fire up but it will turn over..
- Ball joints
- Need infor on installing a Greddy turbo kit from 5th GEN into 4th GEN PRELUDE
- NO pilot bearing in my H22!!!
- 91 2.0Si vs. H22A
- FI CATCHCAN SETUP PIC THREAD (Searched)
- Changed PS Belt - Reservoir now overflows and steering still whines...
- burning 5qts of oil in 1500 miles!
- temperature sending unit
- custom exhaust Question
- Strange Signal Light/Wiper System problem.
- coupler
- When to change oil cooler for 5th gen
- AEM fuel rail? or Venom?
- tire size question
- Muffler on my 97 SH...
- *****Distributer Help*****
- Sh or Base
- -Need opinions on C.A.I (ebay)-
- Any one running 17x7 +42mm 225/40/17?
- H22 idle surge problem.. IAC?
- How would I know if my diff is toast/not working?
- Resetting ECU?
- RMF or SMSP header
- F23 Crank Hybrid Engines Thread
- C32B
- thank you honda-tech
- Car won't turn over
- rear alignment?
- Need help!!! auto tensioner replaced
- Greddy Evo2 exhuast
- SRS light on and FOG light switch wiring.
- Braking The Ice
- help what to do???
- Wiring harness ???
- will h23 aftermarket cams work with the h22
- Odyssey Lightweight drycell battery
- Exhaust Size for jdm h22a
- hit abs in rain = SNAP
- ecu not showing codes
- Axle Question
- Balljoint
- boost
- Driving a 5th gen lude with Sport shift~
- h22 build up
- Crossthreaded Bolt on Fuel Filter...how to fix?
- JDM 93 H22A motor lags before vtec need help!!!
- ** Official H22 Valvetrain Tech, Info, and Measurements Thread **
- vtec doesnt pull
- New (?) product review/install: Megan rear toe arms for 4G & 5G
- Another eBay 4-2-1 manifold
- 89 Honda Prelude Help
- i have started my gearbox conversion on prelude
- 5th gen wheel offset
- odd noise coming from front wheels.......
- 98 prelude Sh car help
- need help with torque converter
- Pulling IM along with head
- New motor is up and running! *pics attached*
- oil drain flange
- Removing axles ..why wont it come out
- Kaaz vs. Quaife LSD
- Speedometer needle doesnt light up.
- Deal or No Deal?
- Caliper replacement / ebrake question
- installing alarm on 97 prelude sh
- Suspension tips
- pilot bearing
- Missing plug h22a?
- Help.
- Head bolt size?
- Need trunk spring reinstalled
- Ugly carpet along door panels... NO MOES :o
- vtec rotors and calipers, will 15" ITR wheels fit...
- honda prelude exhaust queston
- Hood will not open
- F20a Mounting into a 4h gen
- 1992 JDM VTEC Prelude Dizzy, which one?
- test pipe vs cat help
- Tire size for rota gt3's
- MAF SENSOR HELP PLEASE!
- 3rd break light removal
- 1990 prelude timing belt
- Crower stage 3's w/ supertech/RM valvetrain...
- WORM! HELP
- 17yo + Volvo = bent frame
- WANTED: 97-01 Prelude Gauge Cluster
- weir can i find a tunned map for an h22 for s300
- Honda Prelude Manual transmission conversion!
- underdrive pulley
- Turbo for 4th gen h22
- gauge not working
- 5th gen Front Bumper Removal
- does anyone make one
- Endlink ball joint boot
- New Prelude Owner
- 4WS Problem!
- whats wrong with my lude?
- ABS Hard lines
- anyone know how to run the coolant lines on a gt35 turbo
- Oil Pressure Install
- whats the biggest sized rim you can get on your 3rd gen lude?
- H22A valve adjustment problems
- to the guy who's selling the jdm fog lights
- H23 Adjustable cam gear settings...
- horsepower
- Finally some replacement headlights for 5th Gens.....Does anyone already have these?
- My car, pics updated!
- Where Can I Get These
- Replacing Stock Shift Knob!
- Need some advice/input/ideas on what to do next.
- 16x7.5, +22 offset on a lude. Mission impossible???
- OBD2 TO OBD1 HELP...
- Where does this wire go?
- Im looking for a good suspension system for a Prelude SH 98'
- ABS code question
- Riding on uncut bump stops
- aftermarket gaskets...where can i find them?
- Anyone with a sports shift 5th generation chime in please
- ???'s about valve angle on EuroR/TypeS motor...
- Screwed up! How do you adjust idle?
- best bang for buck suspension that is comparable to tein SS
- Valves
- 98 prelude instrument cluster help
- O2 sensor
- JDM 1 piece headlight help!! clear coat is coming off!!!
- Prelude and integra exhaust
- ABS light
- Ecu help please
- ???Loud Exhaust???
- if your valves are moving out of specification what kind of symptoms occur?besides obvoious
- Auto tensioner discussion..
- Honda Techersss.....Help!!! *Searched*
- fire out of echaust
- quick question??
- Bigger injector with S2 Pro 1 cams?
- hey guys new to the forum
- I got three questions and I'm lumping them together because I'm new here.
- windshield wiper problem
- A/C Problem. Whirring sound, not very cold air.
- 5th Gen USDM Foglight Removal
- 5th gen prelude h22 in trouble!
- try
- Euro R Intake mani questions
- Ebay coilovers
- bb4 trying to be cool
- distibutor problem
- Bolt threads on upper arm is screwed.. Can I replace it?
- Is this clutch chatter?
- H22 N/A project
- All H-T build
- Front H&R Race springs way too low?
- really low fuel pressure
- 00 Sh body parts
- P28 ECU
- 99 prelude 4 sale
- h23 need help fast!
- JDM Type S Throttle body on USDM factory intake?
- 93 4ws si 4 sale
- Size Throttle Body from H22 vs. H23
