Turn Signal
Old Oct 15, 2003 | 12:28 PM
White98's Avatar
Default Turn Signal
I replaced mine with LEDs. Now they blink like crazy. Does anyone know how to vary the speed? Could be as simple as changing a cap or a resistor. But I don't know where they are. Thanks.
Old Oct 15, 2003 | 12:42 PM
Sephro's Avatar
Default Re: Turn Signal (bnha)
You replaced the corner bulbs with LED's?
If that's the case you are going to have to put something there to use up some current. I do not know the math right now.
Basically the LED's use a lot less juice to power than the standard bulbs. So if the system is used to taking X amount of juice to run and now it is using Y amount and Y is much less than X then you have to use resistors so the system is using X again.
Sorry if that made no sense. I know what I mean just hard to write out what I mean.
ogorek
Honda Civic (2006 - 2015)
Nov 20, 2016 03:32 PM
rickkane
Nov 29, 2008 11:03 AM
chatman_55
Feb 16, 2008 05:49 AM
B16ED4G
Feb 27, 2002 07:43 AM
BoM
Jul 24, 2001 09:10 AM
