View Full Version : Honda Prelude
- Car acting up
- Removing rear deck
- How to check the CEL in a 3rd Gen OBD1
- 5th gen 215/55/16????
- FINALLY: THE HOW TO: Ebay EG fog -----BB1234 Prelude
- What should i do first
- Hi, im new to my car
- 86 prelude no voltage to fuel pump
- Cold Start Idle
- replacing f22a1 ecu with h22a ecu
- Collector mod 2.5" or 2.25"
- 345 injectors on 98h22
- spring
- MERRY CHRISTMAS!! =)
- Inside lights..
- Choose between OB1 and OB2 in an '92
- interior doorhandle paint
- Officialy X-Mas
- really quick question what kind of trans oil do u use for the lude....
- any reviews on an-r headers?
- H22 Turbo Build--- F22 bottom+h22 head
- noisy manual tensioner
- Flooded Car
- corners lights and rear/side lights won't turn off
- Need a favor from all the people I did retrofits for
- redlining H22A...
- traction bar for SH
- type r intake mani question
- Civic half rad with AC?
- Instrument cluster question!!
- Are these typical compression numbers for a type SH with Type S Pistons?
- frame damage
- subframe question..
- My 2001 Prelude, base. It feels... slow =(
- AC Lights
- clicking sound under/by dashboard
- Advice for parts needed for N/A build
- Invidia N1, Apexi N1, or Skunk2
- So I FINALLY got it running but something still not right..... help please.
- Matt, Dual TB setup.
- OMG!! What happened to my timing belt? PICS!!!!
- So i tried to Tune with Crome on my H22 today
- adjusting timing belt on my prelude.
- SS brake lines
- trouble installing jdm fog light
- Need Help
- B21A1 with shot rings
- Limp Mode ?? 98 Prelude
- 4th gen radiator fan relay switch????
- CHRISTMAS EMERGENCY:need 98-99 mid axle and drivers side
- bad idle problem need help!!
- oil light flashing??
- What gap should I use on my plugs for a 97 with type S pistons?
- anyone know stock wieght for the h23 flywheel
- using jdm distributor with internal coil????????
- where is the MAP sensor.
- 1986 Honda prelude Carburated to Fuel Injected
- Wiring diagram for 1994 Honda Prelude Si
- 4th gen mirror replacement
- How can i disable the imobilizer.
- Japan H23??
- Starter ?????
- aftermarket parts for h23 head questions
- 4th gen cables into a 5th gen (one way to get a 4bidden SS for 5th gens)
- Most for the money
- NEED help asap on m2y4
- Oil Leak! :( NEED HELP PLZ.
- Plz help!! H22 cams allready searched
- I keep blowing my ECU Fuse
- need suggestions on nos
- Blue EL Gauges (Don't worry I searched first)
- Which relay is this?
- Can you swap f22b1 into prelude?
- watch out for TEIN HR SUSPENSION COILOVERS ebay suspension kits, or ebay in general
- would a H23 distributor Work on a H22???
- poor mileage/very rough idle when warm
- Injector Latency and Size?
- Oil Orifice
- Integra,Prelude Trans???
- Need help with idle problem
- B16,B18,GSR throtle body on euro R
- 2point6's final dyno... for now
- h22 civic swap will manual tranni mounts work on auto trnni
- Where can I find this part for my JDM Fogs (bb6)
- Running lights wont go off
- Inner tie rod bushing kit?
- ..prelude.. help...
- What would you Guys do with this engine?
- JDM H22 Question
- bb4 foglights
- h22 and h23 manifolds
- does JDM h22 have vtec solenoid screen?
- Crank Pulley Weight
- problem with clutch pin size!
- eg mugen wing on bb1?
- one other problem with the camshafts
- Skunk2 intake mani causing CEL to come on
- no start 89 lude please help asap
- Valve lashes
- skunk2 stage 2 camshafts... which one is intake/exhaust??
- another starting issue, more electrical
- anyone have a faqs on how to properly time the car?
- how much compression to run? for turbo
- ight bout to buy new wires
- Valve Adjustment
- MadCityLude/LudeFinatic Apology and explanation
- h22a swapped lude for sale
- 4th Gen Traction Bars?
- pics of my 94 si vtec lude
- H22A Swap Idling ruff
- what do you guys think of this?
- Steering rack Problem on 4th gen
- clutch recomendations
- H22 Accord w/ M2B4 LSD trans.....I need a taller 5th gear !! please help
- Help I need a taller 5th Gear! H22 Accord w/ M2B4 LSD trans.
- Cracked F20/F22 head. Reliable place to purchase replacement...
- TUNER IN NEED! Las Vegas NV
- what type of lsd do the prelude trannys come with?
- Fan Switch Location
- Shift Linkage
- ghetto riggin snapped shift cables......teehee
- Will a 5spd p14 work in an auto??
