PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 [241] 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. has anyone ever bought the AN-R header? whats the fitment problem?
  2. 97 prelude turbo questions pls help.....
  3. Can this rim be fixed?
  4. Recommended pieces to my suspension puzzle
  5. Rebuild List
  6. Jackson racing upgrade pulley for prelude!!!
  7. Jackson Racing Supercharger how much boost input?
  8. Need help with dead pedal
  9. Cant get off my oil pan
  10. 2.5" Mandrel Bent Exhaust Piping
  11. 97 Honda Prelude rust problem
  12. Tenzo R products and Vtec question... - Newbie :)
  13. Radiator
  14. crank shaft
  15. Replacing clutch in an SH: day one complete
  16. Question on how to remove rear suspension bolts?
  17. Weight reduction on 4th gen
  18. koni source for G2's
  19. Transmission Swap
  20. Tranny is leaking...
  21. magnetic tranny, oil bolts...
  22. Knock in rearend of car?
  23. 1995 2.2iVTEC ecu blink fault codes
  24. Factory quench distance for A1, A4 & H23?
  25. G2 vid
  26. Large injectors or new pump?
  27. Past H22 swap threads
  28. Fuel gauge dropping to zero then coming back ?
  29. New ECU Questions
  30. where can i get a turbo manifold for h22
  31. h22 swap
  32. 1995 prelude S wiper arms? where to buy?
  33. Some general question about s2000rims on 5th gen
  34. Pepboys tires.
  35. SH Tranny problems.
  36. from 4 cylinders to 3 and back
  37. Timing belt and tensioner Issues
  38. 5th door trim
  39. turbo h23
  40. lude problems: loud ticking and hissing
  41. Power Steering not working on Hard right turn
  42. cams for h23?
  43. balance shaft plugs...
  44. Secondaries?
  45. what settings have people road raced on at a HPDE with tein ss
  46. what years?
  47. What exactly is the prelude SiR???
  48. Test pipe help!
  49. problems wit 5th gen prelude
  50. Level Ten
  51. Installing CamGear : Quick Question
  52. fuel smell ??
  53. how much boost on built h22?
  54. Prelude VAFC
  55. H23 to JDMH22a swap question!!!!
  56. h22a1 vs h22a4 sleeve thickness
  57. JDM H22 Oilpan replacement.
  58. Need help with part # ID
  59. Who is SUCCESSFULLY running forged pistons on STOCK sleeves
  60. Prelude on dyno - Horrifying!!!
  61. Bouncing Idle, H22 (search not informative...)
  62. Gearbox; Filling with transmission fluid ?
  63. Supporting engine without a engine crane; will this work?...
  64. P13 ecu and hondata?!? please help!
  65. is this true, if not then correct me so that i can go correct someone over on the vortex.
  66. Older Prelude to B18c1 engine swap
  67. secondary butterflies with cold air?
  68. Vtec or not?
  69. Heater core
  70. Strut Bar Question
  71. AEM Bypass Valve Help
  72. 92-96 prelude pros and cons
  73. anyone know of places to buy ate super blue in so cal??
  74. Sagging front bumper. 4th gen
  75. Cooling problems!!!!
  76. Strut Bar
  77. is SiR...v-tec??
  78. after ride drop i get squeeling
  79. 5th Gens - Base vs. SH
  80. 97-01 Airbags
  81. Oil in intake????
  82. best underdrive pulley for a h23a?
  83. Performance parts..
  84. Which motor to swap
  85. 98 Lude S
  86. Fuel Injectors covered under warranty????
  87. Turbo Prelude question
  88. h22 tranny lock up
  89. idle dies after reving. 1992 h23 no CEL's (searched)
  90. HELP! SpeedO Needle dose not light up.
  91. H23 Injectors
  92. h22 cam seal
  93. O.E.M Waterpump or/ Aftermarket Waterpump
  94. OEM Kit 97+ Preludes
  95. 98 Lude that does not have H22?
  96. H23 VTEC Question
  97. has anyone had any problems with progress rear sway on 5th gen base rubbing against brake lines?
  98. Prelude o2 sensor
  99. what size bulb for the bumper lights?
  100. OBD1 H22 into ODB2 H22 Car
  101. what nitrous kit?
  102. ride height - blown vs. new
  103. fastest spool and power output
  104. max spring rate? agx/illumina
  105. Quiet exhaust system?
  106. Prelude valve cover
  107. clogged injector
  108. Is a 97 h22 head worth anything?
  109. 1992 prelude si
  110. WHAT IS YOUR HORSEPOWER AND E.T 1/4 Times, SETUP
  111. Manual Transmission (atts)
  112. h22A4 or f20b
  113. JDM LSD vs Quaife or other LSD
  114. question for HGHer hp lude owners(350+whp)
  115. h23a1 block w/ h22 head versus buying a jdm h22a vtec motor
  116. manual transmission install
  117. **How do you tell which H22 cams these are?**
  118. Timing belt...HELP!
  119. Which Honda Woud You Buy??
  120. HELP ME!!! 02 sensor problem????
  121. HCP mount problem, help
  122. H22 oil pumps fail frequently??
  123. mmi need help guyz my lude died
  124. How Brembo blanks can be abused (video)
  125. rear lower tie bar
  126. oil light is blinking......
