PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 [168] 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. good inexpensive header??
  2. cel light... cant find the plug.
  3. tricking out a honda prelude, 2.0
  4. Weird sounds coming from my car..
  5. wierd ass clutch problem
  6. changing my clutch what should i watch out for.(99 base)
  7. 5th gear, 80 mph = 4k rpm on h23?
  8. help please...new prelude with problems
  9. how to install adj cam gears? jg
  10. prelude o2 help
  11. 5th Generation Prelude Owner's Mod list
  12. tachometer uncalibrating itself
  13. Timing jumping around!!
  14. 2point6's new dyno
  15. new motor
  16. what gear do u dyno your car in?
  17. 5th gen prelude gas mileage question
  18. i need a new motor
  19. Vaccuum Diagram
  20. Wires
  21. Hiro Lip
  22. for turbo, what should....
  23. how to do a h23a/h22a frankenstein
  24. head dissassembly help ....headstuds
  25. Brake light on wondering why ?
  26. OMFG.... anyone had to deal with Megan Racing customer service??
  27. exterior window moulding help
  28. Can it be done?
  29. how fast is it stock
  30. Brake light stays on when cold
  31. How long will it last
  32. cam seals/caps
  33. 4th gen antenna fix [searched]
  34. High handbrake???
  35. What stand alone is the most cost effective?
  36. Turbo Like Products
  37. HID's and Light Bulbs
  38. Valve/Head inspection.
  39. Which Exhaust
  40. JDM H22 tranny question?
  41. where is the MES ( memory erase signal ) on a 4th gen prelude
  42. Noob question..... how to install a new bumper
  43. 2.3L vtec?? does it really exist?
  44. maybe electrical, smoking, weired idle, and gaz problem, and bogging, all in one, plz help
  45. slim fans
  46. Question about prelude engines.
  47. 97-01 Prelude Headlight bulb questions
  48. something bad happened!!
  49. Head Rebuild = Trouble :S
  50. Car won't start after sitting for a while.
  51. where can i get the gear that go's on the crankshift of my h22 ? the one for the timing belt.
  52. ford probe turbo and manifold on a f22 will it work fine on stock boost?
  53. should i use my VAFC-II
  54. Chip: Too good to be true?
  55. crower rod studs
  56. h22a oil pan
  57. broken suroof-97 prelude
  58. Ractive Coilovers
  59. Basic Bolt-On Opinions
  60. Crude oil.
  61. JDM H22 Timing Adjustment Procedure
  62. PLEASE HELP: Ignition problem/question.
  63. Ecu Help
  64. jrsc on h23????
  65. tech q's (h22a in a 97 civic)
  66. JDM Fog Lights
  67. H22 With H23 Crank-Oil Squirters(Searched)
  68. axle and halfshaft fitment
  69. Superpro Bushings group buy.......
  70. Parts list... Additions/subtractions/opinions
  71. clutch master cylinder
  72. h22a knocking noise near cranks
  73. H22 Compression Choice
  74. h22 torque specs
  75. DON'T BUY GAS ON SEP 1st
  76. Type S sized B pistons
  77. jdm type s strut bar......
  78. temp going almost all the way up?
  79. which cams?
  80. Nitrous and agressive cams
  81. Vtec acting weird
  82. Little mystery hose
  83. Compression #'s on an H23/VTEC??
  84. Did I get screwed on my bearings?
  85. '92 h23/vtec oil light on
  86. Question about Vtec controller?
  87. Any good mechanics on Long Island?
  88. MY H22A Build.. any advice would be great!
  89. What are the blue pellets that are making my car smell so good?
  90. suspension what is better your opinion drag or auto x
  91. JDM h22, manual. ANYONE HAVE A CD OF IT?????
  92. Name this year
  93. valve cover bolt!!!
  94. bleeder screw?
  95. small 91 prelude problems...
  96. Built motor won't start, please help. PLEASE
  97. Need your advice... check this out?
  98. im building my bottom end but i need some help
  99. 1992 honda prelude
  100. smashed exhaust by tire shop
  101. intermediate shaft play question
  102. timing belt/water pump question?
  103. How many of you know if your iabs are working?
  104. problem: running really rich?
  105. Hey guys some help please 91 prelude si
  106. 95 Lude JDM tranny... how much?
  107. Error code 17(Vehicle Speed Sensor)
  108. What lowering springs are these
  109. 5th gen driver door wires and connectors
  110. High Mileage H22a4 : Rebuilt or Replace
  111. ?'s 4 - Supazzzleepa, @ries, FAS4WS
  112. running lean,from dented in downpipe
  113. Inspection..
  114. trans fluid?
  115. whats the difference on the sh motor?
  116. header different, base vs sh model. already searched.
  117. BUILT h22 turbo TUNING question????? need imput!!!
  118. is my clutch gone??
  119. need advice on cv shafts...
  120. 93prelude
  121. Anyone looking for JRSC?
  122. oem steering wheel
  123. Coolant Lines on H22A Euro R Intake Manifold
  124. 93 prelude parts
  125. Fitment H22 block on H23 head & tranny
  126. Speed needle light not working
  127. Wheel adapters - please help me....
  128. o2 Sensor, Cleaning it???
