help! car won't start unless i push start it
Old Oct 24, 2003 | 12:15 PM
del_parker's Avatar
Default help! car won't start unless i push start it
i just replaced the starter. the motor won't turnover at all. i can see the flywheel spinning but the motor doesn't turn over. what do i need to do?
i can push start the car with no problem.
Old Oct 24, 2003 | 12:17 PM
phildeez's Avatar
Default Re: help! car won't start unless i push start it (del_parker)
check for spark... seized distributor?
Old Oct 24, 2003 | 12:27 PM
4glude's Avatar
Default Re: help! car won't start unless i push start it (phildeez)
if there is no or little light from headlight before starting your car. probably the battery wires should be tighten. --> happened to me
Old Oct 24, 2003 | 12:56 PM
Sephro's Avatar
Default Re: help! car won't start unless i push start it (4glude)
wait the flywheel is turning but the motor isn't???
Old Oct 24, 2003 | 12:57 PM
Sephro's Avatar
Default Re: help! car won't start unless i push start it (Sephro)
Or did you mean it turns the flywheel but not fast enough to start the engine??
When you pop start it does it idle high? Rough??
Old Oct 24, 2003 | 01:38 PM
del_parker's Avatar
idle is the same, it'll crank up now for some reason. go figure...
could a connection somewhere be loose while the engine is cold?
Old Oct 24, 2003 | 02:05 PM
rabvtec's Avatar
Hmmm, good one this! Yeah, could be a loose connection at the starter. these babies get upset if there's a loose wire anywhere.
When you turn the ignition key does the starter motor turn but doesn't crank the engine or does it crank....?
Old Oct 24, 2003 | 05:26 PM
del_parker's Avatar
Default Re: help! car won't start unless i push start it (rabvtec)
the starter was turning the flywheel but the engine wasn't cranking.
Old Oct 25, 2003 | 08:06 AM
kb58's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker &raquo;</TD></TR><TR><TD CLASS="quote">the starter was turning the flywheel but the engine wasn't cranking.</TD></TR></TABLE>
Do you mean exactly what you wrote? I doubt it, but if so, it means the flywheel is not connected to the crank (sheared bolts?), and you had better check it right now.
ayang89
Oct 30, 2011 11:23 AM
Ak_ef9
Jun 12, 2009 11:42 PM
Untouchable13
Honda Civic (2001 - 2005)
15
Jun 10, 2009 01:55 PM
OfTheSun
Apr 6, 2006 10:29 AM
NinjaTech
May 20, 2005 08:12 PM