  127. engine squeaking problem
  128. Installed carsound cat, now have a CEL 67. is this likely?
  129. Bulb type/size for USDM Foglights?
  130. Shock Knock from the rear passenger
  131. Need a 4th gen
  132. mounting non-atts tranny to atts block *searched*
  133. gauge help!
  134. Swapping in a H22
  135. trouble removing trailing arm bolt
  136. fourth generation prelude backseat area, I need pics & responses
  137. are the dohc F-series blocks and the h-blocks the same?
  138. Neuspeed-Koni Yellow questions
  139. Cooling fans wont turn on after cars off??
  140. problems with 93-96 h22 header and 97up h22 header???
  141. Will JDM H22a fit with same...
  142. Never posted here... any pics of 92+ lude seats
  143. CEL reads code 71
  144. tranny trouble
  145. rps clutch install.
  146. prelude side skirts? "tech" advice needed
  147. stock motor in 92-96 lude
  148. turbo: what all am i missing?
  149. spraying a stock motor
  150. Intake manifold ?
  151. Ichibans???? help please
  152. JDM P13 Greddy Blue box wiring?
  153. need some h22 wiring help please
  154. 97 h22 turbo questions pls help....
  155. Comments and Help on an H22 build
  156. Re-installing the stock intake
  157. Hondata not working properly?
  158. SiR S-Spec LSD tranny code - Full H22a list inside!
  159. Motor Pull ?'s
  160. What makes 4WS light come on>
  161. ebay short shifter any good
  162. Block Resleeve
  163. Lowered prelude and alignment
  164. VSS (89)
  165. here is from TAIWAN,have some question in H23A with H22A head
  166. where does this go to??
  167. WON'T EVEN TRY TO TURN OVER :-/
  168. Draft:Here's the plan, tell me what you think!
  169. What do I need for JDM LSD into USDM Trans?
  170. Is there a clean way to drain the coolant from the block?
  171. Swap Day 1
  172. ingalls' Camber kit
  173. obd2 workaround
  174. how many pounds should i torque the head bolts on an h23???
  175. essential to upgrade to aftermarket fuel filter?
  176. 4th gen. jdm mirrors
  177. Vtec not working
  178. Shift boots?
  179. quick ? on cam journals
  180. which ecu is better???
  181. car shakes when I accelerate!!!!!!
  182. head gasket on 91 2.1 Si
  183. quick question
  184. Greddy turbo or JRSC
  185. 2nd Generation Honda Prelude Help (1983 model)
  186. Fuel Question for turbo setup.
  187. The "Firm"..... Input Needed!
  188. Where to mount fuel pressure gauge with stock fuel rail on 4th gen Si??
  189. Help with distributer 92/si
  190. Moderator Approval
  191. need help with h22a1 dizzy
  192. map sensor on a 4th gen lude
  193. Do JDM H22a trannies have cooling lines on them?
  194. check engine ?
  195. Limitations of a stock H22
  196. clutchmaster: good clutch or no?
  197. IACV location
  198. lip kit?
  199. Needed: Advice on a frankenstein swap for a 92 prelude Si.
  200. converstion kit
  201. TRYING TO FIND INFO ON MY MOTOR
  202. Shock makes Banging sound... Help please?
  203. i need help!
  204. Spoon Magnetic drain plugs
  205. Parts Location
  206. Need help on quick question?
  207. do i need a Camber kit?
  208. need help
  209. DIFFERENCE IN ENGINE SIZE??
  210. Building h22 turbo, compression/headwork/piston questions inside....
  211. Double Din Stereo in Prelude SH..
  212. signs of head gasket trouble? (crappy) pics inside
  213. question on PCV pipe when installing intake - urgent
  214. greddy header = backorder??
  215. need tech specs on putting on a new h23 head
  216. Stock Fuel pump LPH?
  217. were can i buy mugen or jun headers?
  218. PMG - light comes AFTER A FEW MILES OF DRIVING
  219. Brake Caliper Clearance......
  220. What can i get for this setup
  221. exhaust for 94 si
  222. what to take off front clip???
  223. Is the factory wing on a 99 lude functional?
  224. Pics of project Prelude
  225. camber/Toe
  226. prelude jdmtype s cams valve adjustment specs?
  227. Prelude Seats.. 5th gen into 4th gen. Will it work?
  228. JDM header=usdm header
  229. Need pictures of turbo 4th gen vtec preludes, please help
  230. HID??? re: 1peice headlights
  231. clutch?
  232. mugen header???
  233. Intake Manifold options
  234. vtec controller and fuel
  235. H23 to H22 swap question
  236. Type S Cams
  237. Mounting AEM Cai...
  238. 94 Prelude vtec STOLEN from AZ
  239. RSX wheels
  240. Price for built motor???
  241. Engine Cutting Out
  242. Will obd2 injectors work on a jdm h22 motor that im guessing is prolly obd 1
  243. Tanabe Sustec Under Brace??
  244. Automatic transmission problems
  245. Ok, I have a question for all of you guys in the know.
  246. surging idle
  247. hondata gasket
  248. better lsd
  249. H4 bulbs using Low & High filament at the same time..??..
  250. better ignition for prelude jacobs ice pak vs msd sci with ss coil
