PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 [239] 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. got dynoed here are the results
  2. DC vs JDM vs USDM Header Pics Inside
  3. a bad couple of days come to a end
  4. A Few questions
  5. How to tell
  6. h23 vtec oil orifice? still need oil line?
  7. h23 vtec rod and piston very technical (i think)
  8. Where da get your JDM motor from?
  9. f22 h22 distributor compatiblity
  10. 30 seconds of happiness - H22 ECU or Distributor failure
  11. Looking for nice mufflers to use for sleeper 2.5inch exhaust system
  12. Why EGR Valves suck
  13. Short shifter little rough
  14. Car makes rubbing noise?!? please help!
  15. oil control orifice
  16. Boosted BB1 Stage 1 pics!
  17. 92-93 Foglight switch?
  18. H22A, H22A1, H22A4 Cylnder heads
  19. Dynojet, Dynopack or Mustang Dyno
  20. Prelude 4-2-1 Header?
  21. my idle is stuck
  22. Help with H23A1 USDM To H22A JDM Swap
  23. HElpp pleaseee:: Oil problemm::
  24. Implications of slightly bent forged rim?
  25. All Motor Results
  26. Do preludes not like OPTIMA batteries?
  27. h22 jdm distributor
  28. Auto tranny rebuild
  29. 40 series tires for h23 gearing?
  30. 2.5" piping with stock muffler on H22? Opinions
  31. HKS Sport exhaust
  32. h23 bolton fitting a f22?
  33. what headlights are these
  34. brake bleeding procedure
  35. Oil problem from top to bottom =O
  36. 92-96 front lip
  37. BEST RADIator for prelude
  38. usdm h23a1 to jdm h22a swap need help with a coil issue
  39. stupid parts place cant locate the gaskets for me need help
  40. Aiming Headlights (4th Gen)
  41. brakes = no power?
  42. not so torquey
  43. Why is my MAP sensor throwing a code? (and what exactly does a MAP sensor do?)
  44. Timing belt gurus (video)
  45. which trans?
  46. Results from the drag strip.
  47. h22 engine with h23stock ecu
  48. TIPS: Basic's for building your motor for FI... and having it LAST
  49. Will this throw the crank balance off??
  50. will tranny leak if the axels are not in?
  51. rebuild h22 tranny
  52. F23A1 engine 93 Prelude S
  53. will h22 JRSC fit h23???
  54. C/F Trunks
  55. Oil leaks from the bottom end? Help! Help! Help!
  56. ECU advice for JDM H22A
  57. d16y8 Dizzy vs. D16z6 Dizzy: NEED HELP FAST!!!
  58. unwelcome intertwining of metal and possibly bad rings?
  59. HELP!! URGENT!! Vtec Rocker Shaft Removal
  60. throwing code 5,7,36,41
  61. valve lash/adjustment questions
  62. Clunking In Front End When Hitting Big Bumps
  63. Turbo VTEC Problem
  64. SMSP header owners, please read
  65. Can u put 19in wheels on prelude sh
  66. low red line help
  67. automatic transmission question
  68. Suspension Question
  69. h22 type-s cams and spray
  70. Identify theses sensors plz!
  71. Type S pistons
  72. DOHC TDC
  73. help, gearbox
  74. Harness for an INX model
  75. 4th gen JUN lip
  76. 98 Lude, DEI 555D immobilizer bypass, flashing immobilizer light
  77. swap question...help please
  78. MIL ON, Code 61, 98 Prelude
  79. Searched:FMU or AFC-hack better for H22A4 6-7 psi?
  80. how to clean...
  81. H22 Engine Build...
  82. 215 on stock 15 in wheels?
  83. Condensation Problems
  84. prelude halfshafts?
  85. Mugen Chip mod for VTEC
  86. loss of power in high rpms...
  87. h22 hytech header any body have it?
  88. h22a with a h23 tranny
  89. chamber kits??? for lowered cars
  90. LOW RATIO RPM
  91. 91 Prelude B20A Timing Belt Broke
  92. DeToNaTiNg VTEC
  93. Engine flooding (too much gas)
  94. turbo-ing my JDM F22B prelude
  95. i need new clutch for 93 lude si
  96. flasher relay for 1987 prelude
  97. Radiator Clearance Issues...
  98. thinking about buying a 94 prelude si. Suggestions?
  99. No brake lights in 89 Prelude Si?
  100. going to look at an h23 TODAY -> what to look for?
  101. Driveshaft 'useable'?
  102. Is this a good price??( sleeve labor cost)
  103. question to all the turbo people
  104. what size T.B. for boosted H22 -- 20+lbs
  105. what is the best size tires for a 01 prelude sh
  106. My Prelude Sold (sniff sniff).Good News Though The Spoon Lip and Mugen Wing Didnt.
  107. h22...all motor
  108. how much does it cost for compression test on prelude 2.2vtec
  109. Is this the right LMA????
  110. Recap from NASA @ VIR - Feb.20th-22nd
  111. Compression from milling
  112. skunk 2 valvetrain
  113. looking for a h22 downpipe
  114. 60 bucks for cupholder!
  115. new to HT. 98 prelude swap in 96 civic HB. need help!
  116. 4th Gen OEM bodykit. Did they ever make it??
