PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. GUYS HELP!!! PLS ASAP INJECTOR PROBLEMS!!!!!
  2. DC Area Mega Meet and Skyline Drive Cruise Oct 28th
  3. Improve handling of 5th gen. Prelude
  4. How reliable is Boosted H22!
  5. floor for my lude 89
  6. Dyno tuned and feeling meaner than hell!
  7. pic request for 06-07 Civic SI wheels on 5th gen prelude?
  8. h23a1 accessories VS h22a4
  9. Question About Slotted Rotors...
  10. Starter Cut Relay
  11. Fire after wire tuck!
  12. JRSC build...I have some questions
  13. RWD / AWD Prelude Ideas
  14. Transmission Help??
  15. h23/vtec need help please.
  16. power goes out when shifting
  17. Best Prelude Coilover Kit
  18. bride seat rails...
  19. Diffrence between manual motors and automatic motors
  20. Camber Kits for 5th gen prelude
  21. 6k to play
  22. question about the bumper
  23. is this the right compression testor for H22 ?
  24. Bent valves or Timing Belt off ?
  25. quick questioN: can the h22 head be removed with intake mani still intact?
  26. Boosted H power bands. 9k+ rpms?
  27. Valve COver Studs??
  28. Smoke coming from A/C Compressor!
  29. 5thprelude +bolt ons need help >.<
  30. If you had a massive intake manifold leak around the gasket would it cause stalling?
  31. omg my clutch
  32. h23a w/ h22a head or type s head
  33. Skunk2 Pro 2 cam Pictures
  34. Blown Fuse
  35. h22a4 drive pulley help
  36. Front Engine Mount Bolts
  37. 5th gen prelude ecu
  38. Aftermarket final drive for Type SH
  39. Timing Belt--4th Gen h23 block and....????
  40. Thermostat install - wrong?
  41. f22a1 to h22a4 swap problems,Concave washer?? Timing belt crank pulley
  42. no power to air conditioning?
  43. window trim
  44. 4th gen front and rear lip
  45. Help Alternator Problem
  46. Just curious
  47. 2001 prelude base... supercharge or turbo?
  48. How To: DIY PCV valve Breather/filter/Catch Can
  49. 1991 si prelude help needed
  50. are these the mugen headlight covers?
  51. Will i need a Camber
  52. Inline Fuel Filter
  53. Trying to rebuild my 1992 Prelude
  54. K series tranny on a 5th gen
  55. Crower Stage 2 3/4 Race cams in an H23.
  56. Does a JDM H22 blocks have a VIN number on it?
  57. Super noob question....
  58. Looking for a place to start
  59. I need allmotor help on Pistons
  60. Strange Smell when accelerating..
  61. turbo h23a1
  62. Prelude insurance
  63. Short Shifter: 3rd Gen (89) Prelude?
  64. how do you remove turn signals??
  65. Quick question about 4th gen Special Editions
  66. forged pistons in h22
  67. Crank pulley
  68. pics of GSR blades on a prelude?
  69. H22a turbo
  70. 4th gen obd1 harness diagram
  71. H22 timing belt jump
  72. can not get my car to start
  73. Vibrant Performance Needs Your Feedback 2.5" Prelude Header Build
  74. Exhaust video clip 5zigen
  75. Unidentified noise from rear left tire well.....HELP !!
  76. **5th Generation Prelude Honda Press Release**
  77. some please tell me where they go
  78. Timing Belt Issue
  79. ATTS light is on?
  80. Building 99 prelude
  81. JDM H22A Distributor and ECU Question
  82. can a accord alternator work on a jdm h22a
  83. New goal for the Prelude Forum - Eliminating Misinformation
  84. Does your 5g Prelude have these two studs in the shock tower?
  85. Compression and Leakdown Tests
  86. clutch help, not engaging i think
  87. H23a/H22a1 what parts are interchangable
  88. frm block?
  89. Powerband question...
  90. 3g overheating problem.
  91. ERZ performance contact numbers
  92. help with h23/h22 build
  93. QUESTION FOR A NEW OWNER
  94. How to get the Brake Lamp Light Off??
  95. my first build, need some specs.
  96. fujitsubo legalis r
  97. play in my steering wheel (removed powersteering)
  98. Are cold air intakes legal in California.
  99. h22 shift linkage maybe bad??
  100. hellp jdm headlights install
  101. Gas and Temp Gauge Light Problem, help.
  102. fuel pump help
  103. connecting VTEC
  104. honda rippin me off?
  105. Question about oil an the head.
  106. A couple of Q's about the auto preludes and tranny conversions
  107. Problem with the Center Brake Light. Help Please.
  108. AC Compressor
  109. 5th Gen Questions
  110. Tachometer problem!!!!
  111. Prelude burning 2 qts of oil per day!
  112. 97-01 prelude stereo with cd-changer
  113. Quick question .. Any alignment marks on the Rear balancer pulley ?
  114. check ingine light
  115. Belt slipping?
  116. clutch and brake pedal problems?
  117. man fuse box question?
  118. What can be wrong?
  119. I can pop my car into different gears with little effort and no clutch..leaking master/slave cylinde
  120. My car will not rev past 3000 rpm
  121. 5thprelude +bolt ons need help >.<
  122. Rear Rack Locking Tool?
  123. Inline Racing's H22 Turbo Prelude- 487WHP/333WTQ - 93 Octane Pump gas
  124. Paint code??
  125. 92-96 Prelude Logo Needed - For New Floor Mats
  126. h22a oil pressure problems.
