View Full Version : Honda Prelude
- JDM H22 Swap in civic
- Found oil all over spark plugs
- Need help on what to do with this fuel tank...
- oil takes a while to drain back to pan h22a4?
- 1995 prelude CEL issues.
- sparksman's random build updates
- Enigine Mechanical and Ignition timing help
- 98 h22a4 oil light flashes
- Removing Upper Control Arm Ball Joints
- 95 Si keeps blowing ecu transistor
- I have a question in what h22
- 98 Prelude build thread
- Lowering springs
- h22a running ragged bad timing or bent valves?
- h22a4 97 Prelude wont rev past 5k RPM
- Anyone ever used a ac auto tech cam gear
- H22a1 swap to f20b
- Oil Light/Pressure Issue
- Code 46 System too lean or too rich (slave)
- need help h22A4
- 5th Gen Oil Tap Port Near Vtec Solenoid Assy?
- Having Trouble picking a car
- h22a problems please help
- --- H22A Prelude Need Help Knock Sensor Replacement ---
- Is this a good deal...?
- 1997 Honda Prelude having trouble turning key over. Any advice?
- Time to get my H23 done
- Speedo needle not lit
- 93 honda prelude abs take out
- Walbro Fuel Pump Problems
- 99 Prelude Code Help!!!!
- car dieds while running
- from dohc to sohc just a few questions.
- Headlights wont turn off
- What should I get with my tax return?
- Lude pulls to the left
- Honda prelude heat issues
- Honda prelude brake light
- 1991 Prelude main relay fuel pump
- can i use pr4 s300 in my 5th gen
- Coming from Preludezone
- 2nd fun car?
- Engine Swap + Turbo
- Need help with a open in my a/c electrical wiring.
- HELP!! 1998 prelude with f20b and auto trans issues!
- 2000 Preulude h22a4 cranks n wont start
- Seized Coilover Ring
- high idle when 25 mph and fluctuates under 25
- 2001 PRELUDE WILL NOT IDLE, STALLS. HELP
- Funny idle after I revved my motor
- Another "No Vtec" thread
- 4th gen headlight wiring??
- swapping motor out opinions needed
- Noise coming from Lude
- Big Issues. Please help
- problem
- H22 build injector size question
- 93 honda prelude tire won't move
- turbocharged 93 prelude spark plug questions
- soaked back seats dunno why
- Side markers install help/advice.
- 93 honda prelude sync gears
- 93 honda prelude noises
- Things that almost gave you a heart attack.
- 93 prelude having water/radiator fluid leak
- Is this 1992 Prelude 4WS worth it? $7995 19k miles.
- Should I keep this exhaust or try to sell?
- JDM F22b dohc with h23 head
- USDM H22A to a JDM H22A
- Need ANTI-THEFT ideas NOW!!!
- Hard time starting after letting the car cool down
- 2001 Prelude Automatic Transmission Question
- ?Looking to buy new shocks and springs for 97 prelude SH
- 96 prelude si sudden starting issue
- new harness need part diagram
- TPS adjustment questions.
- 93 hound prelude running issues
- 93 honda prelude air filer water
- Horrible fuel economy and knocking with BP gas
- H23 trans to H22A4 block?
- H23A 1996 Prelude project
- red top or black top h22a???
- USDM or JDM, sleeving before boost
- prelude sh power steering hose
- Clutch master cylinder
- question on radiator switch B (h22)
- How to take off bottom timing belt cover?
- Beware !!! H22a Gates Racing Timing Belt
- :::Codyh 95 Prelude VTEC:::
- f20b sir-t help
- Lowering springs on stock shocks? (BB6 SH)
- f20a4 block + f22z head??
- Oil Leak Issue with Pictures
- Bad noise coming from engine (Video)
- Help with my 87 Prelude Si
- Connecting Rods
- 1992 Prelude S - Possible Purchase
- H22A1 Shuts off while driving, will not start and turns over slowly
- 1996 Prelude without Vtec?
- Performance Upgrades
- Turbo mani for 400hp??
- jdm h22a into 5th gen type sh?!
- Need help with value of 20k mile '99 Prelude
- Electrical Problems or Mechanical Low Idle/Stalling.
- 92 prelude power loss?
- 4th Gen rear brakes
- What's that engine...
- M2B4 transmission not going in gear
- misfiring
- USDM TO JDM H22A9 TO H22A 1992 PRELUDE NEED HELP
- HELP Uncontrolled chassis movement
- F23a vs H22
- Cabin air not circulating right?
- Will a rack and pinion off a 92 accord fit a 92 prelude s
- Looking for Honda discontinued part
- sleeved block?
- Installing a knock sensor on 92 prelude.
- A/C Delete Q
- 94 prelude need parts any info??
- Remove Aftermarket Tachometer Help
- Brake lamp light in cluster "ON"
- External coil questions... testing...