  117. Prelude Emblem adhesive
  118. H22 vs. H23 revving speed
  119. suspension problems in 4th gen? can ya help me
  120. ***Upper pipe intake piece***
  121. brakes question
  122. h23 snapped rod - crank and tranny ?s
  123. MuGeN prelude bumper
  124. Oil in distributer.
  125. JDM LSD
  126. Full-Race Traction Bars....signup
  127. 1st baseline DYNO
  128. LMA Replacement & Installation: Has anybody done it?
  129. Prelude shifter assembly?????
  130. jdm distributor cap and rotor (SEARCHED)
  131. DROpping out of VTEc
  132. sh suspensions
  133. 5th gen suspension on 4th gen?
  134. icebox?
  135. catback?
  136. Need some help, doing a auto to manual tenstioner swap right now.
  137. help removing 4thgen prelude speakers with out opening door
  138. balancer/auto ten missing? Pic inside?
  139. STILL CONFUSED fix del slow or get 98 PRELUDE SH what would u do
  140. 91 Prelude 4ws?
  141. DSM injectors with Resistor box on H22?
  142. Prelude Type-S Tranny with LSD
  143. I need vouches saying i dont need a new harness!!! h23a1 to h22a swap!!!
  144. big question
  145. Please help save my Engine. Bearing (Spun?)
  146. Wiring for vtec for 92 preludes
  147. how many ribs on your alternator belt/crank
  148. oil on the plugs....
  149. problums with my ride
  150. $194 For helms!! help plz...
  151. anyone deal with www.overnightautoparts.com ?
  152. Is the jdm h22a header the same as the usdm h22a1 header?
  153. CARB EXEMPT PARTS
  154. Distributor problem...I think
  155. Fuel Rail Size Fitting Thread Pitch
  156. Any one know? Where to get one of these?
  157. 4th gen Prelude Fog light Q?s
  158. Timing Belt slack
  159. 1988 Prelude info
  160. timing belt
  161. Weird squeaking noises coming from my suspension...
  162. STR cam sprockets slipped.
  163. Question about my buddies turbo prelude...
  164. please help motor mount questions
  165. PortMatching Head
  166. Urgent Suspension Problem.....any advice???
  167. Oiled timing belt?
  168. best cams to run for h22 going n/a
  169. What Engine is better to put mods in it?
  170. What size injectors?
  171. New to Ludes
  172. h23: cams and cam gears
  173. ?'s on prices
  174. mustang dyno
  175. New Shocks
  176. Will OEm 17" accord 5 spoke wheels fit????????????????
  177. options...
  178. h22 dyno plot...
  179. lug pattern for prelude 96 down
  180. do they make any kind of black headlights for 98 prelude
  181. Need Some Head Advise
  182. 97-01 (SPK) Sunroof Plug Kit, DONE No 56K here!
  183. FMAX Turbo MAni - junk ?
  184. turbo 01 sh part deux
  185. rs-r ex mag exhaust for prelude
  186. busted struts
  187. quik question about neuspeed springs
  188. --PrecisionH23A Approved-- Remaining Stuff for sale...
  189. some ?s on MSD ignition setup
  190. Lock problems
  191. 97 Prelude Sh OBD 2 Ecu Needed!!! and need to know about immobilizor!
  192. how many miles are 2.2 vtec engines good for ?
  193. Holy F'n power window problems!!!!!
  194. Side markers out?
  195. Intermittant Speedometer Issue
  196. turbo 01 sh
  197. Size of apexi ws pipes
  198. 4th Gen Alternator
  199. Help with a friends 97 prelude
  200. Vacuum gauge installation
  201. Just put in GM Synchromesh
  202. Coolant leaking, overheating, should I do heater bypass?
  203. DC Sports cat-back...
  204. Header recommendations for H23...sorry Prelude newb...
  205. fog light
  206. Whats the Best Turbo Manifold for t03/04 on a 5thgen LUDE -
  207. what lude..what lude?
  208. HELMS: Ride Height
  209. Twin Disc options?
  210. Engines i can put in a 93 lude si
  211. Anybody ever installed cam shaft by themself?
  212. Looking into new throttle body on the Euro R..Suggestions?
  213. Help,My car dont rev pass 7500 rpm
  214. question about he drag gen 4 kit for 5g lude sh
  215. Power steering pump, alternator, and AC comp. brackets..why so heavy??
  216. lower ball joints
  217. ngk
  218. VAFC II Question
  219. need new clutch?! :(
  220. will it run if???
  221. Questions about removing the crank pulley off the H22a
  222. Turbo?
  223. h22 skunk2 ecu
  224. Best cams for h22
  225. NewBattery IN!
  226. E-Brake 4th Gen
  227. civic fuel filter on prelude engine?
  228. Turbo Question?
  229. Suspension Lube Points
  230. Rear Rotors?
  231. Bearing clearances
  232. Problem!
  233. 89 Prelude Engine stuttering & Bogging at take off....help??
  234. how do i get 11.5 compression?
  235. Prelude rear defroster
  236. Any hope for this prelude?
  237. Prelude bolts/screws I need to piece back together the Lude
  238. F22b2 block+H22a1 head, F22 VTEC, F22B/VTEC
  239. How to check to see if my AC compressor still works??
  240. CEL 15 and 22
  241. Heads up: M2Z4 SiR s-spec LSD tranny 4 sale
  242. prelude f22a1 to h22a swap wiring problems
  243. h22a distributor
  244. how can you tell if it is type s cams or not?
  245. how much hp expected out of a dc stainless steel header?
  246. Need help with engine...engine Revs back and forth...
  247. Idle problem
  248. 4th gen - how to install steering wheel?
  249. need some price help
  250. How is your auto ss tranny holding up??? for the 5 gen ludes
