PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 [123] 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 4th gen as a demo derby car
  2. Wierd squeaking noises
  3. Prelude problems..
  4. Blox H22 Cams
  5. How to install msd SS coil [searched]
  6. My experience with the H22 Mahle "FRM Compatible" Pistons
  7. H22 or H23?
  8. header wrap? for h22?r
  9. BEGINNERS GUIDE TO BOOSTING.... All pros come and answer!
  10. need help finding speedometer senser!!
  11. do you really need timing belt cover?
  12. Camber Question.
  13. how to diassemble this switch
  14. No tachometer...help
  15. WHAT KIND OF MODS CAN I DO TO THIS??
  16. Duraflex Body Kit - is it worth it? Is it plastic?
  17. Damnit! rear sway ripped out
  18. Installing Air/Fuel Gauge?? Colbalt brand
  19. 89 prelude
  20. wierd key problem?
  21. cf hood vents. does water get in through them?
  22. Looking for a repuitable East coast machine shop
  23. 98 Prelude SH, temp gauge fault or need a thermostat! HELP!
  24. '93 Prelude Won't Start
  25. For exhausts...is BIGGER actual better for the H-series motor???
  26. Scattershield Installs
  27. Differential Preload Question
  28. light dimmer pins?
  29. Have any of you guys changed out your cabin air filter?
  30. no spark..dead cylinder..valves?injectors?..HELP!!!!
  31. rpm guage bouncing!!
  32. how much HP and torque before the AT blows??
  33. JDM H22A distributor cap
  34. headlights dont work
  35. Transmission Fit?
  36. LEAKING OIL
  37. stripped head bolt
  38. bb4 wing ?
  39. Over Reving question
  40. Calling all Prelude Master Mechanics......
  41. Calling all Prelude Master Mechanics......
  42. OEM replacement calipers vs. Aftermarket
  43. replacing engine
  44. serious advice, from serious long-time prelude owners.
  45. Generally, how much do our tranny's weight?
  46. honda security system won't let me turn over. Need help please!!!!
  47. advantage of octane
  48. H23 Troubles
  49. tein ss vs. tein flex
  50. Prelude Type-SH
  51. audio setup recomendations - 4th gen prelude
  52. new to to honda-tech
  53. TUBULAR HEADERS!!! WHERE!!!
  54. help me choose
  55. car won't start
  56. h22/accord power steering pressure hose.
  57. firing order....?
  58. emission control vacuum tubes???
  59. Name Brand CAI??
  60. Front Lip
  61. Polishin my header?
  62. Full-Race H22 Kit?
  63. Is there a adapter kit for the h22 motor/b-series tranny in a 92-95 civic?
  64. Can i remove this??
  65. how are the obx or other ebay camber kits compared to ingalls?
  66. Will an h23 4th gen auto transmission work on a 97 base
  67. H23 crank, rods, pistons in a H22 block?
  68. Compression and Rebound adjustable shocks
  69. obd1 distributor wiring
  70. B20 Fuel System
  71. Blown tein shocks that were brand new???
  72. My lude eats too much
  73. Question for those familiar with jdm headlights (opened them would help most)
  74. h22a no butterflies
  75. H23/Prelude 2.3 Starting Problems HELP!!
  76. car wont start
  77. = H23a1 A/C system removal? Belt question.
  78. 99 p5m pinout need.
  79. Question about OBD2 engines/trannys
  80. skunk2 throttle body ?
  81. H22A with a B16 tranny?
  82. Need a Reputable Shop in the NYC/LI area
  83. Purge Cellinoid???
  84. 205/40/17 5th gen Lude
  85. vibration noise from engine
  86. ebay ecu
  87. Missing Transmission Pieces, pleaseee help
  88. Anyone know anything about VSR Wheels?
  89. hard cold start
  90. Help!! lights don't work
  91. Eletrical problem, any ideas?
  92. Noobiest question ever
  93. Clutch Pressure weak in high RPM only
  94. fogs for 5th gen
  95. H22, what is this rubber piece and where does it go ?
  96. 93 prelude exhaust
  97. Switching H22A4 over to OBD1
  98. H22 Valvetrain components
  99. Constant Vacumm Control Valve/EGR Vacumm control valve
  100. h22 vacuum line pics
  101. Compression To Power Ratio?
  102. Reccomended Amount of Boost for Reliability?
  103. whats your opinion on this car?
  104. What do you think about these cams????
  105. My Prelude is too much trouble.
  106. Electrical gremlins wipers/windows
  107. HELP!!! Unknown Relay
  108. car dies after short drive
  109. will these fit
  110. 5th Gen Manual Rack
  111. H22a4 Block with JDM H22 head?
  112. optilux foglight review (pics)
  113. car making slight clicking noise
  114. Aftermarket header+OEM gasket=blehh
  115. p28 trouble
  116. JDM rear wiper
  117. honda keyless entry on 5th gen
  118. SUPERCHARGED LUDE
  119. Oil pressure sending unit.
  120. tranny/ clutch problem?
  121. AAAGGGGHHHH!! Wont Start!!
  122. attn: h22a owners
  123. Cold Air Intake install question.
  124. Twitching Light Question. Need Assistant pleeeeease.
  125. help me out
  126. (Already searched) Does anyone have a good write up on skunk2 intake manifold.