  129. would these fit???
  130. Do not adjust the gap of platinum tipped plugs, replace if out of spec?
  131. Turbo h22 or not?
  132. Prelude H22 5 Speed Transmission (M2F4)
  133. high flow cat
  134. custom ext adj konis for 88-89 lude
  135. Running Lean??
  136. NITROUS question about Temperature.
  137. Who is running a aftermarket Intake Manifold ...........
  138. clutch engages wierd...
  139. 98 lude Spun a rod bearing whats my options
  140. Need to change valve springs - should I splurge on other headwork?
  141. Intake Manifolds for H22
  142. Stock(ish) springs and shocks-where to get cheap.
  143. need maint. help
  144. mugen front bumper?
  145. H22a 93-95 Headers
  146. Blown downpipe with pics (huge)
  147. turbo or supercharger???
  148. oil loss and check engine light
  149. knock sensor problems
  150. 1997 Honda Prelude?
  151. oil question
  152. buddy club pro spec
  153. Camber Kit Neccesary?
  154. Cams for H23 turbo: OEM, Stage 1, or what??
  155. bushing or bearing at end of input shaft?
  156. Sunroof switch light blew, How do I get to the bulb?
  157. 1993 foglight install?
  158. NSX CALIPERS? "REAR"!
  159. vtec engagment
  160. What is the best setup to get 350-400 bhp on a h22?
  161. Passenger's side axle installation woes...
  162. f22 harness h22 motor
  163. Need some tips on changing the color of the carpet.
  164. Which One?
  165. 5th generation prelude headlights
  166. h22 block h23 head
  167. oil change
  168. random prelude internal motor questions, including stroking and compression
  169. took off my A/C and P/S belt, now what belt am i suppose to use for the altenator?
  170. accord suspension on a prelude?
  171. quick questions on p28 ecu
  172. back deck rattling?
  173. quick fuel filter question (searched)
  174. Car won't start....help!!!
  175. Oil consumption Problem
  176. Questions about 1988 Honda Prelude 2.0SI 4WS B20A5
  177. F20 tranny on H23 will it bolt up?????
  178. Compression question
  179. only 1 cooling fan works?
  180. Prelude LSD's
  181. Need to know part # of Emission control system component
  182. Another H22 hesitation thread (I searched first)
  183. opinions of progress springs
  184. car shuts down
  185. JDM Type-S + Boost
  186. IAB control in Euro R
  187. Question - KYB AGX on SH
  188. Rebuilding my Turbo?
  189. 4th gen alarm?
  190. Difference between LSD tranny and Regular tranny?
  191. h23 timing Marks
  192. quick question
  193. kaaz lsd?
  194. JDM engine swap...any changes?
  195. Engine swap plan
  196. B20A5
  197. Wicked Cool Cold Air Intake Intake Thingamajig
  198. Unreasnable Expectation ?
  199. weapon r intake
  200. the mileage game v. insertyourmiles
  201. $4500 for 80WHP. Is it worth it?
  202. tranny capacity?
  203. What needs to be done to safely run at higher RPMs?
  204. Mobil 1 oil
  205. Intermittent "No Start" Problem
  206. Do fuel rails require DOT approval?
  207. h22a tranny install
  208. fix my head gasket for cash! east coast PA
  209. loud rattle after h22a swap
  210. exterior and interior parts ?
  211. JDM h22a how big of a nitrous shot on stock
  212. NEED HELP Loud Knocking **SO CAL** come help me ill buy beer
  213. 97up prelude headlights..
  214. Reducing Exhaust Vibration
  215. were can i find a jun header or a rmf
  216. timing belt
  217. Cutting Your Bumpstops
  218. ExHAUST GASKETS.......Why can't I find them????
  219. Apexi WSII Question
  220. Will a 99 block work with an 01 bock parts?
  221. tranny or brake problem?
  222. Can you put an air filter on without the piping?
  223. Timing belt change on 89 Prelude Si
  224. My car won't go into gear unless you let it warn up for 10 min, anyone know how to fix it??
  225. Weird hesitation at high RPMs in 3rd gear...
  226. whats the best year for a 5th Gen Lude?
  227. offset
  228. anyone know the OEM deck clearence for the h23 or h22?
  229. Possible to change oil filter w/o draining oil on type SH?
  230. no start when hot outside
  231. Body damage, will it be expensive?
  232. horrible idle surges. 700--> 500 --->700
  233. the bb6 prelude jdm fogs
  234. EGR in a 4th gen?
  235. i just bought an xtd stage 3 6 puck clutch can this be a daily driver
  236. 4th gen coilovers into a 5th generation.
  237. Testing Waters-JDM Foglights for sale..
  238. 97up headlights fade.....
  239. 1991 prelude si 4WS
  240. Iceaman
  241. Engine rebuilding for a turbo
  242. Bad Lagging-H22a swap
  243. JRSC for sell (moderator approved)
  244. usdm/jdm wires the same?
  245. Why am I overheating at idle?
  246. h23a1 firing order
  247. Process For Replacing the Crankshaft Pulley
  248. rebushing H22a1 rods to accept type s pistons
  249. immobilizer system 5th gen
  250. Can idle be smoothed out by adjusting the ignition timing?