  127. Does Honda just sell the oem airbag cover?
  128. prelude tcm pinouts
  129. idling issue... help?
  130. Si clutch choices??
  131. FPR questions.
  132. 4 lug conversion to 5 lug conversion
  133. need help w/ exhaust system
  134. Slave cyl problems or i'm having a retard moment.
  135. prelude ignition help!!!
  136. 4th gen fogs
  137. Is this an OEM alternator pulley? (h22)
  138. RC vs MSD injectors
  139. p28 problem
  140. 60 mph shake
  141. Timing off? Loosen auto tensioner?
  142. High Flow cat 4th gen
  143. FS: '92-'01 Prelude ground controls
  144. clutch (searched)
  145. Oil Filter?
  146. Oil catch can questions (searched)
  147. Decent performing exhaust system without the 'fart'?
  148. f22a1 to h22a swap in my 96 lude...need help
  149. Oil ?
  150. throw bearing install?
  151. H23 to H22?
  152. Reprogram ecu?????
  153. EE break
  154. Proposed H23 vtec build...
  155. Anyone put a b18c1 in an 1986 prelude?
  156. Exhaust pipe is too loud, tire of it, seriously!!
  157. HELP!
  158. Kamikaze header
  159. Prelude JRSC owners or just 5th gen owners
  160. Head Light Problem!!
  161. performance distributor
  162. Check engine light . . .
  163. system too rich too lean
  164. Wilwood 6 piston calipers, 11.75" rotors, and they fit under 15x7 wheels!
  165. rear seat removal
  166. skunk2 coilover sleeves on stock shocks? anybody?
  167. Ignition Problem?? H22 EK
  168. H23 to a F22 ???
  169. honda part number
  170. Need some Jdm H22 Help (parts)
  171. what bulbs to use with jdm headlights?
  172. SRS LIGHT!! how to reset using the paper clip way??
  173. Ignition Wiring (searched)
  174. H2B
  175. hesitation and white smoke
  176. help with auto trans
  177. OEM Valve seals question
  178. Problem after installing Axle(Driver side)
  179. REFLASH
  180. need pic showing different plugs....
  181. Aftermarket Steering Wheel with 4WS
  182. H22 & H23 Fuel Pump Compatibility?
  183. anyone know where to get new airbags?
  184. official intake manifold thread????? wth, i searched...
  185. installing axles
  186. which is better?
  187. 91 honda prelude Si BEAST!!
  188. Adjusting distributor
  189. 98 wont start....
  190. engine swap now check engine light on
  191. help!!!!
  192. Angle Grinding off Cat Conv. Bolts
  193. Operation: Restore my 1995 Prelude: writeups/diy's/ mad pics! no 56k
  194. when I push in the clutch my rpms drop
  195. Completely stumped
  196. what you think
  197. ROCKERS
  198. POCKETROCKETSRACING.COM SCAMMING ME BEWARE
  199. H23 Rocker Arm Play
  200. roller rocker arms
  201. CAR WON'T START!
  202. HELP! amp: Firewall?
  203. Clutch Question
  204. Any good h22a rebuilders in the northeast NJ/NY/PA area
  205. clutch question
  206. How to Install VTEC Controller on a 98 Prelude SH.
  207. H22A HEAD BOLTS???
  208. help me my prelude is acting dumb
  209. Need machine shop on East Coast
  210. @@@ EXHAUST pipe THEORY For H22 (2 1/2 or 3")$$$$$$$$$$$$$$$$
  211. help! weird PCM wiring
  212. Guess what I found out earlier.
  213. missing fuel rail nut, what size is it?
  214. what is this on my fuel rail
  215. Hondata IM gasket does it come with washer?
  216. HELP 91 Prelude Si did not pass emissions
  217. Timing Belt hard to install even with the Tensioner compressed?
  218. FM 5gen Shifter spy photos!!!
  219. 99 honda prelude - Lost key :(
  220. Suspension Setup
  221. SHOW ME SOME CLEAN PRELUDE's PICTURE
  222. overheating
  223. how to check transmition oil
  224. question about camgears
  225. In need of new tranny need information..
  226. '89 CEL code check?
  227. H23A turbo manifold into H22A head
  228. The right side of my bumper sags, what do I need? [97 Prelude]
  229. H22 Type-S pistons in an H23?
  230. Crower Prelude Camshafts
  231. A 2000 Honda Prelude base / auto with 88k on the odometer ......
  232. Any info on 4th Gen JRS mods?
  233. I've searched, (archived aswell) Car stalls after sitting even just over night. Any help please?
  234. Air fuel ratio hook up
  235. power steering having issues
  236. Header port
  237. Fully built H22a, how much it worth?
  238. Prelude meet up
  239. Badging question
  240. Searched long and far before i posted this thread. Engine help
  241. Got the motor an tranny out...
  242. F22 -> H22A1 Swap
  243. What about this H22 setup?
  244. steering wheel fitting
  245. How do u Adjust the clutch pedal?
  246. rsx seats in 96 honda prelude
  247. possibilites with a 88 si with b20a5
  248. so...i think my clutch broke.
  249. 4th Gen Center Vents Replace with daytime running lights
  250. Jdm H22...which injectors work?