- 99 prelude cranks no start
- 99 type SH slow to crank& no fuel after sitting
- gen4 dirt track car is getting closer
- Can someone help with transmission housing bolt question?
- obd2 to obd1 prelude swap question
- 4th Gen Prelude Fenders?
- Building h22 head
- p75 running h22a
- How to tell if this motor is a f20b manual or auto
- jdm h22a speedo dead won't rev past 3500rpms
- Replacement transmission axle seal
- jdm h22a won't rev past 3500 rpms
- changing gear ratios
- Smoke from exhaust
- no start
- no spark, need help
- F20B build rarity?
- 99 base prelude obd1 ecu
- 1996 Prelude H22A Burnt wire issue
- PowerStop Brake Rotors
- will 16x8 wheels +20mm offset fit in 97 honda prelude ?
- What cylinder fails you the most?
- 1995 VTEC Power Steering Leak - Ok to just remove the belt to drive?
- LeMons build- addicted
- Cam alignment pins for H23
- F20B... H22A+H22A4 interchagablility question
- steering wheel shake/vibrate on highway
- Cant start this car
- 4th Gen prelude ABS Code 13
- Imfamous H22a bogging, no vtec, posssible solutions?
- What am i doing wrong? F22 Ignition timing.
- Ingition switch and kill switch
- H22A cams
- JRSC news!!!! Motorvations Motorsports Jackshaft Pulleys now available
- H22a Headers.
- Please help 96 built lude Si
- idle surge 91 prelude
- Anyone has experience with YONAKA coilovers?
- question about tein springs 4th gen
- euro r swap help
- 4th Gen Digital Dash
- high idle after new master cylinder
- parts list help
- 00 prelude transmission injury
- How hard is it to replace the under the hood fuse box?
- Weird Coolant Problems (hose and radiator exploded)
- more power 92 prelude H23
- JUN h22 Cams?
- 2001 Prelude base, 5 speed, will not idle, stalls after warm up, help!
- Has anyone had a problem with the spoiler light?
- H22a1 iacv help
- 1997 Honda Prelude H22A4
- Looking for a 93 prelude widebody front clip
- 99 cv axle ?
- Oil leak I can't seem to figure out? help!
- Car noises.
- Help me please
- h22a no compression on #2 and #3 rings or head??
- 92 Honda Prelude H22A Build/ Interior
- Shifter issues 88 4WS
- code 9
- distributor
- Prelude overheat issue
- H2B wiring harness to ECU issue
- Help guys Prelude in danger. transmission leak
- Where to find/buy rear 6.5" speaker adapters for 4th gen?
- inaccurate fuel gauge, 92S
- decisions decisions turbo or other
- 95 honda odyssey ra1 jdm h22 automatic
- New dyno numbers!
- 2000 Prelude
- Fuel Gauge lights up but doesnt read
- Exhuast leaks
- 95 SI idling badly and stalls on startup
- 1994 Honda Prelude s gear ratio
- 3rd gen: parasitic power drain, A/C cond. circuit
- thinking bout going turbo
- $45 a good deal for si taillights(bb4)?
- built h22 potential hp
- JDM Floor Well Light Question 92-96
- Thermostat question
- Car Stalls when braking/pulling out of gear.
- Can anyone identify the problem
- 5th gen prelude idle issue
- 99 Prelude, Blown H22a4, K series swap ?
- vtec solenoid
- h22a1 dowel pin size?
- Need some opinions before Alternator swap
- oil pressure light comes on
- 86 Prelude starts spitting after Driving for short time?
- halfshaft
- headers h23av?
- h22 axles
- Does anyone on here have experience with Yonaka coil overs ?
- 5th gen prelude transmission problems
- P1381 and car dying out unexpectingly
- pics. h22a AEM tru power alternator pulley
- pressure plate suggestion
- 1992 Honda Prelude SI FUEL/TEMP issue
- Wanting to lower prelude, questions! HELP
- New battery, but car still needs jump start after a day of no use.
- H22 basemap
- New and having prelude issues
- 99 honda prelude heat issues
- 4th gen* Are these 22+year old cars worth all the cash needed for proper maintenance?
- One O2 Sensor conversion to Two O2 Sensors
- Prelude 3rd Gen fog lights
- h23aV Wiring help?
- h22a crank no start
- ebrake issue (it's an odd one)
- WANTED TO BUY ONLY :: NO TRIAL USERS, NO PICTURES
- SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, PICS REQURED (as links)
- Body shop Aurora CO area
- h23a1 putting in a fuel cell. need to know what external pump to run
- Cams in a H22 Type S, What's the best one's
- 3rd Gen F20B Swap Progress Thread
- Manual tranny on auto H22 long block
- H22a Oil Filter
- 91 prelude si ..idk specs
- bleeding air out of coolant
- gen 4 prelude.. mods for faster steering. dirt racing
- koni coilovers..blownout and banging
- A question on distributors!
- Dont click. Double post.
- thermostat idle issue
- Radiator fan not turning on