- History of the Prelude?
- Is the prelude a good platform?
- anybody have this lip or have a pic of someone with it?
- 4th gen prelude leather seats?
- did compression test half compression on every cylinder
- i need a little help with my 91 lude
- Suspension Question.
- Timing belt and TDC marks
- some body has gotta know!!!!!!!!!!
- Stock Fuel Injectors on H22 Build??
- map sensor
- H22 Downpipe
- jdmsh!t front lip install
- possible clutch problem on 5th gen sh
- Help Identify bolt size please
- Low idle and car sometimes doesnt start
- climat control at dash not working....
- F22b 92 Prelude Harness Help... :(
- axle problem
- radiator problems.... major problem
- Noisy Engine and DIzzy noises
- Radiator
- Werid idle with MUGEN chipped P28
- H23 rebuild??
- Sidemarker Help?
- TSX projectors
- Accord Front Lip on a 4th Gen Prelude?
- Exhuast Recommendation, This is NOT a thread on which is better
- 92 prelude won't start!!!!!!!!!
- you think it could be.......?
- p28 or p30?
- Well I'm officialy Back (man I missed it!)
- engine oil cooler gasket
- How do I sell my 1998 Prelude?
- obd2 to obd1 distributor wiring
- 94-96 gauge cluster in 92-93 lude / converter box? help pls
- 240 SX S13 on Prelude 4th gen
- Information/Picture Request: 4th Gen Prelude SE wheel offset
- Grounds to check?
- stock fuel pressure when not running....
- Throwing cells at 3k rpm while driving at 60mph
- h22 swap info
- 93 vtec wiper relay
- radio wont work after head swap
- jdm head vs. usdm head
- clutch fork prelude/accord
- ecu question
- Using the Civic fork on the BB6?????????
- :Attention Fellow Luders ! Clutch beware.
- front brake pad shims..where to get a set?
- need to get rid of a couple things
- b-series gears on h-series tranny?
- unable to pull cell codes
- GC and Koni Yellow question?
- car not starting
- Tuner in need! Syracuse, New York Area
- Info needed on 98 SH.
- h23 rods
- Is my cam ok to use?
- Left in-board CV loose. Normal?
- A couple of Q's regarding the F22/H22 swap's
- H23a series on a '92 civic hatchback
- Prelude fuel pump on a b16a
- replacment seats
- 4th and 5th Gen Prelude Stuff
- h2a8 TRANSMISSION?
- looking for interior parts
- Car Turned Off - Solid CEL - Starter Sticking
- stroker kit questions
- Best Tire/Rim Size on 5th Gen BB6!
- reverse light problems while driving forward
- speed limiter bypass??? (i,ve searched, believe me)
- What Honda brake pads are interchangeable?
- MAP sensor location and Skunk2 IM h22
- Euro-R Intake Manifold question for 99ludesh
- stupid b20a idling. pleasssse help.
- Where can i find the H23 Vtec?
- who has an smsp or hytech header on there 5th gen prelude
- FORSALE: 1997 Honda Prelude Type SH - $6200 MD/DC/VA
- Thinking about stroking the euro R ... should I though?
- 5th Gen Owners---QUESTION ABOUT EXHAUST AND HEADER
- 95 Si High Cruising RPM?
- what trans for an NA prelude
- IAB with vtec
- Compression Test Results
- CLR + Cat?
- f20 b
- CF Intake on 5th Gen
- bad rim
- What headers do these look like?
- NEED AN ITEM
- How do you get out of being a trial
- widest tires on a 4gen
- lower down my car
- Spoon STB F&R
- Timing Belt...shaking
- In direr need of help with an overheating problem
- Will A Mb24 Lsd fit in an si tranny?
- question about cai filter size
- Roof Cover
- Clutch will not DISengauge - new clutch installed
- what would cause this to be happening to my injector?
- 98-01 h22a 5spd ecu????
- 90ish H22 power specs?
- tokico illuminas vs kyb agx
- rear strut....how do i get em out?
- was missin 2nd ecu fuse?
- wiring issue, f22 into a 93 prelude
- what kind of camber kits should i buy
- Manual Tensioner part Numbers ?
- ABS
- Car sat for a week and now it wont start HELP
- Lude Running Rich
- prelude intermediate shaft
- what is this part for?
- Does Depo make headlights for the 5th gen Prelude?
- Engine swap process Q!!
- clutch problem possibly?
- h22 stutterbox at 6500?????
- H23 tranny with f22a1 engine ??
- Quick question for the 5th gen owners
- h22 block sleeving question.
- Fuel cell install/setup how to?
- 2001 prelude, running like crap, need some help.......asap.
- Auto to Stick?
- Oil Pressure on New Build
- problems with my h22
- 4th gen headlights problem : 1 high beam works, rest is dead =(