  127. safe to rev h22 past 8k?
  128. 4bidden Short Shifter Review
  129. F22 Auto to H22 swap
  130. new aftermarket crank pulley jdm h22 cuaseing pinging sound?????
  131. weird problem starting up
  132. valvetrain swapping
  133. New EGR Mod Idea!!!!!!
  134. weird spark plug issue
  135. Stock oil pressure sending unit ? Remove?
  136. need suggestions
  137. B series motor in prelude?
  138. H23 to H22 Brakes
  139. possibly running rich?
  140. IAB (A17) or ICS (A19) - Control Solenoid for VTEC
  141. JDM h22a starting issues
  142. whats that smell?
  143. intake mani fitment
  144. Which ECU??
  145. Funny Idle STILL
  146. are these h22a1's?
  147. bearing colors???
  148. n00b With A Tranny Query!
  149. DIY - How To - 4th gen JDM Black Housing Headlights
  150. direct port nitrous
  151. DIY - Block filling
  152. JDM Honda Prelude BB4 3rd brake lamp
  153. LSD AND HEADER
  154. tranny code M2L5
  155. searched POWERsteering removal on 4th gen
  156. H22A swap promblems need help
  157. Does this exist?
  158. Vafc controller
  159. 4g pass airbag question
  160. Ideling and other issues after timming belt replacement
  161. distributer and misfire question ASAP PLEASE!
  162. 4th gen front lip
  163. 89 prelude motor swap
  164. checking shifter assembly?
  165. ABS Removal in 5th Gen
  166. abs light turns on
  167. What next?
  168. Prelude 96. Tail lights don't work.How to fix?
  169. I need some help
  170. 4WS fault codes (5th gen) BEEPS twice, NO FLASHES can anyone help?
  171. s2000 steering wheel...worth it?
  172. Exact Differences between USDM H22a1, H22a4 and JDM H22a
  173. sound system help (firewall)
  174. Bypassing O2 Sensors for 5th Gen
  175. H22A4 Timing Help
  176. el gauge question
  177. H22a4 ODB1 conversion
  178. Stroker H22 with JUN valvetrain and cams
  179. just got this off ebay (peice of crap)
  180. water bypass valve installation
  181. searched... where can i get jun cams
  182. transmission fluid gone?
  183. jdm h22a swap shop bay area
  184. quick question
  185. New here... 90si Turbo
  186. Clutch Help !!
  187. timing
  188. 4th Gen. Rear Brake Conversion.
  189. '93 Prelude Si h22/h23 hybrid..... please help
  190. DYNO PROVEN!BlackTrax H-Series Intake Manifold Spacer. Has anyone tried it???
  191. Axle recommendation please
  192. So my buddy bought a 1997 Prelude SH back in 2002...
  193. Vibrant Streetpower Exhaust
  194. Pic request.
  195. no fuel h22a accord 94 ex?
  196. B18C engine in 89 BA4 lude
  197. 4th Gen's with Rota GT3's Please post pictures
  198. h22 balance shaft belt
  199. antifreeze drain bolt?
  200. accord a pillar
  201. timing belt issue
  202. is 205/65/15 too big a tire for the 4th gen prelude
  203. 93 prelude H22a turbo project/ NEED TURBO PARTS ASAP
  204. Brake Falling to Floor
  205. are h22 injectors 345cc ?
  206. Tiptronic vs. 5 Speed
  207. Spare Key
  208. spongy brakes on 93 Prelude Si
  209. H22 problems help my white ass please
  210. buddy club rims
  211. PLX ?
  212. Stumbling problem
  213. F22A Timing Belt Inspection......................already searched
  214. taking main crank pulley bolt off...?
  215. which way to boost honda f20a engine?
  216. some prelude history
  217. tips on installing cams???
  218. Best psi to run to guarontee longivity h22a
  219. where can I find the following? PLEASE READ!!!
  220. Weird Tps problem
  221. ideal wheel size on 4th gen prelude
  222. Carb legal turbo?
  223. h23 w/h22 head
  224. camber kit
  225. how much power can you get out of a built h22a turbo
  226. tunable ecu
  227. Failed Smog...Need Help from Fellow H22 swappers and Emissions Gurus
  228. info on an h22 in 89 prelude
  229. 92-96 H22A 550 Injectors?? Where Are They??
  230. After replacing windsheild?
  231. Valvetrain question
  232. engine idle low 99 prelude h22a
  233. help needed
  234. H22 head removal...
  235. Deciding whether i should get a hatch back or a prelude
  236. How to tell if my muffler is blown?
  237. Where is the IAT sensor on my 1998 non SH prelude?
  238. speedometer doesn't work. fuse blown
  239. looking for a part number
  240. Fuel pump installation
  241. Is there a High flow muffler that won't get me pulled over?
  242. hks sport exhaust pics!!!
  243. problem..idk wtf
  244. Wierd problem,electrical related????
  245. problem with an intake....
  246. in or out dizzy
  247. different size tires front and back
  248. heard of vecco?
  249. Occasional random rev cut
  250. What brand oil pump gear are you running on your h22?
